Other Parts Discussed in Thread: LAUNCHCC3235MOD, CC3235SF, SYSBIOS
I am using the LAUNCHCC3235MOD launchpad. When I am trying to build the hello example projects I get the following errors for both projects.
CCS Version: 10.4.0.00006
**** Build of configuration MCU+Image for project hello_CC3235SF_LAUNCHXL_tirtos_gcc **** "C:\\ti\\ccs1040\\ccs\\utils\\bin\\gmake" -k -j 8 all -O Building file: "../hello.cfg" Invoking: XDCtools "C:/ti/ccs1040/xdctools_3_62_01_15_core/xs" --xdcpath="C:/ti/simplelink_cc32xx_sdk_5_20_00_06/source;C:/ti/simplelink_cc32xx_sdk_5_20_00_06/kernel/tirtos/packages;C:/ti/simplelink_cc32xx_sdk_5_20_00_06;" xdc.tools.configuro -o configPkg -t gnu.targets.arm.M4 -p ti.platforms.simplelink:CC32XX -r release -c "C:/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-9-2019-q4-major" --compileOptions "-mcpu=cortex-m4 -march=armv7e-m -mthumb -mfloat-abi=soft -I\"C:/TI_Workspace/hello_CC3235SF_LAUNCHXL_tirtos_gcc\" -I\"C:/TI_Workspace/hello_CC3235SF_LAUNCHXL_tirtos_gcc/MCU+Image\" -I\"C:/ti/simplelink_cc32xx_sdk_5_20_00_06/source\" -I\"C:/ti/simplelink_cc32xx_sdk_5_20_00_06/source/ti/posix/gcc\" -I\"C:/ti/simplelink_cc32xx_sdk_5_20_00_06/kernel/tirtos/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/include/newlib-nano\" -I\"C:/ti/simplelink_cc32xx_sdk_5_20_00_06/kernel/tirtos/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/include\" -I\"C:/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-9-2019-q4-major/arm-none-eabi/include\" -ffunction-sections -fdata-sections -g -gstrict-dwarf -Wall -std=c99 " "../hello.cfg" subdir_rules.mk:19: recipe for target 'build-1057507295-inproc' failed /usr/bin/sh: 0: Can't open C:/Users/KEOND~1/AppData/Local/Temp/make17624-1.sh C:/ti/ccs1040/xdctools_3_62_01_15_core/packages/xdc/bld/xdc_rules.mak:307: *** Error: Specified build configuration file '' is not found. Stop. js: "C:/ti/ccs1040/xdctools_3_62_01_15_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake[1]: *** [build-1057507295-inproc] Error 1 Building file: "../image.syscfg" Invoking: SysConfig "C:/ti/ccs1040/ccs/utils/sysconfig_1.9.0/sysconfig_cli.bat" -s "C:/ti/simplelink_cc32xx_sdk_5_20_00_06/.metadata/product.json" --script "C:/TI_Workspace/hello_CC3235SF_LAUNCHXL_tirtos_gcc/image.syscfg" -o "syscfg" --compiler gcc Running script... Validating... Generating Code (image.syscfg)... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\RegDomainSum5.csv... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\RegDomainSum24.csv... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_drivers_net_wifi_config.json... Finished building: "../image.syscfg" gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/linker.cmd'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. Building file: "../hello.syscfg" Invoking: SysConfig "C:/ti/ccs1040/ccs/utils/sysconfig_1.9.0/sysconfig_cli.bat" -s "C:/ti/simplelink_cc32xx_sdk_5_20_00_06/.metadata/product.json" --script "C:/TI_Workspace/hello_CC3235SF_LAUNCHXL_tirtos_gcc/hello.syscfg" -o "syscfg" --compiler gcc Running script... Validating... Generating Code (hello.syscfg)... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_drivers_config.c... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_drivers_config.h... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_utils_build_linker.cmd.genlibs... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\syscfg_c.rov.xs... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_utils_runtime_model.gv... Writing C:\TI_Workspace\hello_CC3235SF_LAUNCHXL_tirtos_gcc\MCU+Image\syscfg\ti_utils_runtime_Makefile... Finished building: "../hello.syscfg" gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-1057507295', needed by 'configPkg/compiler.opt'. gmake: Target 'all' not remade because of errors. **** Build Finished ****
The way that I am importing them are:
Project
Import CCS Projects
Search Directory is the location of the SDK
Is there something that I am missing?
Thank you in advance.
