Linker Error
I have got the Linker error in the Build Window like this:
[Linking...] "C:\Program Files\Texas Instruments\C6000 Code Generation Tools 6.1.11\bin\cl6x" -@"DM643x.lkf"
<Linking>
"C:\\SVS_Projects\\MKS\\10_Application\\code\\own\\svc\\os\\D1175_Applicationcfg.cmd", line 600: error:
   run placement fails for object ".far", size 0xac94fd (page 0).  Available
   ranges:
   DDR2_VIDEO   size: 0x1d00000    unused: 0xa61400     max hole: 0xa61400
error: errors encountered during linking;
   "C:/SVS_Projects/MKS/10_Application/build/DM643x/d1175_dsp.out" not built
>> Compilation failure
I'm using the DM6437, custom made board with 32 MB of DDR2 memory.
The Linker error points me to the next line in the .cmd code:
.DDR2$heap: {
            . += 0x100000;
        } RUN_START(DDR2$B), RUN_START(_DDR2_base), RUN_SIZE(DDR2$L), RUN_SIZE(_DDR2_length) > DDR2
        .far:     {} > DDR2_VIDEO
but I have defined DDR2_VIDEO as :
/* MODULE MEM */
-stack 0x800
MEMORY {
   DDR2        : origin = 0x80004000,  len = 0x2fc000
   L1D_RAM     : origin = 0x10f04000,  len = 0xc000
   L2_RAM      : origin = 0x10800000,  len = 0x10000
   DDR2_MSGQ32 : origin = 0x80000000,  len = 0x4000
   DDR2_VIDEO  : origin = 0x80300000,  len = 0x1d00000
   L1D_CACHE   : origin = 0x10f10000,  len = 0x8000
   L2_CACHE    : origin = 0x10810000,  len = 0x10000
   L1P_CACHE   : origin = 0x10e08000,  len = 0x8000
Any help is appreciated.
Marko
  • Well, your .far section, with a size of 0xac94fd, is too big to fit in the DDR2_VIDEO memory range, which has only 0xa61400 left.  However, DDR2_VIDEO also has a hole that is 0xa61400.  That doesn't look right.  How can it have a hole that big?  Are you experiencing the linker bug described here http://e2e.ti.com/support/development_tools/compiler/f/343/t/70465.aspx ?
    Thanks and regards,
    -George
  • Hi George,
    Thanks for the replay.
    Actually, I'm getting these holes, but they are like couple of bytes.
    You can see .map file below.
    Marko
                   TMS320C6x Linker PC v6.1.11
    >> Linked Tue Nov 02 09:25:09 2010
    OUTPUT FILE NAME:   <C:/SVS_Projects/MKS/10_Application/build/DM643x/d1175_dsp.out>
    ENTRY POINT SYMBOL: "_c_int00"  address: 8027d560
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
      L2_RAM                10800000   00010000  0000e988  00001678  RWIX
      L2_CACHE              10810000   00010000  00000000  00010000  RWIX
      L1P_CACHE             10e08000   00008000  00000000  00008000  RWIX
      L1D_RAM               10f04000   0000c000  0000c000  00000000  RWIX
      L1D_CACHE             10f10000   00008000  00000000  00008000  RWIX
      DDR2_MSGQ32           80000000   00004000  00000000  00004000  RWIX
      DDR2                  80004000   002fc000  0027d051  0007efaf  RWIX
      DDR2_VIDEO            80300000   01d00000  0129ec00  00a61400  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    .vers      0    00000000    00000048     COPY SECTION
                      00000000    00000048     d1175_applicationcfg.obj (.vers)
    .far       0    00000000    00ac9524     FAILED TO ALLOCATE
    .l2_ram_data
    *          0    10800000    0000c280     UNINITIALIZED
                      10800000    0000c000     edma3framework.obj (.l2_ram_data)
                      1080c000    00000160     ovl.obj (.l2_ram_data)
                      1080c160    00000020     --HOLE--
                      1080c180    00000100     edma3utils.obj (.l2_ram_data)
    .sem       0    1080c280    000007bc     UNINITIALIZED
                      1080c280    000007bc     d1175_applicationcfg.obj (.sem)
    .switch    0    1080ca3c    00000550
                      1080ca3c    000000e4     mcasp_drv_lib.lib : llc_mcasp.obj (.switch)
                      1080cb20    000000b8     edma3_drv_bios.lib : edma3.obj (.switch)
                      1080cbd8    00000090     app_app_messagereceiver.obj (.switch)
                      1080cc68    00000090     edma3_rm_bios.lib : edma3resmgr.obj (.switch)
                      1080ccf8    00000050     mcasp_drv_lib.lib : ddc_mcasp.obj (.switch)
                      1080cd48    00000040     fpgacom_highlevel.obj (.switch)
                      1080cd88    00000038     app_algo_DDE.obj (.switch)
                      1080cdc0    00000038     draw_handler.obj (.switch)
                      1080cdf8    00000038     ipc_rx.obj (.switch)
                      1080ce30    00000028     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_cs.obj (.switch)
                      1080ce58    00000020     DiagnosticHandler.obj (.switch)
                      1080ce78    00000020     app_app_messagehandler.obj (.switch)
                      1080ce98    00000020     eol_calibrationmain.obj (.switch)
                      1080ceb8    00000020     vfw_vio.obj (.switch)
                      1080ced8    00000018     uart_driver.obj (.switch)
                      1080cef0    00000014     app_algo_CCF.obj (.switch)
                      1080cf04    00000014     app_algo_EC.obj (.switch)
                      1080cf18    00000014     app_algo_GT.obj (.switch)
                      1080cf2c    00000010     app_app_statehandler.obj (.switch)
                      1080cf3c    00000010     calc_euler.obj (.switch)
                      1080cf4c    00000010     ccdc_md.obj (.switch)
                      1080cf5c    00000010     draw.obj (.switch)
                      1080cf6c    00000010     mcasp_drv_lib.lib : dda_mcasp_bios.obj (.switch)
                      1080cf7c    00000010     vfw_vio_vpss.obj (.switch)
    .prd       0    1080cf8c    00000020     UNINITIALIZED
                      1080cf8c    00000020     d1175_applicationcfg.obj (.prd)
    .idl       0    1080cfac    00000014     UNINITIALIZED
                      1080cfac    00000014     d1175_applicationcfg.obj (.idl)
    .rtdx_data
    *          0    1080cfc0    000004f4     UNINITIALIZED
                      1080cfc0    00000080     --HOLE--
                      1080d040    00000410     d1175_applicationcfg.obj (.rtdx_data)
                      1080d450    00000044     rtdx64xplus.lib : rtdx_mon.o64P (.rtdx_data)
                      1080d494    00000020                     : buffer1.o64P (.rtdx_data)
    .hst       0    1080d4b4    0000003c     UNINITIALIZED
                      1080d4b4    0000003c     d1175_applicationcfg.obj (.hst)
    .hst1      0    1080d4f0    00000010     UNINITIALIZED
                      1080d4f0    00000010     d1175_applicationcfg.obj (.hst1)
    .LOG_MIC$buf
    *          0    1080d500    00000100     UNINITIALIZED
                      1080d500    00000100     d1175_applicationcfg.obj (.LOG_MIC$buf)
    .LOG_CamCtrl$buf
    *          0    1080d600    00000200     UNINITIALIZED
                      1080d600    00000200     d1175_applicationcfg.obj (.LOG_CamCtrl$buf)
    .hwi_vec   0    1080d800    00000200
                      1080d800    00000200     d1175_applicationcfg.obj (.hwi_vec)
    .trace     0    1080da00    00000200
                      1080da00    00000200     --HOLE-- [fill = 00000000]
    .sts       0    1080dc00    00000190
                      1080dc00    00000190     d1175_applicationcfg.obj (.sts)
    .swi       0    1080dd90    00000058     UNINITIALIZED
                      1080dd90    00000058     d1175_applicationcfg.obj (.swi)
    .idlcal    0    1080dde8    00000014     UNINITIALIZED
                      1080dde8    00000014     d1175_applicationcfg.obj (.idlcal)
    .LOG_UART$buf
    *          0    1080de00    00000100     UNINITIALIZED
                      1080de00    00000100     d1175_applicationcfg.obj (.LOG_UART$buf)
    .hst0      0    1080df00    00000100     UNINITIALIZED
                      1080df00    00000100     d1175_applicationcfg.obj (.hst0)
    .pip       0    1080e000    000000c8     UNINITIALIZED
                      1080e000    000000c8     d1175_applicationcfg.obj (.pip)
    .log       0    1080e0c8    00000090
                      1080e0c8    00000090     d1175_applicationcfg.obj (.log)
    .clk       0    1080e158    00000008     UNINITIALIZED
                      1080e158    00000008     d1175_applicationcfg.obj (.clk)
    .dio       0    1080e160    00000008     UNINITIALIZED
                      1080e160    00000008     d1175_applicationcfg.obj (.dio)
    .l1p_ram   0    1080e180    00000820
                      1080e180    00000380     edma3framework.obj (.l1p_ram)
                      1080e500    00000300     ovl.obj (.l1p_ram)
                      1080e800    00000060     edma3helper.obj (.l1p_ram)
                      1080e860    00000020     rts64plus.lib : push.obj ($Tramp$L$PI$$__pop_rts)
                      1080e880    00000020     bios.a64P : sem_post_asm.o64P ($Tramp$L$PI$$_SEM_postBinary)
                      1080e8a0    00000020     edma3_drv_bios.lib : edma3.obj ($Tramp$L$PI$$_EDMA3_DRV_getPaRAMPhyAddr)
                      1080e8c0    00000020     rts64plus.lib : divu.obj ($Tramp$L$PI$$__divu)
                      1080e8e0    00000020                   : memset.obj ($Tramp$L$PI$$_memset)
                      1080e900    00000020                   : push.obj ($Tramp$L$PI$$__push_rts)
                      1080e920    00000020     edma3_drv_bios.lib : edma3.obj ($Tramp$L$PI$$_EDMA3_DRV_enableTransfer)
                      1080e940    00000020     biosDM420.a64P : bcache_wait.o64P ($Tramp$L$PI$$_BCACHE_wait)
                      1080e960    00000020     bios.a64P : sem_pend_counting.o64P ($Tramp$L$PI$$_SEM_pend)
                      1080e980    00000020     biosDM420.a64P : bcache_block.o64P ($Tramp$L$PI$$_BCACHE_wbInv)
    .l2_ram    0    1080ea00    00000004
                      1080ea00    00000004     vfw_ovly_pool.obj (.l2_ram)
    .l1d_ram   0    10f04000    0000c000     UNINITIALIZED
                      10f04000    0000c000     edma3framework.obj (.l1d_ram)
    .data      0    80004000    00000000     UNINITIALIZED
    .DDR2$heap
    *          0    80004000    00100000     UNINITIALIZED
                      80004000    00100000     --HOLE--
    .const     0    80104000    00065b59
                      80104000    0001b360     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarZooReaShape_au8)
                      8011f360    0001890c     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarZooFroShape_au8)
                      80137c6c    00000004     bios.a64P : gio_crea.o64P (.const)
                      80137c70    00008dc0     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarTopShape_au8)
                      80140a30    00004c80     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarFullGlow_au8)
                      801456b0    000032c8     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarFullShape_au8)
                      80148978    00003100     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooFro1_au8)
                      8014ba78    00002a30     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooRea0_au8)
                      8014e4a8    000025fc     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooFro0_au8)
                      80150aa4    00000004     bios.a64P : mem_allo.o64P (.const)
                      80150aa8    00001edc     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooFro2_au8)
                      80152984    00000004     bios.a64P : mem_free.o64P (.const)
                      80152988    00001c94     app_algo_DDE.obj (.const:_aAlgoDDE_v_DoorBoot_au8)
                      8015461c    00000004     bios.a64P : mem_unde.o64P (.const)
                      80154620    00001b00     app_algo_DDE.obj (.const:_aAlgoDDE_v_DoorFront_au8)
                      80156120    00001a40     app_algo_DDE.obj (.const:_aAlgoDDE_v_DoorRear_au8)
                      80157b60    0000193c     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooRea2_au8)
                      8015949c    00000004     sioboth.a64P : sio_crea.o64P (.const)
                      801594a0    00001900     app_algo_DDE.obj (.const:_aAlgoDDE_v_GndZooRea1_au8)
                      8015ada0    00001720     app_algo_DDE.obj (.const:_aAlgoDDE_v_GroundFront_au8)
                      8015c4c0    00001524     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcTopFro0_au8)
                      8015d9e4    00000002     rts64plus.lib : fputs.obj (.const:.string)
                      8015d9e6    00000002     --HOLE-- [fill = 0]
                      8015d9e8    00001524     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcTopFro1_au8)
                      8015ef0c    00000001     bios.a64P : sem_crea.o64P (.const)
                      8015ef0d    00000003     --HOLE-- [fill = 0]
                      8015ef10    00001524     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcTopFro2_au8)
                      80160434    00000001     bios.a64P : tsk.o64P (.const)
                      80160435    00000003     --HOLE-- [fill = 0]
                      80160438    00000f00     app_algo_DDE.obj (.const:_aAlgoDDE_v_Pic025_au8)
                      80161338    00000e58     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarZooReaColor_au8)
                      80162190    00000cf3     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarZooFroColor_au8)
                      80162e83    00000005     --HOLE-- [fill = 0]
                      80162e88    00000b90     app_algo_DDE.obj (.const:_aAlgoDDE_v_GroundRear_au8)
                      80163a18    000007b8     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullFro0_au8)
                      801641d0    000007b8     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullFro1_au8)
                      80164988    000007b8     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullFro2_au8)
                      80165140    00000680     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullRea0_au8)
                      801657c0    00000680     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullRea1_au8)
                      80165e40    00000680     app_algo_DDE.obj (.const:_aAlgoDDE_v_PdcFullRea2_au8)
                      801664c0    00000618     app_algo_DDE.obj (.const:_aAlgoDDE_v_Pic100_au8)
                      80166ad8    00000510     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarTopColor_au8)
                      80166fe8    000004ac     app_algo_DDE.obj (.const:_aAlgoDDE_v_Pic400_au8)
                      80167494    00000220     vfw_vio.obj (.const:.string)
                      801676b4    00000220     fpgacom_highlevel.obj (.const)
                      801678d4    00000004     --HOLE-- [fill = 0]
                      801678d8    000001f8     app_algo_DDE.obj (.const:_aAlgoDDE_v_TrackData_as)
                      80167ad0    000001f4     app_algo_DDE.obj (.const:_aAlgoDDE_v_CarFullColor_au8)
                      80167cc4    00000004     --HOLE-- [fill = 0]
                      80167cc8    000001b0     app_algo_DDE.obj (.const:_aAlgoDDE_v_VirtCam_a3f32)
                      80167e78    000001a8     zlib.lib : zlib_inflate.obj (.const:.string)
                      80168020    00000193     bios.a64P : exc.o64P (.const)
                      801681b3    00000001     --HOLE-- [fill = 0]
                      801681b4    0000015c     vfw_converter.obj (.const:.string)
                      80168310    00000148     vfw_vio_vpss_internal.obj (.const:.string)
                      80168458    00000134     msgq_if.obj (.const:.string)
                      8016858c    00000124     vfw_algo.obj (.const:.string)
                      801686b0    00000101     rts64plus.lib : ctype.obj (.const:__ctypes_)
                      801687b1    00000003     --HOLE-- [fill = 0]
                      801687b4    00000100     mcasphandler.obj (.const:.string)
                      801688b4    000000f4     vfw_frontend.obj (.const:.string)
                      801689a8    000000f0     app_algo_DDE.obj (.const:_aAlgoDDE_v_BezierData_a2s)
                      80168a98    000000a8     vfw.obj (.const:.string)
                      80168b40    000000a8     vfw_backend.obj (.const:.string)
                      80168be8    00000098     mcasp_drv_lib.lib : ddc_mcasp.obj (.const)
                      80168c80    00000088     vfw_vio_vpss.obj (.const:.string)
                      80168d08    00000088     ipcll_handler.obj (.const:_as_CallbackTable)
                      80168d90    00000068     app_algo_CCF.obj (.const:.string)
                      80168df8    00000068     app_algo_EC.obj (.const:.string)
                      80168e60    00000068     app_algo_DDE.obj (.const:_aAlgoDDE_v_PictIdxCombi_a2u8)
                      80168ec8    00000064     main.obj (.const:.string)
                      80168f2c    00000004     --HOLE-- [fill = 0]
                      80168f30    00000060     calc_euler.obj (.const:_$P$T0$1)
                      80168f90    00000060     edma3framework.obj (.const)
                      80168ff0    0000005c     vfw_vmsg.obj (.const:.string)
                      8016904c    00000050     zlib.lib : zlib_inffast.obj (.const:.string)
                      8016909c    0000004e     bios.a64P : pool_init.o64P (.const)
                      801690ea    00000006     --HOLE-- [fill = 0]
                      801690f0    00000048     calc_euler.obj (.const:_$P$T1$2)
                      80169138    00000048     vgg_H_from_x_lin.obj (.const:_$P$T2$3)
                      80169180    00000048     vgg_H_from_x_lin.obj (.const:_$P$T3$4)
                      801691c8    00000048     vgg_H_from_x_lin.obj (.const:_$P$T4$5)
                      80169210    00000048     app_algo_DDE.obj (.const:_aAlgoDDE_v_TrackIdxCombi_a2u8)
                      80169258    00000043     bios.a64P : tsk_chec.o64P (.const)
                      8016929b    00000001     --HOLE-- [fill = 0]
                      8016929c    00000040     Dm643x_chip.obj (.const:.string)
                      801692dc    00000040     prj_buf.obj (.const)
                      8016931c    0000003c     mcaspdevice.obj (.const)
                      80169358    00000032     bios.a64P : mem_rede.o64P (.const)
                      8016938a    00000031     d1175_applicationcfg.obj (.const)
                      801693bb    00000001     --HOLE-- [fill = 0]
                      801693bc    00000030     cam.obj (.const:.string)
                      801693ec    00000030     edma3helper.obj (.const:.string)
                      8016941c    00000004     --HOLE-- [fill = 0]
                      80169420    00000030     fpgacom_highlevel.obj (.const:_c_Requests_as$52)
                      80169450    00000030     fpgacom_highlevel.obj (.const:_c_Requests_as$60)
                      80169480    00000030     fpgacom_highlevel.obj (.const:_c_Requests_as$7)
