Other Parts Discussed in Thread: CCSTUDIO
Hi
Has anyone tried running the debug server from Matlab. I'm stuck on the matlab syntax needed to recognize the scripts in http://processors.wiki.ti.com/index.php/Scripting_Console
Cheers
Hi
Cheers
Hi Ki
Yes, its custom.
I don't entirely understand it, but this link talks about calling Java from Matlab.
http://www.caspur.it/risorse/softappl/doc/matlab_help/techdoc/matlab_external/ch_java.html
Your examples in C:\Program Files\Texas Instruments\ccsv4\scripting\examples got me wondering if I can run these from Matlab somehow.
I'm hoping that I can run a matlab script, have it call java which uses the CCSv4 debug server. The functions I want to use are debugServer(), .openSession(), target.connect(), memory.loadProgram(), symbols.getAddress(), memory.loadData().
Possible?
Matlab said they are not planning have their Embedded IDE tool support CCSv4 and will support CCSv5: which according to your Wiki, won't be out until Q3, 2011. Thats too late for our product.
http://processors.wiki.ti.com/index.php/Category:Code_Composer_Studio_v5
Cheers
That's interesting. It certainly looks possible. DSS is just a bunch of Java APIs.
You may want to look at the wiki topic for calling DSS from a Java app.
http://processors.wiki.ti.com/index.php/Java_Scripting_with_DSS
Good luck!
ki
I present the solution I used to run DSS from MATLAB:
CCS_DIR = 'C:\TI\ccsv4';
DEBUG_DIR = [CCS_DIR '\DebugServer'];
TARGETCFG_DIR = 'C:\TI\target_cfg'; %Please be sure the path does not contain the space
javaaddpath([DEBUG_DIR '/packages/ti/dss/java/js.jar']);
javaaddpath([DEBUG_DIR '/packages/ti/dss/java/dss.jar']);
javaaddpath([DEBUG_DIR '/packages/ti/dss/java/com.ti.debug.engine_1.0.0.jar']);
javaaddpath([DEBUG_DIR '/packages/ti/dss/java/com.ti.ccstudio.scripting.environment_3.1.0.jar']);
javaaddpath([DEBUG_DIR '/packages/ti/dss/java/com.ti.ccstudio.scripting.rtdx_1.0.0.jar']);
import com.ti.ccstudio.scripting.environment.*;
import com.ti.debug.engine.scripting.*;
import java.lang.System;
% Sets the system property indicated by the specified key
System.setProperty('XPCOM.RUNTIME',[DEBUG_DIR '\win32']);
% Create scripting environment object - which is the main entry point into
% any script, set timeout 60s
script = ScriptingEnvironment.instance();
script.setScriptTimeout(60000);
% Create a log file in the current directory to log script execution
if diagnostic
script.traceBegin('MemoryTestLog.xml', 'DefaultStylesheet.xsl');
script.traceSetConsoleLevel(TraceLevel.ALL);
script.traceSetFileLevel(TraceLevel.ALL);
end
% Get the user Debug Server and Session
try
uDebugServer = script.getServer('DebugServer.1');
uDebugServer.setConfig([TARGETCFG_DIR '\sim67xx.ccxml']);
uDebugSession = uDebugServer.openSession();
catch ee
error('Debug Server could not run because configuration has not been set');
end
% Get the RTDX Server and Session
rtdxServer = script.getServer('RTDXServer.1');
rtdxSession = rtdxServer.openSession(uDebugSession);
% Connect if necessary
if ~uDebugSession.target.isConnected();
uDebugSession.target.connect();
end
% Load the program from the out file
uDebugSession.memory.loadProgram('prog.out');
uDebugSession.target.runAsynch();
Hope it will be usefull for You.
Hi Andre
andreiltd said:Hope it will be usefull for Yo
Are you kidding me! You're post helped me immensely.
