Other Parts Discussed in Thread: SYSCONFIG, CCSTUDIO
Here is the information requested:
Code Composer Studio version 12.3.0
SysConfig version is 1.16.1
!SESSION 2023-07-10 13:50:41.974 -----------------------------------------------
eclipse.buildId=4.23.0.I20220308-0310
java.version=11.0.13
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2023-07-10 13:50:45.569
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 1 0 2023-07-10 13:50:45.572
!MESSAGE debugServerDir=C:/ti/ccs1230/ccs/ccs_base/DebugServer
!ENTRY com.ti.ccstudio.ui 1 0 2023-07-10 13:50:50.105
!MESSAGE CCS IDE session started!
CCS build: 12.3.0.00005
CCS location: C:/ti/ccs1230/ccs
Workspace location: D:/Documents/AASP/Code/PMDSP
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2023-07-10 13:50:50.194
!MESSAGE constructor
!MESSAGE done with directories
!MESSAGE loading ti_logger
!MESSAGE Platform os: win32
!MESSAGE loading cToolsIF
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2023-07-10 13:50:50.205
!MESSAGE loading TraceFactory
!MESSAGE loading sqlite3
!MESSAGE loading CloudTrace
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2023-07-10 13:50:50.215
!MESSAGE CloudTrace interface loaded
!ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2023-07-10 13:50:50.279
!MESSAGE CCS HTTP adapter started! [ccs.port:58841] - Open 'localhost:58841/ide' in web browser to see listing of available APIs...
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:51.665
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:52.685
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:53.602
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY com.ti.ccstudio.project.ui.webcontent 4 0 2023-07-10 13:50:54.520
!MESSAGE An internal error was logged by 'com.ti.ccstudio.project.ui.webcontent'.
!STACK 0
java.lang.RuntimeException: Unsupported API
at com.ti.browser.contribution.AbstractBrowser.addInjectJsCallback(AbstractBrowser.java:89)
at com.ti.browser.internal.TIBrowser.addInjectJsCallback(TIBrowser.java:487)
at com.ti.ccstudio.project.ui.webcontent.internal.sysconfig.SysConfigEditor.createPartControl(SysConfigEditor.java:565)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:995)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:960)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:403)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:330)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:105)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4779)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:660)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:624)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:787)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1261)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3207)
at org.eclipse.ui.internal.WorkbenchPage.lambda$9(WorkbenchPage.java:3097)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3095)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3065)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3048)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:606)
at com.ti.ccstudio.project.ui.internal.navigator.SysConfigFileOpenActionProvider$1.run(SysConfigFileOpenActionProvider.java:101)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:215)
at org.eclipse.ui.navigator.CommonNavigatorManager$1.open(CommonNavigatorManager.java:183)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:800)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:797)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1116)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:454)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:296)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:331)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4243)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1063)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4060)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3632)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
!ENTRY com.ti.ccstudio.webcontent 4 0 2023-07-10 13:50:54.655
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4918)
at org.eclipse.swt.SWT.error(SWT.java:4833)
at org.eclipse.swt.SWT.error(SWT.java:4804)
at org.eclipse.swt.widgets.Widget.error(Widget.java:447)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:366)
at org.eclipse.swt.browser.Browser.checkWidget(Browser.java:212)
at org.eclipse.swt.browser.Browser.execute(Browser.java:537)
at com.ti.browser.contribution.swt.SWTBrowser.execute(SWTBrowser.java:162)
at com.ti.browser.internal.TIBrowser.execute(TIBrowser.java:331)
at com.ti.ccstudio.webcontent.internal.ABrowserExtension.createNamespaces(ABrowserExtension.java:47)
at com.ti.ccstudio.webcontent.internal.ABrowserExtension.init(ABrowserExtension.java:26)
at com.ti.ccstudio.webcontent.cloudagent.CloudAgentBrowserExtension.init(CloudAgentBrowserExtension.java:24)
at com.ti.ccstudio.webcontent.internal.CommonBrowserExtensionContributor.init(CommonBrowserExtensionContributor.java:29)
at com.ti.browser.internal.TIBrowser$1.run(TIBrowser.java:104)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4035)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3635)
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:54.762
!ENTRY com.ti.ccstudio.webcontent 4 0 2023-07-10 13:50:55.717
!STACK 0
at com.ti.ccstudio.webcontent.cloudagent.CloudAgentBrowserExtension.changed(CloudAgentBrowserExtension.java:31)
at com.ti.ccstudio.webcontent.cloudagent.CloudAgentBrowserExtension.init(CloudAgentBrowserExtension.java:25)
!ENTRY com.ti.ccstudio.webcontent 4 0 2023-07-10 13:50:55.727
!STACK 0
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension.init(DebugUIBrowserExtension.java:214)
at com.ti.ccstudio.webcontent.internal.CommonBrowserExtensionContributor.init(CommonBrowserExtensionContributor.java:30)
!MESSAGE Unsupported API
!STACK 0
at com.ti.browser.contribution.AbstractBrowser.setProperty(AbstractBrowser.java:80)
at com.ti.browser.internal.TIBrowser.setProperty(TIBrowser.java:482)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$DebugEventHandler.updateDebugContext(DebugUIBrowserExtension.java:198)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$DebugEventHandler.<init>(DebugUIBrowserExtension.java:132)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension.init(DebugUIBrowserExtension.java:216)
!ENTRY org.eclipse.ui 4 4 2023-07-10 13:50:55.797
!MESSAGE An internal error has occurred.
