SN74TVC3010: How to use SN74TVC3010?
Part Number: SN74TVC3010
Other Parts Discussed in Thread: LSF0108
1, SN74TVC3010 as a FET switch used in  voltage-limiting application where GATE is connected to the VBIAS of the reference tansistor,how to disable and enable this switch since there is no OE# pin to do this?
2, When SN74TVC3010  is used in  voltage-limiting application where GATE is connected to the VBIAS of the reference tansistor,what's the value of voltage of GATE pin? And what's the value of voltage of Vgs of the reference transistor MOSFET?
3, When SN74TVC3010  is used in  voltage-limiting application where GATE is connected to the VBIAS of the reference tansistor, what region is the reference transistor is working in, saturation region or ohm region? How about the other transistors?
4, In what scenario is the voltage-limiting application of SN74TVC3010 used? Please help understand the VREF settings and examplify the usage of SN74TVC3010.