I was able to get it to work with Matlab 2010a and 2008b using spaces in my directories. The following script worked
CCS_DIR = 'C:/Program Files/Texas Instruments/ccsv4';
DEBUG_DIR = [CCS_DIR '/DebugServer'];
TARGETCFG_DIR = 'C:/Documents and Settings/epatto/user/CCSTargetConfigurations'; %Please be sure the path does not contain the space
TARGET_EMULATOR = '/EVM6472_XDS510USB.ccxml';
WORK_DIR = 'D:/vws/ejp_M2_evm6472_pwcw/spDsp/EVM/Test.Filter';
javaaddpath([ DEBUG_DIR '/packages/ti/dss/java/js.jar' ]);
javaaddpath([ DEBUG_DIR '/packages/ti/dss/java/dss.jar' ]);
javaaddpath([ DEBUG_DIR '/packages/ti/dss/java/com.ti.debug.engine_1.0.0.jar' ]);
javaaddpath([ DEBUG_DIR '/packages/ti/dss/java/com.ti.ccstudio.scripting.environment_3.1.0.jar' ]);
javaaddpath([ DEBUG_DIR '/packages/ti/dss/java/com.ti.ccstudio.scripting.rtdx_1.0.0.jar' ]);
System.setProperty('XPCOM.RUNTIME',[ DEBUG_DIR '\win32' ]);
uDebugServer.setConfig([TARGETCFG_DIR TARGET_EMULATOR]);
uDebugSession = uDebugServer.openSession('Spectrum Digital XDS510USB Emulator_0/C6472_0');
uDebugSession.memory.loadProgram([ WORK_DIR '/Debug/Test.Filter.out']);
Hi
I thought I'd try to start the CCSv4 IDE from Matlab as they did in TI's example (http://processors.wiki.ti.com/index.php/Debugging_Your_DSS_Script_Using_CCS)
Wow, did I get errors when I tried the commands below. I know the debug server session is working because I can read and write to my EVM. But apparently I've not configured Matlab correctly.
Also, I was getting the error
java.lang.OutOfMemoryError: PermGen space
which I resolved by increasing the MaxPermSize to 128 M as per
http://www.mathworks.com/support/solutions/en/data/1-20FV2Z/index.html?product=SL&solution=1-20FV2Z
***********The dreaded output errors follow the two commands in green**************************
>> javaaddpath([ DEBUG_DIR '/../eclipse/startup.jar' ]); % Used for starting IDE.
>> script.getServer('CCSServer.1').openSession('.*');
java.lang.NoClassDefFoundError: com/ti/ccstudio/debug/engine/proxies/PxyLicenseManager
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:160)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:498)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:468)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:427)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:339)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:388)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.ti.ccstudio.debug.server.factory.LicenseEngineFactory.createInstance(LicenseEngineFactory.java:14)
at com.ti.ccstudio.update.CCEUpdateStartup.heartbeat(CCEUpdateStartup.java:34)
at com.ti.ccstudio.update.CCEUpdateStartup.earlyStartup(CCEUpdateStartup.java:13)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1759)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Caused by: java.lang.ClassNotFoundException: com.ti.ccstudio.debug.engine.proxies.PxyLicenseManager
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:407)
... 23 more ("Yeah right. Like I need more errors!)
Re: Quest to run CCSv4 IDE and Matlab at the same time.
Well according to the info http://processors.wiki.ti.com/index.php/Debugging_Your_DSS_Script_Using_CCS, the DSS and CCS can share the same debug server instance. So I thought I'd try this:
And thats where I run into the problem. Seems you can't access the debug server as I'd hoped. The CCS session I have opened appears to have 100% control of the debug server session.
Perhaps this can only be done with the simulator?
