I'm trying to load a DSS script from outside CCS scripting console and running into some issues. I'm running on Rhino 1.7 and get the following message when I try loading the script:
SEVERE: Can not connect to DebugServer. Path not found: '/Users/bin' SEVERE: Could not start server: DebugServer.1: Can not connect to DebugServer. Path not found: '/Users/bin' org.mozilla.javascript.WrappedException: Wrapped com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1: Can not connect to DebugServer. Path not found: '/Users/bin'
This directory did not exist so I created it, ran it again and it failed to load libti_xpcom.dylib. I found this file in <INSTALL_DIRECTORY>/ccsv6/ccs_base/DebugServer/bin so I copied this directory to /Users/bin. Now I get this error message:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /Users/bin/libti_xpcom.dylib: dlopen(/Users/bin/libti_xpcom.dylib, 1): Library not loaded: @rpath/libti_logger.dylib Referenced from: /Users/bin/libti_xpcom.dylib Reason: image not found at java.lang.ClassLoader$NativeLibrary.load(Native Method) ...
This same script runs from CCS scripting console by running loadJSFile fileName.js.
What's the best way to call the .js scripts from Java?