                      801694b0    00000030     draw.obj (.const)
                      801694e0    00000030     edma3utils.obj (.const)
                      80169510    00000030     msgq32.l64p : msgq32_init.o64p (.const)
                      80169540    0000002c     vfw_app_wrapper_api.obj (.const:.string)
                      8016956c    0000002b     palos_bios_lib.lib : pal_oscache.obj (.const)
                      80169597    00000001     --HOLE-- [fill = 0]
                      80169598    00000028     app_app.obj (.const:.string)
                      801695c0    00000028     svd.obj (.const:.string)
                      801695e8    00000028     vfw_app_wrapper_que.obj (.const:.string)
                      80169610    00000028     fpgacom_highlevel.obj (.const:_c_Requests_as$66)
                      80169638    00000028     mcasp_drv_lib.lib : dda_mcasp_bios.obj (.const)
                      80169660    00000026     msgq32.l64p : msgq32_stup.o64p (.const)
                      80169686    00000002     --HOLE-- [fill = 0]
                      80169688    00000024     vfw_app_wrapper.obj (.const)
                      801696ac    00000023     rts64plus.lib : _printfi.obj (.const:.string)
                      801696cf    00000022     bios.a64P : tsk_stup.o64P (.const)
                      801696f1    00000022               : utl_doer.o64P (.const)
                      80169713    00000001     --HOLE-- [fill = 0]
                      80169714    00000020     app_app_messagereceiver.obj (.const:.string)
                      80169734    00000020     app_app_messagesender.obj (.const:.string)
                      80169754    00000004     --HOLE-- [fill = 0]
                      80169758    00000020     fpgacom_highlevel.obj (.const:_c_Requests_1_as$68)
                      80169778    00000020     fpgacom_highlevel.obj (.const:_c_Requests_2_as$69)
                      80169798    00000020     fpgacom_highlevel.obj (.const:_c_Requests_3_as$70)
                      801697b8    00000020     fpgacom_highlevel.obj (.const:_c_Requests_4_as$71)
                      801697d8    00000020     fpgacom_highlevel.obj (.const:_c_Requests_as$1)
                      801697f8    00000020     fpgacom_highlevel.obj (.const:_c_Requests_as$46)
                      80169818    00000020     fpgacom_highlevel.obj (.const:_c_Requests_as$57)
                      80169838    00000020     bios.a64P : dev_init.o64P (.const)
                      80169858    0000001c     app_algo_CCF.obj (.const)
                      80169874    0000001c     app_algo_EC.obj (.const)
                      80169890    0000001b     app_algo_DDE.obj (.const:_aAlgoDDE_v_CombiIdx_au8)
                      801698ab    00000005     --HOLE-- [fill = 0]
                      801698b0    00000018     vgg_H_from_x_lin.obj (.const:_$P$T0$1)
                      801698c8    00000018     vgg_H_from_x_lin.obj (.const:_$P$T1$2)
                      801698e0    00000018     app_algo_DDE.obj (.const:_aAlgoDDE_v_ProjSetIdxCombi_a2u8)
                      801698f8    00000018     fpgacom_highlevel.obj (.const:_c_Requests_as$64)
                      80169910    00000018     msgq32.l64p : msgq32.o64p (.const)
                      80169928    00000014     vfw_ovly_pool.obj (.const:.string)
                      8016993c    00000004     --HOLE-- [fill = 0]
                      80169940    00000012     app_algo_DDE.obj (.const:_aAlgoDDE_v_ProjSetIdx_au8)
                      80169952    00000006     --HOLE-- [fill = 0]
                      80169958    00000011     bios.a64P : sys_prin.o64P (.const:_digtohex)
                      80169969    00000007               : sys_prin.o64P (.const)
                      80169970    00000010     app_algo_DDE.obj (.const:_$P$T0$1)
                      80169980    00000010     app_algo_DDE.obj (.const:_$P$T1$2)
                      80169990    00000010     app_algo_DDE.obj (.const:_$P$T2$3)
                      801699a0    00000010     app_algo_DDE.obj (.const:_$P$T3$4)
                      801699b0    00000010     largest_component.obj (.const:_$P$T3$4)
                      801699c0    00000010     app_algo_DDE.obj (.const:_$P$T4$5)
                      801699d0    00000010     largest_component.obj (.const:_$P$T4$5)
                      801699e0    00000010     bios.a64P : staticpool_vt.o64P (.const)
                      801699f0    00000010     edma3helper.obj (.const)
                      80169a00    00000010     ipc_rx.obj (.const)
                      80169a10    00000010     vfw_vio_vpss.obj (.const)
                      80169a20    0000000c     bios.a64P : staticpool_open.o64P (.const)
                      80169a2c    00000008     zlib.lib : zlib_uncompr.obj (.const:.string)
                      80169a34    00000004     --HOLE-- [fill = 0]
                      80169a38    00000008     largest_component.obj (.const:_$P$T0$1)
                      80169a40    00000008     corner_graph.obj (.const:_$P$T1$2)
                      80169a48    00000008     largest_component.obj (.const:_$P$T1$2)
                      80169a50    00000008     fpgacom_highlevel.obj (.const:_c_OffRequests_as$19)
                      80169a58    00000008     fpgacom_highlevel.obj (.const:_c_OffRequests_as$24)
                      80169a60    00000008     fpgacom_highlevel.obj (.const:_c_OnRequests_as$18)
                      80169a68    00000008     fpgacom_highlevel.obj (.const:_c_OnRequests_as$23)
                      80169a70    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$12)
                      80169a78    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$15)
                      80169a80    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$28)
                      80169a88    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$30)
                      80169a90    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$32)
                      80169a98    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$34)
                      80169aa0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$36)
                      80169aa8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$38)
                      80169ab0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$3)
                      80169ab8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$40)
                      80169ac0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$42)
                      80169ac8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$44)
                      80169ad0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$48)
                      80169ad8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$50)
                      80169ae0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$54)
                      80169ae8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$5)
                      80169af0    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$62)
                      80169af8    00000008     fpgacom_highlevel.obj (.const:_c_Requests_as$9)
                      80169b00    00000008     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_init.obj (.const)
                      80169b08    00000006     fpgacom_cmdlevel.obj (.const)
                      80169b0e    00000002     --HOLE-- [fill = 0]
                      80169b10    00000006     fpgacom_msglevel.obj (.const)
                      80169b16    00000002     --HOLE-- [fill = 0]
                      80169b18    00000004     corner_graph.obj (.const:_$P$T0$1)
                      80169b1c    00000004     --HOLE-- [fill = 0]
                      80169b20    00000004     largest_component.obj (.const:_$P$T2$3)
                      80169b24    00000004     --HOLE-- [fill = 0]
                      80169b28    00000004     fpgacom_highlevel.obj (.const:_c_IValues_au8$59)
                      80169b2c    00000004     --HOLE-- [fill = 0]
                      80169b30    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$11)
                      80169b31    00000007     --HOLE-- [fill = 0]
                      80169b38    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$14)
                      80169b39    00000007     --HOLE-- [fill = 0]
                      80169b40    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$17)
                      80169b41    00000007     --HOLE-- [fill = 0]
                      80169b48    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$22)
                      80169b49    00000007     --HOLE-- [fill = 0]
                      80169b50    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$27)
                      80169b51    00000007     --HOLE-- [fill = 0]
                      80169b58    00000001     fpgacom_highlevel.obj (.const:_c_IValues_au8$56)
    .printf    0    80169b59    0000027e     COPY SECTION
                      80169b59    0000027e     d1175_applicationcfg.obj (.printf)
    .args      0    80169b5c    00000004
                      80169b5c    00000004     --HOLE-- [fill = 0]
    .text      0    80169b60    0004fc80
                      80169b60    000081c0     mcasp_drv_lib.lib : ddc_mcasp.obj (.text)
                      80171d20    00005ac0     edma3_rm_bios.lib : edma3resmgr.obj (.text)
                      801777e0    00004060     draw.obj (.text)
                      8017b840    00003f80     edma3_drv_bios.lib : edma3.obj (.text)
                      8017f7c0    00003380     app_algo_DDE.obj (.text)
                      80182b40    00002340     app_app_messagehandler.obj (.text)
                      80184e80    00002340     svd.obj (.text)
                      801871c0    00002320     calc_euler.obj (.text)
                      801894e0    00002200     mcasp_drv_lib.lib : llc_mcasp.obj (.text)
                      8018b6e0    00001fc0     local_extrema.obj (.text)
                      8018d6a0    00001c00     ccdc_md.obj (.text)
                      8018f2a0    00001980     app_algo_CCF.obj (.text)
                      80190c20    00001740     lucchese.obj (.text)
                      80192360    00001600     largest_component.obj (.text)
                      80193960    00001420     fpgacom_highlevel.obj (.text)
                      80194d80    000012a0     app_algo_EC.obj (.text)
                      80196020    00001140     mcasphandler.obj (.text)
                      80197160    00000fc0     vgg_H_from_x_lin.obj (.text)
                      80198120    00000f20     app_app_statehandler.obj (.text)
                      80199040    00000ec0     corner_graph.obj (.text)
                      80199f00    00000d80     corner_detection.obj (.text)
                      8019ac80    00000d00     uart_driver.obj (.text)
                      8019b980    00000ce0     edma3framework.obj (.text)
                      8019c660    00000c80     fpgacom_cmdlevel.obj (.text)
                      8019d2e0    00000c00     vpbe_md.obj (.text)
                      8019dee0    00000b60     Dm643x_chip.obj (.text)
                      8019ea40    00000a60     mcasp_drv_lib.lib : dda_mcasp_bios.obj (.text)
                      8019f4a0    00000a60     vfw_app_wrapper_api.obj (.text)
                      8019ff00    00000a60     vfw_vio.obj (.text)
                      801a0960    00000a40     eol_calibrationmain.obj (.text)
                      801a13a0    00000a20     edma3helper.obj (.text)
                      801a1dc0    00000980     rts64plus.lib : pow.obj (.text:_pow)
                      801a2740    00000960     vfw_vio_vpss_internal.obj (.text)
                      801a30a0    00000920     app_algo_GT.obj (.text)
                      801a39c0    00000900     DiagnosticHandler.obj (.text)
                      801a42c0    00000900     app_state.obj (.text)
                      801a4bc0    000008c0     vfw.obj (.text)
                      801a5480    00000880     ipc_rxmultiframe.obj (.text)
                      801a5d00    000007c0     rts64plus.lib : divd.obj (.text:__divd)
                      801a64c0    000007c0     vfw_frontend.obj (.text)
                      801a6c80    000007a0     ipc_protocol.obj (.text)
                      801a7420    00000760     vfw_converter.obj (.text)
                      801a7b80    00000740     draw_handler.obj (.text)
                      801a82c0    00000700     app_app.obj (.text)
                      801a89c0    00000680     app_app_algocontrol.obj (.text)
                      801a9040    00000620     palos_bios_lib.lib : pal_osList.obj (.text)
                      801a9660    00000600     fpgacom_msglevel.obj (.text)
                      801a9c60    00000580     cam.obj (.text)
                      801aa1e0    00000520     app_app_messagereceiver.obj (.text)
                      801aa700    00000500     rts64plus.lib : divf.obj (.text:__divf)
                      801aac00    00000500     msgq_if.obj (.text)
                      801ab100    000004a0     vfw_ovly_pool.obj (.text)
                      801ab5a0    00000480     ipc_tx.obj (.text)
                      801aba20    00000460     rts64plus.lib : _printfi.obj (.text:__setfield)
                      801abe80    00000440                   : _printfi.obj (.text:__getarg_diouxp)
                      801ac2c0    00000440     vfw_backend.obj (.text)
                      801ac700    00000420     ipc_rx.obj (.text)
                      801acb20    000003e0     rts64plus.lib : tan.obj (.text:_tan)
                      801acf00    000003e0     fpgacom_lowlevel.obj (.text)
                      801ad2e0    000003c0     rts64plus.lib : cos.obj (.text:_cos)
                      801ad6a0    000003c0     app_app_eolcontrol.obj (.text)
                      801ada60    000003c0     ipcll_handler.obj (.text)
                      801ade20    000003c0     vfw_app_wrapper_que.obj (.text)
                      801ae1e0    000003c0     vgg_conditioner_from_pts.obj (.text)
                      801ae5a0    000003a0     rts64plus.lib : _printfi.obj (.text:__printfi)
                      801ae940    000003a0     edma3utils.obj (.text)
                      801aece0    00000360     rts64plus.lib : sin.obj (.text:_sin)
                      801af040    00000340     fpgacom_ringbuffer.obj (.text)
                      801af380    00000300     rts64plus.lib : addf.obj (.text:__addf)
                      801af680    00000300                   : _printfi.obj (.text:_ecvt)
                      801af980    00000300                   : _printfi.obj (.text:_fcvt)
                      801afc80    00000300                   : fputs.obj (.text:_fputs)
                      801aff80    00000300     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_cs.obj (.text)
                      801b0280    00000300                               : bios_edma3_drv_sample_init.obj (.text)
                      801b0580    00000300     mcaspdevice.obj (.text)
                      801b0880    000002e0     rts64plus.lib : _printfi.obj (.text:__pproc_fge)
                      801b0b60    000002e0                   : _printfi.obj (.text:__pproc_fwp)
                      801b0e40    000002e0                   : cosf.obj (.text:_cosf)
                      801b1120    000002c0                   : sinf.obj (.text:_sinf)
                      801b13e0    000002a0                   : _printfi.obj (.text:__pconv_e)
                      801b1680    000002a0                   : atan.obj (.text:_atan)
                      801b1920    000002a0     fpgacom.obj (.text)
                      801b1bc0    000002a0     vfw_algo.obj (.text)
                      801b1e60    00000280     drivers.a64P : dio_tsk.o64P (.text)
                      801b20e0    00000260     rts64plus.lib : imath64.obj (.text:__divull)
                      801b2340    00000260                   : mpyd.obj (.text:__mpyd)
                      801b25a0    00000260                   : asin.obj (.text:_asin)
                      801b2800    00000240                   : sqrt.obj (.text:_sqrt)
                      801b2a40    00000220                   : addd.obj (.text:__addd)
                      801b2c60    00000220                   : _printfi.obj (.text:__pproc_diouxp)
                      801b2e80    00000220                   : _printfi.obj (.text:__pproc_str)
                      801b30a0    00000220     drivers.a64P : dio_tskDynamic.o64P (.text)
                      801b32c0    00000220     main.obj (.text)
                      801b34e0    00000220     vfw_vio_vpss.obj (.text)
                      801b3700    00000220     vgg_condition_2d.obj (.text)
                      801b3920    00000200     rts64plus.lib : frcaddd.obj (.text:__frcaddd)
                      801b3b20    00000200                   : mpyf.obj (.text:__mpyf)
                      801b3d20    00000200                   : asinf.obj (.text:_asinf)
                      801b3f20    000001e0                   : frcmpyd_div.obj (.text:__frcmpyd_div)
                      801b4100    000001e0                   : sqrtf.obj (.text:_sqrtf)
                      801b42e0    000001e0     crc.obj (.text)
                      801b44c0    000001c0     rts64plus.lib : _printfi.obj (.text:__mcpy)
                      801b4680    000001c0                   : ldexp.obj (.text:_ldexp)
                      801b4840    000001c0     ovl.obj (.text)
                      801b4a00    000001a0     rts64plus.lib : trgdrv.obj (.text:_HOSTrename)
                      801b4ba0    000001a0                   : imath40.obj (.text:__divul)
                      801b4d40    000001a0                   : _printfi.obj (.text:__pconv_g)
                      801b4ee0    000001a0                   : frexp.obj (.text:_frexp)
                      801b5080    000001a0                   : setvbuf.obj (.text:_setvbuf)
                      801b5220    000001a0     palos_bios_lib.lib : pal_osmem.obj (.text)
                      801b53c0    000001a0     prj_buf.obj (.text)
                      801b5560    00000180     rts64plus.lib : ldexpf.obj (.text:_ldexpf)
                      801b56e0    00000160                   : atanf.obj (.text:_atanf)
                      801b5840    00000160                   : frexpf.obj (.text:_frexpf)
                      801b59a0    00000160     palos_bios_lib.lib : pal_oscache.obj (.text)
                      801b5b00    00000160     vfw_algo_pool.obj (.text)
                      801b5c60    00000140     rts64plus.lib : fputc.obj (.text:_fputc)
                      801b5da0    00000140                   : lowlev.obj (.text:_getdevice)
                      801b5ee0    00000140     fpgacom_txbuffer.obj (.text)
