Dgrid has suddenly disappeared from my layout and source and no longer works. When I try to add a new Dgrid it appears to add without issue. However, as soon as I try to enter any text in the widget Column Names field - as soon as I exit (click anywhere else) the widget disappears. The new widget shows up in app.html till I try to enter a column name then it vanishes from there as well. All other widgets behave normally. in fact, the parts of my layout I have tested work fine. Seems just Dgrid is broken.
I'm using CCS 6.1 and Gui Composer 6.0. Any ideas how to make Drid stick around.
Dan
Dn Ballard said:When I try to add a new Dgrid it appears to add without issue. However, as soon as I try to enter any text in the widget Column Names field - as soon as I exit (click anywhere else) the widget disappears.
I can reproduce this as well and it looks like a bug. The issue appears to only be with entering the Widget Column Names. If you leave the Widget Column Names blank the widget itself works fine and can bind to variables ok. I will file a bug report for this and update this thread with the bug tracking number.
Thank you for bringing this to our attention and I apologize for the inconvenience.
