backtrace after getting exception in C66x sysbios
we've run into an exception when we develop and debug on C6657 based system using jtag. We run SysBios 6.32.05.54 with CCS5.1.1. From the exception print out, we can find out the pc and sp at the time of crash. Even though we could find out the offending assembly instruction, we could not find out why we got there, because that particular function is called frequently.
We would like to have a way to either 1) do a backtrace, so that we can find out how the function call hierarchy cause the exception or 2) to find out the local variables in the function failed so that we can know why the function failed.
We tried several ways to get those information, but none of them work.
1. add ti.sysbios.family.c64p.Exception.enable_print in cfg file
2. use the following functions as exception hook, try to get back to the offending function. We could return from exception handler, but ccs does not generate backtrace of the calling hierarchy.
Could anyone give us some suggestions on how to debug this kind of problems?
thanks
Weichun
  • Hello Weichun,
    C6657 supports various tracing capability, which can be a powerful feature to debug cases such as yours. Which JTAG emulator are you using with your target?
    ki
  • Hi, Ki,
    we are using BH-USB-100v2 jtag. How can we use trace buffer to back trace? Is there a document or demo which we can follow?
    thanks
    Weichun
    This emulator is pretty limited. But you should be able to use the ETB on the device. Check out the ETB wiki for more details:
    http://processors.wiki.ti.com/index.php/ETB
    ki
  • Hi, Ki,
    thank you so much for the information, which is really useful.
    What is the best way for me to find the HWI vector? The closest I found is ti_sysbios_family_c64p_Hwi_dispatchC_I. Is this a good one?
    in our particular case, the exception happened before the sysbios started. That is probably why we could not catch it using the trace buffer after we stopped trace.
    any more suggestions?
    thanks
    Weichun
    I suggest posting in the BIOS forum for this questions. The BIOS experts there can help you best.
    ki
