I have a project where I want to access a shared header file. We have a project structure like this:
SVN_ROOT
>branch
->Personal
- ->MyProj
>trunk
->MainProj
- - > shared
->Proj2
->MyProj
Ideally, I want to be able to #include the header file from the SVN_ROOT/trunk/MainProj/shared. I've been getting around this by doing a hard copy of the shared header into an include folder in MyProj. Is there a way that I can either tell CCS the location of the file using the SVN path or to go up a level? I'd like to be able to check into the trunk from my branch without having to manually always go and change settings, and where if I keep the shared folder of the trunk up to date I can always have the latest copy of it without having to go and manually copy it into a local folder just for my project.
I hope my question makes sense!
Andrew,
I haven't personally worked with SVN so cannot answer your question with certainty. Hopefully some community members who have used SVN can help share their experiences here.
Are you using a SVN plugin for Eclipse? If so, it might be appropriate to also direct the question to the developers of the plugin that you are using.
