How to avoid opening external editor (CCS4)
whenever i try to jump to a bookmark (or compiler error), CCS tries to open my external system editor and responds with an error. This is only true for *.c files, *,h files are opened correctly in the internal editor. How can this behaviour be avoided?
Ulf
    Can you please check under Window->Preferences->General->Editors->File Associations (see screenshot below) ?   Are c files set to default open with an external editor?  If so, this is where you can change that.
    Please keep us informed whether this helps.
    Lisa
  • Hi Lisa,
    i once configured CCS to use my external editor, but in the meantime i removed that association (and re-installed CSS). This is what i have:
    It look's like there is no default editor selected, but whenever i try to select the C/C++ editor as default, CCS doesn't remember that setting.
    Ulf
  • Hi Lisa,
    i did'nt manage to add the screenshort now, but it seems that something with my settings went wrong. After having set up a blank new wokspace, the problem doesn't appear any more.
    Ulf
  • Hi Ulf,
    ok, glad that things are now working as expected for you.
    Lisa
