CCS/EK-TM4C123GXL: meta-data cannot be interpreted
Part Number: EK-TM4C123GXL
Hi I have a project built on CCSv5.3.0. When i am trying to import the same on the same verision of CCS It is giving "Error: Import failed for project 'Thales' because its meta-data cannot be interpreted. Please contact support" error.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?fileVersion 4.0.0?><cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage">
	<storageModule configRelations="2" moduleId="org.eclipse.cdt.core.settings">
		<cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922">
			<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922" moduleId="org.eclipse.cdt.core.settings" name="ThalesDebug">
				<macros>
					<stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/ek-lm4f232/interrupts/ccs"/>
					<stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="Z:\Sandbox\StellarisWare-8555"/>
				</macros>
				<externalSettings/>
				<extensions>
					<extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
					<extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
					<extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
					<extension id="org.eclipse.cdt.core.GmakeErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
					<extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/>
				</extensions>
			</storageModule>
			<storageModule moduleId="cdtBuildSystem" version="4.0.0">
				<configuration artifactExtension="out" artifactName="thales" buildProperties="" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922" name="ThalesDebug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep="&quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin&quot; &quot;${BuildArtifactFileName}&quot; &quot;${BuildArtifactFileBaseName}.bin&quot; &quot;${CG_TOOL_ROOT}/bin/armofd&quot; &quot;${CG_TOOL_ROOT}/bin/armhex&quot; &quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin&quot;">
					<folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.2020069937" name="/" resourcePath="">
						<toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.DebugToolchain.1525199835" name="TI Build Tools" secondaryOutputs="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.outputType__BIN" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug.1153629190">
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.1861287401" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList">
								<listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM4F232H5QD"/>
								<listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/>
								<listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/>
								<listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.5.0"/>
								<listOptionValue builtIn="false" value="LINKER_COMMAND_FILE=thales_ccs.cmd"/>
								<listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/>
								<listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/>
								<listOptionValue builtIn="false" value="PRODUCTS="/>
							</option>
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1603793578" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="5.2.5" valueType="string"/>
							<targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformDebug.703576982" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.targetPlatformDebug"/>
							<builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug.182557545" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.builderDebug"/>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.1907528255" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.SILICON_VERSION.7M4" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.960295545" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.CODE_STATE.16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.1559931403" name="Application binary interface. [See 'General' page to edit] (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.ABI.eabi" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.238886083" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.FLOAT_SUPPORT.FPv4SPD16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GCC.423041771" name="Enable support for GCC extensions (DEPRECATED) (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GCC" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE.1788604114" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEFINE" valueType="definedSymbols">
									<listOptionValue builtIn="false" value="ccs"/>
									<listOptionValue builtIn="false" value="UART_BUFFERED"/>
									<listOptionValue builtIn="false" value="PART_LM4F232H5QD"/>
									<listOptionValue builtIn="false" value="TARGET_IS_BLIZZARD_RA1"/>
									<listOptionValue builtIn="false" value="&quot;ccs&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN.1359862018" name="Little endian code [See 'General' page to edit] (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH.1297868416" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.INCLUDE_PATH" valueType="includePath">
									<listOptionValue builtIn="false" value="&quot;C:\ti\TivaWare_C_Series-2.1.4.178\driverlib&quot;"/>
									<listOptionValue builtIn="false" value="&quot;C:\ti\ccsv6\tools\compiler\arm_15.12.3.LTS\include&quot;"/>
									<listOptionValue builtIn="false" value="&quot;${workspace_loc:/${ProjName}}&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.1516648446" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING.520230347" name="Treat diagnostic &lt;id&gt; as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.DIAG_WARNING" valueType="stringList">
									<listOptionValue builtIn="false" value="225"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.561012580" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.UAL.1014708418" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compilerID.UAL" value="true" valueType="boolean"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.1426230337" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.130216153" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.1838000029" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.2053923979" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
							</tool>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug.1153629190" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.linkerDebug">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE.603859338" name="Link information (map) listed into &lt;file&gt; (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.MAP_FILE" value="&quot;thales_ccs.map&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE.1254825406" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.STACK_SIZE" value="4096" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE.659153682" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.HEAP_SIZE" value="1024" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE.806134944" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.OUTPUT_FILE" value="&quot;thales.out&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY.1446204240" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.LIBRARY" valueType="libs">
