[ TS3USB221 ] USB Hub Fail to Perform Reset issue
My customer has reported that their USB Hub occasionally fail to perform reset when TS3USB221 switch the route. Circuit is as below.
The TS3USB221 switch cause the reset of USB hub in most of case. However, sometimes (like 4% - 5%), USB hub does not perform reset, even though TS3USB221 is switched.
Q1: Do you have any ideas and/or comments on this behavior?
Q2: Have you seen this before?
Q3: When my customer attempt to change S pin high to low and/or low to high, VCC supplied and OE_ remains low (device enabled). Does this cause any of potential failure?
Thank you for your support in advance.
Please let me know, if you need further information.
Ken
