Hi Sir:
I would like use TS5A3357 to switch SPI CS from different SPI device.
But i can't find propagation delay(tpd) of TS5A3357.
I need to check propagation delay because other SPI signals(CLK.MOSI.MISO) switch by SN74CBTLV3257 and
need to check SPI timing(setup/hold) time.
Any analog switch behaves pretty much like a small resistor. The propagation delay is smaller than 1 ns, but can increase if there is a capacitance on the line.
Ryan,
Clemens is correct. I found some similar responses on the forum when searching for propagation delay:
https://e2e.ti.com/support/switches-multiplexers/f/388/t/758953
https://e2e.ti.com/support/switches-multiplexers/f/388/t/722414
These are just passive FET switches so you'll effectively see no propagation delay (low ns to ps) coming from a direct result of the switch.
Rami Mooti
