error #10264: DEFAULT memory range overlaps existing memory range
Other Parts Discussed in Thread: TMS320C6472
I am trying to modify a TMS320C6472 based platform's memory map, as the DDR3 mem on the board has been extended in hardware.
However, after using a customized RTSC package with modified memory layout, we are having an error message from linking phase "error #10264: DEFAULT memory range overlaps existing memory range", we are assuming that the customized memory map in the cmd file is conflicting with a "DEFAULT" memory map -  the question is, who defines the DEFAULT memory map?
Thanks in advance,
Euan
  • Hi Euan,
    Moved your thread to TI-RTOS(BIOS) Forum to get appropriate response.
    Thanks.
    Please take a look at this related thread and see if it helps. Are there any other linker command files being passed to the linker? If so, check that there are no conflicts/overlaps in the memory specifications.
    If that does not help fix the issue, would it possible for you to send us a simple CCS project that uses your custom RTSC patform and reproduces the error? If we can reproduce the error at our end we should be able to analyze it further.
