I have been using CCS Version: 5.2.1.00018 fine for a few months. But today, I get the following error messages when the Debugger is started. Please help me to check. Thanks!
Allen
The error messages in the CCS console window:
Debugger Initialization Error
Cannot read System Setup data from XLM file
C:\proj\dsp\NPF\DSP_0\user\targets\MotherBoard.ccxml
Error parsing file
"C:\DOCUME~1\user\LOCALS~1\APPLIC~1\.TI\46491157\0\0\4237748574.cache":
Could not fetch next record for SQL statement (database disk image is malformed) at line 84 column 159.
Hi Allen,
did anything change when this started to happen? Have you tried regenerating the ccxml or deleting the projects metadata? Are there further clues you can provide?
Lisa
Hi Lisa,
I didn't notice any changes before the problem occurred. Just started the debugger as I have done for the same project in last several months. I have not tried to regenerate the ccxml or deleting the projects metadata. Should I try to do that?
One clue is that, when the problem first occurred, I have two CCSs running with two different WorkSpaces and projects - but only state the debugger from one CCS. Both CCS workspace and projects work fine for months before the problem occurred. I have tried to create new workspace - still failed with the same messages.
I have run "chkdsk" from window XP console - still failed with the same error messages.
Should I try to re-install the CCS?
Allen
Hi Allen,
I would first try redoing the ccxml and deleting the .metadata. Please keep us informed.
Lisa
Hi Allen,
ok, great. Glad to hear. Thanks for the update and all the best with development.
Lisa
How did you make ccs well?
I got the same problem with you , could you help me ?
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/219762.aspx
I should have said imported the code to a different computer and copy of CCS.
My problem is the CCS not working is in a remote computer and I need to modify the MSP430 code on that remote computer.
Any suggestions?
LDT
hi
I have a problem,that my debugger is not getting initialised for CCS. I have used the same project and worked with with for a while,but suddenly today I am not able to debug my project.
I have done the fsclean,I have deleted the metadata and worked with a new gel file also.All of these are of no help.
Please help me with this.
Arun