                      801b6020    00000120     rts64plus.lib : _printfi.obj (.text:__pproc_fflags)
                      801b6140    00000120                   : fclose.obj (.text:_fclose)
                      801b6260    00000120     load.obj (.text)
                      801b6380    00000120     vfw_app_wrapper.obj (.text)
                      801b64a0    00000100     DM643x_psc.obj (.text)
                      801b65a0    00000100     rts64plus.lib : trgdrv.obj (.text:_HOSTlseek)
                      801b66a0    00000100                   : frcmpyd.obj (.text:__frcmpyd)
                      801b67a0    00000100                   : _printfi.obj (.text:__ltostr)
                      801b68a0    00000100                   : round.obj (.text:__nround)
                      801b69a0    00000100                   : _io_perm.obj (.text:__wrt_ok)
                      801b6aa0    00000100                   : sinit.obj (.text:_call_dtors)
                      801b6ba0    000000e0                   : trgdrv.obj (.text:_HOSTopen)
                      801b6c80    000000e0                   : cmpd.obj (.text:__cmpd)
                      801b6d60    000000e0                   : divi.obj (.text:__divi)
                      801b6e40    000000e0                   : roundf.obj (.text:__roundf)
                      801b6f20    000000e0                   : atoi.obj (.text:_atoi)
                      801b7000    000000e0                   : lowlev.obj (.text:_close)
                      801b70e0    000000e0                   : memset.obj (.text:_memset)
                      801b71c0    000000c0                   : trgdrv.obj (.text:_HOSTread)
                      801b7280    000000c0                   : trgdrv.obj (.text:_HOSTunlink)
                      801b7340    000000c0                   : trgdrv.obj (.text:_HOSTwrite)
                      801b7400    000000c0     bios.a64P : staticpool_open.o64P (.text:_STATICPOOL_open)
                      801b74c0    000000c0     rts64plus.lib : fopen.obj (.text:__cleanup)
                      801b7580    000000c0                   : _printfi.obj (.text:__div)
                      801b7640    000000c0                   : divu.obj (.text:__divu)
                      801b7700    000000c0                   : fflush.obj (.text:__doflush)
                      801b77c0    000000c0                   : remi.obj (.text:__remi)
                      801b7880    000000c0                   : atexit.obj (.text:_atexit)
                      801b7940    000000c0                   : fseek.obj (.text:_fseek)
                      801b7a00    000000c0                   : lowlev.obj (.text:_lseek)
                      801b7ac0    000000c0                   : ltoa.obj (.text:_ltoa)
                      801b7b80    000000c0                   : modf.obj (.text:_modf)
                      801b7c40    000000c0                   : lowlev.obj (.text:_write)
                      801b7d00    000000c0     fpgacom_rxbuffer.obj (.text)
                      801b7dc0    000000c0     ipc.obj (.text)
                      801b7e80    000000a0     rts64plus.lib : trgdrv.obj (.text:_HOSTclose)
                      801b7f20    000000a0                   : cvtdf.obj (.text:__cvtdf)
                      801b7fc0    000000a0                   : imath40.obj (.text:__divli)
                      801b8060    000000a0                   : _printfi.obj (.text:__ecpy)
                      801b8100    000000a0                   : _printfi.obj (.text:__fcpy)
                      801b81a0    000000a0                   : fixdli.obj (.text:__fixdli)
                      801b8240    000000a0                   : frcmpyf_div.obj (.text:__frcmpyf_div)
                      801b82e0    000000a0                   : _printfi.obj (.text:__pconv_f)
                      801b8380    000000a0                   : remu.obj (.text:__remu)
                      801b8420    000000a0                   : lowlev.obj (.text:_finddevice)
                      801b84c0    000000a0                   : memcpy64.obj (.text:_memcpy)
                      801b8560    000000a0     palos_bios_lib.lib : pal_osprotect.obj (.text)
                      801b8600    000000a0                        : pal_ossem.obj (.text)
                      801b86a0    000000a0     que_interface.obj (.text)
                      801b8740    000000a0     vfw_vmsg.obj (.text)
                      801b87e0    00000080     bios.a64P : staticpool_alloc.o64P (.text:_STATICPOOL_alloc)
                      801b8860    00000080     rts64plus.lib : cmpf.obj (.text:__cmpf)
                      801b88e0    00000080                   : fixdi.obj (.text:__fixdi)
                      801b8960    00000080                   : fixdu.obj (.text:__fixdu)
                      801b89e0    00000080                   : fixfi.obj (.text:__fixfi)
                      801b8a60    00000080                   : fixfu.obj (.text:__fixfu)
                      801b8ae0    00000080                   : fltlid.obj (.text:__fltlid)
                      801b8b60    00000080                   : llshift.obj (.text:__llshl)
                      801b8be0    00000080                   : renormd.obj (.text:__renormd)
                      801b8c60    00000080                   : printf.obj (.text:_printf)
                      801b8ce0    00000080                   : trgmsg.obj (.text:_readmsg)
                      801b8d60    00000080                   : lowlev.obj (.text:_unlink)
                      801b8de0    00000080     app_app_messagesender.obj (.text)
                      801b8e60    00000060     DM643x_pmx.obj (.text)
                      801b8ec0    00000060     rts64plus.lib : cvtfd.obj (.text:__cvtfd)
                      801b8f20    00000060                   : fltid.obj (.text:__fltid)
                      801b8f80    00000060                   : fltif.obj (.text:__fltif)
                      801b8fe0    00000060                   : frcmpyf.obj (.text:__frcmpyf)
                      801b9040    00000060                   : llshift.obj (.text:__llshru)
                      801b90a0    00000060                   : imath64.obj (.text:__subcull)
                      801b9100    00000060                   : floor.obj (.text:_floor)
                      801b9160    00000060                   : memccpy.obj (.text:_memccpy)
                      801b91c0    00000060                   : modff.obj (.text:_modff)
                      801b9220    00000060                   : trgmsg.obj (.text:_writemsg)
                      801b9280    00000040                   : sinit.obj (.text:___add_dtor)
                      801b92c0    00000040                   : isinf.obj (.text:___isinf)
                      801b9300    00000040                   : _printfi.obj (.text:___isnan)
                      801b9340    00000040                   : divd.obj (.text:___isnan)
                      801b9380    00000040                   : push.obj (.text:__call_stub)
                      801b93c0    00000040                   : fltud.obj (.text:__fltud)
                      801b9400    00000040                   : fltuf.obj (.text:__fltuf)
                      801b9440    00000040                   : negd.obj (.text:__negd)
                      801b9480    00000040                   : negf.obj (.text:__negf)
                      801b94c0    00000040                   : imath40.obj (.text:__remli)
                      801b9500    00000040                   : strasg.obj (.text:__strasgi_64plus)
                      801b9540    00000040                   : subd.obj (.text:__subd)
                      801b9580    00000040                   : subf.obj (.text:__subf)
                      801b95c0    00000040     drivers.a64P : dio.o64P (.text)
                      801b9600    00000020     bios.a64P : staticpool_free.o64P (.text:_STATICPOOL_free)
                      801b9620    00000020     rts64plus.lib : divf.obj (.text:___isnanf)
                      801b9640    00000020                   : negll.obj (.text:__negll)
                      801b9660    00000020                   : _lock.obj (.text:__nop)
                      801b9680    00000020                   : printf.obj (.text:__outc)
                      801b96a0    00000020                   : printf.obj (.text:__outs)
                      801b96c0    00000020                   : push.obj (.text:__pop_rts)
                      801b96e0    00000020                   : push.obj (.text:__push_rts)
                      801b9700    00000020                   : _lock.obj (.text:__register_lock)
                      801b9720    00000020                   : _lock.obj (.text:__register_unlock)
                      801b9740    00000020                   : trunc.obj (.text:__trunc)
                      801b9760    00000020                   : truncf.obj (.text:__truncf)
                      801b9780    00000020                   : remove.obj (.text:_remove)
                      801b97a0    00000020     palos_bios_lib.lib : pal_osInt.obj (.text)
                      801b97c0    00000020     edma3framework.obj ($Tramp$L$PI$$_edma3fw_processFrame)
    .cinit     0    801b97e0    000313ec
                      801b97e0    000243e1     app_app_messagehandler.obj (.cinit)
                      801ddbc1    00000007     --HOLE-- [fill = 0]
                      801ddbc8    00006d01     mcasphandler.obj (.cinit)
                      801e48c9    00000007     --HOLE-- [fill = 0]
                      801e48d0    00002e74     d1175_applicationcfg.obj (.cinit)
                      801e7744    00000004     --HOLE-- [fill = 0]
                      801e7748    00000588     edma3_rm_bios.lib : edma3_dm643x_cfg.obj (.cinit)
                      801e7cd0    00000571     app_algo_DDE.obj (.cinit)
                      801e8241    00000007     --HOLE-- [fill = 0]
                      801e8248    00000408     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_dm643x_cfg.obj (.cinit)
                      801e8650    0000026c     bios.a64P : biosdata.o64P (.cinit)
                      801e88bc    00000004     --HOLE-- [fill = 0]
                      801e88c0    0000023b     app_state.obj (.cinit)
                      801e8afb    00000005     --HOLE-- [fill = 0]
                      801e8b00    000001a4     bios.a64P : knl.o64P (.cinit)
                      801e8ca4    00000004     --HOLE-- [fill = 0]
                      801e8ca8    00000140     rts64plus.lib : pow.obj (.cinit)
                      801e8de8    00000138     vfw_frontend.obj (.cinit)
                      801e8f20    0000012c     msgq_if.obj (.cinit)
                      801e904c    00000004     --HOLE-- [fill = 0]
                      801e9050    0000011c     uart_driver.obj (.cinit)
                      801e916c    00000004     --HOLE-- [fill = 0]
                      801e9170    00000114     mcaspdevice.obj (.cinit)
                      801e9284    00000004     --HOLE-- [fill = 0]
                      801e9288    0000010b     app_app.obj (.cinit)
                      801e9393    00000005     --HOLE-- [fill = 0]
                      801e9398    00000104     mcasp_drv_lib.lib : dda_mcasp_bios.obj (.cinit)
                      801e949c    00000004     --HOLE-- [fill = 0]
                      801e94a0    000000de     cam.obj (.cinit)
                      801e957e    00000002     --HOLE-- [fill = 0]
                      801e9580    000000c4     vfw_backend.obj (.cinit)
                      801e9644    00000004     --HOLE-- [fill = 0]
                      801e9648    000000b1     app_algo_EC.obj (.cinit)
                      801e96f9    00000007     --HOLE-- [fill = 0]
                      801e9700    000000b0     bios.a64P : swi.o64P (.cinit)
                      801e97b0    0000009c     fpgacom_cmdlevel.obj (.cinit)
                      801e984c    00000004     --HOLE-- [fill = 0]
                      801e9850    00000091     app_algo_CCF.obj (.cinit)
                      801e98e1    00000007     --HOLE-- [fill = 0]
                      801e98e8    00000090     calc_euler.obj (.cinit)
                      801e9978    00000089     app_algo_GT_Supp.obj (.cinit)
                      801e9a01    00000007     --HOLE-- [fill = 0]
                      801e9a08    00000089     fpgacom_lowlevel.obj (.cinit)
                      801e9a91    00000007     --HOLE-- [fill = 0]
                      801e9a98    0000007a     edma3_rm_bios.lib : edma3resmgr.obj (.cinit)
                      801e9b12    00000006     --HOLE-- [fill = 0]
                      801e9b18    00000070     bios.a64P : tsk.o64P (.cinit)
                      801e9b88    00000070     rts64plus.lib : atan.obj (.cinit)
                      801e9bf8    0000006c     local_extrema.obj (.cinit)
                      801e9c64    00000004     --HOLE-- [fill = 0]
                      801e9c68    00000069     draw.obj (.cinit)
                      801e9cd1    00000007     --HOLE-- [fill = 0]
                      801e9cd8    00000068     rtdx64xplus.lib : rtdx_mon.o64P (.cinit)
                      801e9d40    00000068     rts64plus.lib : asin.obj (.cinit)
                      801e9da8    00000064     app_algo_GT.obj (.cinit)
                      801e9e0c    00000004     --HOLE-- [fill = 0]
                      801e9e10    0000005c     edma3framework.obj (.cinit)
                      801e9e6c    00000004     --HOLE-- [fill = 0]
                      801e9e70    0000005c     fpgacom_msglevel.obj (.cinit)
                      801e9ecc    00000004     --HOLE-- [fill = 0]
                      801e9ed0    0000005c     ipc_tx.obj (.cinit)
                      801e9f2c    00000004     --HOLE-- [fill = 0]
                      801e9f30    0000005c     lnkrtdx.a64P : rtdx.o64P (.cinit)
                      801e9f8c    00000004     --HOLE-- [fill = 0]
                      801e9f90    0000005c     load.obj (.cinit)
                      801e9fec    00000004     --HOLE-- [fill = 0]
                      801e9ff0    0000005c     rts64plus.lib : defs.obj (.cinit)
                      801ea04c    00000004     --HOLE-- [fill = 0]
                      801ea050    0000005c                   : lowlev.obj (.cinit)
                      801ea0ac    00000004     --HOLE-- [fill = 0]
                      801ea0b0    00000058     evmdm6437_gpio.obj (.cinit)
                      801ea108    0000004c     app_app_eolcontrol.obj (.cinit)
                      801ea154    00000004     --HOLE-- [fill = 0]
                      801ea158    0000004c     bios.a64P : rta.o64P (.cinit)
                      801ea1a4    00000004     --HOLE-- [fill = 0]
                      801ea1a8    0000004c     rtdx64xplus.lib : buffer1.o64P (.cinit)
                      801ea1f4    00000004     --HOLE-- [fill = 0]
                      801ea1f8    00000048     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_init.obj (.cinit)
                      801ea240    00000048     rts64plus.lib : cos.obj (.cinit)
                      801ea288    00000048                   : sin.obj (.cinit)
                      801ea2d0    00000048                   : tan.obj (.cinit)
                      801ea318    00000040     ccdc_md.obj (.cinit)
                      801ea358    00000040     draw_handler.obj (.cinit)
                      801ea398    0000003c     app_app_messagereceiver.obj (.cinit)
                      801ea3d4    00000004     --HOLE-- [fill = 0]
                      801ea3d8    0000003c     bios.a64P : exc.o64P (.cinit)
                      801ea414    00000004     --HOLE-- [fill = 0]
                      801ea418    0000003c     main.obj (.cinit)
                      801ea454    00000004     --HOLE-- [fill = 0]
                      801ea458    0000003c     vfw_converter.obj (.cinit)
                      801ea494    00000004     --HOLE-- [fill = 0]
                      801ea498    0000003c     vfw_vio.obj (.cinit)
                      801ea4d4    00000004     --HOLE-- [fill = 0]
                      801ea4d8    00000039     vfw_vio_vpss_internal.obj (.cinit)
                      801ea511    00000007     --HOLE-- [fill = 0]
                      801ea518    00000038     eol_calibrationmain.obj (.cinit)
                      801ea550    00000034     bios.a64P : hwi.o64P (.cinit)
                      801ea584    00000004     --HOLE-- [fill = 0]
                      801ea588    00000030               : tsk_stup.o64P (.cinit)
                      801ea5b8    0000002c               : utl_putc.o64P (.cinit)
                      801ea5e4    00000004     --HOLE-- [fill = 0]
                      801ea5e8    0000002c     fpgacom_txbuffer.obj (.cinit)
                      801ea614    00000004     --HOLE-- [fill = 0]
                      801ea618    0000002c     ipc_rx.obj (.cinit)
                      801ea644    00000004     --HOLE-- [fill = 0]
                      801ea648    0000002c     ovl.obj (.cinit)
                      801ea674    00000004     --HOLE-- [fill = 0]
                      801ea678    0000002c     rts64plus.lib : exit.obj (.cinit)
                      801ea6a4    00000004     --HOLE-- [fill = 0]
                      801ea6a8    0000002c     vpbe_md.obj (.cinit)
                      801ea6d4    00000004     --HOLE-- [fill = 0]
                      801ea6d8    00000029     app_app_algocontrol.obj (.cinit)
                      801ea701    00000007     --HOLE-- [fill = 0]
                      801ea708    00000029     app_app_statehandler.obj (.cinit)
                      801ea731    00000007     --HOLE-- [fill = 0]
                      801ea738    00000029     edma3utils.obj (.cinit)
                      801ea761    00000007     --HOLE-- [fill = 0]
                      801ea768    00000028     edma3helper.obj (.cinit)
                      801ea790    00000028     rts64plus.lib : atanf.obj (.cinit)
                      801ea7b8    00000024     bios.a64P : obj_init.o64P (.cinit)
                      801ea7dc    00000004     --HOLE-- [fill = 0]
                      801ea7e0    00000024     drivers.a64P : dio_tskDynamic.o64P (.cinit)
                      801ea804    00000004     --HOLE-- [fill = 0]
                      801ea808    00000024     sioboth.a64P : sio.o64P (.cinit)
                      801ea82c    00000004     --HOLE-- [fill = 0]
                      801ea830    00000020     rts64plus.lib : tanf.obj (.cinit)
                      801ea850    0000001c     DiagnosticHandler.obj (.cinit)
                      801ea86c    00000004     --HOLE-- [fill = 0]
                      801ea870    0000001c     bios.a64P : exc_asm.o64P (.cinit)
                      801ea88c    00000004     --HOLE-- [fill = 0]
                      801ea890    0000001c               : mem_defi.o64P (.cinit)
