Read float variable using DSS
Hi
All the readData APIs in debug sever scripting returns either long or long[]. My question is how do I read a float variable? Is there any specific API to read a float variable?
Bhavin
  • Unfortuantely, it is currently not supported.
  • There is no specific API to read a float variable but it is possible to read a float (or any data type) using some java.
    Edit your main module to have a void* pointed to the float.
    float a;
    void* ptr = &a;
    Now in DSS, find the address ptr is pointed to and readData from that address. Finally, convert int bits to a float.
    var address = debugSession.expression.evaluate("ptr");
    var result = debugSession.memory.readData(0, address, 32);
    result = Float.intBitsToFloat(result);
