Part Number: LM61495
I would like to delete the following threads I have created.
Thank you.
Thank you.
Hi Ben,
Then would it at least be acceptable to request to only delete the following thread as this may contain potentially sensitive content if it were to be used in any projects? I understand if not.
Thank you.
Hi Aaron,
The material seen in the particular thread that you have listed above is very common to other designs that I have advised. Nothing in the thread seems to be "sensitive" if that makes you feel better. The schematic for the dual phase setup is just unique to the IC and not to your system design. I can understand your request if you had a schematic that showed the system design of your application. I hope I am making myself clear.
Ben