                      801ea8ac    00000004     --HOLE-- [fill = 0]
                      801ea8b0    0000001c               : swi_seta.o64P (.cinit)
                      801ea8cc    00000004     --HOLE-- [fill = 0]
                      801ea8d0    0000001c               : sys.o64P (.cinit)
                      801ea8ec    00000004     --HOLE-- [fill = 0]
                      801ea8f0    0000001c     fpgacom_rxbuffer.obj (.cinit)
                      801ea90c    00000004     --HOLE-- [fill = 0]
                      801ea910    0000001c     rts64plus.lib : _lock.obj (.cinit)
                      801ea92c    00000004     --HOLE-- [fill = 0]
                      801ea930    0000001c                   : atexit.obj (.cinit)
                      801ea94c    00000004     --HOLE-- [fill = 0]
                      801ea950    0000001c     vfw.obj (.cinit)
                      801ea96c    00000004     --HOLE-- [fill = 0]
                      801ea970    0000001c     vfw_app_wrapper_que.obj (.cinit)
                      801ea98c    00000004     --HOLE-- [fill = 0]
                      801ea990    0000001a     app_algo_MAP.obj (.cinit)
                      801ea9aa    00000006     --HOLE-- [fill = 0]
                      801ea9b0    00000018     bios.a64P : knl_tick.o64P (.cinit)
                      801ea9c8    00000018     rts64plus.lib : asinf.obj (.cinit)
                      801ea9e0    00000018                   : cosf.obj (.cinit)
                      801ea9f8    00000018                   : sinf.obj (.cinit)
                      801eaa10    00000018     vfw_vio_vpss.obj (.cinit)
                      801eaa28    00000014     bios.a64P : hwi_disp.o64P (.cinit)
                      801eaa3c    00000004     --HOLE-- [fill = 0]
                      801eaa40    00000014     sdf.obj (.cinit)
                      801eaa54    00000004     --HOLE-- [fill = 0]
                      801eaa58    00000010     bios.a64P : gio.o64P (.cinit)
                      801eaa68    00000010               : sem_crea.o64P (.cinit)
                      801eaa78    00000010     rts64plus.lib : divd.obj (.cinit)
                      801eaa88    00000010                   : divf.obj (.cinit)
                      801eaa98    00000010     spi_spi.obj (.cinit)
                      801eaaa8    0000000e     bios.a64P : ecm_dispatch.o64P (.cinit)
                      801eaab6    00000002     --HOLE-- [fill = 0]
                      801eaab8    0000000c               : buf.o64P (.cinit)
                      801eaac4    00000004     --HOLE-- [fill = 0]
                      801eaac8    0000000c               : idl_busy.o64P (.cinit)
                      801eaad4    00000004     --HOLE-- [fill = 0]
                      801eaad8    0000000c               : knl_swit.o64P (.cinit)
                      801eaae4    00000004     --HOLE-- [fill = 0]
                      801eaae8    0000000c               : pool.o64P (.cinit)
                      801eaaf4    00000004     --HOLE-- [fill = 0]
                      801eaaf8    0000000c               : que_crea.o64P (.cinit)
                      801eab04    00000004     --HOLE-- [fill = 0]
                      801eab08    0000000c               : tsk_chec.o64P (.cinit)
                      801eab14    00000004     --HOLE-- [fill = 0]
                      801eab18    0000000c               : tsk_disa.o64P (.cinit)
                      801eab24    00000004     --HOLE-- [fill = 0]
                      801eab28    0000000c     biosDM420.a64P : bcache_wait.o64P (.cinit)
                      801eab34    00000004     --HOLE-- [fill = 0]
                      801eab38    0000000c     crc.obj (.cinit)
                      801eab44    00000004     --HOLE-- [fill = 0]
                      801eab48    0000000c     msgq32.l64p : msgq32.o64p (.cinit)
                      801eab54    00000004     --HOLE-- [fill = 0]
                      801eab58    0000000c     rts64plus.lib : errno.obj (.cinit)
                      801eab64    00000004     --HOLE-- [fill = 0]
                      801eab68    0000000c                   : fopen.obj (.cinit)
                      801eab74    00000004     --HOLE-- [fill = 0]
                      801eab78    0000000c                   : sinit.obj (.cinit)
                      801eab84    00000004     --HOLE-- [fill = 0]
                      801eab88    0000000a     bios.a64P : pool_init.o64P (.cinit)
                      801eab92    00000006     --HOLE-- [fill = 0]
                      801eab98    0000000a     edma3_drv_bios.lib : edma3.obj (.cinit)
                      801eaba2    00000006     --HOLE-- [fill = 0]
                      801eaba8    0000000a     msgq32.l64p : msgq32_init.o64p (.cinit)
                      801eabb2    00000006     --HOLE-- [fill = 0]
                      801eabb8    0000000a                 : msgq32_stup.o64p (.cinit)
                      801eabc2    00000006     --HOLE-- [fill = 0]
                      801eabc8    00000004     (.pad.cinit) [fill = 0]
    .mem       0    801eabcc    00000004     UNINITIALIZED
                      801eabcc    00000004     d1175_applicationcfg.obj (.mem)
    .TSK_FpgaCom_RX$stk
    *          0    801eabd0    00002000     UNINITIALIZED
                      801eabd0    00002000     d1175_applicationcfg.obj (.TSK_FpgaCom_RX$stk)
    .TSK_FpgaCom_Tx$stk
    *          0    801ecbd0    00002000     UNINITIALIZED
                      801ecbd0    00002000     d1175_applicationcfg.obj (.TSK_FpgaCom_Tx$stk)
    .TSK_DRAWLIB$stk
    *          0    801eebd0    00000400     UNINITIALIZED
                      801eebd0    00000400     d1175_applicationcfg.obj (.TSK_DRAWLIB$stk)
    .que       0    801eefd0    00000020     UNINITIALIZED
                      801eefd0    00000020     d1175_applicationcfg.obj (.que)
    .gio       0    801eeff0    00000010     UNINITIALIZED
                      801eeff0    00000010     d1175_applicationcfg.obj (.gio)
    .LOG_system$buf
    *          0    801ef000    00001000     UNINITIALIZED
                      801ef000    00001000     d1175_applicationcfg.obj (.LOG_system$buf)
    .DVTEvent_Log$buf
    *          0    801f0000    00008000     UNINITIALIZED
                      801f0000    00008000     d1175_applicationcfg.obj (.DVTEvent_Log$buf)
    .TSK_App$stk
    *          0    801f8000    00008000     UNINITIALIZED
                      801f8000    00008000     d1175_applicationcfg.obj (.TSK_App$stk)
    .TSK_VfwCapture$stk
    *          0    80200000    00008000     UNINITIALIZED
                      80200000    00008000     d1175_applicationcfg.obj (.TSK_VfwCapture$stk)
    .TSK_VfwConverterBE$stk
    *          0    80208000    00008000     UNINITIALIZED
                      80208000    00008000     d1175_applicationcfg.obj (.TSK_VfwConverterBE$stk)
    .TSK_VfwDisplay$stk
    *          0    80210000    00008000     UNINITIALIZED
                      80210000    00008000     d1175_applicationcfg.obj (.TSK_VfwDisplay$stk)
    .TSK_VfwDistri$stk
    *          0    80218000    00008000     UNINITIALIZED
                      80218000    00008000     d1175_applicationcfg.obj (.TSK_VfwDistri$stk)
    .TSK_VideoAlgo$stk
    *          0    80220000    00008000     UNINITIALIZED
                      80220000    00008000     d1175_applicationcfg.obj (.TSK_VideoAlgo$stk)
    .TSK_VideoAlgoLow$stk
    *          0    80228000    00008000     UNINITIALIZED
                      80228000    00008000     d1175_applicationcfg.obj (.TSK_VideoAlgoLow$stk)
    .TSK_VideoAlgoMed$stk
    *          0    80230000    00008000     UNINITIALIZED
                      80230000    00008000     d1175_applicationcfg.obj (.TSK_VideoAlgoMed$stk)
    .TSK_aAlgoCCF$stk
    *          0    80238000    00008000     UNINITIALIZED
                      80238000    00008000     d1175_applicationcfg.obj (.TSK_aAlgoCCF$stk)
    .TSK_aAlgoEC$stk
    *          0    80240000    00008000     UNINITIALIZED
                      80240000    00008000     d1175_applicationcfg.obj (.TSK_aAlgoEC$stk)
    .TSK_idle$stk
    *          0    80248000    00008000     UNINITIALIZED
                      80248000    00008000     d1175_applicationcfg.obj (.TSK_idle$stk)
    .TSK_mcuIPC_rx$stk
    *          0    80250000    00008000     UNINITIALIZED
                      80250000    00008000     d1175_applicationcfg.obj (.TSK_mcuIPC_rx$stk)
    .TSK_mcuIPC_tx$stk
    *          0    80258000    00008000     UNINITIALIZED
                      80258000    00008000     d1175_applicationcfg.obj (.TSK_mcuIPC_tx$stk)
    .TSK_VfwControl$stk
    *          0    80260000    00007d00     UNINITIALIZED
                      80260000    00007d00     d1175_applicationcfg.obj (.TSK_VfwControl$stk)
    .bios      0    80267d00    000070e0
                      80267d00    000005c0     bios.a64P : sys_prin.o64P (.bios)
                      802682c0    000005c0     lnkrtdx.a64P : rtdx.o64P (.bios)
                      80268880    00000520     bios.a64P : exc.o64P (.bios)
                      80268da0    000004e0               : hwi_disp_asm.o64P (.bios)
                      80269280    000004c0               : swi.o64P (.bios)
                      80269740    00000360               : prd.o64P (.bios)
                      80269aa0    00000300     sioboth.a64P : sio_crea.o64P (.bios)
                      80269da0    000002a0     bios.a64P : gio_crea.o64P (.bios)
                      8026a040    000002a0               : malloc.o64P (.bios)
                      8026a2e0    00000280               : rta.o64P (.bios)
                      8026a560    00000240               : knl_run.o64P (.bios)
                      8026a7a0    00000240               : mem_defi.o64P (.bios)
                      8026a9e0    00000220               : mem_rede.o64P (.bios)
                      8026ac00    00000200               : sem_pend.o64P (.bios)
                      8026ae00    000001e0               : mem_allo.o64P (.bios:.near)
                      8026afe0    000001e0               : c62_plug.o64P (.bios)
                      8026b1c0    000001e0               : exc_asm.o64P (.bios)
                      8026b3a0    000001e0               : knl_tick.o64P (.bios)
                      8026b580    000001e0               : pip.o64P (.bios)
                      8026b760    000001e0     sioboth.a64P : sio_dele.o64P (.bios)
                      8026b940    000001c0     bios.a64P : mem_free.o64P (.bios:.near)
                      8026bb00    000001c0               : gio_sbmt.o64P (.bios)
                      8026bcc0    000001c0               : sem_dopo.o64P (.bios)
                      8026be80    000001c0     biosDM420.a64P : bcache_block.o64P (.bios)
                      8026c040    000001a0     bios.a64P : tsk_setu.o64P (.bios)
                      8026c1e0    000001a0     biosDM420.a64P : clk.o64P (.bios)
                      8026c380    00000180     bios.a64P : buf_crea.o64P (.bios)
                      8026c500    00000180               : knl_swit.o64P (.bios)
                      8026c680    00000160     msgq32.l64p : msgq32_open.o64p (.bios)
                      8026c7e0    00000140     bios.a64P : autoinit.o64P (.bios)
                      8026c920    00000140               : tsk_exit.o64P (.bios)
                      8026ca60    00000140     biosDM420.a64P : bcache_init.o64P (.bios)
                      8026cba0    00000120     bios.a64P : gbl_cacheinit64P.o64P (.bios)
                      8026ccc0    00000120               : knl_chec.o64P (.bios)
                      8026cde0    00000120               : mem_unde.o64P (.bios)
                      8026cf00    00000120               : tsk_stup.o64P (.bios)
                      8026d020    00000100               : ecm_dispatch.o64P (.bios)
                      8026d120    00000100               : gio_dele.o64P (.bios)
                      8026d220    00000100     msgq32.l64p : msgq32_stup.o64p (.bios)
                      8026d320    000000e0     bios.a64P : sem_post_asm.o64P (.bios)
                      8026d400    000000e0               : tsk_chec.o64P (.bios)
                      8026d4e0    000000c0               : dev_matc.o64P (.bios)
                      8026d5a0    000000c0               : knl_exit.o64P (.bios)
                      8026d660    000000c0     msgq32.l64p : msgq32_alloc.o64p (.bios)
                      8026d720    000000c0                 : msgq32_get.o64p (.bios)
                      8026d7e0    000000c0     sioboth.a64P : sio_recl.o64P (.bios)
                      8026d8a0    000000a0     bios.a64P : dev_mkfr.o64P (.bios)
                      8026d940    000000a0               : sem_post.o64P (.bios)
                      8026d9e0    000000a0               : swi_seta.o64P (.bios)
                      8026da80    000000a0               : sys_exit.o64P (.bios)
                      8026db20    000000a0     msgq32.l64p : msgq32_put.o64p (.bios)
                      8026dbc0    000000a0     sioboth.a64P : sio_issu.o64P (.bios)
                      8026dc60    00000080     bios.a64P : atm.o64P (.bios)
                      8026dce0    00000080               : gio_cbck.o64P (.bios)
                      8026dd60    00000080               : hwi_disp.o64P (.bios)
                      8026dde0    00000080               : hwi_eventmap64P.o64P (.bios)
                      8026de60    00000080               : knl_ipos.o64P (.bios)
                      8026dee0    00000080               : knl_post.o64P (.bios)
                      8026df60    00000080               : lck.o64P (.bios)
                      8026dfe0    00000080               : log.o64P (.bios)
                      8026e060    00000080               : obj_crea.o64P (.bios)
                      8026e0e0    00000080               : sem_crea.o64P (.bios)
                      8026e160    00000080               : swi_crea.o64P (.bios)
                      8026e1e0    00000080               : tsk_disa.o64P (.bios)
                      8026e260    00000080     biosDM420.a64P : bcache_wait.o64P (.bios)
                      8026e2e0    00000080                    : idl_cal.o64P (.bios)
                      8026e360    00000080     msgq32.l64p : msgq32_count.o64p (.bios)
                      8026e3e0    00000060     bios.a64P : mem_vall.o64P (.bios:.near)
                      8026e440    00000060               : sys_erro.o64P (.bios:.near)
                      8026e4a0    00000060               : buf_free.o64P (.bios)
                      8026e500    00000060               : dev_rmfr.o64P (.bios)
                      8026e560    00000060               : ecm_dispatchPlug.o64P (.bios)
                      8026e5c0    00000060               : fxn.o64P (.bios)
                      8026e620    00000060               : hwi_c.o64P (.bios)
                      8026e680    00000060               : idl_busy.o64P (.bios)
                      8026e6e0    00000060               : obj_dele.o64P (.bios)
                      8026e740    00000060               : sem_pend_binary.o64P (.bios)
                      8026e7a0    00000060               : sem_pend_counting.o64P (.bios)
                      8026e800    00000060               : sts.o64P (.bios)
                      8026e860    00000060               : sys_abor.o64P (.bios)
                      8026e8c0    00000060               : utl_putc.o64P (.bios)
                      8026e920    00000060     biosDM420.a64P : clk_meas.o64P (.bios)
                      8026e980    00000040     bios.a64P : buf_allo.o64P (.bios)
                      8026e9c0    00000040               : buf_stat.o64P (.bios)
                      8026ea00    00000040               : c62_c.o64P (.bios)
                      8026ea40    00000040               : ecm_disableEvent.o64P (.bios)
                      8026ea80    00000040               : ecm_enableEvent.o64P (.bios)
                      8026eac0    00000040               : idl_stub.o64P (.bios)
                      8026eb00    00000040               : que_crea.o64P (.bios)
                      8026eb40    00000040               : que_get.o64P (.bios)
                      8026eb80    00000040               : rta_andn.o64P (.bios)
                      8026ebc0    00000040     msgq32.l64p : msgq32_free.o64p (.bios)
                      8026ec00    00000020     bios.a64P : clk_countspms.o64P (.bios)
                      8026ec20    00000020               : clk_getltime.o64P (.bios)
                      8026ec40    00000020               : clk_getprd.o64P (.bios)
                      8026ec60    00000020               : fxn_c.o64P (.bios)
                      8026ec80    00000020               : gbl_vers.o64P (.bios)
                      8026eca0    00000020               : idl.o64P (.bios)
                      8026ecc0    00000020               : iom_stub.o64P (.bios)
                      8026ece0    00000020               : log_printf.o64P (.bios)
                      8026ed00    00000020               : sem_dele.o64P (.bios)
                      8026ed20    00000020               : sts_set.o64P (.bios)
                      8026ed40    00000020               : sys_one.o64P (.bios)
                      8026ed60    00000020               : utl_doer.o64P (.bios)
                      8026ed80    00000020               : utl_halt.o64P (.bios)
                      8026eda0    00000020     biosDM420.a64P : clk_gethtime.o64P (.bios)
                      8026edc0    00000020     msgq32.l64p : msgq32_seterrhandler.o64p (.bios)
    .sys       0    8026ede0    00000010     UNINITIALIZED
                      8026ede0    00000010     d1175_applicationcfg.obj (.sys)
    .pinit     0    8026edf0    0000000c
                      8026edf0    00000004     rtdx64xplus.lib : buffer1.o64P (.pinit)
                      8026edf4    00000004                     : rtdx_mon.o64P (.pinit)
                      8026edf8    00000004     --HOLE-- [fill = 0]
    .messages
    *          0    8026ee00    00005900     UNINITIALIZED
                      8026ee00    00005900     msgq_if.obj (.messages)
    .TSK_VfwInit$stk
    *          0    80274700    00002000     UNINITIALIZED
                      80274700    00002000     d1175_applicationcfg.obj (.TSK_VfwInit$stk)
    .TSK_Diagnostic$stk
    *          0    80276700    00001000     UNINITIALIZED
                      80276700    00001000     d1175_applicationcfg.obj (.TSK_Diagnostic$stk)
    .stack     0    80277700    00000800     UNINITIALIZED
                      80277700    00000800     --HOLE--
    .BUF_PoolTxSingleFrameData_s$data
    *          0    80277f00    000000f0     UNINITIALIZED
                      80277f00    000000f0     --HOLE--
    .trcdata   0    80277ff0    0000000c
