Other Parts Discussed in Thread: CCSTUDIO
Hi All,
I have a question on CCS Debugger termination issue.
We installed CCSv4(4.0.1.01001) Software in two Windws7 PCs that are same model.
After installing, one PC's CCS is operating correctly. And other PC's CCS have a problem.
There is no problem in debug operation. But when we click on termination button to terminate debugger, CCS crashes abnormally.
The following message was displayed.
JVM terminated. Exit code=-1073740940
C:\Program files(x86)\Texas Instruments\ccsv4\eclipse\jre\bin\javw.exe
-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:\Program Files(x86)\TexasInstruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=yes
-Dorg.eclipse.swt.browser.XULRunnerPath=C:Program Files(x86)\TexasInstruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=file:/D:/Users/user/Documents/workspace/
-jar C:\Program files(x86)\Texas Instruments\ccsv4\eclipse\startup.jar
-os win32
-ws win32
-arch x86
-launcher C:\Program files(x86)\Texas Instruments\ccsv4\eclipse\eclipse.exe
-vmargs
-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:Program Files(x86)\TexasInstruments\ccsv4\DebugServer\win32
And ".log file" message is as follows.
!SESSION 2014-12-01 14:18:35.112 -----------------------------------------------
eclipse.buildId=4.0.1.01001
java.version=1.5.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ja_JP
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.debug.core 4 120 2014-12-01 14:18:53.812
!MESSAGE Error logged from Debug Core:
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource is out of sync with the file system: /SPROMSB00/.launches/SPROMSB00.launch.
at org.eclipse.core.internal.localstore.FileSystemResourceManager.read(FileSystemResourceManager.java:606)
at org.eclipse.core.internal.resources.File.getContents(File.java:290)
at org.eclipse.core.internal.resources.File.getContents(File.java:279)
at org.eclipse.debug.internal.core.LaunchManager.getInfo(LaunchManager.java:1158)
at org.eclipse.debug.internal.core.LaunchConfiguration.getInfo(LaunchConfiguration.java:374)
at org.eclipse.debug.internal.core.LaunchConfiguration.getType(LaunchConfiguration.java:505)
at org.eclipse.debug.internal.core.LaunchManager.isValid(LaunchManager.java:1702)
at org.eclipse.debug.internal.core.LaunchManager.verifyConfigurations(LaunchManager.java:2023)
at org.eclipse.debug.internal.core.LaunchManager.getAllLaunchConfigurations(LaunchManager.java:928)
at org.eclipse.debug.internal.core.LaunchManager.getLaunchConfigurations(LaunchManager.java:1208)
at com.ti.ccstudio.breakpoint.core.PropertyUtils.getTargetName(PropertyUtils.java:60)
at com.ti.ccstudio.breakpoint.ui.action.base.AbstractEditorActionDelegate.determineTargetBreakpoint(AbstractEditorActionDelegate.java:67)
at com.ti.ccstudio.breakpoint.ui.action.EditorPropertiesRulerActionDelegate.updateMenuItem(EditorPropertiesRulerActionDelegate.java:31)
at com.ti.ccstudio.breakpoint.ui.action.base.AbstractEditorActionDelegate.setActiveEditor(AbstractEditorActionDelegate.java:44)
at org.eclipse.ui.internal.EditorPluginAction.editorChanged(EditorPluginAction.java:75)
at org.eclipse.ui.internal.EditorPluginAction.<init>(EditorPluginAction.java:34)
at org.eclipse.ui.internal.ActionDescriptor.createAction(ActionDescriptor.java:256)
at org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:170)
at org.eclipse.ui.internal.ViewerActionBuilder.createActionDescriptor(ViewerActionBuilder.java:53)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:158)
at org.eclipse.ui.internal.ViewerActionBuilder.readElement(ViewerActionBuilder.java:88)
at org.eclipse.ui.internal.registry.RegistryReader.readElements(RegistryReader.java:138)
at org.eclipse.ui.internal.registry.RegistryReader.readElementChildren(RegistryReader.java:127)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:141)
at org.eclipse.ui.internal.registry.RegistryReader.readExtension(RegistryReader.java:149)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry(RegistryReader.java:170)
at org.eclipse.ui.internal.PluginActionBuilder.readContributions(PluginActionBuilder.java:112)
at org.eclipse.ui.internal.ViewerActionBuilder.readViewerContributions(ViewerActionBuilder.java:106)
at org.eclipse.ui.internal.PopupMenuExtender.readStaticActionsFor(PopupMenuExtender.java:373)
at org.eclipse.ui.internal.PopupMenuExtender.<init>(PopupMenuExtender.java:125)
at org.eclipse.ui.internal.PartSite.registerContextMenu(PartSite.java:114)
at org.eclipse.ui.internal.EditorSite.registerContextMenu(EditorSite.java:151)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:2673)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:368)
at org.eclipse.cdt.internal.ui.editor.CEditor.createPartControl(CEditor.java:843)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:596)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:263)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1420)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.java:1005)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.EditorManager.restoreState(EditorManager.java:1000)
at org.eclipse.ui.internal.WorkbenchPage.restoreState(WorkbenchPage.java:2836)
at org.eclipse.ui.internal.WorkbenchWindow.restoreState(WorkbenchWindow.java:1949)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.java:2869)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2817)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681)
at org.eclipse.ui.internal.Workbench.runStartupWithProgress(Workbench.java:1421)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1473)
at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(WorkbenchConfigurer.java:183)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:996)
at org.eclipse.core.launcher.Main.main(Main.java:971)
!SUBENTRY 1 org.eclipse.core.resources 4 274 2014-12-01 14:18:53.812
!MESSAGE Resource is out of sync with the file system: /SPROMSB00/.launches/SPROMSB00.launch.
We tried a reinstallation of the CCS software, but the result did not change.
Please teach me the solution.
Thank you.
