Error: Error in action ExecuteAction
trying to install CCS 4.2.4.00033 on a Windows 7 64-bit computer.  but I keep getting this message then the install locks up
here are the details...
Error in action ExecuteScript
can't read "::info(CGT_C2800_NAME)": no such element in array
    while executing
"::InstallJammer::actions::$component $this"
    while executing
"$obj execute"
    (procedure "::InstallJammer::ExecuteActions" line 62)
    invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
    (procedure "::InstallJammer::actions::ExecuteAction" line 35)
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
    (procedure "::InstallJammer::RaiseEventHandler" line 79)
    invoked from within
"::InstallJammer::RaiseEventHandler  .wizard"
    (command bound to event)
  • Kurt,
    Severe install issues are easier to detect as they are more deterministic. In this case I suggest providing the install logs (check this section).
    Parallel thread at: http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/152839.aspx
    Rafael
  • I have the log.
    I no longer see a button to attach a file.  How do I send you the log?
  • While posting, go to the top of the page and select the link Options between Compose and Preview.
  • Kurt,
    I know it sounds silly, but are you sure you copied/unzipped all the installer contents into the C:\Users\kurtjensen.SPIRICON\Downloads directory?
    The reason for my question is that the first siginficant error that shows up is the absence of the file install_images/package.properties (lines 141 and 142):
    12/14/2011 14:52:20PM - ** Checking to see if C:\Users\kurtjensen.SPIRICON\Downloads/install_images/package.properties exists
    12/14/2011 14:52:20PM - Condition failed
    This causes the failure in properly expanding the variables for the compiler tools (starting with %CGT_MSP430_SETUP_NAME% in line 910) and therefore failing to find the appropriate installers for these tools:
    12/14/2011 14:52:41PM - Executing Command Line: {C:\Users\kurtjensen.SPIRICON\Downloads/install_images/cgt/<%CGT_MSP430_SETUP_NAME%>} /pro /y /prefix {C:\ccs/ccsv4/tools/compiler/msp430}
    12/14/2011 14:52:41PM - Error while executing: couldn't execute "C:\Users\kurtjensen.SPIRICON\Downloads\install_images\cgt\<%CGT_MSP430_SETUP_NAME%>": no such file or directory
    Please be sure to extract everything to a directory with read and execute permissions, so you can get the installer to properly find these files.
    Let me know if that is not the case, ok?
    Rafael
  • what I have is "setup_CCS_4.2.4.00033.exe", downloaded July 2011, 6,802 Kb - I ran it as Administrator from my "C:\Users\kurtjensen.SPIRICON\Downloads" folder
    I have installed CCS 4 multiple times using this file.  I checked yesterday and 4.2.4.00033 is the latest CCS 4 installation.  I will try downloading a new copy
  • ok, now I understand. I had a directory with the ZIP and the EXE and the LIC and some other files.  this was where I had unzipped the ZIP.  I got confused and only copied over the EXE.  now when I download a new copy I see that i need all the other files in the install_images folder.
    works find when you got all the stuff.  sorry 'bout that.
  • PLS DELETE THIS POST
    //installation is ok, where previous installations was correctly (fully) deleted - uninstalled
