IWR6843: What's wrong with profileCfg of IWR6843's cfg?
Part Number: IWR6843
Dear TechnicalSupport
I use IWR6843 ISK(ES2.0) following FW was burned.
C:\ti\mmwave_industrial_toolbox_4_2_1\labs\people_counting\68xx_3D_people_counting\prebuilt_binaries\3D_people_count_68xx_demo.bin
And, I can work IWR6843 using following cfg.
C:\ti\mmwave_industrial_toolbox_4_2_1\labs\people_counting\68xx_3D_people_counting\chirp_configs\ISK_6m_default.cfg
But, I changed "profileCfg", IWR6843 is not able to work.
What's wrong with profileCfg?
sensorStop
flushCfg
dfeDataOutputMode 1
channelCfg 15 7 0
adcCfg 2 1
adcbufCfg -1 0 1 1 1
lowPower 0 0
%profileCfg 0 60.75 7 7 41.10 1184274 0 54.7125 1   96 2950.00 0 0 36    orginal
profileCfg 0 60 7 7 28 0 0 60 1 256 12500 0 0 48
chirpCfg 0 0 0 0 0 0 0 1
chirpCfg 1 1 0 0 0 0 0 2
chirpCfg 2 2 0 0 0 0 0 4
frameCfg 0 2  96  0 50 1 0
dynamicRACfarCfg -1 4 4 2 4 8 16 4 4 4.00 4.50 0.50 1 1
staticRACfarCfg -1 4 4 2 4 8 16 4 6 8.00 13.00 0.30 0 0
dynamicRangeAngleCfg -1 0.75 0.0010 1 0
dynamic2DAngleCfg -1 3 0.0300 1 0 1 0.50 0.85 8.00
staticRangeAngleCfg -1 1 8 2
antGeometry0 0 -1 -2 -3 -2 -3 -4 -5 -4 -5 -6 -7
antGeometry1 -1 -1 -1 -1 0 0 0 0 -1 -1 -1 -1
antPhaseRot 1 1 1 1 1 1 1 1 1 1 1 1
fovCfg -1 70.0 20.0
compRangeBiasAndRxChanPhase 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0
staticBoundaryBox -2 2 2 8.5 -2 2
boundaryBox -2.5 2.5 0.5 6 -2.5 2.5
sensorPosition 2 0 10
gatingParam 3 1.5 1.5 2 0
stateParam 3 3 10 40 5 600
allocationParam 200 800 0.1 15 0.5 20
trackingCfg 1 2 1000 20 67 105 50
sensorStart
Best Regrads
  • Hi User,
    Can you elaborate on why you have changed the profileCfg this way?
    We'll need a few days for a response.
    AG
  • Former Member
    0 Former Member
    The cfg you have created is invalid because it exceeds the radar cube size limitation. In your cfg the radar cube size would 1152 kB when the limit is 768.
    Please see this thread on how you can perform these calculations yourself: https://e2e.ti.com/support/sensors/f/1023/t/895114
    Amanda
  • Dear Amanda
    Thank you for your reply.
    The calculate method of "radar cube size" is below, isn't it?
    {radar cube size} = {float:4Byte} × {Tx Antenna:4} × {Tx Antenna:4} × numAdcSamples × numberOfLoops
    But even if I reduce numberOfLoops to reduce radar cube size, it doesn't work.
    The radar cube size of below cfg is 197kB and smaller than 768kB.
    sensorStop
    flushCfg
    dfeDataOutputMode 1
    channelCfg 15 7 0
    adcCfg 2 1
    lowPower 0 0
    %frameCfg 0 2  96  0 50 1 0
    frameCfg 0 2  16  0 50 1 0
    fovCfg -1 70.0 20.0
    sensorStart
    Bes Regards.
  • Former Member
    0 Former Member in reply to user6005362
    This issue is continues on this thread: https://e2e.ti.com/support/sensors/f/1023/t/897426
    I'll close this one.
    Amanda