                      80277ff0    0000000c     bios.a64P : trc.o64P (.trcdata)
    .trace$buf
    *          0    80278000    00002000     UNINITIALIZED
                      80278000    00002000     d1175_applicationcfg.obj (.trace$buf)
    .TSK_McASP$stk
    *          0    8027a000    00001000     UNINITIALIZED
                      8027a000    00001000     d1175_applicationcfg.obj (.TSK_McASP$stk)
    .rtdx_text
    *          0    8027b000    00000fc0
                      8027b000    000002a0     rtdx64xplus.lib : rtdx_mon.o64P (.rtdx_text:_HSRTDX_rec)
                      8027b2a0    00000260                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_WriteCB)
                      8027b500    00000260                     : buffer1.o64P (.rtdx_text:_RTDX_write_next)
                      8027b760    000001a0                     : rtdx_mon.o64P (.rtdx_text:_HSRTDX_xmt)
                      8027b900    00000160                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Send_To_Host)
                      8027ba60    000000e0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Mon_Queue)
                      8027bb40    000000e0                     : buffer1.o64P (.rtdx_text:_claim)
                      8027bc20    000000a0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_GetH2THeader)
                      8027bcc0    000000a0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Poll)
                      8027bd60    00000080                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Final_RT_Monitor)
                      8027bde0    00000060                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Initialize)
                      8027be40    00000060                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Init_RT_Monitor)
                      8027bea0    00000040                     : buffer2.o64P (.rtdx_text:_RTDX_Buffer_ReadCB)
                      8027bee0    00000040                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Size)
                      8027bf20    00000040                     : memfill.o64P (.rtdx_text:_RTDX_memfill)
                      8027bf60    00000020                     : buffer2.o64P (.rtdx_text:_RTDX_Buffer_Read)
                      8027bf80    00000020                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Write)
                      8027bfa0    00000020                     : intr_tgt.o64P (.rtdx_text)
    .McASP_Buffers
    *          0    8027c000    00000d20     UNINITIALIZED
                      8027c000    00000d20     mcasphandler.obj (.McASP_Buffers)
    .sysinit   0    8027cd20    00000ae0
                      8027cd20    00000400     d1175_applicationcfg.obj (.sysinit)
                      8027d120    00000120     bios.a64P : dev_init.o64P (.sysinit)
                      8027d240    00000120               : pool_init.o64P (.sysinit)
                      8027d360    00000120     msgq32.l64p : msgq32_init.o64p (.sysinit)
                      8027d480    000000e0     biosDM420.a64P : clk_enable64LcTimer.o64P (.sysinit)
                      8027d560    000000c0     bios.a64P : boot.o64P (.sysinit)
                      8027d620    000000a0               : mem_init.o64P (.sysinit)
                      8027d6c0    00000080               : buf_init.o64P (.sysinit)
                      8027d740    00000060               : tsk_init.o64P (.sysinit)
                      8027d7a0    00000020               : gio.o64P (.sysinit)
                      8027d7c0    00000020               : obj_init.o64P (.sysinit)
                      8027d7e0    00000020     drivers.a64P : dio.o64P (.sysinit)
    .bss       0    8027d800    00000a38     UNINITIALIZED
                      8027d800    00000440     d1175_applicationcfg.obj (.bss)
                      8027dc40    00000100     bios.a64P : hwi_disp_asm.o64P (.bss)
                      8027dd40    000000cc               : biosdata.o64P (.bss)
                      8027de0c    0000009c               : swi.o64P (.bss)
                      8027dea8    00000048               : knl.o64P (.bss)
                      8027def0    00000048     uart_driver.obj (.bss)
                      8027df38    0000002c     app_app.obj (.bss)
                      8027df64    00000004     app_algo_MAP.obj (.bss)
                      8027df68    00000020     bios.a64P : exc_asm.o64P (.bss)
                      8027df88    00000019     app_app_messagehandler.obj (.bss)
                      8027dfa1    00000003     app_app_algocontrol.obj (.bss)
                      8027dfa4    00000018     bios.a64P : hwi.o64P (.bss)
                      8027dfbc    00000018     fpgacom_cmdlevel.obj (.bss)
                      8027dfd4    00000018     ipc_tx.obj (.bss)
                      8027dfec    00000018     lnkrtdx.a64P : rtdx.o64P (.bss)
                      8027e004    00000018     load.obj (.bss)
                      8027e01c    00000018     vfw_frontend.obj (.bss)
                      8027e034    00000017     mcasphandler.obj (.bss)
                      8027e04b    00000001     cam.obj (.bss)
                      8027e04c    00000014     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_dm643x_cfg.obj (.bss)
                      8027e060    00000014     vfw_backend.obj (.bss)
                      8027e074    00000011     fpgacom_lowlevel.obj (.bss)
                      8027e085    00000001     ipcll_handler.obj (.bss)
                      8027e086    00000002     bios.a64P : pool_init.o64P (.bss)
                      8027e088    00000011     vfw_vio_vpss_internal.obj (.bss)
                      8027e099    00000001     --HOLE--
                      8027e09a    00000002     edma3_drv_bios.lib : edma3.obj (.bss)
                      8027e09c    00000010     app_app_messagereceiver.obj (.bss)
                      8027e0ac    00000010     bios.a64P : exc.o64P (.bss)
                      8027e0bc    00000010     draw.obj (.bss)
                      8027e0cc    00000010     msgq_if.obj (.bss)
                      8027e0dc    00000010     rtdx64xplus.lib : buffer1.o64P (.bss)
                      8027e0ec    00000010                     : rtdx_mon.o64P (.bss)
                      8027e0fc    00000010     vfw_converter.obj (.bss)
                      8027e10c    00000010     vfw_vio.obj (.bss)
                      8027e11c    0000000f     app_algo_CCF.obj (.bss)
                      8027e12b    00000001     --HOLE--
                      8027e12c    0000000e     edma3_rm_bios.lib : edma3resmgr.obj (.bss)
                      8027e13a    00000002     msgq32.l64p : msgq32_init.o64p (.bss)
                      8027e13c    0000000d     app_app_statehandler.obj (.bss)
                      8027e149    00000001     --HOLE--
                      8027e14a    00000002     msgq32.l64p : msgq32_stup.o64p (.bss)
                      8027e14c    0000000c     app_app_eolcontrol.obj (.bss)
                      8027e158    0000000c     bios.a64P : tsk.o64P (.bss)
                      8027e164    0000000c     edma3utils.obj (.bss)
                      8027e170    0000000c     ipc_rx.obj (.bss)
                      8027e17c    0000000c     main.obj (.bss)
                      8027e188    0000000c     mcaspdevice.obj (.bss)
                      8027e194    0000000c     vfw_app_wrapper_que.obj (.bss)
                      8027e1a0    00000009     app_algo_EC.obj (.bss)
                      8027e1a9    00000003     --HOLE--
                      8027e1ac    00000008     DiagnosticHandler.obj (.bss)
                      8027e1b4    00000008     app_algo_DDE.obj (.bss)
                      8027e1bc    00000008     bios.a64P : clk_data.o64P (.bss)
                      8027e1c4    00000008               : sys.o64P (.bss)
                      8027e1cc    00000008     draw_handler.obj (.bss)
                      8027e1d4    00000008     edma3_drv_bios_sample.lib : bios_edma3_drv_sample_init.obj (.bss)
                      8027e1dc    00000008     fpgacom_msglevel.obj (.bss)
                      8027e1e4    00000008     ovl.obj (.bss)
                      8027e1ec    00000008     vfw.obj (.bss)
                      8027e1f4    00000005     app_algo_GT.obj (.bss)
                      8027e1f9    00000003     --HOLE--
                      8027e1fc    00000005     app_algo_GT_Supp.obj (.bss)
                      8027e201    00000003     --HOLE--
                      8027e204    00000004     bios.a64P : clk_data2.o64P (.bss)
                      8027e208    00000004               : dev_init.o64P (.bss)
                      8027e20c    00000004               : idl_busy.o64P (.bss)
                      8027e210    00000004               : mem_asm.o64P (.bss)
                      8027e214    00000004               : mem_defi.o64P (.bss)
                      8027e218    00000004               : pool.o64P (.bss)
                      8027e21c    00000004               : tsk_chec.o64P (.bss)
                      8027e220    00000004               : tsk_disa.o64P (.bss)
                      8027e224    00000004     ccdc_md.obj (.bss)
                      8027e228    00000004     crc.obj (.bss)
                      8027e22c    00000004     edma3framework.obj (.bss)
                      8027e230    00000004     mcasp_drv_lib.lib : dda_mcasp_bios.obj (.bss)
                      8027e234    00000004     msgq32.l64p : msgq32.o64p (.bss)
    .BUF_PoolTxMultiFrameData_s$data
    *          0    8027e238    00000a00     UNINITIALIZED
                      8027e238    00000a00     --HOLE--
    .hRxAppBufMulFrame$data
    *          0    8027ec38    00000a00     UNINITIALIZED
                      8027ec38    00000a00     --HOLE--
    .tsk       0    8027f638    000007e0     UNINITIALIZED
                      8027f638    000007e0     d1175_applicationcfg.obj (.tsk)
    .BUF_McASPQueueMemPool$data
    *          0    8027fe18    00000460     UNINITIALIZED
                      8027fe18    00000460     --HOLE--
    .TSK_UART0_TX$stk
    *          0    80280278    00000400     UNINITIALIZED
                      80280278    00000400     d1175_applicationcfg.obj (.TSK_UART0_TX$stk)
    .hRxAppBuf$data
    *          0    80280678    00000280     UNINITIALIZED
                      80280678    00000280     --HOLE--
    .BUF_PoolTxFrames_s$data
    *          0    802808f8    000001e0     UNINITIALIZED
                      802808f8    000001e0     --HOLE--
    .BUF_PoolTxMessages_s$data
    *          0    80280ad8    00000190     UNINITIALIZED
                      80280ad8    00000190     --HOLE--
    .gblinit   0    80280c68    0000016c
                      80280c68    0000016c     d1175_applicationcfg.obj (.gblinit)
    .cio       0    80280dd8    00000120     UNINITIALIZED
                      80280dd8    00000120     rts64plus.lib : trgmsg.obj (.cio)
    .buf       0    80280ef8    00000118     UNINITIALIZED
                      80280ef8    00000118     d1175_applicationcfg.obj (.buf)
    .devtable
    *          0    80281010    00000090     UNINITIALIZED
                      80281010    00000090     d1175_applicationcfg.obj (.devtable)
    .ddr2_video
    *          0    80300000    0129ec00     UNINITIALIZED
                      80300000    00b0e800     vfw_frontend.obj (.ddr2_video)
                      80e0e800    0040b000     vfw_ovly_pool.obj (.ddr2_video)
                      81219800    00308400     vfw_backend.obj (.ddr2_video)
                      81521c00    0007d000     vfw_algo_pool.obj (.ddr2_video)
    FAR CALL TRAMPOLINES
    callee name               trampoline name
       callee addr  tramp addr   call addr  call info
    $.l1p_ram:edma3framework.obj$0x84  $Tramp$L$PI$$_edma3fw_processFrame
       1080e204     801b97c0     8019c210   edma3framework.obj (.text)
    $.text:__pop_rts:rts64plus.lib<push.obj>$0x0  $Tramp$L$PI$$__pop_rts
       801b96c0     1080e860     1080e4f4   edma3framework.obj (.l1p_ram)
    $.bios:bios.a64P<sem_post_asm.o64P>$0x0  $Tramp$L$PI$$_SEM_postBinary
       8026d320     1080e880     1080e384   edma3framework.obj (.l1p_ram)
                                 1080e394   edma3framework.obj (.l1p_ram)
                                 1080e3a8   edma3framework.obj (.l1p_ram)
                                 1080e820   edma3helper.obj (.l1p_ram)
                                 1080e828   edma3helper.obj (.l1p_ram)
                                 1080e830   edma3helper.obj (.l1p_ram)
    $.text:edma3_drv_bios.lib<edma3.obj>$0x2d00  $Tramp$L$PI$$_EDMA3_DRV_getPaRAMPhyAddr
       8017e540     1080e8a0     1080e270   edma3framework.obj (.l1p_ram)
                                 1080e32c   edma3framework.obj (.l1p_ram)
    $.text:__divu:rts64plus.lib<divu.obj>$0x0  $Tramp$L$PI$$__divu
       801b7640     1080e8c0     1080e238   edma3framework.obj (.l1p_ram)
                                 1080e798   ovl.obj (.l1p_ram)
    $.text:_memset:rts64plus.lib<memset.obj>$0x0  $Tramp$L$PI$$_memset
       801b70e0     1080e8e0     1080e210   edma3framework.obj (.l1p_ram)
                                 1080e220   edma3framework.obj (.l1p_ram)
    $.text:__push_rts:rts64plus.lib<push.obj>$0x0  $Tramp$L$PI$$__push_rts
       801b96e0     1080e900     1080e204   edma3framework.obj (.l1p_ram)
    $.text:edma3_drv_bios.lib<edma3.obj>$0x3480  $Tramp$L$PI$$_EDMA3_DRV_enableTransfer
       8017ecc0     1080e920     1080e1c8   edma3framework.obj (.l1p_ram)
                                 1080e2b8   edma3framework.obj (.l1p_ram)
                                 1080e424   edma3framework.obj (.l1p_ram)
    $.bios:biosDM420.a64P<bcache_wait.o64P>$0x0  $Tramp$L$PI$$_BCACHE_wait
       8026e260     1080e940     1080e1c4   edma3framework.obj (.l1p_ram)
    $.bios:bios.a64P<sem_pend_counting.o64P>$0x0  $Tramp$L$PI$$_SEM_pend
       8026e7a0     1080e960     1080e1b0   edma3framework.obj (.l1p_ram)
                                 1080e3e0   edma3framework.obj (.l1p_ram)
                                 1080e4c8   edma3framework.obj (.l1p_ram)
                                 1080e4d4   edma3framework.obj (.l1p_ram)
                                 1080e4e4   edma3framework.obj (.l1p_ram)
    $.bios:biosDM420.a64P<bcache_block.o64P>$0x170  $Tramp$L$PI$$_BCACHE_wbInv
       8026bff0     1080e980     1080e1a0   edma3framework.obj (.l1p_ram)
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    address    name
    8027d800   $bss
    8027d800   .bss
    80004000   .data
    80169b60   .text
    8027cf28   BIOS$$CLKOFF
    8027cee8   BIOS$$CLKON
    8027cd20   BIOS_init
    8027cfe8   BIOS_start
    00000001   BUF$
    00000001   BUF_ENABLED
    80280ff4   BUF_McASPQueueMemPool
    8027fe18   BUF_McASPQueueMemPool$databeg
    80280f54   BUF_PoolTxFrames_s
    802808f8   BUF_PoolTxFrames_s$databeg
    80280f7c   BUF_PoolTxMessages_s
    80280ad8   BUF_PoolTxMessages_s$databeg
    80280fa4   BUF_PoolTxMultiFrameData_s
    8027e238   BUF_PoolTxMultiFrameData_s$databeg
    80280fcc   BUF_PoolTxSingleFrameData_s
    80277f00   BUF_PoolTxSingleFrameData_s$databeg
    801b9278   C$$IO$$
    00000001   CLK$
    1080e158   CLK_A_TABBEG
    00000001   CLK_CALDIV
    00000001   CLK_CALMULT
    0005c490   CLK_COUNTSPMS
    00000005   CLK_COUNTSPMSHIGH
    8027dd68   CLK_D_idletime
    8027dd64   CLK_D_isrhook
    8027dd60   CLK_D_tabbeg
    8027dd5c   CLK_D_timefxn
    00000001   CLK_ENABLEHTIME
    8026eda0   CLK_F_gethtime
    8026c1e0   CLK_F_getltime
    8026c1f0   CLK_F_isr
    8026c330   CLK_F_itime
    80268da0   CLK_HOOKFXN
    00000001   CLK_HTIMEDIV
    00000001   CLK_HTIMEMULT
    0005c490   CLK_HTIMEPERLTIME
    00006978   CLK_INPUTCLK
    00004000   CLK_INTBIT
    00000001   CLK_LTIMEDIV
    0005c490   CLK_LTIMEMULT
    000003e8   CLK_MICROSECS
    00006978   CLK_PRD
    00000000   CLK_PRDHIGH
    01c21400   CLK_REGS
    00000001   CLK_RESETTIMER
    8027dd58   CLK_R_time
    00000020   CLK_TCR
    00000000   CLK_TDDR
    00000000   CLK_TDDRHIGH
    8026eda0   CLK_TIMEFXN
    00000000   CLK_TIMERNUM
    00000005   CLK_TIMMODE
    00000001   CLK_USETIMER
    1080e15c   CLK_null
    1080cfb8   CpuLoadCheck
    1080ddf4   CpuLoadCheck$
    8027dc10   DDR2
    80004000   DDR2$B
    00100000   DDR2$L
    ffffffff   DDR2_MSGQ32
    ffffffff   DDR2_VIDEO
    00000000   DEV$
    00000000   DGN$
    00000000   DHL$
    00000000   DHL_gChannelsAvailable
    00000001   DIO$
    80281040   DIO_DIO_McASP$device
    80281034   DIO_DIO_McASP$obj
    00000000   DIO_NUMSWIBASE
    00000000   DIO_NUMTSKBASE
    00000000   DIO_STATIC
    00000000   DPI$
    1080e0f8   DVTEvent_Log
    801f0000   DVTEvent_Log$buf
    00000001   DVTEvent_Log$datatype
    00000000   DVTEvent_Log$log
    00002000   DVTEvent_Log$size
    00000001   ECM$
    00000001   ECM_ENABLE
    ffffffff   ECM_EVTMASK0
    ffffffff   ECM_EVTMASK1
    ffdfffff   ECM_EVTMASK2
    ffffffff   ECM_EVTMASK3
    0000000a   EVENT10
    00000064   EVENT100
    00000065   EVENT101
    00000066   EVENT102
    00000067   EVENT103
    00000068   EVENT104
    00000069   EVENT105
    0000006a   EVENT106
    0000006b   EVENT107
    0000006c   EVENT108
    0000006d   EVENT109
    0000000b   EVENT11
    0000006e   EVENT110
    0000006f   EVENT111
    00000070   EVENT112
    00000071   EVENT113
    00000072   EVENT114
    00000073   EVENT115
    00000074   EVENT116
    00000075   EVENT117
    00000076   EVENT118
    00000077   EVENT119
    0000000c   EVENT12
    00000078   EVENT120
    00000079   EVENT121
    0000007a   EVENT122
    0000007b   EVENT123
    0000007c   EVENT124
    0000007d   EVENT125
    0000007e   EVENT126
    0000007f   EVENT127
    0000000d   EVENT13
    0000000e   EVENT14
    0000000f   EVENT15
    00000010   EVENT16
    00000011   EVENT17
    00000012   EVENT18
    00000013   EVENT19
    00000014   EVENT20
    00000015   EVENT21
    00000016   EVENT22
    00000017   EVENT23
    00000018   EVENT24
    00000019   EVENT25
    0000001a   EVENT26
    0000001b   EVENT27
    0000001c   EVENT28
    0000001d   EVENT29
    0000001e   EVENT30
    0000001f   EVENT31
    00000020   EVENT32
    00000021   EVENT33
    00000022   EVENT34
    00000023   EVENT35
    00000024   EVENT36
    00000025   EVENT37
    00000026   EVENT38
    00000027   EVENT39
    00000004   EVENT4
    00000028   EVENT40
    00000029   EVENT41
    0000002a   EVENT42
    0000002b   EVENT43
    0000002c   EVENT44
    0000002d   EVENT45
    0000002e   EVENT46
    0000002f   EVENT47
    00000030   EVENT48
    00000031   EVENT49
    00000005   EVENT5
    00000032   EVENT50
    00000033   EVENT51
    00000034   EVENT52
    00000035   EVENT53
    00000036   EVENT54
    00000037   EVENT55
    00000038   EVENT56
    00000039   EVENT57
    0000003a   EVENT58
    0000003b   EVENT59
    00000006   EVENT6
    0000003c   EVENT60