									<listOptionValue builtIn="false" value="&quot;libc.a&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH.309617558" name="Add &lt;dir&gt; to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.SEARCH_PATH" valueType="libPaths">
									<listOptionValue builtIn="false" value="&quot;${CG_TOOL_ROOT}/lib&quot;"/>
									<listOptionValue builtIn="false" value="&quot;${CG_TOOL_ROOT}/include&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO.534243564" name="Detailed link information data-base into &lt;file&gt; (--xml_link_info, -xml_link_info)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.linkerID.XML_LINK_INFO" value="&quot;thales_linkInfo.xml&quot;" valueType="string"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__CMD_SRCS.1727191946" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__CMD_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__CMD2_SRCS.1409535209" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__CMD2_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__GEN_CMDS.1707109227" name="Generated Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exeLinker.inputType__GEN_CMDS"/>
							</tool>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.815856646" name="ARM Hex Utility" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.TOOL_ENABLE.849682217" name="Enable tool" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.TOOL_ENABLE" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.OUTPUT_FORMAT.235084305" name="Output format" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.OUTPUT_FORMAT" value="com.ti.ccstudio.buildDefinitions.TMS470_5.2.hex.OUTPUT_FORMAT.INTEL" valueType="enumerated"/>
							</tool>
						</toolChain>
					</folderInfo>
					<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.kirchhoff-mcu/thales_pin_map.c" name="thales_pin_map.c" rcbsApplicability="disable" resourcePath="kirchhoff-mcu/thales_pin_map.c" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543.401055451">
						<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543.401055451" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543">
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.1918771073" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.270898350" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.75519384" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.1302649444" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
						</tool>
						<tool command="" customBuildStep="true" id="org.eclipse.cdt.managedbuilder.ui.rcbs.115627029.595286852.165672383.1949938654.1613078607" name="Resource Custom Build Step">
							<inputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.inputtype.1639265711.1138366151.2122440743.1101978133.624416726" name="Resource Custom Build Step Input Type">
								<additionalInput kind="additionalinputdependency" paths=""/>
							</inputType>
							<outputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.outputtype.2035288667.973823534.1155746462.1793481193.1824870904" name="Resource Custom Build Step Output Type"/>
						</tool>
					</fileInfo>
					<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.kirchhoff-mcu/kk_i2c_master.c" name="kk_i2c_master.c" rcbsApplicability="disable" resourcePath="kirchhoff-mcu/kk_i2c_master.c" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543.661379229">
						<tool id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543.661379229" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.exe.compilerDebug.1244150543">
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS.1206972258" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__C_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS.1620126933" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__CPP_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS.1179905370" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS.871634591" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_5.2.compiler.inputType__ASM2_SRCS"/>
						</tool>
						<tool command="" customBuildStep="true" id="org.eclipse.cdt.managedbuilder.ui.rcbs.1676925901.1836503200.817677983.1892608558.1615555059" name="Resource Custom Build Step">
							<inputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.inputtype.1768986099.58659738.2075007034.1422634131.1006549470" name="Resource Custom Build Step Input Type">
							</inputType>
							<outputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.outputtype.249282381.1864155835.898648700.253467880.1428998331" name="Resource Custom Build Step Output Type"/>
						</tool>
					</fileInfo>
					<sourceEntries>
						<entry excluding="lm4f232h5qd.cmd|kirchhoff-mcu/thales_pin_map.c|kirchhoff-mcu/kk_i2c_master.c|kirchhoff-mcu/kk_main.c|kirchhoff-common/uart.c|kirchhoff-common/timers.c|kirchhoff-common/srec.c|kirchhoff-common/queue.c|kirchhoff-mcu/kk_j2a.c|kirchhoff-mcu/kk_interrupts.c|kirchhoff-mcu/kk_dmsg.c|kirchhoff-mcu/kk_uart.c" flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
					</sourceEntries>
				</configuration>
			</storageModule>
			<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
		</cconfiguration>
		<cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Release.1936800841">
			<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.1936800841" moduleId="org.eclipse.cdt.core.settings" name="ThalesRelease">
				<macros>
					<stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/>
				</macros>
				<externalSettings/>
				<extensions>
				</extensions>
			</storageModule>
				<configuration artifactExtension="out" artifactName="interrupts" buildProperties="" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.1936800841" name="ThalesRelease" parent="com.ti.ccstudio.buildDefinitions.TMS470.Release" postbuildStep="&quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin&quot; &quot;${BuildArtifactFileName}&quot; &quot;${BuildArtifactFileBaseName}.bin&quot; &quot;${CG_TOOL_ROOT}/bin/ofd470&quot; &quot;${CG_TOOL_ROOT}/bin/hex470&quot; &quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin&quot;">
					<folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Release.1936800841.1679992762" name="/" resourcePath="">
						<toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain.538673546" name="TI Code Generation Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.1860006182">
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.1804129429" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList">
								<listOptionValue builtIn="false" value="LINKER_COMMAND_FILE="/>
							</option>
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1369069048" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.0" valueType="string"/>
							<targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease.2035634966" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease"/>
