I have a problem to install the INA226EVM tool , i get an error message just after i click "setup".
Is there any fix for it?
Amir.
Hello 6354578,
Thanks for considering to use Texas Instruments. If I run setup.exe on my computer, I do not run into any particular issues. Is it possible you could share a screen shot of the error message? Without further details, there are only three reasons I can think of that may result in your issue. The first would be that your downloaded file was somehow corrupted. The second would be that you need to unzip or extract the files before running setup.exe. The final reason, may be that you need to run setup.exe as administrator.
Hello Amir,
I think the issue may be that the software has a conflict with one of the Microsoft Windows components that is on your computer or simply one of the runtime components might be missing. Here are some links I found that might help you fix your problem.
https://www.techwalla.com/articles/how-to-fix-the-microsoft-visual-c-runtime-error
