AWR2E44PEVM: QSPI issue continue
Part Number: AWR2E44PEVM
For the W25Q32JV, for the cmd 0xEB, it need an 0xEBh instruction+Addr(3byte)+M(1byte 0xFF)+dummy(2 byte)+data......, for 2E44P, how to configure the register to realize the M (1 byte 0xFF), in the QSPI_SPI_SETUP0_REG, it don't have such configuration bit
  • Hi Chen,
    I suggest you to follow below points
    1. Refer this AppNote to understand the supported sFlash with mmWave Sensor device variants
    https://www.ti.com/lit/an/sprach9g/sprach9g.pdf
    2. Refer mmWave MCU PLus SDK QSPI driver where it has implemented QSPI and Flash driver access based on specific flash part type.
    mmwave_mcuplus_sdk_04_06_01_02/mcu_plus_sdk_awr294x_09_02_00_15/source/drivers/qspi
    Meanwhile, I will request relevant expert to assist you further.
    Jitendra