							<builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease.1509816580" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease"/>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease.18277550" name="TMS470 Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.1087894439" name="Treat diagnostic &lt;id&gt; as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.581096629" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M4" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.100905877" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.1802716316" name="Application binary interface (tiabi, ti_arm9_abi, eabi) [See 'General' page to edit] (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT.1159403543" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT.FPv4SPD16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.1879830388" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath">
									<listOptionValue builtIn="false" value="&quot;${SW_ROOT}/boards/ek-lm4f232&quot;"/>
									<listOptionValue builtIn="false" value="&quot;${SW_ROOT}&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.1626225849" name="Little endian code [See 'General' page to edit] (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.1531339832" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.1330753915" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.1579286980" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.1151204852" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.1128771156" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.178776446" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1298474499" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.40868832" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.97078901" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/>
							</tool>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.1860006182" name="TMS470 Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.187033534" name="Input and output sections listed into &lt;file&gt; (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value="&quot;interrupts_ccs.map&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.367266393" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="1024" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.1275558927" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.989981718" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value="&quot;interrupts.out&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.1449509946" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs">
									<listOptionValue builtIn="false" value="&quot;${SW_ROOT}/driverlib/ccs-cm4f/Debug/driverlib-cm4f.lib&quot;"/>
									<listOptionValue builtIn="false" value="&quot;${SW_ROOT}/grlib/ccs-cm4f/Debug/grlib-cm4f.lib&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.2138545515" name="Add &lt;dir&gt; to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.XML_LINK_INFO.1587052424" name="Detailed link information data-base into &lt;file&gt; (--xml_link_info, -xml_link_info)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.XML_LINK_INFO" value="&quot;interrupts_linkInfo.xml&quot;" valueType="string"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD_SRCS.726402857" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD2_SRCS.787973178" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD2_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__GEN_CMDS.1860080174" name="Generated Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__GEN_CMDS"/>
							</tool>
						</toolChain>
					</folderInfo>
					<sourceEntries>
						<entry excluding="thales_ccs.cmd|cisco_i2c" flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
					</sourceEntries>
				</configuration>
			</storageModule>
		</cconfiguration>
		<cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778">
			<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778" moduleId="org.eclipse.cdt.core.settings" name="HalogenDebug">
				<macros>
				</macros>
				<externalSettings/>
				<extensions>
				</extensions>
			</storageModule>
				<configuration artifactExtension="out" artifactName="thales" buildProperties="" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778" name="HalogenDebug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep="&quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin&quot; &quot;${BuildArtifactFileName}&quot; &quot;${BuildArtifactFileBaseName}.bin&quot; &quot;${CG_TOOL_ROOT}/bin/armofd&quot; &quot;${CG_TOOL_ROOT}/bin/armhex&quot; &quot;${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin&quot;">
					<folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778." name="/" resourcePath="">
						<toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain.1564151899" name="TI Code Generation Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.1908589624">
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.681165093" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList">
							</option>
							<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1070927552" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.0" valueType="string"/>
							<targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug.80432103" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug"/>
							<builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug.741211326" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug">
								<outputEntries>
									<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="outputPath" name="Debug"/>
									<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="outputPath" name="Release"/>
								</outputEntries>
							</builder>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.393512724" name="TMS470 Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.1137592798" name="Treat diagnostic &lt;id&gt; as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.1886740359" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M4" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.159940309" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.588225838" name="Application binary interface (tiabi, ti_arm9_abi, eabi) [See 'General' page to edit] (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT.1061402565" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.FLOAT_SUPPORT.FPv4SPD16" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.1887762368" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath">
									<listOptionValue builtIn="false" value="&quot;C:\ti\ccsv5\tools\compiler\arm_5.0.1\include&quot;"/>
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.699842100" name="Little endian code [See 'General' page to edit] (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.1843620758" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.1731469463" name="Optimization level (--opt_level, -O)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL._none" valueType="enumerated"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.640830978" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.474906017" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.247075978" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.71232569" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.415250271" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1465824774" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.1354157567" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.792359572" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/>
