Other Parts Discussed in Thread: PGA460-Q1, PGA460
Hi everyone,
I recently bought a PGA450Q1EVM-S sensor and I'm doing some preliminary tests to understand how it works and how to configure it.
I kept all EEPROM with default values, and i want to measure the distance from a 60cm wide and 80cm high object.
Using the PGA450Q1 command 2, I triggered a long distance burst (command 00 55 11 02 00) and a short distance burst (command 00 55 11 01 00) and I read the corresponding Time Of Flight (TOF).
My experiment runs as follows: I trigger a long distance burst, read the TOF and save the corresponding FIFO data, then i repeat the same procedure with the short distance burst.
Afterwards, I used your 8780.PGA450-Q1 THRESHOLD CALC for UART OTP EXAMPLE.xlsx to plot all the FIFO data.
In the attached Excel file you will find all the FIFO readings of all the experiments (Excel sheets with corresponding distances), together with the measured distance vs the true distance (Excel sheet EXPERIMENTAL DATA).
Here comes my problems:
1) Very rarely the measured data corresponds to real data, both in the Long and in the Short mode
2) I fail in finding any correspondence between the calculated FIFO and the ones on the plot in the Excel.
To check in the plot I look for the first threshold crossing. All the formulas I used come from the YouTube video here https://www.youtube.com/watch?v=SV1X6o9sgS4
Am I missing something? I know the crossing depends on the threshold tuning, but before doing that at least i should have reliable readings from the sensor.
Every help is much appreciated.
Thanks in advance,
GD
