I was arranging the code composer debug window when I inadvertently caused the Expressions window to disappear. I go to view expressions and a blank box appears. View registers or anything else works fine. Out of frustration I installed code composer 12.6, copied my working directory to a new folder. My hope was the new install would restore the default debugger settings. No Luck. Same problem... How can I fix this? Here's the screen when I go to view expressions: The blank box comes up when I select view expressions.
