I did follow the similar procedure to run capture demo and save data from CCS memory browser. However, I couldn't see data coming from the tera term data com port because I understood that the baud rate for Data port should be 921600. But I saw in this thread that you advice to set baud rate of 115200 similar to the config port. Why is that ?. Furthermore, If I see the raw data coming from the data com port , is it possible to capture the data in pc for say, few minutes ?. for post-processing purposes. If so, can you guide how to save it ?. Thanks,
Sheeraz