    0000003d   EVENT61
    0000003e   EVENT62
    0000003f   EVENT63
    00000040   EVENT64
    00000041   EVENT65
    00000042   EVENT66
    00000043   EVENT67
    00000044   EVENT68
    00000045   EVENT69
    00000007   EVENT7
    00000046   EVENT70
    00000047   EVENT71
    00000048   EVENT72
    00000049   EVENT73
    0000004a   EVENT74
    0000004b   EVENT75
    0000004c   EVENT76
    0000004d   EVENT77
    0000004e   EVENT78
    0000004f   EVENT79
    00000008   EVENT8
    00000050   EVENT80
    00000051   EVENT81
    00000052   EVENT82
    00000053   EVENT83
    00000054   EVENT84
    00000055   EVENT85
    00000056   EVENT86
    00000057   EVENT87
    00000058   EVENT88
    00000059   EVENT89
    00000009   EVENT9
    0000005a   EVENT90
    0000005b   EVENT91
    0000005c   EVENT92
    0000005d   EVENT93
    0000005e   EVENT94
    0000005f   EVENT95
    00000060   EVENT96
    00000061   EVENT97
    00000062   EVENT98
    00000063   EVENT99
    8026e5c0   FXN_F_nop
    8026e5c4   FXN_F_run
    8026e600   FXN_F_zero
    00000001   GBL$
    00005204   GBL_A_VERSION
    00000000   GBL_BCACHEREADADDR0
    00000000   GBL_BCACHEREADADDR1
    00000000   GBL_BCACHEREADADDR2
    00000000   GBL_BIGENDIAN
    00000000   GBL_CACHE
    00000000   GBL_CALLCSLCFGINIT
    00006978   GBL_CLKIN
    00001918   GBL_CLKTYPE
    00001963   GBL_DSPSUBTYPE
    0000003e   GBL_DSPTYPE
    00000001   GBL_ENABLEINST
    00000000   GBL_ENABLE_SK
    00000042   GBL_FOOTPRINT
    0005c490   GBL_FREQ
    00000000   GBL_GEMTRUECOMPEN
    00000007   GBL_L1DMODE
    00000007   GBL_L1PMODE
    00000001   GBL_L2CONFIGURE
    00000000   GBL_L2MAR0_31
    ffffffff   GBL_L2MAR128_159
    00000000   GBL_L2MAR160_191
    00000000   GBL_L2MAR192_223
    00000000   GBL_L2MAR224_255
    00000000   GBL_L2MAR32_63
    00000000   GBL_L2MAR64_95
    00000000   GBL_L2MAR96_127
    00000002   GBL_L2MODE
    00000000   GBL_NULL
    00000000   GBL_PROCID
    00000000   GBL_ROM
    00000000   GBL_SUPPORTCSL
    0000dbef   GBL_TRCMASKVALUE
    00000001   GBL_USERINIT
    801b32d8   GBL_USERINITFXN
    00000001   GBL_boot
    80277ff8   GBL_initdone
    80277700   GBL_stackbeg
    80277eff   GBL_stackend
    00000001   GIO$
    801eeff0   GIO$config
    8026e0e0   GIO_CREATEFXN
    8026ed00   GIO_DELETEFXN
    8026e7a0   GIO_PENDFXN
    8026d320   GIO_POSTFXN
    00000000   HOOK$
    00000000   HOOK_KNLID
    00000001   HST$
    1080d4b4   HST_A_TABBEG
    1080d4f0   HST_A_TABEND
    00000000   HST_DSM
    ffffffff   HST_DSMBUFSEG
    00000400   HST_DSMMEMSIZE
    8027ddd4   HST_D_chanmask
    8027ddd8   HST_D_tabbeg
    8027dddc   HST_D_tabend
    000000ff   HST_MAXFRAMEALLOWED
    00000040   HST_MAXFRAMESET
    00000000   HST_NONE
    00000001   HST_RTDX
    00000001   HWI$
    1080d800   HWI_A_VECS
    000078f8   HWI_CFGDISPATCHED
    8027dfb4   HWI_D_bss
    8027dfb8   HWI_D_ccmask
    8027dfa4   HWI_D_spsave
    00000001   HWI_ENABLE_EXC
    80268da0   HWI_F_dispatch
    00000000   HWI_GENERATE_RESET_VEC
    0000000a   HWI_INT10
    00000000   HWI_INT10$hwi
    0000000b   HWI_INT11
    00000000   HWI_INT11$hwi
    0000000c   HWI_INT12
    00000000   HWI_INT12$hwi
    0000000d   HWI_INT13
    00000000   HWI_INT13$hwi
    0000000e   HWI_INT14
    00000000   HWI_INT14$hwi
    0000000f   HWI_INT15
    00000000   HWI_INT15$hwi
    00000004   HWI_INT4
    00000000   HWI_INT4$hwi
    00000005   HWI_INT5
    00000000   HWI_INT5$hwi
    00000006   HWI_INT6
    00000000   HWI_INT6$hwi
    00000007   HWI_INT7
    00000000   HWI_INT7$hwi
    00000008   HWI_INT8
    00000000   HWI_INT8$hwi
    00000009   HWI_INT9
    00000000   HWI_INT9$hwi
    03020100   HWI_INTRMUX1
    0b0a0908   HWI_INTRMUX2
    06042f0c   HWI_INTRMUX3
    00000001   HWI_NMI
    00000000   HWI_NMI$hwi
    00000000   HWI_POLARITYMASK
    00000002   HWI_RESERVED0
    00000000   HWI_RESERVED0$hwi
    00000003   HWI_RESERVED1
    00000000   HWI_RESERVED1$hwi
    00000000   HWI_RESET
    00000000   HWI_RESET$hwi
    00000000   HWI_ZEROTAB
    00000001   IDL$
    1080dde8   IDL_A_CALBEG
    1080cfac   IDL_A_TABBEG
    00000006   IDL_CALIBRERROR
    8026eac0   IDL_CALIBRFXN
    8027e20c   IDL_D_busyObj
    8027dd48   IDL_D_calbeg
    8027dd44   IDL_D_calibrate
    8027dd40   IDL_D_tabbeg
    1080cfbc   IDL_END
    1080ddf8   IDL_END$
    8026e680   IDL_F_busy
    8026e2e0   IDL_F_calibrate
    8026eca0   IDL_F_loop
    8026eac0   IDL_F_stub
    00000001   IDL_USECLKIDLTIME
    1080dd84   IDL_busyObj
    80169dd2   IDL_busyObj$avgfmt
    00000001   IDL_busyObj$filter
    00000001   IDL_busyObj$iA
    00000000   IDL_busyObj$iB
    00000001   IDL_busyObj$iC
    80169dcc   IDL_busyObj$maxfmt
    00000000   IDL_busyObj$operation
    1080dd80   IDL_busyObj$stsobj
    80169dcf   IDL_busyObj$sumfmt
    00000002   IDL_busyObj$unittype
    1080cfac   IDL_cpuLoad
    1080dde8   IDL_cpuLoad$
    00000001   ISRC$
    8026c658   KNL_glue
    1080dd90   KNL_swi
    00000001   KNL_swi$dorta
    00000000   KNL_swi$ord
    00000000   KNL_swi$pri
    1080dc14   KNL_swi$sts
    80169b86   KNL_swi$sts$avgfmt
    00000002   KNL_swi$sts$filter
    00000001   KNL_swi$sts$filtmaxmult
    00000001   KNL_swi$sts$filtsummult
    80169b76   KNL_swi$sts$maxfmt
    1080dc10   KNL_swi$sts$stsobj
    80169b7e   KNL_swi$sts$sumfmt
    00000000   KNL_swi$sts$unittype
    00000000   KNL_swi$swi
    ffffffff   L1D_CACHE
    ffffffff   L1D_RAM
    ffffffff   L1P_CACHE
    ffffffff   L2_CACHE
    ffffffff   L2_RAM
    00000001   LCK$
    802682c0   LNK_F_checkBufferCall
    80268340   LNK_F_dataPump
    802682e0   LNK_F_getChanPtr
    80268338   LNK_F_init
    80268848   LNK_F_readCallBack
    1080cfb0   LNK_dataPump
    1080ddec   LNK_dataPump$
    8027dff0   LNK_dspFrameReadyMask
    8027dfec   LNK_dspFrameRequestMask
    802685c0   LNK_newin
    802686f4   LNK_newout
    80268350   LNK_rcloop
    80268414   LNK_rdrtry
    8027dff8   LNK_readDone
    8027dffc   LNK_readFail
    8027dff4   LNK_readPend
    80268424   LNK_rrloop
    8027e000   LNK_writeFail
    802684f0   LNK_wrloop
    802684e4   LNK_wrrtry
    00000001   LOG$
    1080e0c8   LOG_A_TABBEG
    1080e158   LOG_A_TABEND
    00000006   LOG_A_TABLEN
    1080e140   LOG_CamCtrl
    1080d600   LOG_CamCtrl$buf
    00000001   LOG_CamCtrl$datatype
    00000000   LOG_CamCtrl$log
    00000080   LOG_CamCtrl$size
    8027dd4c   LOG_D_system
    00000001   LOG_ENABLED
    8026dfe0   LOG_F_event
    1080e128   LOG_MIC
    1080d500   LOG_MIC$buf
    00000001   LOG_MIC$datatype
    00000000   LOG_MIC$log
    00000040   LOG_MIC$size
    1080e110   LOG_UART
    1080de00   LOG_UART$buf
    00000001   LOG_UART$datatype
    00000000   LOG_UART$log
    00000040   LOG_UART$size
    1080e0c8   LOG_system
    801ef000   LOG_system$buf
    00000000   LOG_system$datatype
    00000000   LOG_system$log
    00000400   LOG_system$size
    00000000   MBX$
    00000001   MEM$
    8027dc10   MEM_MALLOCSEG
    00000000   MEM_NULL
    8027dc10   MEM_SEGZERO
    00000000   MEM_USEMPC
    00000001   MEM_gNumHeap
    00000000   MSGQ$
    00000000   MSGQ_USEMSGQ
    00000000   OBJ$
    00000000   PIP$
    1080e000   PIP_A_TABBEG
    1080e0c8   PIP_A_TABEND
    00000002   PIP_A_TABLEN
    8027dd50   PIP_D_tabbeg
    8027dd54   PIP_D_tablen
    8026b5f8   PIP_F_give
    8026b5f8   PIP_F_probe
    8026b6c8   PIP_F_start
    8026b580   PIP_F_take
    00000064   PIP_OBJSIZE
    00000000   PIP_gNextId
    00000002   PIP_gNumEmbed
    00000001   POOL$
    00000001   POOL_USEPOOL
    00000001   PRD$
    1080cf8c   PRD_A_TABBEG
    1080cfac   PRD_A_TABEND
    00000001   PRD_A_TABLEN
    8027dd90   PRD_D_cur
    8027dd94   PRD_D_elapsed
    8027dd98   PRD_D_prevtim
    8027dd9c   PRD_D_scalar
    8027dda0   PRD_D_swihandle
    8027dda4   PRD_D_tabbeg
    8027dda8   PRD_D_tablen
    8027ddac   PRD_D_thook
    8027dd8c   PRD_D_tick
    80269740   PRD_F_swi
    802699c0   PRD_F_tick
    00000001   PRD_SCALAR
    1080ddbc   PRD_SWIHANDLE
    8026b56c   PRD_THOOKFXN
    1080cf8c   PRD_TriggerFrameWatchdog
    1080cfa8   PRD_TriggerFrameWatchdog$aaa
    00000001   PRD_TriggerFrameWatchdog$mode
    00000001   PRD_TriggerFrameWatchdog$ord
    00000028   PRD_TriggerFrameWatchdog$period
    00000000   PRD_TriggerFrameWatchdog$prd
    1080dc04   PRD_TriggerFrameWatchdog$sts
    80169b6b   PRD_TriggerFrameWatchdog$sts$avgfmt
    00000000   PRD_TriggerFrameWatchdog$sts$filter
    80169b59   PRD_TriggerFrameWatchdog$sts$maxfmt
    1080dc00   PRD_TriggerFrameWatchdog$sts$stsobj
    80169b62   PRD_TriggerFrameWatchdog$sts$sumfmt
    00000002   PRD_TriggerFrameWatchdog$sts$unittype
    1080e158   PRD_clock
    1080ddbc   PRD_swi
    00000001   PRD_swi$dorta
    00000000   PRD_swi$ord
    00000001   PRD_swi$pri
    1080dc24   PRD_swi$sts
    80169ba0   PRD_swi$sts$avgfmt
    00000002   PRD_swi$sts$filter
    00000001   PRD_swi$sts$filtmaxmult
    00000001   PRD_swi$sts$filtsummult
    80169b90   PRD_swi$sts$maxfmt
    1080dc20   PRD_swi$sts$stsobj
    80169b98   PRD_swi$sts$sumfmt
    00000000   PRD_swi$sts$unittype
    00000000   PRD_swi$swi
    00000001   QUE$
    801eefe8   QUE_McASPTxFrame
    801eefe0   QUE_TxFrames_s
    801eefd8   QUE_TxMessages_s
    8027ddb0   RTA_D_fromHost
    8027ddb8   RTA_D_logval
    8027ddc8   RTA_D_stsval
    8027ddb4   RTA_D_toHost
    8026eb80   RTA_F_andn
    8026a3c0   RTA_F_dispatch
    8026a2e0   RTA_F_getlog
    8026a318   RTA_F_getsts
    8026eb98   RTA_F_or
    8026a358   RTA_F_readblk
    8026a380   RTA_F_resetmem
    8026a374   RTA_F_writeword
    1080cfb4   RTA_dispatcher
    1080ddf0   RTA_dispatcher$
    8026a40c   RTA_execute
    1080d4b8   RTA_fromHost
    1080d4f0   RTA_fromHost$buf
    00000004   RTA_fromHost$framesize
    00000000   RTA_fromHost$hst
    00000001   RTA_fromHost$id
    00000000   RTA_fromHost$mode
    1080e000   RTA_fromHost$pipe
    1080e030   RTA_fromHost$pipe$aaa
    1080e060   RTA_fromHost$pipe$bbb
    8027dc14   RTA_fromHost$pipe$dtab
    1080e004   RTA_fromHost$pipe$rd
    1080e034   RTA_fromHost$pipe$wr
    1080d4c0   RTA_fromHost$rtdx
    1080d4d4   RTA_toHost
    1080df00   RTA_toHost$buf
    00000040   RTA_toHost$framesize
    00000000   RTA_toHost$hst
    00000000   RTA_toHost$id
    00000001   RTA_toHost$mode
    1080e064   RTA_toHost$pipe
    1080e094   RTA_toHost$pipe$aaa
    1080e0c4   RTA_toHost$pipe$bbb
    8027dc20   RTA_toHost$pipe$dtab
    1080e068   RTA_toHost$pipe$rd
    1080e098   RTA_toHost$pipe$wr
    1080d4dc   RTA_toHost$rtdx
    00000001   RTDX$
    00000408   RTDX_BUFMEMSIZE
    ffffffff   RTDX_DATAMEMSEG
    00000000   RTDX_MODE
    00000001   RTDX_NORMALIZED_HDR
    00000001   RTDX_USERTDX
    00000000   RTDX_USERTEXECUTION
    00000001   SEM$
    1080c418   SEM_APPInit
    1080c8bc   SEM_Cam_Read_Register
    1080c890   SEM_Cam_Write_Register
    1080c9c4   SEM_DiagnosticReq
    1080c8e8   SEM_McASP_CCDC_VSYNC
    1080c998   SEM_McASP_DIAG_LUTS_STATUS_RDY
    1080c914   SEM_McASP_PACKET_STATUS
    1080c940   SEM_McASP_QDataReady
    1080c96c   SEM_McASP_SIOInit
    1080c4c8   SEM_RxFramesInFifo
    1080c520   SEM_TxFramesFree
    1080c4f4   SEM_TxMessagesInQueue
    1080c2b8   SEM_ctrl
    1080c2e4   SEM_data
    1080c470   SEM_uart0
    1080c368   SEM_uart0_send_fifo_empty
    1080c3c0   SEM_uart0_send_tel_rdy
    1080c310   SEM_uart0_sendbuf_empty
    1080c838   SEM_uart0_tx_data_pending
    1080c49c   SEM_uart1
    1080c394   SEM_uart1_send_fifo_empty
    1080c3ec   SEM_uart1_send_tel_rdy
    1080c33c   SEM_uart1_sendbuf_empty
    1080c864   SEM_uart1_tx_data_pending
    1080c28c   SEM_videoConfigReady
    00000000   SIO$
    00000001   STS$
    1080dc00   STS_A_TABBEG
    1080dd90   STS_A_TABEND
    8026e82c   STS_F_add
    8026e800   STS_F_delta
    8026e848   STS_F_reset
    00000001   SWI$
    1080dd90   SWI_A_TABBEG
    1080dde8   SWI_A_TABEND
    00000002   SWI_A_TABLEN
    8027de24   SWI_D_curfxn
    8027de14   SWI_D_curmask
    8027de20   SWI_D_curmbox
    8027de18   SWI_D_curset
    8027de10   SWI_D_execaddr
    8027de2c   SWI_D_inswi
    8027de1c   SWI_D_lock
    8027de28   SWI_D_rdybeg
    8027de30   SWI_D_rdytab
    8027de0c   SWI_D_runaddr
    00000000   SWI_EHOOKFXN
    80269464   SWI_EXECFXN
    80269280   SWI_F_enable
    80269464   SWI_F_exec
    8026948c   SWI_F_iexec
    802692f0   SWI_F_post
    8026950c   SWI_F_run
    00000000   SWI_IHOOKFXN
    8026950c   SWI_RUNFXN
    00000001   SYS$
    8026ede0   SYS$config
    801b32f8   SYS_ABORTFXN
    8026ed60   SYS_ERRORFXN
    801b32f8   SYS_EXITFXN
    8026e8c0   SYS_PUTCFXN
    80277ff4   TRC_R_mask
    80277ff0   TRC_cinit
    00000001   TSK$
    8027fac4   TSK_App
    0000000d   TSK_App$ord
    00000007   TSK_App$pri
    801f8000   TSK_App$stack
    801fff98   TSK_App$stkptr
    1080dcf4   TSK_App$sts
    80169cf2   TSK_App$sts$avgfmt
    00000002   TSK_App$sts$filter
    00000001   TSK_App$sts$filtmaxmult
    00000001   TSK_App$sts$filtsummult
    80169ce2   TSK_App$sts$maxfmt
    1080dcf0   TSK_App$sts$stsobj
    80169cea   TSK_App$sts$sumfmt
    00000000   TSK_App$sts$unittype
    00000000   TSK_App$tsk
    8027fa64   TSK_DRAWLIB
    0000000c   TSK_DRAWLIB$ord
    00000006   TSK_DRAWLIB$pri
    801eebd0   TSK_DRAWLIB$stack
    801eef68   TSK_DRAWLIB$stkptr
    1080dce4   TSK_DRAWLIB$sts
    80169cd8   TSK_DRAWLIB$sts$avgfmt
    00000002   TSK_DRAWLIB$sts$filter
    00000001   TSK_DRAWLIB$sts$filtmaxmult
    00000001   TSK_DRAWLIB$sts$filtsummult
    80169cc8   TSK_DRAWLIB$sts$maxfmt
    1080dce0   TSK_DRAWLIB$sts$stsobj
    80169cd0   TSK_DRAWLIB$sts$sumfmt
    00000000   TSK_DRAWLIB$sts$unittype
    00000000   TSK_DRAWLIB$tsk
    8027fdc4   TSK_Diagnostic
    00000014   TSK_Diagnostic$ord
    00000001   TSK_Diagnostic$pri
    80276700   TSK_Diagnostic$stack
    80277698   TSK_Diagnostic$stkptr
    1080dd74   TSK_Diagnostic$sts
    80169dc2   TSK_Diagnostic$sts$avgfmt
    00000002   TSK_Diagnostic$sts$filter
    00000001   TSK_Diagnostic$sts$filtmaxmult
    00000001   TSK_Diagnostic$sts$filtsummult
    80169db2   TSK_Diagnostic$sts$maxfmt
    1080dd70   TSK_Diagnostic$sts$stsobj
    80169dba   TSK_Diagnostic$sts$sumfmt
    00000000   TSK_Diagnostic$sts$unittype
    00000000   TSK_Diagnostic$tsk
    8027fca4   TSK_FpgaCom_RX
    00000011   TSK_FpgaCom_RX$ord
    0000000e   TSK_FpgaCom_RX$pri
    801eabd0   TSK_FpgaCom_RX$stack
    801ecb68   TSK_FpgaCom_RX$stkptr
    1080dd44   TSK_FpgaCom_RX$sts
    80169d74   TSK_FpgaCom_RX$sts$avgfmt
    00000002   TSK_FpgaCom_RX$sts$filter
    00000001   TSK_FpgaCom_RX$sts$filtmaxmult
    00000001   TSK_FpgaCom_RX$sts$filtsummult
    80169d64   TSK_FpgaCom_RX$sts$maxfmt
    1080dd40   TSK_FpgaCom_RX$sts$stsobj
    80169d6c   TSK_FpgaCom_RX$sts$sumfmt
    00000000   TSK_FpgaCom_RX$sts$unittype
    00000000   TSK_FpgaCom_RX$tsk
    8027fd04   TSK_FpgaCom_Tx
    00000012   TSK_FpgaCom_Tx$ord
    0000000e   TSK_FpgaCom_Tx$pri
    801ecbd0   TSK_FpgaCom_Tx$stack
    801eeb68   TSK_FpgaCom_Tx$stkptr
    1080dd54   TSK_FpgaCom_Tx$sts
    80169d8e   TSK_FpgaCom_Tx$sts$avgfmt
    00000002   TSK_FpgaCom_Tx$sts$filter
    00000001   TSK_FpgaCom_Tx$sts$filtmaxmult
    00000001   TSK_FpgaCom_Tx$sts$filtsummult
    80169d7e   TSK_FpgaCom_Tx$sts$maxfmt
    1080dd50   TSK_FpgaCom_Tx$sts$stsobj
    80169d86   TSK_FpgaCom_Tx$sts$sumfmt
    00000000   TSK_FpgaCom_Tx$sts$unittype
    00000000   TSK_FpgaCom_Tx$tsk
    8027fd64   TSK_McASP
    00000013   TSK_McASP$ord
    0000000e   TSK_McASP$pri
    8027a000   TSK_McASP$stack
    8027af98   TSK_McASP$stkptr
    1080dd64   TSK_McASP$sts
    80169da8   TSK_McASP$sts$avgfmt
    00000002   TSK_McASP$sts$filter
    00000001   TSK_McASP$sts$filtmaxmult
    00000001   TSK_McASP$sts$filtsummult
    80169d98   TSK_McASP$sts$maxfmt
    1080dd60   TSK_McASP$sts$stsobj
    80169da0   TSK_McASP$sts$sumfmt
    00000000   TSK_McASP$sts$unittype
    00000000   TSK_McASP$tsk
    00000000   TSK_NUM_HOOKS
    00000001   TSK_PRIORITY
    00000000   TSK_READYFXN
    8027dc10   TSK_STACKSEG
    00001000   TSK_STACKSIZE
    00000000   TSK_SWITCHFXN
    8027fa04   TSK_UART0_TX
    0000000b   TSK_UART0_TX$ord
    0000000d   TSK_UART0_TX$pri
    80280278   TSK_UART0_TX$stack
    80280610   TSK_UART0_TX$stkptr
    1080dcd4   TSK_UART0_TX$sts
    80169cbe   TSK_UART0_TX$sts$avgfmt
    00000002   TSK_UART0_TX$sts$filter
    00000001   TSK_UART0_TX$sts$filtmaxmult
    00000001   TSK_UART0_TX$sts$filtsummult
    80169cae   TSK_UART0_TX$sts$maxfmt
    1080dcd0   TSK_UART0_TX$sts$stsobj
    80169cb6   TSK_UART0_TX$sts$sumfmt
    00000000   TSK_UART0_TX$sts$unittype
    00000000   TSK_UART0_TX$tsk
    8026ec60   TSK_VCREATEFXN
    8026ec60   TSK_VDELETEFXN
    8026ec60   TSK_VEXITFXN
    8027f7c4   TSK_VfwCapture
    00000005   TSK_VfwCapture$ord
    0000000b   TSK_VfwCapture$pri
    80200000   TSK_VfwCapture$stack
    80207f98   TSK_VfwCapture$stkptr
    1080dc74   TSK_VfwCapture$sts
    80169c22   TSK_VfwCapture$sts$avgfmt
    00000002   TSK_VfwCapture$sts$filter
    00000001   TSK_VfwCapture$sts$filtmaxmult
    00000001   TSK_VfwCapture$sts$filtsummult
    80169c12   TSK_VfwCapture$sts$maxfmt
    1080dc70   TSK_VfwCapture$sts$stsobj
    80169c1a   TSK_VfwCapture$sts$sumfmt
    00000000   TSK_VfwCapture$sts$unittype
    00000000   TSK_VfwCapture$tsk
    8027f824   TSK_VfwControl
    00000006   TSK_VfwControl$ord
    0000000c   TSK_VfwControl$pri
    80260000   TSK_VfwControl$stack
    80267c98   TSK_VfwControl$stkptr
    1080dc84   TSK_VfwControl$sts
    80169c3c   TSK_VfwControl$sts$avgfmt
    00000002   TSK_VfwControl$sts$filter
    00000001   TSK_VfwControl$sts$filtmaxmult
    00000001   TSK_VfwControl$sts$filtsummult
    80169c2c   TSK_VfwControl$sts$maxfmt
    1080dc80   TSK_VfwControl$sts$stsobj
    80169c34   TSK_VfwControl$sts$sumfmt
    00000000   TSK_VfwControl$sts$unittype
    00000000   TSK_VfwControl$tsk
    8027f944   TSK_VfwConverterBE
    00000009   TSK_VfwConverterBE$ord
    00000008   TSK_VfwConverterBE$pri
    80208000   TSK_VfwConverterBE$stack
    8020ff98   TSK_VfwConverterBE$stkptr
    1080dcb4   TSK_VfwConverterBE$sts
    80169c8a   TSK_VfwConverterBE$sts$avgfmt
    00000002   TSK_VfwConverterBE$sts$filter
    00000001   TSK_VfwConverterBE$sts$filtmaxmult
    00000001   TSK_VfwConverterBE$sts$filtsummult
    80169c7a   TSK_VfwConverterBE$sts$maxfmt
    1080dcb0   TSK_VfwConverterBE$sts$stsobj
    80169c82   TSK_VfwConverterBE$sts$sumfmt
    00000000   TSK_VfwConverterBE$sts$unittype
    00000000   TSK_VfwConverterBE$tsk
    8027f9a4   TSK_VfwDisplay
    0000000a   TSK_VfwDisplay$ord
    00000009   TSK_VfwDisplay$pri
    80210000   TSK_VfwDisplay$stack
    80217f98   TSK_VfwDisplay$stkptr
    1080dcc4   TSK_VfwDisplay$sts
    80169ca4   TSK_VfwDisplay$sts$avgfmt
    00000002   TSK_VfwDisplay$sts$filter
    00000001   TSK_VfwDisplay$sts$filtmaxmult
    00000001   TSK_VfwDisplay$sts$filtsummult