Cheers
>> uDebugSession = uDebugServer.openSession('Spectrum Digital XDS510USB Emulator_0/C6472_0'); % Exclude the text in the quotes to get list of targets"
SEVERE: ICEPICK_C: Error initializing emulator
SEVERE: Can not initialize DebugServer. ICEPICK_C: Error initializing emulator
SEVERE: Could not start server: DebugServer.1: Can not initialize DebugServer. ICEPICK_C: Error initializing emulator
??? Java exception occurred:
com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1:
at com.ti.debug.engine.scripting.DebugServer$SessionFactory.<init>(DebugServer.java:142)
at com.ti.debug.engine.scripting.DebugServer.openSession(DebugServer.java:1119)
at com.ti.debug.engine.scripting.DebugServer.openSession(DebugServer.java:49)
Eddie,
DSS needs to launch CCS (using: script.getServer("CCSServer.1").openSession(".*");) to ensure they are interfacing to the same debug server. You should not be manually starting up CCS. I'm pretty sure the error you are seeing is because you are starting two separate debug sessions, both of which are trying to use the same emulator.
ki
Thanks for explaining that Ki
I tried starting DSS as described in my Thu, Sep 23 2010 7:21 PM post above and got a ton of errors. Any thoughts on how to fix the errors?
Eddie said:>> javaaddpath([ DEBUG_DIR '/../eclipse/startup.jar' ]); % Used for starting IDE.
Is this some Matlab script? Or are you entering commands manually from some Matlab console?
Could you attach an Eclipse error log?
http://processors.wiki.ti.com/index.php/Troubleshooting_CCS#Eclipse_Error_Log
Just launch CCS manually and get the log
ki
% Specify the driver you use to connect to the chip/EVM
% Specify your working directory.
WORK_DIR = 'D:/vws/ejp_M2_evm6472_pwcw/spDsp/EVM/Test/Test.Doppler/Test.WallFilter';
% Add java jar libs to Matlab classpath (use javaclasspath to see if this worked)
% Start GUI
---doCreatePage: firstime=true solutionBased=false
Exception in thread "Scripting Console - Rhino" java.lang.NoClassDefFoundError: com/ti/ccstudio/scripting/environment/ScriptingException
at com.ti.ccstudio.scripting.gss.ScriptingService.getScriptableObject(ScriptingService.java:95)
at com.ti.ccstudio.scripting.console.internal.RhinoAdapter.initScriptableObectjs(RhinoAdapter.java:302)
at com.ti.ccstudio.scripting.console.internal.RhinoAdapter.access$2(RhinoAdapter.java:296)
at com.ti.ccstudio.scripting.console.internal.RhinoAdapter$2.run(RhinoAdapter.java:115)
at com.ti.ccstudio.rhino.internal.RhinoThreadExecutor$1.run(RhinoThreadExecutor.java:53)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at com.ti.ccstudio.rhino.internal.RhinoThreadExecutor$RhinoThread.run(RhinoThreadExecutor.java:73)
Caused by: java.lang.ClassNotFoundException: com.ti.ccstudio.scripting.environment.ScriptingException
... 9 more
... 23 more
java.lang.NullPointerException at com.ti.ccstudio.breakpoint.core.PropertyBreakpoint.updateMarkerMessage(PropertyBreakpoint.java:463) at com.ti.ccstudio.breakpoint.core.PropertyBreakpoint.setSourceLocation(PropertyBreakpoint.java:630) at com.ti.ccstudio.breakpoint.core.PropertyBreakpoint.updateMarker(PropertyBreakpoint.java:337) at com.ti.ccstudio.breakpoint.core.PropertyBreakpoint.setMarker(PropertyBreakpoint.java:179) at org.eclipse.debug.internal.core.BreakpointManager.createBreakpoint(BreakpointManager.java:430) at org.eclipse.debug.internal.core.BreakpointManager.loadBreakpoints(BreakpointManager.java:167) at org.eclipse.debug.internal.core.BreakpointManager.initializeBreakpoints(BreakpointManager.java:327) at org.eclipse.debug.internal.core.BreakpointManager.getBreakpoints0(BreakpointManager.java:296) at org.eclipse.debug.internal.core.BreakpointManager.getBreakpoints(BreakpointManager.java:305) at com.ti.ccstudio.breakpoint.ui.action.base.AbstractEditorActionDelegate.determineTargetBreakpoint(AbstractEditorActionDelegate.java:64) at com.ti.ccstudio.breakpoint.ui.action.EditorPropertiesRulerActionDelegate.updateMenuItem(EditorPropertiesRulerActionDelegate.java:31) at com.ti.ccstudio.breakpoint.ui.action.base.AbstractEditorActionDelegate.setActiveEditor(AbstractEditorActionDelegate.java:44) at org.eclipse.ui.internal.EditorPluginAction.editorChanged(EditorPluginAction.java:75) at org.eclipse.ui.internal.EditorPluginAction.