Other Parts Discussed in Thread: MMWAVEICBOOST, IWR6843
Hello support team,
Could you please explain more detail of radiation pattern measurement of ISK antenna?
dBFS value of Bore-sight is about 96 by looking at Figure 41 to 46 in mmWaveICBoost and Antenna Module User's Guide.
How ~96dBFS is measured?
Is it measured by IWR6843?
How ~96dBFS is calculated?
In case of conventional radiation pattern measurement, E(I)RP at test antenna is measured only by TX side. Assuming that TX output power is known, antenna gain is obtained by comparing to reference antenna.
"Here corner reflector is kept at bore-sight and Radar is rotated in Azimuth/Elevation planes and measurement is plotted across Tx and Rx combinations. " seems to indicate that received signal strength is measured and plotted to get radiation pattern.
Katsuhiro