!STACK 0
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$ThemeEventHandler.updateTheme(DebugUIBrowserExtension.java:118)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$ThemeEventHandler.notifyThemeChanged(DebugUIBrowserExtension.java:86)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$ThemeEventHandler.access$0(DebugUIBrowserExtension.java:85)
at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension$ThemeEventHandler$1.runInUIThread(DebugUIBrowserExtension.java:70)
at org.eclipse.ui.progress.UIJob.lambda$0(UIJob.java:95)
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:55.917
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:57.254
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:57.791
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:58.650
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:50:59.643
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:51:00.819
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:51:00.825
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 0 2023-07-10 13:51:00.825
!MESSAGE Unexpected error loading extension: org.eclipse.equinox.p2.metadata.repository.simpleRepository
!STACK 0
java.lang.NullPointerException
at org.osgi.util.tracker.ServiceTracker.<init>(ServiceTracker.java:187)
at org.osgi.util.tracker.ServiceTracker.<init>(ServiceTracker.java:250)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient5.Activator.getHttpClientFactory(Activator.java:242)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient5.Activator.getBrowseHttpClient(Activator.java:267)
at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientBrowseFileTransferFactory$1.sendBrowseRequest(HttpClientBrowseFileTransferFactory.java:59)
at org.eclipse.ecf.provider.filetransfer.browse.MultiProtocolFileSystemBrowserAdapter.sendBrowseRequest(MultiProtocolFileSystemBrowserAdapter.java:97)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.sendBrowseRequest(FileInfoReader.java:184)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getRemoteFiles(FileInfoReader.java:109)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getRemoteFile(FileInfoReader.java:125)
at org.eclipse.equinox.internal.p2.transport.ecf.FileInfoReader.getLastModified(FileInfoReader.java:130)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.getLastModified(RepositoryTransport.java:249)
at org.eclipse.equinox.internal.p2.repository.CacheManager.getLastModified(CacheManager.java:283)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:231)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105)
at com.ti.ccstudio.p2app.DirectorApplication.getInstallableUnits(DirectorApplication.java:1507)
at com.ti.ccstudio.p2app.DirectorApplication$LocationQueryable.query(DirectorApplication.java:180)
at org.eclipse.equinox.p2.query.CompoundQueryable.getIteratorFromQueryable(CompoundQueryable.java:178)
at org.eclipse.equinox.p2.query.CompoundQueryable.everything(CompoundQueryable.java:128)
at org.eclipse.equinox.internal.p2.metadata.expression.RepeatableIterator$IndexProviderIterator.<init>(RepeatableIterator.java:142)
at org.eclipse.equinox.internal.p2.metadata.expression.RepeatableIterator.create(RepeatableIterator.java:60)
at org.eclipse.equinox.p2.query.ExpressionMatchQuery.perform(ExpressionMatchQuery.java:64)
at org.eclipse.equinox.internal.p2.metadata.index.IndexProvider.query(IndexProvider.java:26)
at org.eclipse.equinox.internal.p2.metadata.index.IndexProvider.query(IndexProvider.java:36)
at com.ti.ccstudio.p2app.DirectorApplication.collectRootIUs(DirectorApplication.java:639)
at com.ti.ccstudio.p2app.DirectorApplication.performList(DirectorApplication.java:1038)
at com.ti.ccstudio.p2app.DirectorApplication.run(DirectorApplication.java:1396)
at com.ti.ccstudio.p2app.DirectorApplication.listIUsFoundInRepos(DirectorApplication.java:1775)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.listIUsFoundInRepos(DirectorApplicationDelegate.java:40)
at com.ti.ccstudio.app.center.p2.DirectorApplicationDelegate.resolveIU(DirectorApplicationDelegate.java:72)
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:391)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:358)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:234)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.equinox.p2.repository 2 0 2023-07-10 13:51:00.832
!ENTRY org.eclipse.core.jobs 4 2 2023-07-10 13:51:00.840
!MESSAGE An internal error occurred during: "Replace IU Job".
!STACK 0
at com.ti.ccstudio.app.center.internal.CCSAppCenter.log(CCSAppCenter.java:446)
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:414)