<init>(EditorPluginAction.java:34) at org.eclipse.ui.internal.ActionDescriptor.createAction(ActionDescriptor.java:256) at org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:170) at org.eclipse.ui.internal.ViewerActionBuilder.createActionDescriptor(ViewerActionBuilder.java:53) at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:158) at org.eclipse.ui.internal.ViewerActionBuilder.readElement(ViewerActionBuilder.java:88) at org.eclipse.ui.internal.registry.RegistryReader.readElements(RegistryReader.java:138) at org.eclipse.ui.internal.registry.RegistryReader.readElementChildren(RegistryReader.java:127) at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:141) at org.eclipse.ui.internal.ViewerActionBuilder.readElement(ViewerActionBuilder.java:88) at org.eclipse.ui.internal.registry.RegistryReader.readElements(RegistryReader.java:138) at org.eclipse.ui.internal.registry.RegistryReader.readExtension(RegistryReader.java:149) at org.eclipse.ui.internal.registry.RegistryReader.readRegistry(RegistryReader.java:170) at org.eclipse.ui.internal.PluginActionBuilder.readContributions(PluginActionBuilder.java:112) at org.eclipse.ui.internal.ViewerActionBuilder.readViewerContributions(ViewerActionBuilder.java:106) at org.eclipse.ui.internal.PopupMenuExtender.readStaticActionsFor(PopupMenuExtender.java:373) at org.eclipse.ui.internal.PopupMenuExtender.<init>(PopupMenuExtender.java:125) at org.eclipse.ui.internal.PartSite.registerContextMenu(PartSite.java:114) at org.eclipse.ui.internal.EditorSite.registerContextMenu(EditorSite.java:151) at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:2673) at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53) at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:368) at org.eclipse.cdt.internal.ui.editor.CEditor.createPartControl(CEditor.java:843) at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:596) at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372) at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566) at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:263) at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1420) at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.java:1005) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37) at org.eclipse.core.runtime.Platform.run(Platform.java:843) at org.eclipse.ui.internal.EditorManager.restoreState(EditorManager.java:1000) at org.eclipse.ui.internal.WorkbenchPage.restoreState(WorkbenchPage.java:2836) at org.eclipse.ui.internal.WorkbenchWindow.restoreState(WorkbenchWindow.java:1949) at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.java:2869) at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2817) at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681) at org.eclipse.ui.internal.Workbench.runStartupWithProgress(Workbench.java:1414) at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1679) at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1650) at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37) at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1473) at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(WorkbenchConfigurer.java:183) at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:702) at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:97) at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336) at org.eclipse.core.launcher.Main.basicRun(Main.java:280) at org.eclipse.core.launcher.Main.run(Main.java:996) at org.eclipse.core.launcher.Main.main(Main.java:971) at org.eclipse.core.launcher.Main.main(Main.java:950) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.ti.ccstudio.scripting.CCSSession$CCSLauncher.run(CCSSession.java:36) at java.lang.Thread.run(Unknown Source)
5556.OpenGuiFromMatlab_CCSv4ErrorLog.log
Hi Ki
I am running a Matlab scfipt. Here are the files I uploaded. Let me know if you also need the Debug Server Logging output. I only did the Eclipse Error Log.
OpenGuiFromMatlab_script.txt: - run this to configure and start the GUI (but it doesn't work unfortunately)
OpenGuiFromMatlab_MatlabErrors.txt - errors that were output on Matlab
OpenGuiFromMatlab_CCSv4Errors.txt - errors that popped up in my CCSv4 text edit window
OpenGuiFromMatlab_CCSv4ErrorLog.log - eclipse error log I exported as per the above wiki page.
Thanks for your help.
