OS: Windows 7 64-bit, Service Pack 1
CCS: v 6.1.0.00104
During compile across many projects I intermittently get a compile error.
error: unable to rename C:\Users\MY.USER\AppData\Local\Temp\018002 to
Application\\board_key.obj: File exists
The .obj file called out is not consistent nor is the temp file, they vary. If I do a clean and a rebuild I may get the error again or I may not. If I get the error again it might be a different file or everything might compile cleanly.
I would consider this error more annoying than anything as i can rebuild and sometimes get past it although its frequency appears to be dependent on how many files are being compiled so it looks like it occurs more frequently on my larger projects.
Any thoughts or ideas would be appreciated.
