Compiler: Some compiler flags incompatible between CGT and GCC
Let's assume a common library for multiple architectures: arm (GCC) and c6x (CGT). Maintainers of the library would like to provide a pkg-config file (pkg-config -- tool to get compile/link flags). pkg-config tool is designed to work natively with gcc-like flags [1]. Unfortunately due to incompatibility between GCC and CGT [2], it is not possible to provide uniform pkg-config file for both architectures, because neither pkg-config will properly return flags, nor other systems that depend on pkg-config behavior (for example cmake-based build systems).
What is your proposed way to solve this incompatibility?
With regards,
Bartek
[1] quote from  pkg-config --help:
  --libs-only-l                                  output -l flags
  --libs-only-other                              output other libs (e.g.
                                                 -pthread)
  --libs-only-L                                  output -L flags
  --cflags                                       output all pre-processor and
                                                 compiler flags
  --cflags-only-I                                output -I flags
  --cflags-only-other                            output cflags not covered by
[2] See below table for incompatible flags that matters for this report:
GCC CGT comments
-L<path> -i=<path> library search path
-l<name> -l<fullname>
link against a library/archive/shared object;
GCC guess library name (either lib<name>.so or lib<name>.a)
