HDC2010: Recommendation diameter of opening window
Part Number: HDC2010
Hi Team,
Due to the customer mechanical structure design that PCB to case has gap 3.3mm.
Please kindly help to provide design guide and recommend diameter of opening window. Thank you.
Mike
  • Hi Mike,
    Thank you for your post. We aren't able to specify opening sizes for case designs, as there are too many variables and this is not our area of expertise.
    They would have to perform some functional testing or simulate in order to determine if airflow from the opening is enough to keep the conditions inside and outside the case close to each other.
    Brandon Fisher