							</tool>
							<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.1949534196" name="TMS470 Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug">
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.1027836162" name="Input and output sections listed into &lt;file&gt; (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value="&quot;thales_ccs.map&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.1297111946" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="4096" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.1582452682" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="1024" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.310094953" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value="&quot;thales.out&quot;" valueType="string"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.546734895" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.720111492" name="Add &lt;dir&gt; to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList">
								</option>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.generatedLinkerCommandFiles.1377159356" name="[Deprecated] Generated Linker Command files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.generatedLinkerCommandFiles"/>
								<option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.XML_LINK_INFO.798629320" name="Detailed link information data-base into &lt;file&gt; (--xml_link_info, -xml_link_info)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.XML_LINK_INFO" value="&quot;thales_linkInfo.xml&quot;" valueType="string"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD_SRCS.636389943" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD2_SRCS.559175167" name="Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__CMD2_SRCS"/>
								<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__GEN_CMDS.64710295" name="Generated Linker Command Files" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exeLinker.inputType__GEN_CMDS"/>
							</tool>
						</toolChain>
					</folderInfo>
					<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778.kirchhoff-mcu/thales_pin_map.c" name="thales_pin_map.c" rcbsApplicability="disable" resourcePath="kirchhoff-mcu/thales_pin_map.c" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.1841644480">
						<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.1841644480" name="TMS470 Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.393512724">
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.1336410054" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1159838763" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.1274610370" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.670234131" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/>
						</tool>
						<tool customBuildStep="true" id="org.eclipse.cdt.managedbuilder.ui.rcbs.115627029.1472553978" name="Resource Custom Build Step">
							<inputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.inputtype.1639265711.1441449569" name="Resource Custom Build Step Input Type">
							</inputType>
							<outputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.outputtype.2035288667.840098715" name="Resource Custom Build Step Output Type"/>
						</tool>
					</fileInfo>
					<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.668825922.693487778.kirchhoff-mcu/kk_i2c_master.c" name="kk_i2c_master.c" rcbsApplicability="disable" resourcePath="kirchhoff-mcu/kk_i2c_master.c" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.1865672243">
						<tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.1865672243" name="TMS470 Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.393512724">
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.392689735" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1710878248" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.938913145" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/>
							<inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.142613529" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/>
						</tool>
						<tool customBuildStep="true" id="org.eclipse.cdt.managedbuilder.ui.rcbs.1676925901.1989055804" name="Resource Custom Build Step">
							<inputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.inputtype.1768986099.1151785728" name="Resource Custom Build Step Input Type">
							</inputType>
							<outputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.outputtype.249282381.1401393685" name="Resource Custom Build Step Output Type"/>
						</tool>
					</fileInfo>
					<sourceEntries>
						<entry excluding="thales_ccs.cmd|kirchhoff-mcu/thales_pin_map.c|kirchhoff-mcu/kk_i2c_master.c|kirchhoff-mcu/kk_main.c|kirchhoff-common/uart.c|kirchhoff-common/timers.c|kirchhoff-common/srec.c|kirchhoff-common/queue.c|kirchhoff-mcu/kk_j2a.c|kirchhoff-mcu/kk_interrupts.c|kirchhoff-mcu/kk_dmsg.c|kirchhoff-mcu/kk_uart.c" flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
					</sourceEntries>
				</configuration>
			</storageModule>
		</cconfiguration>
	</storageModule>
		<project id="interrupts.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.981315729" name="ARM" projectType="com.ti.ccstudio.buildDefinitions.TMS470.ProjectType"/>
	</storageModule>
	<storageModule moduleId="org.eclipse.cdt.core.language.mapping">
		<project-mappings>
			<content-type-mapping configuration="" content-type="org.eclipse.cdt.core.asmSource" language="com.ti.ccstudio.core.TIASMLanguage"/>
			<content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cHeader" language="com.ti.ccstudio.core.TIGCCLanguage"/>
			<content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cSource" language="com.ti.ccstudio.core.TIGCCLanguage"/>
			<content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxHeader" language="com.ti.ccstudio.core.TIGPPLanguage"/>
			<content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxSource" language="com.ti.ccstudio.core.TIGPPLanguage"/>
		</project-mappings>
	</storageModule>
	<storageModule moduleId="refreshScope" versionNumber="1">
		<resource resourceType="PROJECT" workspacePath="/Thales"/>
	</storageModule>
	<storageModule moduleId="scannerConfiguration"/>
	<storageModule moduleId="org.eclipse.cdt.internal.ui.text.commentOwnerProjectMappings"/>
	<storageModule moduleId="org.eclipse.cdt.core.LanguageSettingsProviders"/>
</cproject>
    The most common causes of the error you see is is missing device support or compiler version in the CCS version that is importing the project. CCS 5.3 is very old and does not give very descriptive error messages so I can only guess. Can you also provide the .project and .ccsproject files?
