little changes to the project configuration results in huge change in .cproject
Other Parts Discussed in Thread: CCSTUDIO
I would call this a bug: I've experienced this two times now. I just made a little change to a project (add LibSearch as prebuild step). I can see that difference in the .cproject file. But in addition, I see tons of other changes. For example:
<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1995350098" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
is changed to:
<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1995350098" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
I consider this to be a bug, because now I have to go through every changed setting and to make sure that I did not changed anything by accident and this costs a lot of time.
I've attached the complete diff. I hope you can fix this. CCS Version is  6.1.1.00022.
Kind regards,
Torsten
Index: .cproject
--- .cproject   (revision 18)
+++ .cproject   (working copy)
@@ -13,7 +13,7 @@
                </extensions>
            </storageModule>
            <storageModule moduleId="cdtBuildSystem" version="4.0.0">
-               <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" errorParsers="org.eclipse.rtsc.xdctools.parsers.ErrorParser;com.ti.ccstudio.errorparser.CoffErrorParser;com.ti.ccstudio.errorparser.LinkErrorParser;com.ti.ccstudio.errorparser.AsmErrorParser" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.51385213" name="Debug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep="" prebuildStep="">
+               <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" errorParsers="org.eclipse.rtsc.xdctools.parsers.ErrorParser;com.ti.ccstudio.errorparser.CoffErrorParser;com.ti.ccstudio.errorparser.LinkErrorParser;com.ti.ccstudio.errorparser.AsmErrorParser" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.51385213" name="Debug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep="" prebuildStep="echo ${PROJECT_LOC};${TI_BLE_STACK}/Projects/tools/LibSearch/libSearch.exe ${PROJECT_LOC}/buildConfig.opt ${TI_BLE_STACK}/Projects/tools/LibSearch/parameters.xml ${TI_BLE_STACK}/Projects/ble/Libraries/CC26xx/IAR ${PROJECT_LOC}/Lib/CC2640Stack.a FlashROM;">
                    <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.51385213." name="/" resourcePath="">
                        <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.DebugToolchain.1253274906" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug.1665841832">
                            <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.82749640" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList">
@@ -29,32 +29,32 @@
                                <listOptionValue builtIn="false" value="EXPANDED_REPOS="/>
                                <listOptionValue builtIn="false" value="OUTPUT_TYPE=rtscApplication:executable"/>
                            </option>
-                           <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1995350098" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
+                           <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1995350098" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
                            <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformDebug.1521182413" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformDebug"/>
-                           <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug.1123742780" name="GNU Make.Debug" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug"/>
+                           <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug.1123742780" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug"/>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1555942667" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug">
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.1730543655" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.870948165" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.16" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.1889359089" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.eabi" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE.594155806" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE" valueType="definedSymbols">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.1730543655" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.870948165" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.16" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.1889359089" name="Application binary interface. [See 'General' page to edit] (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.eabi" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE.594155806" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE" valueType="definedSymbols">
                                    <listOptionValue builtIn="false" value="DEBUG"/>
                                    <listOptionValue builtIn="false" value="ccs"/>
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.666052098" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING.1079491913" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING" valueType="stringList">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.666052098" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING.1079491913" name="Treat diagnostic &lt;id&gt; as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING" valueType="stringList">
                                    <listOptionValue builtIn="false" value="225"/>
                                    <listOptionValue builtIn="false" value="255"/>
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER.494339089" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.1069352263" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.off" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.816605531" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER.494339089" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.1069352263" name="Wrap diagnostic messages (--diag_wrap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.off" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.816605531" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
                                    <listOptionValue builtIn="false" value="&quot;${CG_TOOL_ROOT}/include&quot;"/>
                                    <listOptionValue builtIn="false" value="&quot;${workspace_loc:/${ProjName}}&quot;"/>
                                    <listOptionValue builtIn="false" value="&quot;${COM_TI_RTSC_TIRTOSSIMPLELINK_INSTALL_DIR}/products/cc26xxware_2_21_03_15980&quot;"/>
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN.819857109" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.1199640893" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.266120282" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.vfplib" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN.819857109" name="Little endian code [See 'General' page to edit] (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.1199640893" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.266120282" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.vfplib" valueType="enumerated"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.1755332962" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.967059003" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.1357226836" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
@@ -61,18 +61,18 @@
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.1651236391" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
                            </tool>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug.1665841832" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug">
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE.1745255" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE" value="256" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE.1318072278" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE" value="0" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE.901519218" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE" value="&quot;${ProjName}.out&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE.1140149030" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE" value="&quot;${ProjName}.map&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO.872049108" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO" value="&quot;${ProjName}_linkInfo.xml&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER.1069234780" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.1922020300" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.off" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH.1637635203" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH" valueType="libPaths">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE.1745255" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE" value="256" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE.1318072278" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE" value="0" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE.901519218" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE" value="&quot;${ProjName}.out&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE.1140149030" name="Link information (map) listed into &lt;file&gt; (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE" value="&quot;${ProjName}.map&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO.872049108" name="Detailed link information data-base into &lt;file&gt; (--xml_link_info, -xml_link_info)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO" value="&quot;${ProjName}_linkInfo.xml&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER.1069234780" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.1922020300" name="Wrap diagnostic messages (--diag_wrap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.off" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH.1637635203" name="Add &lt;dir&gt; to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH" valueType="libPaths">
