Other Parts Discussed in Thread: TS3DV642
Hi Team,
Could ts5mp646 be used as MIPI switch?
Amelie,
Yes the TS5MP646 is a MIPI switch that can be used to switch between MIPI compliant devices to connect to a single CSI/DSI, C-PHY/D-PHY module. It could also be used as a 10 channel 2:1 switch is you utilize a pair of differential lines as 2 single ended channels
Rami
Hi Rami,
Thanks for your reply!
What about TS3DV642? Could it also support MIPI switch or C-PHY?
Amelie,
It looks like the TS3DV642 may be a good fit as well. It's a 12 channel 2:1 switch with high bandwidth. I'm going to loop in someone from the high speed data converters team, who actually own this device in their portfolio who would have more knowledge on this to get you a clearer answer on whether the TS3DV642 can be used as a C-PHY MIPI compliant switch.
Rami Mooti
Amelie,
Yes, the TS3DV642 will able to support the C-PHY application.
David