    ki
  • <?xml version="1.0" encoding="UTF-8" ?>
    <?ccsproject version="1.0"?>
    <projectOptions>
    	<deviceVariant value="Cortex M.LM4F232H5QD"/>
    	<deviceEndianness value="little"/>
    	<codegenToolVersion value="4.9.0"/>
    	<isElfFormat value="true"/>
    	<rts value="libc.a"/>
    	<deviceFamily value="TMS470"/>
    	<connection value="common/targetdb/connections/TIXDS2XXUSB_Connection.xml"/>
    	<isTargetManual value="true"/>
    	<origin value="C:/Users/gurudpra.CISCO/Desktop/MCU/Code/Code Changes/18_May_2018/18_May_2018/Thales"/>
    </projectOptions>
    <projectOptions>
    </projectOptions>
  • <?xml version="1.0" encoding="UTF-8"?>
    <projectDescription>
    	<name>Thales</name>
    	<comment></comment>
    	<projects>
    	</projects>
    	<buildSpec>
    		<buildCommand>
    			<name>org.eclipse.cdt.managedbuilder.core.genmakebuilder</name>
    			<arguments>
    				<dictionary>
    					<key>?children?</key>
    					<value>?name?=outputEntries\|?children?=?name?=entry\\\\\\\|\\\|?name?=entry\\\\\\\|\\\|\||</value>
    				</dictionary>
    				<dictionary>
    					<key>?name?</key>
    					<value></value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.append_environment</key>
    					<value>true</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.autoBuildTarget</key>
    					<value>all</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.buildArguments</key>
    					<value>-k</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.buildCommand</key>
    					<value>${CCS_UTILS_DIR}/bin/gmake</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.buildLocation</key>
    					<value>${BuildDirectory}</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.cleanBuildTarget</key>
    					<value>clean</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.contents</key>
    					<value>org.eclipse.cdt.make.core.activeConfigSettings</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.enableAutoBuild</key>
    					<value>true</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.enableCleanBuild</key>
    					<value>true</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.enableFullBuild</key>
    					<value>true</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.fullBuildTarget</key>
    					<value>all</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.stopOnError</key>
    					<value>false</value>
    				</dictionary>
    				<dictionary>
    					<key>org.eclipse.cdt.make.core.useDefaultBuildCmd</key>
    					<value>true</value>
    				</dictionary>
    			</arguments>
    		</buildCommand>
    		<buildCommand>
    			<name>org.eclipse.cdt.managedbuilder.core.ScannerConfigBuilder</name>
    			<triggers>full,incremental,</triggers>
    			<arguments>
    			</arguments>
    		</buildCommand>
    	</buildSpec>
    	<natures>
    		<nature>org.eclipse.cdt.core.cnature</nature>
    		<nature>org.eclipse.cdt.core.ccnature</nature>
    		<nature>org.eclipse.cdt.managedbuilder.core.managedBuildNature</nature>
    		<nature>com.ti.ccstudio.core.ccsNature</nature>
    		<nature>org.eclipse.cdt.managedbuilder.core.ScannerConfigNature</nature>
    	</natures>
    	<variableList>
    		<variable>
    			<name>ORIGINAL_PROJECT_ROOT</name>
    			<value>file:/C:/StellarisWare/boards/ek-lm4f232/interrupts/ccs</value>
    		</variable>
    		<variable>
    			<name>SW_ROOT</name>
    			<value>$%7BPARENT-4-ORIGINAL_PROJECT_ROOT%7D</value>
    		</variable>
    	</variableList>
    </projectDescription>
  • Both files are for .ccsproject. Please also attach .project
    ki
  • i see it now
  • I can reproduce the issue with CCSv5.x. It imports fine with CCSv6.2. I would recommend updating to that version since we have made various improvements/fixes to the import wizard.
    ki
