Is there any possibility to capture the radar ADC data in real time using DCA1000 (every frame), sothat I can run signal processing script written in matlab on the radar data.
We are using mmWave Studio.
Resmi Johnson
Resmi Johnson
Thank you Cesar for your reply.
Using DCA1000, the radar data will be available as a file only after 'PostProc' . We need the ADC data for each frame till the end so that each frame data will be used for signal processing using the matlab code.
If this capture of ADC data is possible frame by frame using DCA1000, could you share the document related to that sothat we will get more clarity on that.
Resmi Johnson
This is a common question asked on the forum
Run time processing with DCA1000 is not supported
thank you
cesar
