Hi
When I start ROV (Tools->RTOS Object View (ROV)) in CCS 6.2.0.00050, a ROV window pops up with a progress status bar showing "Creating XDC Shell". The status of "Creating XDC Shell" stops at 10% and hangs there forever. Any kind of help is appreciated.
Thanks!
Wai Kwok
Hi John
The XDCTools version is 3.32.1.2_core. Is there any way to see the log where ROV gets stuck. I know ROV will extract some info from the DSP executable file (.out). It is possible it get stuck there.
Thanks!
Wai Kwok
Following is what I get from the console. ROV hangs up at "Loading ROV recap file ..." stage.
osgi> dvtLogOptions.xml DOES NOT exists
log4j:WARN No appenders could be found for logger (org.eclipse.jetty.util.log).
log4j:WARN Please initialize the log4j system properly.
Loaded FPGA Image: C:\ti\ccsv6\ccs_base\common\uscif\dtc_top.jbc
[Controller] +++ (0ms) 0ms: Beginning of ROVController constructor.
[Controller] XDCROOT = C:/ti/xdctools_3_32_01_22_core
[Controller] XDCPATH = C:/ti/ipc_3_44_01_01/packages;C:/ti/bios_6_46_04_53/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;/RTSC_Platform;C:/ti/uia_2_00_06_52/packages;/packages;/packages;
[Controller] +++ (0ms) 0ms: End of ROVController constructor.
[Controller] +++ (0ms) 0ms: Beginning of ROVController.initialize
[Controller] ===== Initialize has been called ========
[Controller] Filename = C:\git\phoenix_develop\DevProjects\Output\dsp_app.out
[MemoryReader] Number of sections: 74
[MemoryReader] #0 ti.sdo.ipc.SharedRegion_0: 0xc000000 length: 65536
[MemoryReader] #1 ti.sdo.ipc.SharedRegion_1: 0x81000000 length: 1159725056
[MemoryReader] #2 ti.sdo.ipc.SharedRegion_3: 0xc010000 length: 3604480
[MemoryReader] Excluding: #3 .ti.decompress: 0x0 length: 0
[MemoryReader] #4 .init_array: 0x0 length: 0
[MemoryReader] #5 .bss: 0x818174 length: 4
[MemoryReader] #6 .neardata: 0x818178 length: 8
[MemoryReader] #7 .rodata: 0x818180 length: 28
[MemoryReader] Excluding: #8 .args: 0x800000 length: 0
[MemoryReader] Excluding: #9 .ti.handler_table: 0x0 length: 0
[MemoryReader] Excluding: #10 .c6xabi.exidx: 0x0 length: 0
[MemoryReader] Excluding: #11 .c6xabi.extab: 0x0 length: 0
[MemoryReader] Excluding: #12 .qmss: 0x0 length: 0
[MemoryReader] Excluding: #13 .cppi: 0x0 length: 0
[MemoryReader] Excluding: #14 .desc: 0x0 length: 0
[MemoryReader] Excluding: #15 platform_lib: 0x0 length: 0
[MemoryReader] Excluding: #16 .sysbios: 0xc6869e80 length: 3072
[MemoryReader] Excluding: #17 xdc.meta: 0x800000 length: 264
[MemoryReader] Excluding: #18 .sect_SL2: 0xc3ec6a0 length: 2176
[MemoryReader] #19 .cinit: 0xc686b800 length: 8960
[MemoryReader] #20 .const: 0xc6860460 length: 35828
[MemoryReader] Excluding: #21 .sect_DDR2: 0xc6853c40 length: 51232
[MemoryReader] Excluding: #22 .sect_DDR2_code: 0xc680dba0 length: 286880
[MemoryReader] Excluding: #23 .sect_doppler_output: 0x0 length: 0
[MemoryReader] #24 .far: 0x800000 length: 65588
[MemoryReader] #25 .cio: 0x810038 length: 288
[MemoryReader] #26 .sysmem: 0x810158 length: 0
[MemoryReader] #27 .bss: 0x810158 length: 0
[MemoryReader] #28 .pinit: 0x810158 length: 0
[MemoryReader] #29 .switch: 0x810158 length: 936
[MemoryReader] #30 .data: 0x810500 length: 48
[MemoryReader] #31 .stack: 0x810530 length: 4096
[MemoryReader] #32 .sect_LL2: 0x811530 length: 1460
[MemoryReader] #33 .sect_doppler_data_LL2: 0x811ae8 length: 60
[MemoryReader] #34 .sect_host_interface_struct: 0x80000000 length: 7864
[MemoryReader] #35 .sect_params: 0x80001eb8 length: 104716
[MemoryReader] #36 .sect_params_misc: 0x8001b7c8 length: 2
[MemoryReader] #37 .sect_error: 0x8001b7d0 length: 840
[MemoryReader] #38 .sect_noncached_DDR2: 0x8001bb80 length: 1200824
[MemoryReader] #39 .sect_diagnostics: 0x80140e38 length: 0
[MemoryReader] #40 .sect_dup_vers_struct: 0x80140e38 length: 32
[MemoryReader] #41 .sect_ibl_version: 0x80fffe00 length: 32
