Other Parts Discussed in Thread: SYSBIOS, CC1310, LAUNCHXL-CC2650
Even single-stepping through, when I try to 'step into' Semaphore_pend in my task, it throws a fault and stops at the breakpoint in my fault handler.
It doesn't show code for Semaphore_pend, doesn't break at the start of the fault handler, or do any of the other things I've learned to expect when using 'step into' in other debugging suites.
CCS seems unable to give any sort of usable backtrace, so I've no clue where it's actually crashing, other than "somewhere in the call chain initiated by Semaphore_pend".
ROV Task viewer tabs don't show any Task other than idle even when I'm stepping through my task function. Curiously, my Task only shows up in the ReadyQ readout and the Raw Instance States, but nowhere else.
I've checked my stack, it's far from full immediately before the fault gets thrown - maybe a solid kilobyte unused since I've bumped it up a few times when suspecting stack overflow as a cause.
I've also checked most of my variables and pointers for sensible values and they all seem fine.
So, CCS experts, how do I get CCS to tell me what's going on so I can fix it?
