Other Parts Discussed in Thread: SK-TDA4VM, TDA4VM, UNIFLASH, CC2340R5
I have a similar problem to ticket:
(+) CCS: New XDS110 unable to update firmware - Code Composer Studio forum - Code Composer Studio︎ - TI E2E support forums
I have a XDS110 Probe with CMSIS-DAP wich I what to debug a R5 core on SK-TDA4VM.
CCS version 8, 9, 10, 11, 12 was not able to update my board.
And manualy it shows the same erros.
I tried everithink on Windows as recomended.
Here are my logs from manual update with windows console
Microsoft Windows [Version 10.0.22621.2283]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>cd C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110
C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110>dir
Volume in drive C has no label.
Volume Serial Number is 1E32-D189
Directory of C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110
13.08.2024 23:15 <DIR> .
13.08.2024 23:16 <DIR> ..
25.07.2024 02:45 74 900 boot_loader.axf
25.07.2024 02:45 6 202 boot_loader.bin
25.07.2024 02:45 3 227 eZ_FetDcdcController.txt
25.07.2024 02:45 337 281 firmware_3.0.0.31.bin
25.07.2024 02:45 173 056 xds110reset.exe
25.07.2024 02:45 176 023 XDS110SupportReadMe.pdf
25.07.2024 02:45 214 016 xdsdfu.exe
7 File(s) 984 705 bytes
2 Dir(s) 124 880 371 712 bytes free
C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -e
USB Device Firmware Upgrade Utility
Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved.
Scanning USB buses for supported XDS110 devices...
<<<< Device 0 >>>>
VID: 0x0451 PID: 0xbef3
Device Name: XDS110 Probe with CMSIS-DAP
Version: 2.3.0.5
Manufacturer: Texas Instruments
Serial Num: 00000000
Mode: Runtime
Configuration: Standard
Found 1 device.
C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -m
<<<< Device 0 >>>>
Version: 2.3.0.5
Mode: Runtime
Switching device into DFU mode.
C:\ti\ccs1280\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -f firmware_3.0.0.31.bin -r
The requested device was not found on the bus.
<<<< Device 0 >>>>
Version: 2.3.0.5
Mode: Runtime
Found 1 device.
<<<< Device 0 >>>>
Version: 2.3.0.5
Mode: Runtime
I also installed CCS 7 but it does not support SK_TDA4VM
How should I use the XDS110?
Photos:
Connector should go here
