"ERROR: PROJECT BUILD OPTIONS DO NOT MATCH GLOBAL CONFIGURATION"
Dear all,
              We are working on DSP320(TMS320C5416,CCS_v2) kit and designing a FIR filter( in C) which reads input from Signal generator and after processing displays output on CRO. But we are  getting an error as mentioned below.
ERROR1: "User error"
               project build option do not match global configuration settings.
               compiler options specify near model, configuration set for far model.
ERROR2: Error in source: assembler aborted.
I'm waiting for  your valuable reply..
Thanking you
BY:VILAS I M
    I suspect your project uses DSP/BIOS and the memory model setting in the BIOS cfg file is different than what is set in the build options. Make sure that they are both the same.
    ki
