I'm curious if you have any layout recommendation for TMAG5170? Usually, magnetic encoders need a copper keepout under the body so that the magnetic field can go through and close the loop. I don't see any recommendation in the data sheet. I'm curious if it's okay to route traces under the IC?
I see that you routed traces and you have vias under the body of the IC so not sure if that will create any issue.