    80169c94   TSK_VfwDisplay$sts$maxfmt
    1080dcc0   TSK_VfwDisplay$sts$stsobj
    80169c9c   TSK_VfwDisplay$sts$sumfmt
    00000000   TSK_VfwDisplay$sts$unittype
    00000000   TSK_VfwDisplay$tsk
    8027f8e4   TSK_VfwDistri
    00000008   TSK_VfwDistri$ord
    0000000a   TSK_VfwDistri$pri
    80218000   TSK_VfwDistri$stack
    8021ff98   TSK_VfwDistri$stkptr
    1080dca4   TSK_VfwDistri$sts
    80169c70   TSK_VfwDistri$sts$avgfmt
    00000002   TSK_VfwDistri$sts$filter
    00000001   TSK_VfwDistri$sts$filtmaxmult
    00000001   TSK_VfwDistri$sts$filtsummult
    80169c60   TSK_VfwDistri$sts$maxfmt
    1080dca0   TSK_VfwDistri$sts$stsobj
    80169c68   TSK_VfwDistri$sts$sumfmt
    00000000   TSK_VfwDistri$sts$unittype
    00000000   TSK_VfwDistri$tsk
    8027f884   TSK_VfwInit
    00000007   TSK_VfwInit$ord
    0000000d   TSK_VfwInit$pri
    80274700   TSK_VfwInit$stack
    80276698   TSK_VfwInit$stkptr
    1080dc94   TSK_VfwInit$sts
    80169c56   TSK_VfwInit$sts$avgfmt
    00000002   TSK_VfwInit$sts$filter
    00000001   TSK_VfwInit$sts$filtmaxmult
    00000001   TSK_VfwInit$sts$filtsummult
    80169c46   TSK_VfwInit$sts$maxfmt
    1080dc90   TSK_VfwInit$sts$stsobj
    80169c4e   TSK_VfwInit$sts$sumfmt
    00000000   TSK_VfwInit$sts$unittype
    00000000   TSK_VfwInit$tsk
    8027f6a4   TSK_VideoAlgo
    00000002   TSK_VideoAlgo$ord
    00000006   TSK_VideoAlgo$pri
    80220000   TSK_VideoAlgo$stack
    80227f98   TSK_VideoAlgo$stkptr
    1080dc44   TSK_VideoAlgo$sts
    80169bd4   TSK_VideoAlgo$sts$avgfmt
    00000002   TSK_VideoAlgo$sts$filter
    00000001   TSK_VideoAlgo$sts$filtmaxmult
    00000001   TSK_VideoAlgo$sts$filtsummult
    80169bc4   TSK_VideoAlgo$sts$maxfmt
    1080dc40   TSK_VideoAlgo$sts$stsobj
    80169bcc   TSK_VideoAlgo$sts$sumfmt
    00000000   TSK_VideoAlgo$sts$unittype
    00000000   TSK_VideoAlgo$tsk
    8027f704   TSK_VideoAlgoLow
    00000003   TSK_VideoAlgoLow$ord
    00000003   TSK_VideoAlgoLow$pri
    80228000   TSK_VideoAlgoLow$stack
    8022ff98   TSK_VideoAlgoLow$stkptr
    1080dc54   TSK_VideoAlgoLow$sts
    80169bee   TSK_VideoAlgoLow$sts$avgfmt
    00000002   TSK_VideoAlgoLow$sts$filter
    00000001   TSK_VideoAlgoLow$sts$filtmaxmult
    00000001   TSK_VideoAlgoLow$sts$filtsummult
    80169bde   TSK_VideoAlgoLow$sts$maxfmt
    1080dc50   TSK_VideoAlgoLow$sts$stsobj
    80169be6   TSK_VideoAlgoLow$sts$sumfmt
    00000000   TSK_VideoAlgoLow$sts$unittype
    00000000   TSK_VideoAlgoLow$tsk
    8027f764   TSK_VideoAlgoMed
    00000004   TSK_VideoAlgoMed$ord
    00000004   TSK_VideoAlgoMed$pri
    80230000   TSK_VideoAlgoMed$stack
    80237f98   TSK_VideoAlgoMed$stkptr
    1080dc64   TSK_VideoAlgoMed$sts
    80169c08   TSK_VideoAlgoMed$sts$avgfmt
    00000002   TSK_VideoAlgoMed$sts$filter
    00000001   TSK_VideoAlgoMed$sts$filtmaxmult
    00000001   TSK_VideoAlgoMed$sts$filtsummult
    80169bf8   TSK_VideoAlgoMed$sts$maxfmt
    1080dc60   TSK_VideoAlgoMed$sts$stsobj
    80169c00   TSK_VideoAlgoMed$sts$sumfmt
    00000000   TSK_VideoAlgoMed$sts$unittype
    00000000   TSK_VideoAlgoMed$tsk
    8027fb84   TSK_aAlgoCCF
    0000000f   TSK_aAlgoCCF$ord
    00000001   TSK_aAlgoCCF$pri
    80238000   TSK_aAlgoCCF$stack
    8023ff98   TSK_aAlgoCCF$stkptr
    1080dd14   TSK_aAlgoCCF$sts
    80169d26   TSK_aAlgoCCF$sts$avgfmt
    00000002   TSK_aAlgoCCF$sts$filter
    00000001   TSK_aAlgoCCF$sts$filtmaxmult
    00000001   TSK_aAlgoCCF$sts$filtsummult
    80169d16   TSK_aAlgoCCF$sts$maxfmt
    1080dd10   TSK_aAlgoCCF$sts$stsobj
    80169d1e   TSK_aAlgoCCF$sts$sumfmt
    00000000   TSK_aAlgoCCF$sts$unittype
    00000000   TSK_aAlgoCCF$tsk
    8027fc44   TSK_aAlgoEC
    00000010   TSK_aAlgoEC$ord
    00000002   TSK_aAlgoEC$pri
    80240000   TSK_aAlgoEC$stack
    80247f98   TSK_aAlgoEC$stkptr
    1080dd34   TSK_aAlgoEC$sts
    80169d5a   TSK_aAlgoEC$sts$avgfmt
    00000002   TSK_aAlgoEC$sts$filter
    00000001   TSK_aAlgoEC$sts$filtmaxmult
    00000001   TSK_aAlgoEC$sts$filtsummult
    80169d4a   TSK_aAlgoEC$sts$maxfmt
    1080dd30   TSK_aAlgoEC$sts$stsobj
    80169d52   TSK_aAlgoEC$sts$sumfmt
    00000000   TSK_aAlgoEC$sts$unittype
    00000000   TSK_aAlgoEC$tsk
    8027f644   TSK_idle
    00000001   TSK_idle$ord
    00000000   TSK_idle$pri
    80248000   TSK_idle$stack
    8024ff98   TSK_idle$stkptr
    1080dc34   TSK_idle$sts
    80169bba   TSK_idle$sts$avgfmt
    00000002   TSK_idle$sts$filter
    00000001   TSK_idle$sts$filtmaxmult
    00000001   TSK_idle$sts$filtsummult
    80169baa   TSK_idle$sts$maxfmt
    1080dc30   TSK_idle$sts$stsobj
    80169bb2   TSK_idle$sts$sumfmt
    00000000   TSK_idle$sts$unittype
    00000000   TSK_idle$tsk
    8027fb24   TSK_mcuIPC_rx
    0000000e   TSK_mcuIPC_rx$ord
    00000007   TSK_mcuIPC_rx$pri
    80250000   TSK_mcuIPC_rx$stack
    80257f98   TSK_mcuIPC_rx$stkptr
    1080dd04   TSK_mcuIPC_rx$sts
    80169d0c   TSK_mcuIPC_rx$sts$avgfmt
    00000002   TSK_mcuIPC_rx$sts$filter
    00000001   TSK_mcuIPC_rx$sts$filtmaxmult
    00000001   TSK_mcuIPC_rx$sts$filtsummult
    80169cfc   TSK_mcuIPC_rx$sts$maxfmt
    1080dd00   TSK_mcuIPC_rx$sts$stsobj
    80169d04   TSK_mcuIPC_rx$sts$sumfmt
    00000000   TSK_mcuIPC_rx$sts$unittype
    00000000   TSK_mcuIPC_rx$tsk
    8027fbe4   TSK_mcuIPC_tx
    0000000f   TSK_mcuIPC_tx$ord
    00000007   TSK_mcuIPC_tx$pri
    80258000   TSK_mcuIPC_tx$stack
    8025ff98   TSK_mcuIPC_tx$stkptr
    1080dd24   TSK_mcuIPC_tx$sts
    80169d40   TSK_mcuIPC_tx$sts$avgfmt
    00000002   TSK_mcuIPC_tx$sts$filter
    00000001   TSK_mcuIPC_tx$sts$filtmaxmult
    00000001   TSK_mcuIPC_tx$sts$filtsummult
    80169d30   TSK_mcuIPC_tx$sts$maxfmt
    1080dd20   TSK_mcuIPC_tx$sts$stsobj
    80169d38   TSK_mcuIPC_tx$sts$sumfmt
    00000000   TSK_mcuIPC_tx$sts$unittype
    00000000   TSK_mcuIPC_tx$tsk
    00000001   UDEV$
    80281064   UDEV_CCDC$device
    80281058   UDEV_CCDC$obj
    8028101c   UDEV_McASPDevice$device
    80281010   UDEV_McASPDevice$obj
    80281088   UDEV_VPBE$device
    8028107c   UDEV_VPBE$obj
    1080c444   VFW_Overlay_SEM_OvlState
    8026dc60   _ATM_andi
    8026dc60   _ATM_andu
    8026dc70   _ATM_cleari
    8026dc70   _ATM_clearu
    8026dc80   _ATM_deci
    8026dc80   _ATM_decu
    8026dc90   _ATM_inci
    8026dc90   _ATM_incu
    8026dca4   _ATM_ori
    8026dca4   _ATM_oru
    8026dcb4   _ATM_seti
    8026dcb4   _ATM_setu
    007e5970   _AdjMatrix2d_s8
    8026caf4   _BCACHE_bootInit
    8026cb74   _BCACHE_getMar
    8026cb24   _BCACHE_getSize
    8026c014   _BCACHE_inv
    8026caf4   _BCACHE_setCacheToSram
    8026caa4   _BCACHE_setMar
    8026ca60   _BCACHE_setSize
    8026e260   _BCACHE_wait
    8026c004   _BCACHE_wb
    8026bff0   _BCACHE_wbInv
    8027cd20   _BIOS_init
    8027cfe8   _BIOS_start
    00a5d9f4   _BUF_ATTRS
    80280ff4   _BUF_McASPQueueMemPool
    80280f54   _BUF_PoolTxFrames_s
    80280f7c   _BUF_PoolTxMessages_s
    80280fa4   _BUF_PoolTxMultiFrameData_s
    80280fcc   _BUF_PoolTxSingleFrameData_s
    8026e980   _BUF_alloc
    8026c380   _BUF_create
    8026e4a0   _BUF_free
    8027d6c0   _BUF_init
    8026e9c0   _BUF_stat
    8026ea2c   _C62_clearIFR
    8026ea00   _C62_disableIER
    8026afe8   _C62_dispatchPlug
    8026ea18   _C62_enableIER
    8026afe0   _C62_plug
    8026ea2c   _C64_clearIFR
    8026ea00   _C64_disableIER
    8026afe8   _C64_dispatchPlug
    8026ea18   _C64_enableIER
    8026afe0   _C64_plug
    00ac78a0   _CCDCDrv_GlobalStr
    00ac92a4   _CCDC_FXN_TABLE
    8018d6a0   _CCDC_IsrVD0
    8018d814   _CCDC_IsrVD1
    8018db34   _CCDC_init
    8018db58   _CCDC_mdBindDev
    8018f050   _CCDC_mdControlChan
    8018dbb8   _CCDC_mdCreateChan
    8018e42c   _CCDC_mdDeleteChan
    8018eb64   _CCDC_mdSubmitChan
    8018db38   _CCDC_myInit
    8018e4f8   _CCDC_readChan
    8018e9f8   _CCDC_writeChan
    00abf638   _CCF_Exposure_Data
    0005c490   _CLK_COUNTSPMS
    8027e1bc   _CLK_DFLTMICROSECS
    8027dd88   _CLK_D_countspms
    8027dd7c   _CLK_D_dirty
    8027e1c0   _CLK_D_microseconds
    8027dd80   _CLK_D_prd
    8027dd84   _CLK_D_tddr
    8026c330   _CLK_F_itime
    00006978   _CLK_PRD
    01c21400   _CLK_REGS
    00000000   _CLK_TDDR
    00000000   _CLK_TIMERNUM
    00000001   _CLK_USETIMER
    8026ec00   _CLK_countspms
    8027d480   _CLK_enableTimer
    8026eda0   _CLK_gethtime
    8026ec20   _CLK_getltime
    8026ec40   _CLK_getprd
    8027dd6c   _CLK_htimeDiv
    8027dd70   _CLK_htimeMult
    8027e204   _CLK_htimePerLtime
    00ac6d2c   _CLK_inputClock
    8026c330   _CLK_itime
    8027dd74   _CLK_ltimeDiv
    8027dd78   _CLK_ltimeMult
    8026e920   _CLK_measure
    00abfd68   _ColorMatrixData
    1080cfb8   _CpuLoadCheck
    8027dc10   _DDR2
    ffffffff   _DDR2_MSGQ32
    ffffffff   _DDR2_VIDEO
    80004000   _DDR2_base
    00100000   _DDR2_length
    00ac9520   _DEV_D_devinit
    8027dc2c   _DEV_devinit
    8027d120   _DEV_init
    8026d4e0   _DEV_match
    8026d8a0   _DEV_mkframe
    8026e500   _DEV_rmframe
    801b95c0   _DIO_ctrl
    8027d7e0   _DIO_init
    801b2044   _DIO_tskCallback
    00ac93c0   _DIO_tskDynamicFxns
    801b1f48   _DIO_tskIdle
    801b1ea4   _DIO_tskIssue
    801b1e88   _DIO_tskReady
    801b1e60   _DIO_tskReclaim
    801b8e60   _DM643x_PinMux
    801b64a0   _DM643x_PowerON
    8019df28   _DM643x_SwitchPowerModule
    8019dee0   _DM643x_init
    8027df98   _DOOR_STATUS
    8027e1b0   _DSP_Diagnostic_Status
    8027df94   _DSP_EOL_Status
    8027df8c   _DSP_QU_ACK_REQ_DATA_ID
    1080e0f8   _DVTEvent_Log
    00aa89a8   _DiagGammaLUT_040
    00aa8da8   _DiagGammaLUT_070
    00aae468   _Diag_EXTLUT14_32_mod
    00aab308   _Diag_EXTLUT2_32_mod
    00aaf468   _Diag_RGBMATRIX_alternative_mod
    00aaf4b0   _Diag_RGBMATRIX_default_mod
    00aac308   _Diag_STDLUT14_mod
    00aa91a8   _Diag_STDLUT2_mod
    00aaf4f8   _DiagnosticMcASPLuts
    8019e1f4   _Disable_EDMA
    8019e1c4   _Disable_VPSS
    00ac94d4   _ECM_ATTRS
    8026ea40   _ECM_disableEvent
    8026d020   _ECM_dispatch
    8026e560   _ECM_dispatchPlug
    8027d80c   _ECM_dispatchTab
    8026ea80   _ECM_enableEvent
    8017f700   _EDMA3_DRV_Ioctl
    8017f568   _EDMA3_DRV_chainChannel
    8017f480   _EDMA3_DRV_checkAndClearTcc
    8017f370   _EDMA3_DRV_clearErrorBits
    8017f260   _EDMA3_DRV_close
    8017efe0   _EDMA3_DRV_create
    8017ef00   _EDMA3_DRV_delete
    8017cbc8   _EDMA3_DRV_disableTransfer
    8017ecc0   _EDMA3_DRV_enableTransfer
    8017d080   _EDMA3_DRV_freeChannel
    8017ec44   _EDMA3_DRV_getCCRegister
    8017eb60   _EDMA3_DRV_getMapChToEvtQ
    8017e9e0   _EDMA3_DRV_getOptField
    8017e8c0   _EDMA3_DRV_getPaRAM
    8017e800   _EDMA3_DRV_getPaRAMEntry
    8017e5e8   _EDMA3_DRV_getPaRAMField
    8017e540   _EDMA3_DRV_getPaRAMPhyAddr
    8017e40c   _EDMA3_DRV_linkChannel
    8017e234   _EDMA3_DRV_mapChToEvtQ
    8017dfac   _EDMA3_DRV_open
    8017d3a8   _EDMA3_DRV_requestChannel
    8017cacc   _EDMA3_DRV_setCCRegister
    8017c9c8   _EDMA3_DRV_setDestIndex
    8017c7e4   _EDMA3_DRV_setDestParams
    8017c62c   _EDMA3_DRV_setEvtQPriority
    8017c3c8   _EDMA3_DRV_setOptField
    8017c2c0   _EDMA3_DRV_setPaRAM
    8017c200   _EDMA3_DRV_setPaRAMEntry
    8017bfa8   _EDMA3_DRV_setPaRAMField
    8017bf08   _EDMA3_DRV_setQdmaTrigWord
    8017be00   _EDMA3_DRV_setSrcIndex
    8017bc04   _EDMA3_DRV_setSrcParams
    8017bacc   _EDMA3_DRV_setTransferParams
    8017b9f0   _EDMA3_DRV_unchainChannel
    8017b944   _EDMA3_DRV_unlinkChannel
    8017b840   _EDMA3_DRV_waitAndClearTcc
    80177720   _EDMA3_RM_Ioctl
    80176f50   _EDMA3_RM_allocContiguousResource
    801759d4   _EDMA3_RM_allocLogicalChannel
    80174f58   _EDMA3_RM_allocResource
    80174e80   _EDMA3_RM_checkAndClearTcc
    80174cf8   _EDMA3_RM_close
    80174a4c   _EDMA3_RM_create
    80174890   _EDMA3_RM_delete
    80174740   _EDMA3_RM_freeContiguousResource
    801740ec   _EDMA3_RM_freeLogicalChannel
    80173d20   _EDMA3_RM_freeResource
    80173c80   _EDMA3_RM_getBaseAddress
    80173c0c   _EDMA3_RM_getCCRegister
    80173a60   _EDMA3_RM_getPaRAM
    801738e0   _EDMA3_RM_getPaRAMPhyAddr
    801737a8   _EDMA3_RM_mapEdmaChannel
    80173644   _EDMA3_RM_mapQdmaChannel
    8017302c   _EDMA3_RM_open
    80172cd4   _EDMA3_RM_registerTccCb
    80172bf8   _EDMA3_RM_setCCRegister
    80172a50   _EDMA3_RM_setPaRAM
    8017292c   _EDMA3_RM_unregisterTccCb
    80172820   _EDMA3_RM_waitAndClearTcc
    00a9fee0   _EOL_FRONT
    00aa6300   _EOL_LEFT
    00aa41a0   _EOL_REAR
    00aa2040   _EOL_RIGHT
    0000000a   _EVENT10
    00000064   _EVENT100
    00000065   _EVENT101
    00000066   _EVENT102
    00000067   _EVENT103
    00000068   _EVENT104
    00000069   _EVENT105
    0000006a   _EVENT106
    0000006b   _EVENT107
    0000006c   _EVENT108
    0000006d   _EVENT109
    0000000b   _EVENT11
    0000006e   _EVENT110
    0000006f   _EVENT111
    00000070   _EVENT112
    00000071   _EVENT113
    00000072   _EVENT114
    00000073   _EVENT115
    00000074   _EVENT116
    00000075   _EVENT117
    00000076   _EVENT118
    00000077   _EVENT119
    0000000c   _EVENT12
    00000078   _EVENT120
    00000079   _EVENT121
    0000007a   _EVENT122
    0000007b   _EVENT123
    0000007c   _EVENT124
    0000007d   _EVENT125
    0000007e   _EVENT126
    0000007f   _EVENT127
    0000000d   _EVENT13
    0000000e   _EVENT14
    0000000f   _EVENT15
    00000010   _EVENT16
    00000011   _EVENT17
    00000012   _EVENT18
    00000013   _EVENT19
    00000014   _EVENT20
    00000015   _EVENT21
    00000016   _EVENT22
    00000017   _EVENT23
    00000018   _EVENT24
    00000019   _EVENT25
    0000001a   _EVENT26
    0000001b   _EVENT27
    0000001c   _EVENT28
    0000001d   _EVENT29
    0000001e   _EVENT30
    0000001f   _EVENT31
    00000020   _EVENT32
    00000021   _EVENT33
    00000022   _EVENT34
    00000023   _EVENT35
    00000024   _EVENT36
    00000025   _EVENT37
    00000026   _EVENT38
    00000027   _EVENT39
    00000004   _EVENT4
    00000028   _EVENT40
    00000029   _EVENT41
    0000002a   _EVENT42
    0000002b   _EVENT43
    0000002c   _EVENT44
    0000002d   _EVENT45
    0000002e   _EVENT46
    0000002f   _EVENT47
    00000030   _EVENT48
    00000031   _EVENT49
    00000005   _EVENT5
    00000032   _EVENT50
    00000033   _EVENT51
    00000034   _EVENT52
    00000035   _EVENT53
    00000036   _EVENT54
    00000037   _EVENT55
    00000038   _EVENT56
    00000039   _EVENT57
    0000003a   _EVENT58
    0000003b   _EVENT59
    00000006   _EVENT6
    0000003c   _EVENT60
    0000003d   _EVENT61
    0000003e   _EVENT62
    0000003f   _EVENT63
    00000040   _EVENT64
    00000041   _EVENT65
    00000042   _EVENT66
    00000043   _EVENT67
    00000044   _EVENT68
    00000045   _EVENT69
    00000007   _EVENT7
    00000046   _EVENT70
    00000047   _EVENT71
    00000048   _EVENT72
    00000049   _EVENT73
    0000004a   _EVENT74
    0000004b   _EVENT75
    0000004c   _EVENT76
    0000004d   _EVENT77
    0000004e   _EVENT78
    0000004f   _EVENT79
    00000008   _EVENT8
    00000050   _EVENT80
    00000051   _EVENT81
    00000052   _EVENT82
    00000053   _EVENT83
    00000054   _EVENT84
    00000055   _EVENT85
    00000056   _EVENT86
    00000057   _EVENT87
    00000058   _EVENT88
    00000059   _EVENT89
    00000009   _EVENT9
    0000005a   _EVENT90
    0000005b   _EVENT91
    0000005c   _EVENT92
    0000005d   _EVENT93
    0000005e   _EVENT94
    0000005f   _EVENT95
    00000060   _EVENT96
    00000061   _EVENT97
    00000062   _EVENT98
    00000063   _EVENT99
    80268d70   _EXC_clearLastStatus
    8026b1c0   _EXC_dispatch
    80268bf4   _EXC_exceptionHandler
    8027e0ac   _EXC_exceptionHook
    80268bc0   _EXC_external
    8027e0b4   _EXC_externalHook
    80268ba0   _EXC_getLastStatus
    80268b60   _EXC_init
    802688b4   _EXC_internal
    8027e0b0   _EXC_internalHook
    80268880   _EXC_nmi
    8027e0b8   _EXC_nmiHook
    8027df70   _EXC_returnPtr
    8026b384   _EXC_setReturnPtr
    00ac9424   _EXC_status
    8027df68   _EXC_sysTrapTable
    801b0268   _Edma3_CacheFlush
    801b0258   _Edma3_CacheInvalidate
    80188880   _EulerAnglesFromR
    801879a4   _ExtractRotTranFromH_K
    00a84280   _FULL_FRO
    00a863e0   _FULL_FRO_EXT
    00a873e0   _FULL_REA
    00a89540   _FULL_REA_EXT
    8026ec60   _FXN_F_nop
    8026e5c4   _FXN_F_run
    8026e600   _FXN_F_zero
    00000000   _GBL_CACHE
    8026cc04   _GBL_cacheInit64P
    8027dde4   _GBL_clkIn
    8027dde8   _GBL_freq
    8026ec80   _GBL_getVersion
    8027dde0   _GBL_procId
    8027dc0c   _GIO
    00ac94dc   _GIO_ATTRS
    80269da0   _GIO_create
    8026d120   _GIO_delete
    8027d7a0   _GIO_init
    8026bb00   _GIO_submit
    801b7e80   _HOSTclose
    801b65a0   _HOSTlseek
    801b6ba0   _HOSTopen
    801b71c0   _HOSTread
    801b4a00   _HOSTrename
    801b7280   _HOSTunlink
    801b7340   _HOSTwrite
    8027b000   _HSRTDX_rec
    8027b760   _HSRTDX_xmt
    1080d4b4   _HST_A_TABBEG
    1080d4f0   _HST_A_TABEND
    00ac9498   _HWI_ATTRS
    000078f8   _HWI_CFGDISPATCHED
    8027dfb0   _HWI_D_inhwi
    8027dfa4   _HWI_D_spsave
    80268da0   _HWI_F_dispatch
    0000000a   _HWI_INT10
    0000000b   _HWI_INT11
    0000000c   _HWI_INT12
    0000000d   _HWI_INT13
    0000000e   _HWI_INT14
    0000000f   _HWI_INT15
    00000004   _HWI_INT4
    00000005   _HWI_INT5
    00000006   _HWI_INT6
    00000007   _HWI_INT7
    00000008   _HWI_INT8
    00000009   _HWI_INT9
    00000001   _HWI_NMI
    00000002   _HWI_RESERVED0
    00000003   _HWI_RESERVED1
    00000000   _HWI_RESET
    80277ef8   _HWI_STKBOTTOM
    80277700   _HWI_STKTOP
    8027dfa4   _HWI_data
    8026e620   _HWI_disable
    8026dd60   _HWI_dispatchPlug
    8027dc40   _HWI_dispatchTab
    8026e638   _HWI_enable
    8026dde0   _HWI_eventMap
    8026e64c   _HWI_restore
    1080dd84   _IDL_busyObj
    1080cfac   _IDL_cpuLoad
    8026eca0   _IDL_loop
    8026ecc0   _IOM_mdNotImpl
    801adb20   _IPCLL_ui8_TreatRxMessage
    801adda0   _IPCLL_v_DetectBreakLevel
    801adc98   _IPCLL_v_DetectFrame
    801addd4   _IPCLL_v_GetVersion
    801adae8   _IPCLL_v_Init
    00ac8d58   _K
    8027deb0   _KNL_alarm
    8026ccc0   _KNL_check
    8027ded4   _KNL_curqueue
    8027dec4   _KNL_curtask
    8027decc   _KNL_curtime
    00ac89d0   _KNL_dummy
    8026d5e0   _KNL_enter
    8026d5a0   _KNL_exit
    8026cd88   _KNL_idle
    8027deec   _KNL_idlefxn
    8027deb8   _KNL_inactive
    8026de60   _KNL_ipost
    8026cdb0   _KNL_max
    8027ded8   _KNL_maxqueue
    8026dee0   _KNL_post
    8027dec8   _KNL_prevtask
    8027debc   _KNL_priority
    00ac8930   _KNL_queues
    8026a560   _KNL_run
    8026c500   _KNL_saveIsrFrame
    8027dec0   _KNL_set
    8027deb4   _KNL_setpri
    1080dd90   _KNL_swi
    8027ded0   _KNL_swiptr
    8026c5ac   _KNL_switch
    8027dee0   _KNL_tcreatefxn
    8027dee4   _KNL_tdeletefxn
    8026b56c   _KNL_tick
    8027dee8   _KNL_treadyfxn
    8027dedc   _KNL_tswitchfxn
    8027dea8   _KNL_wFlag
    8027deac   _KNL_wList
