Ki has addressed this issue in this forum:
Is it supported? Yes. Assuming that the compiler discovery path was added to CCS and the compilers in question were properly discovered by CCS:
https://dev.ti.com/tirex/explore/node?node=A__AJRfIGmBSkp9naUDysxAFg__ccs_devtools__FUz-xrs__LATEST
Is it safe? Well, I'm not sure how to answer this question. All I can say is that CCS is designed to support various versions of the compiler, including ones installed standalone.
Hi Ki,
Please provide comments for these cases:
1. CCS 6.1.1 - User Environment Variable not configured by the installer
"XDAIS_CG_ROOT" - Manually added!
This patch is required to rebuild some libraries.
2. CCS 6.1.1 + bundle compiler 7.4.14 vs CCS 6.1.1 + stand-alone compiler 6.1.21 - File size difference
I had problem loading up the second file, here's the contents:
---Compiler 7.4.14------ ----Compiler.6.1.21------
Date File Size Lib Name Date File Size Lib Name
8/19/2025 2,236,150 lib1 10/1/2015 3,84`,478 Lib1
124,498 lib2 152,184 Lib2
242,280 lib3 315,444 Lb3
Based on my experience and trust TI's IDE tool, compiler 7.4.14 is the obvious choice.
What is this variable pointing to? Is XDAIS being used in your project?
The difference could be related to the debug symbol generation. COFF vs ELF or even differences between the DWARF versions. The key thing is the size of the actual binary loaded to the target.
1. CCS 6.1.1
One particular project has this setting:
Properties > Build > C6000 Compiler > Include Options
"$(XDAIS_CG_ROOT)/packages/ti/xdais"
I assume that the above setting is referring to this folder:
C:\RTN\xdctools_3_31_00_24_core
2. File size
Great valuable information - Thank you!
1. CCS 6.1.1
Properties > Build > C6000 Compiler > Include Options"$(CDAIS_CG_ROOT)/packages/ti/xdais"
XDAIS and XDC are different tools. You can get XDAIS from:
https://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/xdais/index.html
Note that XDAIS has been obsoleted long ago and I don't have much expertise on it so I will not be able to provide much support for XDAIS related questions.
