Other Parts Discussed in Thread: MSP430F5438A
I'm using MSP430F5438A.
I can debug and run my codes without any problems via TI FET debugger.
But when i attempt to run it without debug, the code doesn't work at all
What is the wrong ?
What is the wrong ?
My board has LCD to display some status messages.
The board based on MSP430F5438A.
I use CCS 5.4.0 and TI FET debugger.
I can run and debug the code without problems using FET debugger
But when i disconnect the FET debugger and power on the board nothing happens. LCD is always blank.
What is the wrong ?
BR,
Hi Mohamed,
I believe you may be running into the same issue as described in this post:
http://e2e.ti.com/support/microcontrollers/msp430/f/166/t/263728.aspx
