Other Parts Discussed in Thread: TXS0108E
I am giving a LVCMOS output(3V3 level) to the TS3L301DGGR, from mux output i am giving it to level translator TXS0108ERGYR to translate from 3.3V to 1.8 V,
Will it work??
Harish,
If i'm understanding properly, you're aiming to pass a DC signal through a multiplexer to TS3L301 to a level shifter, the TXS0108E, and you want to confirm if after passing through the mux you'll see any problems by the time it reaches the level shifter? If so, then you shouldn't see any problem.
I can't give you much confident feedback on the TXS0108E or any set up guides though but I would see if the logic forum has answers you'd be looking for on that end:
https://e2e.ti.com/support/logic/f/151
Hope this helps
Rami