                                    <listOptionValue builtIn="false" value="&quot;${CG_TOOL_ROOT}/lib&quot;"/>
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY.767705266" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY" valueType="libs">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY.767705266" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY" valueType="libs">
                                    <listOptionValue builtIn="false" value="&quot;libc.a&quot;"/>
                                    <listOptionValue builtIn="false" value="&quot;${COM_TI_RTSC_TIRTOSSIMPLELINK_INSTALL_DIR}/products/cc26xxware_2_21_03_15980/driverlib/bin/ccs/driverlib.lib&quot;"/>
                                </option>
@@ -82,16 +82,16 @@
                            </tool>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.551546687" name="ARM Hex Utility" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex"/>
                            <tool id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.327553575" name="XDCtools" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool">
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR.592195537" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR" value="&quot;${CG_TOOL_ROOT}&quot;" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.213381378" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M3" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM.697586706" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW.315713470" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE.1207094196" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE" value="release" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.1995524845" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR.592195537" name="Compiler tools directory (-c)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR" value="&quot;${CG_TOOL_ROOT}&quot;" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.213381378" name="Target (-t)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M3" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM.697586706" name="Platform (-p)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW.315713470" name="Platform (-p)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE.1207094196" name="Build-profile (-r)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE" value="release" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.1995524845" name="Package repositories (--xdcpath)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
                                    <listOptionValue builtIn="false" value="${COM_TI_RTSC_TIRTOSSIMPLELINK_REPOS}"/>
                                    <listOptionValue builtIn="false" value="${TARGET_CONTENT_BASE}"/>
                                </option>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS.370948319" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS" value="&quot;${COMPILER_FLAGS} &quot;" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS.370948319" name="Additional compiler options (--compileOptions)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS" value="&quot;${COMPILER_FLAGS} &quot;" valueType="string"/>
                            </tool>
                        </toolChain>
                    </folderInfo>
@@ -130,32 +130,32 @@
                            </option>
-                           <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.175402298" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
+                           <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.175402298" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
                            <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformRelease.591692219" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformRelease"/>
-                           <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderRelease.1343816611" name="GNU Make.Release" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderRelease"/>
+                           <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderRelease.1343816611" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderRelease"/>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerRelease.715932412" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerRelease">
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.597758329" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.247625407" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.16" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.1045895020" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.eabi" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE.1137491028" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE" valueType="definedSymbols">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.597758329" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.247625407" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.16" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.1045895020" name="Application binary interface. [See 'General' page to edit] (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.eabi" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE.1137491028" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE" valueType="definedSymbols">
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING.1142578237" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING" valueType="stringList">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING.1142578237" name="Treat diagnostic &lt;id&gt; as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING" valueType="stringList">
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER.1598647802" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.384925442" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.off" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.1429714162" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER.1598647802" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.384925442" name="Wrap diagnostic messages (--diag_wrap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WRAP.off" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.1429714162" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN.554909685" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.1907935244" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.403833693" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.903581802" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.vfplib" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN.554909685" name="Little endian code [See 'General' page to edit] (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.1907935244" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.403833693" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.903581802" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.vfplib" valueType="enumerated"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.694209404" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.1450243409" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.1357691375" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
@@ -162,18 +162,18 @@
                                <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.2050636466" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
                            </tool>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerRelease.254319614" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerRelease">
