Other Parts Discussed in Thread: ADS114S08, TMUX1119, TMUX1108, TMUX1109
I am designing an instrumentation circuit with ADS114s08, and I am planning to use TS5A26542 switch for the following purposes:
1. Routing thermocouple signal through the switch, it is in uV.
2. Routing RTD excitation current through the switch to use the same current source for many RTDs.
3. Using the switch to connect a different value of the bias resistor in RTD measurement.
Will this downgrade my measurement accuracy? and will it behave exactly as a mechanical relay if I assume the relay has the same on resistance?
Mahmoud