[MemoryReader] #42 .sect_top_of_DDR_vars: 0x80fffe20 length: 4
[MemoryReader] Excluding: #43 boot: 0xc686b400 length: 1024
[MemoryReader] Excluding: #44 .boot_entry: 0x0 length: 0
[MemoryReader] #45 .far: 0x0 length: 0
[MemoryReader] #46 .sect_Core0_LL2: 0x811b30 length: 18816
[MemoryReader] #47 .sect_RSC_LL2: 0x811b30 length: 0
[MemoryReader] #48 .sect_Doppler_LL2: 0x811b30 length: 6812
[MemoryReader] Excluding: #49 .debug_info: 0x0 length: 5420092
[MemoryReader] Excluding: #50 .debug_aranges: 0x0 length: 35192
[MemoryReader] Excluding: #51 .debug_pubnames: 0x0 length: 126301
[MemoryReader] Excluding: #52 .debug_line: 0x0 length: 526017
[MemoryReader] Excluding: #53 .debug_frame: 0x0 length: 223148
[MemoryReader] Excluding: #54 .debug_abbrev: 0x0 length: 404249
[MemoryReader] Excluding: #55 .debug_pubtypes: 0x0 length: 1954554
[MemoryReader] Excluding: #56 .debug_str: 0x0 length: 3169141
[MemoryReader] #57 .fardata.1: 0x811b28 length: 8
[MemoryReader] #58 .fardata.2: 0x8164b0 length: 7364
[MemoryReader] #59 .heapll2: 0x819f00 length: 286976
[MemoryReader] #60 .text: 0xc380000 length: 439360
[MemoryReader] Excluding: #61 .vecs: 0xc3ed000 length: 512
[MemoryReader] #62 .sect_SL2_EDMA.1: 0xc3eb480 length: 4560
[MemoryReader] #63 .sect_SL2_EDMA.2: 0xc3ec680 length: 32
[MemoryReader] #64 .sect_colorflow_ddr: 0xc6869080 length: 3584
[MemoryReader] #65 .sect_doppler_data.1: 0xc686ac00 length: 586
[MemoryReader] #66 .sect_doppler_data.2: 0xc686b000 length: 32
[MemoryReader] #67 .sect_cine_data: 0xc9400000 length: 918552576
[MemoryReader] #68 .sect_mem_ext: 0xc6200000 length: 6347668
[MemoryReader] Excluding: #69 .c6xabi.attributes: 0x0 length: 59
[MemoryReader] Excluding: #70 .symtab: 0x0 length: 702240
[MemoryReader] Excluding: #71 .TI.section.flags: 0x0 length: 71
[MemoryReader] Excluding: #72 .strtab: 0x0 length: 791692
[MemoryReader] Excluding: #73 .shstrtab: 0x0 length: 959
[Controller] +++ (62ms) 62ms: ROVController.initialize creating new ROVServerReader instance.
[Controller] CPU = 102
[Controller] +++ (62ms) 0ms: Creating new xdc.tools.Server.
[Controller] ROVServerReader XDCPATH = C:/ti/ipc_3_44_01_01/packages;C:/ti/bios_6_46_04_53/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;/RTSC_Platform;C:/ti/uia_2_00_06_52/packages;/packages;/packages;
[Controller] ROVServerReader XDCROOT = C:/ti/xdctools_3_32_01_22_core
[Controller] +++ (62ms) 0ms: Calling xdc.tools.Server start.
[Controller] +++ (78ms) 16ms: ROVController.initialize calling start on ROVServerReader thread.
[Controller] Server Reader started.
[Controller] Waiting for response from server...
[Controller] ROVController - Adding controller listener
[Controller] ROVController - Inside getParentNodes...
[Controller] Placing new module list request
[Controller] ===== Setting percentage to 10% =======
[Controller] ROVController - Updating startup exception.
[Server ] +++ (1497983550009ms) Beginning of xdc.rov.server Main.xs run.
[Server ] Version = 3.4
[Server ] Executable = C:/git/phoenix_develop/DevProjects/Output/dsp_app.out
[Server ] Controller = 0
[Server ] serverVers = 4
[Server ] Creating ISymbolReader Instance
[Server ] Creating ICallStack Instance
[Server ] Creating ICallBack Instance
[Controller] Firing LHS Refresh
[Controller] ROVController - Received refresh command.
[Server ] Retrieving Recap File
[Controller] ROVController.refresh: Firing CPU_RUNNING.
[Controller] ------ Received event: CPU_RUNNING
[Controller] Server not yet initialized...
[Controller] ROVController.refresh: Firing CPU_HALTED.
[Controller] ------ Received event: CPU_HALTED
[SymbolTable] Symbol: BIOS_start Address: -1
[Server ] Failed to find symbol: 'BIOS_start'!
[Server ] Found RTSC recap file: C:/git/phoenix_develop/PhoenixPlatformCfg/Default/configPkg/package/cfg/Phx_C6678_configuration_pe66.rov.xs
[Server ] Creating MemoryReader Instance
[Server ] Starting ROV Model