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE.1592354755" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE" value="256" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE.542697533" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE" value="0" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE.1811951161" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE" value="&quot;${ProjName}.out&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE.1631760981" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE" value="&quot;${ProjName}.map&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO.1368517420" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO" value="&quot;${ProjName}_linkInfo.xml&quot;" valueType="string"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER.1951716489" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.1450367947" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.off" valueType="enumerated"/>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH.85818838" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH" valueType="libPaths">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE.1592354755" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE" value="256" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE.542697533" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE" value="0" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE.1811951161" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE" value="&quot;${ProjName}.out&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE.1631760981" name="Link information (map) listed into &lt;file&gt; (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE" value="&quot;${ProjName}.map&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO.1368517420" name="Detailed link information data-base into &lt;file&gt; (--xml_link_info, -xml_link_info)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO" value="&quot;${ProjName}_linkInfo.xml&quot;" valueType="string"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER.1951716489" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.1450367947" name="Wrap diagnostic messages (--diag_wrap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.DIAG_WRAP.off" valueType="enumerated"/>
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH.85818838" name="Add &lt;dir&gt; to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH" valueType="libPaths">
                                </option>
-                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY.1718616974" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY" valueType="libs">
+                               <option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY.1718616974" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY" valueType="libs">
                                </option>
@@ -183,16 +183,16 @@
                            </tool>
                            <tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.540236827" name="ARM Hex Utility" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex"/>
                            <tool id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.30164823" name="XDCtools" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool">
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR.1840344377" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR" value="&quot;${CG_TOOL_ROOT}&quot;" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.2064796329" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M3" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM.2124982288" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW.1778229665" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE.511739713" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE" value="release" valueType="string"/>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.2073894130" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR.1840344377" name="Compiler tools directory (-c)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.CODEGEN_TOOL_DIR" value="&quot;${CG_TOOL_ROOT}&quot;" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.2064796329" name="Target (-t)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M3" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM.2124982288" name="Platform (-p)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW.1778229665" name="Platform (-p)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.PLATFORM_RAW" value="ti.platforms.simplelink:CC2650F128" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE.511739713" name="Build-profile (-r)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_PROFILE" value="release" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.2073894130" name="Package repositories (--xdcpath)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
                                </option>
-                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS.1936374730" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS" value="&quot;${COMPILER_FLAGS} &quot;" valueType="string"/>
+                               <option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS.1936374730" name="Additional compiler options (--compileOptions)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.COMPILE_OPTIONS" value="&quot;${COMPILER_FLAGS} &quot;" valueType="string"/>
                            </tool>
                        </toolChain>
                    </folderInfo>
@@ -218,4 +218,12 @@
            <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxSource" language="com.ti.ccstudio.core.TIGPPLanguage"/>
        </project-mappings>
    </storageModule>
+   <storageModule moduleId="refreshScope" versionNumber="2">
+       <configuration configurationName="Release">
+           <resource resourceType="PROJECT" workspacePath="/rcp_cc2650"/>
+       </configuration>
+       <configuration configurationName="Debug">
+       </configuration>
+   </storageModule>
 </cproject>
  • Torsten,
    Do you know if your origianl Project was created with a previous release of CCS?
    The reason is that I have the impression some additional fields were added in newer releases to either fix bugs or add new features; therefore CCS leaves these files untouched until a Project-level configuration is changed, which in turn makes the whole Project adapted to the newer specifications.
    In any case I am reporting this to one of the resident experts on this to see if he can have additional insights.
    Rafael
  • Hi Rafael,
    I'm quite sure, that I have installed CCS only once on the machine. But what might happened is, that an CCS update was installed meanwhile.
    Kind regards,
    Torsten
  • Hi Rafael,
    now I have a similar case. I think this might happen, when I start debugging. See this diff:
    Index: .cproject
    --- .cproject	(revision 33)
    @@ -64,6 +64,7 @@
     								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.475721446" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
     									<listOptionValue builtIn="false" value="&quot;${PROJECT_LOC}/../Source/Application&quot;"/>
    +									<listOptionValue builtIn="false" value="&quot;${PROJECT_LOC}/../Source/Common&quot;"/>
     									<listOptionValue builtIn="false" value="&quot;${TI_BLE_STACK}/Projects/ble/include&quot;"/>
     									<listOptionValue builtIn="false" value="&quot;${TI_BLE_STACK}/Projects/ble/ICall/Include&quot;"/>
     									<listOptionValue builtIn="false" value="&quot;${TI_BLE_STACK}/Projects/ble/Profiles/Roles/CC26xx&quot;"/>
    @@ -146,6 +147,14 @@
     							</tool>
     						</toolChain>
     					</folderInfo>
    +					<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Default.67178137.328797329" name="ext_flash.c" rcbsApplicability="disable" resourcePath="Board/Devices/ext_flash.c" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.157309872.64610718">
    +						<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.157309872.64610718" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.157309872">
    +							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.576470033" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
    +							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.381663195" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
    +							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.659170778" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
    +							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.808362618" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
    +						</tool>
    +					</fileInfo>
     					<sourceEntries>
     						<entry excluding="PROFILES/oad.c|PROFILES/oad_target_externalFlash.c|TOOLS/cc26xx_ble_app_oad.cmd|Startup/ST|Board|cc26x0f128.cmd|PROFILES/simplekeys.h|PROFILES/simplekeys.c" flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
     					</sourceEntries>
    @@ -327,5 +336,12 @@
     		</project-mappings>
     	</storageModule>
     	<storageModule moduleId="scannerConfiguration"/>
    -	<storageModule moduleId="refreshScope"/>
    +		<configuration configurationName="FlashOnly_ST_OAD_ExtFlash">
    +			<resource resourceType="PROJECT" workspacePath="/rcp_server"/>
    +		</configuration>
    +		<configuration configurationName="FlashROM">
    +		</configuration>
    +	</storageModule>
     </cproject>
    The only change, I've made was the first added line.
    Kind regards,
    Torsten
  • Torsten,
    We agree with you it is a bug in the open source CDT (where CCS is based). CDT persists the “name” of each build-option into the .cproject file for some reason, but there is no good reason to persist option names.
    In this case I filed the bug number SDSCM00052402 (check its status in the link SDOWP in my signature below). However, given this is an issue with the open source components of CCS, a definitive fix may take a while to be implemented.
    A workaround suggestion from our resident expert: "So as a workaround he could just check-in the version of the file with the additional “name” attributes, and after that he shouldn’t see these bogus changes anymore."
    I apologize for the inconvenience,
    Rafael
  • The workaround sounds good to me :-) Thank you for elaborating on this.