    ffffffff   _L1D_CACHE
    ffffffff   _L1D_RAM
    ffffffff   _L1P_CACHE
    ffffffff   _L2_CACHE
    ffffffff   _L2_RAM
    8026df80   _LCK_pend
    8026df60   _LCK_post
    8018b5b0   _LLC_mcaspActivateClkRcvXmt
    8018b4ec   _LLC_mcaspActivateRcvClkSer
    8018b40c   _LLC_mcaspActivateXmtClkSer
    8018b3dc   _LLC_mcaspClose
    8018b3c4   _LLC_mcaspConfigAudioMute
    8018b39c   _LLC_mcaspConfigGpio
    8018b04c   _LLC_mcaspConfigLoopBack
    8018ae80   _LLC_mcaspConfigRcvSection
    8018abc4   _LLC_mcaspConfigXmtSection
    8018a620   _LLC_mcaspGetHwStatus
    8018a2a4   _LLC_mcaspHwSetup
    8018a29c   _LLC_mcaspInit
    8018a1a8   _LLC_mcaspOpen
    8018a0e0   _LLC_mcaspRead
    80189fd0   _LLC_mcaspReadRcvConfig
    80189eb0   _LLC_mcaspReadXmtConfig
    80189d00   _LLC_mcaspRegReset
    80189c7c   _LLC_mcaspResetRcv
    80189c40   _LLC_mcaspResetSmFsRcv
    80189be8   _LLC_mcaspResetSmFsXmt
    80189b44   _LLC_mcaspResetXmt
    80189ac0   _LLC_mcaspSetDitMode
    80189968   _LLC_mcaspSetSerRcv
    80189814   _LLC_mcaspSetSerXmt
    8018974c   _LLC_mcaspWrite
    80189604   _LLC_mcaspWriteChanStatRam
    801894e0   _LLC_mcaspWriteUserDataRam
    1080cfb0   _LNK_dataPump
    8027dff0   _LNK_dspFrameReadyMask
    8027dfec   _LNK_dspFrameRequestMask
    8027dff8   _LNK_readDone
    8027dffc   _LNK_readFail
    8027dff4   _LNK_readPend
    8027e000   _LNK_writeFail
    801b6260   _LOAD_getcpuload
    801b6268   _LOAD_idlefxn
    801b6340   _LOAD_init
    1080e0c8   _LOG_A_TABBEG
    1080e158   _LOG_A_TABEND
    00000006   _LOG_A_TABLEN
    1080e140   _LOG_CamCtrl
    8027dd4c   _LOG_D_system
    1080e128   _LOG_MIC
    1080e110   _LOG_UART
    8026dfe0   _LOG_event
    8026ece0   _LOG_printf
    1080e0c8   _LOG_system
    801b32d8   _MAIN_userEarlyInit
    00ac2ee8   _MCASP_DRIVER_EDMA_FXNS
    801b0754   _MCASP_DRIVER_EDMA_INIT
    8019f3f8   _MCASP_IOM_init
    00aa86e8   _MCUVirtualCamPositions
    8027e210   _MEM
    00ab3d94   _MEM_ATTRS
    8027ddec   _MEM_D_NUMSEGMENTS
    8027ddf4   _MEM_D_freelist
    8027ddf8   _MEM_D_lockaddr
    8027ddf0   _MEM_D_memtab
    8027ddfc   _MEM_D_unlockaddr
    8026ae00   _MEM_alloc
    8026a7a0   _MEM_define
    8026b940   _MEM_free
    8027d620   _MEM_init
    8027d800   _MEM_memtab
    8026a9e0   _MEM_redefine
    8027e214   _MEM_staticMemtab
    8026cde0   _MEM_undefine
    8026e3e0   _MEM_valloc
    8027df9c   _MIRROR_STATUS
    8027e234   _MSGQ32
    80169910   _MSGQ32_ATTRS
    80169920   _MSGQ32_LOCATEASYNCATTRS
    8016991c   _MSGQ32_LOCATEATTRS
    8026d660   _MSGQ32_alloc
    00ac7c74   _MSGQ32_config
    8026e360   _MSGQ32_count
    8026ebc0   _MSGQ32_free
    8026d720   _MSGQ32_get
    8027d360   _MSGQ32_init
    8026c680   _MSGQ32_open
    8026db20   _MSGQ32_put
    8026edc0   _MSGQ32_setErrorHandler
    8026d220   _MSGQ32_startup
    801aae60   _MSGQ_userEarlyInit
    8027e17c   _MajorVersion
    00ac88e0   _McASP_IOM_FXNS
    00aa8670   _McASP_Tx_Msg
    8027e17d   _MinorVersion
    8026e060   _OBJ_create
    8026e6e0   _OBJ_delete
    8027d7c0   _OBJ_init
    00ac9038   _OBJ_segtab
    00ac9000   _OBJ_table
    801b5a90   _PAL_osCacheFlush
    801b5a24   _PAL_osCacheFlushAndInvalidate
    801b5a20   _PAL_osCacheGetCacheLineLength
    801b59a8   _PAL_osCacheInvalidate
    801b59a4   _PAL_osCacheSetCacheLineLength
    801b97a8   _PAL_osEvtDisable
    801b97a0   _PAL_osEvtEnable
    801a95d8   _PAL_osListAppend
    801a9244   _PAL_osListDequeue
    801a9550   _PAL_osListEnqueue
    801a94cc   _PAL_osListInsert
    801a9464   _PAL_osListIsEmpty
    801a93e0   _PAL_osListPrepend
    801a9334   _PAL_osListRemove
    801a92c8   _PAL_osListRemoveHead
    801a9210   _PAL_osList_NP_Append
    801a9040   _PAL_osList_NP_Dequeue
    801a91c8   _PAL_osList_NP_Enqueue
    801a9180   _PAL_osList_NP_Insert
    801a9164   _PAL_osList_NP_IsEmpty
    801a9110   _PAL_osList_NP_Prepend
    801a90ac   _PAL_osList_NP_Remove
    801a9084   _PAL_osList_NP_RemoveHead
    801b5378   _PAL_osMemAlloc
    801b532c   _PAL_osMemCopy
    801b5310   _PAL_osMemFree
    801b530c   _PAL_osMemInit
    801b5304   _PAL_osMemLock
    801b5300   _PAL_osMemPhy2Virt
    801b52f4   _PAL_osMemReport
    801b5280   _PAL_osMemSegDefine
    801b526c   _PAL_osMemSegUndefine
    801b522c   _PAL_osMemSet
    801b5224   _PAL_osMemUnlock
    801b5220   _PAL_osMemVirt2Phy
    801b8588   _PAL_osProtectEntry
    801b8560   _PAL_osProtectExit
    801b8640   _PAL_osSemCreate
    801b862c   _PAL_osSemDelete
    801b8618   _PAL_osSemGive
    801b8600   _PAL_osSemTake
    1080e000   _PIP_A_TABBEG
    1080e0c8   _PIP_A_TABEND
    8027e218   _POOL
    00ac7b78   _POOL_config
    8027d240   _POOL_init
    8027dd8c   _PRD_D_tick
    1080cf8c   _PRD_TriggerFrameWatchdog
    1080e158   _PRD_clock
    1080ddbc   _PRD_swi
    801a07f4   _PRD_triggerFrameWatchdog
    801b59a0   _PSP_cacheDrainWriteBuffer
    8016fb60   _PSP_mcaspAbortRequests
    8016e928   _PSP_mcaspClose
    80171b24   _PSP_mcaspCreate
    80171aa8   _PSP_mcaspDelete
    801717c0   _PSP_mcaspFlushRequests
    8016fc60   _PSP_mcaspIoctl
    8016f040   _PSP_mcaspOpen
    8016e6c0   _PSP_mcaspRead
    8016e64c   _PSP_mcaspWrite
    00ac3500   _ParamDataBuff
    00ac3900   _ParamDataBuffCompressed
    00ac1404   _QUE_ATTRS
    801eefe8   _QUE_McASPTxFrame
    801eefe0   _QUE_TxFrames_s
    801eefd8   _QUE_TxMessages_s
    8026eb00   _QUE_create
    801ade20   _QUE_drop
    8026eb40   _QUE_get
    801b86c0   _QUE_headq
    801b86a0   _QUE_newq
    801b870c   _QUE_nextq
    8026eb68   _QUE_put
    801b86d4   _QUE_removeq
    1080cfb4   _RTA_dispatcher
    1080d4b8   _RTA_fromHost
    1080d4d4   _RTA_toHost
    1080d040   _RTDX_Buffer
    1080d44c   _RTDX_Buffer_End
    8027bde0   _RTDX_Buffer_Initialize
    8027bf60   _RTDX_Buffer_Read
    8027bea0   _RTDX_Buffer_ReadCB
    8027bee0   _RTDX_Buffer_Size
    1080d448   _RTDX_Buffer_Start
    8027bf80   _RTDX_Buffer_Write
    8027b2a0   _RTDX_Buffer_WriteCB
    8027bd60   _RTDX_Final_RT_Monitor
    8027be40   _RTDX_Init_RT_Monitor
    00000002   _RTDX_JTAGONLY
    8027bfa0   _RTDX_Mask_IER
    8027ba60   _RTDX_Mon_Queue
    8027bcc0   _RTDX_Poll
    00000000   _RTDX_interrupt_mask
    8027bf20   _RTDX_memfill
    1080d4a0   _RTDX_writing
    1080c418   _SEM_APPInit
    00ac94e4   _SEM_ATTRS
    1080c8bc   _SEM_Cam_Read_Register
    1080c890   _SEM_Cam_Write_Register
    1080c9c4   _SEM_DiagnosticReq
    00ac90e4   _SEM_IPCInit
    1080c8e8   _SEM_McASP_CCDC_VSYNC
    1080c998   _SEM_McASP_DIAG_LUTS_STATUS_RDY
    1080c914   _SEM_McASP_PACKET_STATUS
    1080c940   _SEM_McASP_QDataReady
    1080c96c   _SEM_McASP_SIOInit
    1080c4c8   _SEM_RxFramesInFifo
    1080c520   _SEM_TxFramesFree
    1080c4f4   _SEM_TxMessagesInQueue
    8026e0e0   _SEM_create
    1080c2b8   _SEM_ctrl
    1080c2e4   _SEM_data
    8026ed00   _SEM_delete
    8026e7a0   _SEM_pend
    8026e740   _SEM_pendBinary
    8026ac00   _SEM_pendEnterKnl
    8026d320   _SEM_post
    8026d320   _SEM_postBinary
    8026d940   _SEM_postEnterKnl
    1080c470   _SEM_uart0
    1080c368   _SEM_uart0_send_fifo_empty
    1080c3c0   _SEM_uart0_send_tel_rdy
    1080c310   _SEM_uart0_sendbuf_empty
    1080c838   _SEM_uart0_tx_data_pending
    1080c49c   _SEM_uart1
    1080c394   _SEM_uart1_send_fifo_empty
    1080c3ec   _SEM_uart1_send_tel_rdy
    1080c33c   _SEM_uart1_sendbuf_empty
    1080c864   _SEM_uart1_tx_data_pending
    1080c28c   _SEM_videoConfigReady
    00ac93dc   _SIO_ATTRS
    80269aa0   _SIO_create
    8026b760   _SIO_delete
    8026dbc0   _SIO_issue
    8026d7e0   _SIO_reclaim
    801699e0   _STATICPOOL_FXNS
    00ac7b08   _STATICPOOL_LOG_FXNS
    801aacac   _STATICPOOL_LOG_alloc
    801aac78   _STATICPOOL_LOG_close
    801aacf4   _STATICPOOL_LOG_free
    801aac14   _STATICPOOL_LOG_init
    801aac34   _STATICPOOL_LOG_open
    1080dc00   _STS_A_TABBEG
    1080dd90   _STS_A_TABEND
    8026e82c   _STS_add
    8026e800   _STS_delta
    8026e848   _STS_reset
    8026ed20   _STS_set
    00ac9410   _SWI_ATTRS
    8027de24   _SWI_D_curfxn
    8027de14   _SWI_D_curmask
    8027de18   _SWI_D_curset
    8027de10   _SWI_D_execaddr
    8027de2c   _SWI_D_inswi
    8027de1c   _SWI_D_lock
    8027de28   _SWI_D_rdybeg
    8027de0c   _SWI_D_runaddr
    8026e160   _SWI_create
    8027de0c   _SWI_data
    802692f0   _SWI_post
    8026d9e0   _SWI_setattrs
    8027de00   _SYS
    1080da00   _SYS_PUTCBEG
    1080dbff   _SYS_PUTCEND
    8026e860   _SYS_abort
    8026e440   _SYS_error
    8026da80   _SYS_exit
    00ac9320   _SYS_exitStack
    8027e1c4   _SYS_exitStackPtr
    8027e1c8   _SYS_exitStackTop
    8026ed48   _SYS_one
    80268270   _SYS_printf
    80268244   _SYS_sprintf
    80268234   _SYS_vprintf
    80267e00   _SYS_vsprintf
    8026ed40   _SYS_zero
    00ac94bc   _SdfObject0
    8019e260   _Setup_Cache
    8019e900   _Setup_DDR_162_MHz
    8019e4cc   _Setup_PLL1_387_MHz_OscIn
    8019e4b8   _Setup_PLL1_594_MHz_OscIn
    8019e780   _Setup_PLL2_DDR_162_MHz_OscIn
    00ac9508   _SpiObject0
    8019b72c   _TASK_UART0_TX
    8019b898   _TASK_UART1_TX
    007e78b0   _TKernel_s8
    00a8a540   _TOP_FRO
    00a99c20   _TOP_FROZOO
    00a9bd80   _TOP_FROZOO_EXT
    00a8c6a0   _TOP_FRO_EXT
    00a8d6a0   _TOP_REA
    00a9cd80   _TOP_REAZOO
    00a9eee0   _TOP_REAZOO_EXT
    00a8f800   _TOP_REA_EXT
    00a96ac0   _TOP_SIDBAC
    00a98c20   _TOP_SIDBAC_EXT
    00a93960   _TOP_SIDFOR
    00a95ac0   _TOP_SIDFOR_EXT
    00a90800   _TOP_TRA
    00a92960   _TOP_TRA_EXT
    80277ff4   _TRC_R_mask
    8027e160   _TSK
    00ac8fa0   _TSK_ATTRS
    8027fac4   _TSK_App
    8027fa64   _TSK_DRAWLIB
    8027fdc4   _TSK_Diagnostic
    8027fca4   _TSK_FpgaCom_RX
    8027fd04   _TSK_FpgaCom_Tx
    8027fd64   _TSK_McASP
    8027fa04   _TSK_UART0_TX
    801b1d94   _TSK_VFW_algo
    8027f7c4   _TSK_VfwCapture
    8027f824   _TSK_VfwControl
    8027f944   _TSK_VfwConverterBE
    8027f9a4   _TSK_VfwDisplay
    8027f8e4   _TSK_VfwDistri
    8027f884   _TSK_VfwInit
    8027f6a4   _TSK_VideoAlgo
    8027f704   _TSK_VideoAlgoLow
    8027f764   _TSK_VideoAlgoMed
    8027fb84   _TSK_aAlgoCCF
    8027fc44   _TSK_aAlgoEC
    8026d400   _TSK_checkstacks
    00ac8fbc   _TSK_config
    8026e204   _TSK_disable
    8026e1e0   _TSK_enable
    8026c920   _TSK_exit
    8027f644   _TSK_idle
    8027d740   _TSK_init
    8027fb24   _TSK_mcuIPC_rx
    8027fbe4   _TSK_mcuIPC_tx
    8027e158   _TSK_nTasks
    8027e15c   _TSK_pid
    8026c040   _TSK_setup
    8026cfa4   _TSK_startup
    00ac8fdc   _TSK_timerSem
    801a29d4   _TSK_vfwCapture
    801a2d2c   _TSK_vfwControl
    801a7a74   _TSK_vfwConverterBE
    801a2c68   _TSK_vfwDisplay
    801a0884   _TSK_vfwDistribute
    8019b5b4   _UART_ui8_FIFOTransmit
    8019b004   _UART_v_ISR
    8019ac80   _UART_v_Init
    8019b924   _UART_v_NotifyTxDataPending
    8026ed60   _UTL_doError
    8026e8c0   _UTL_doPutc
    8026ed80   _UTL_halt
    801b1ca4   _VFW_AlgoDistributeCallback
    801b5b00   _VFW_AlgoFramePoolAlloc
    801b5b78   _VFW_AlgoFramePoolFree
    801b5c00   _VFW_AlgoFramePoolInit
    801b1bc0   _VFW_AlgoPriorityTask
    801ac58c   _VFW_BackEndEQReadFrame
    801ac560   _VFW_BackEndEQWriteEmptyFrame
    801ac618   _VFW_BackEndEQWriteFrame
    801ac6a4   _VFW_BackEndInit
    801a76c4   _VFW_ConvBackEndGetResults
    801a7ad0   _VFW_ConvExchangeOverlay
    801a7a58   _VFW_ConvFrontEndPutVMSG
    801a75e0   _VFW_ConvFrontEndStartConversion
    801a7420   _VFW_ConvGetResults
    801a7b6c   _VFW_ConvRequestOverlay
    801a4cb8   _VFW_Create
    801a6888   _VFW_FrontEndCCDCReadFrame
    801a64f4   _VFW_FrontEndCCDC_WriteFramePacket
    801a6878   _VFW_FrontEndInit
    801a4c70   _VFW_GetVFWHandle
    801a4bc0   _VFW_Initialize
    801ab524   _VFW_OverlayCleanUpOvl
    801ab100   _VFW_OverlayFramePoolAlloc
    801ab390   _VFW_OverlayFramePoolDefault
    801ab184   _VFW_OverlayFramePoolFree
    801ab2e8   _VFW_OverlayFramePoolInit
    801ab498   _VFW_OverlayGetOverlayState
    801ab3cc   _VFW_OverlayLockOverlayState
    801ab3b0   _VFW_OverlayLockOverlayStateIndefinite
    801ab418   _VFW_OverlaySetOverlayState
    801ab404   _VFW_OverlayUnLockOverlayState
    1080c444   _VFW_Overlay_SEM_OvlState
    801b640c   _VFW_SetupVFWTask
    801a5448   _VFW_StartVFW
    801a5404   _VFW_StartVIO
    801a0310   _VFW_VIOAllocVMSG
    801a03f0   _VFW_VIOBindVIOFrame
    801a0574   _VFW_VIOCloneVMSG
    801a0760   _VFW_VIOCreateVMF_VMSG
    8019ff00   _VFW_VIOCreateVMSG
    801a0174   _VFW_VIOFreeDataBlock
    801a0290   _VFW_VIOFreeVMSG
    801a0138   _VFW_VIOGetDataBlock
    801a008c   _VFW_VIOGetDataPointer
    801a006c   _VFW_VIOGetVIOFrame
    801a0864   _VFW_VIORestartWatchdog
    801a0710   _VFW_VIOStage1PutVMSG
    801a07b0   _VFW_VIOStage1SendVMF
    801a04ec   _VFW_VIOUnBindVIOFrame
    00ac9488   _VFW_VIO_VPSS_Config
    80169a10   _VFW_VIO_VPSS_FXNS
    801b35ec   _VFW_VPSSAlgoDistributeVMSG
    801a2a30   _VFW_VPSSInternalFreeFrameCCDC
    801a2a44   _VFW_VPSSInternalFreeFrameVPBE
    801a2d10   _VFW_VPSSInternalInitThreads
    801a2958   _VFW_VPSSInternalPrepareVideoBuffers
    801a2c10   _VFW_VPSSInternalPutVMSG
    801b3548   _VFW_VPSSSetupNextDatablockInVMSG
    801b8740   _VFW_VideoMsgSendCtrlMsg
    8019f4a0   _VFW_WrapperAPIAddActiveROIs
    8019f648   _VFW_WrapperAPICreate
    8019f56c   _VFW_WrapperAPIGetAlgoPtr
    8019f550   _VFW_WrapperAPIGetInfo
    8019fe50   _VFW_WrapperAPIInitModule
    8019f584   _VFW_WrapperAPISetStatus
    8019fae4   _VFW_WrapperAPIUpdate
    801adec8   _VFW_WrapperQUEAddElem
    801ae098   _VFW_WrapperQUECallPrioAlgos
    801adf30   _VFW_WrapperQUEDropNotMatchingFrameNum
    801ade38   _VFW_WrapperQUEInit
    801adfa8   _VFW_WrapperQUEMoveElemsWithEnoughLines
    801ae024   _VFW_WrapperQUEMoveElemsWithSamePrio
    801ae12c   _VFW_WrapperQUEPreFrameCallback
    80270b00   _VFW_algo_distri_prio0_MsgBuffer
    80271f00   _VFW_algo_distri_prio1_MsgBuffer
    80273300   _VFW_algo_distri_prio2_MsgBuffer
    00ac81b0   _VFW_s_ObjectCore
    8027e118   _VFW_u32_WatchdogMessageCirculating
    8026f700   _VFW_vio_distri_MsgBuffer
    00ac8814   _VPBEDrv_GlobalStr
    00ac92f8   _VPBE_FXN_TABLE
    8019d2e0   _VPBE_Isr
    8019d4c4   _VPBE_init
    8019d4c8   _VPBE_mdBindDev
    8019de94   _VPBE_mdControlChan
    8019d50c   _VPBE_mdCreateChan
    8019d8f8   _VPBE_mdDeleteChan
    8019dce4   _VPBE_mdSubmitChan
    8019d9c0   _VPBE_readChan
    8019db90   _VPBE_writeChan
    8027e045   _V_DIagMode_b
    00aa8998   _V_DiagTestLUTsResult
    00aa8518   _V_EOL_LUT_s
    8027e046   _V_FirstTimeCall_b
    8027e049   _V_Index_u8
    8027e047   _V_IsMcASPIdle
    8027e048   _V_LUTSentToFPGA
    00aa8460   _V_Luts_s
    00aa8684   _VariantCoding
    00ac5cfc   __BCACHE_emifAddr
    80280dd8   __CIOBUF_
    8026c350   __CLK_lat1beg
    8026c370   __CLK_lat1end
    8019f300   __DDA_McASP_RegisterInt
    8019f290   __DDA_McASP_UnRegisterInt
    8027e208   __DEV_D_NUMINITFXNS
    8027dc3c   __DEV_NUMINITFXNS
    8026dce0   __GIO_iomCallback
    8027de08   __HOOK_NUMHOOKS
    8027de04   __HOOK_knlId
    80268da0   __HWI_lat1beg
    80268f28   __HWI_lat1end
    80268f28   __HWI_lat2beg
    80269104   __HWI_lat2end1
    80269090   __HWI_lat2end2
    80269120   __HWI_lat3beg
    802690c0   __HWI_lat3end2
    8026e680   __IDL_lat1beg
    8026e6c0   __IDL_lat1end
    8026cd0c   __KNL_lat1beg
    8026cd88   __KNL_lat1end
    8026dfe0   __LOG_lat1beg
    8026eb40   __QUE_lat1beg
    8026eb60   __QUE_lat1end
    8026eb68   __QUE_lat2beg
    8026eb74   __QUE_lat2end
    8026a380   __RTA_lat1beg
    8026a3b4   __RTA_lat1end
    8026bcc0   __SEM_dopost
    00000800   __STACK_SIZE
    801b87e0   __STATICPOOL_alloc
    801b9600   __STATICPOOL_free
    801b7400   __STATICPOOL_open
    802693f8   __SWI_lat1beg
    802694a4   __SWI_lat1end
    802694a8   __SWI_lat2beg
    80269508   __SWI_lat2end
    80269280   __SWI_lat3beg
    802692ec   __SWI_lat3end
    00ac927c   __TSK_mutex
    00ac94b8   ___TI_enable_exit_profile_output
    ffffffff   ___TI_pprof_out_hndl
    ffffffff   ___TI_prof_data_size
    ffffffff   ___TI_prof_data_start
    801b9280   ___add_dtor
    00ac8028   ___atexit_func_id__
    ffffffff   ___binit__
    8027d800   ___bss__
    ffffffff   ___c_args__
    801b97e0   ___cinit__
    80004000   ___data__
    80004000   ___edata__
    8027e238   ___end__
    801b97e0   ___etext__
    801b92c0   ___isinf
    8026edf0   ___pinit__
    80169b60   ___text__
    801b2a40   __addd
    801af380   __addf
    8026c7e0   __auto_init
    801b9380   __call_stub
    801b74c0   __cleanup
    00ac94b0   __cleanup_ptr
    801b6c80   __cmpd
    801b8860   __cmpf
    801686b0   __ctypes_
    801b7f20   __cvtdf
    801b8ec0   __cvtfd
    801a5d00   __divd
    801aa700   __divf
    801b6d60   __divi
    801b7fc0   __divli
    801b7640   __divu
    801b4ba0   __divul
    801b20e0   __divull
    801b7700   __doflush
    00ac94b4   __dtors_ptr
    801b88e0   __fixdi
    801b81a0   __fixdli
    801b8960   __fixdu
    801b89e0   __fixfi
    801b8a60   __fixfu
    801b8f20   __fltid
    801b8f80   __fltif
    801b8ae0   __fltlid
    801b93c0   __fltud
    801b9400   __fltuf
    801b3920   __frcaddd
    801b66a0   __frcmpyd
    801b3f20   __frcmpyd_div
    801b8fe0   __frcmpyf
    801b8240   __frcmpyf_div
    00ac8020   __ft_end
    00ac7e90   __ftable
    801b8b60   __llshl
    801b9040   __llshru
    00ac94ec   __lock
    801b2340   __mpyd
    801b3b20   __mpyf
    801b9440   __negd
    801b9480   __negf
    801b9640   __negll
    801b9660   __nop
    801b68a0   __nround
    801b96c0   __pop_rts
    801ae5a0   __printfi
    801b96e0   __push_rts
    801b9700   __register_lock
    801b9720   __register_unlock
    801b77c0   __remi
    801b94c0   __remli
    801b8380   __remu
    801b8be0   __renormd
    801b6e40   __roundf
    80277700   __stack
    801b9500   __strasgi_64plus
    801b90a0   __subcull
    801b9540   __subd
    801b9580   __subf
    00ac7f80   __tmpnams
    801b9740   __trunc
    801b9760   __truncf
    00ac94f0   __unlock
    801b69a0   __wrt_ok
    80184e18   _aAPPMessageHandler_F_UpdateDiagnosticResult
    80184e60   _aAPPMessageHandler_ResetDiagMode
    80184d94   _aAPPMessageHandler_f_EOLViewSelect_v
    80184dc8   _aAPPMessageHandler_f_SetViewBeforeEOLCalled_v
    801905d0   _aAlgoCCF_ColourCorrection
    8027e124   _aAlgoCCF_CurrentMode_s32
    8018f2a0   _aAlgoCCF_F_Create_v
    80190558   _aAlgoCCF_F_TASK_v
    80190870   _aAlgoCCF_exposure_control
    80190510   _aAlgoCCF_f_VFWLinkInit_s
    8018fe48   _aAlgoCCF_f_setResultToZero
    8027e129   _aAlgoCCF_v_CurrentResultIndex_u8
    1080c7e0   _aAlgoCCF_v_ImgInUseSemaphore_s
    8027e128   _aAlgoCCF_v_OutIndex_u8
    1080c7b4   _aAlgoCCF_v_ProcessSemaphore_s
    1080c788   _aAlgoCCF_v_TskSemaphore_s
    1080c730   _aAlgoCCF_v_WaitForProcessSemaphore_s
    1080c75c   _aAlgoCCF_v_WaitForVFWCallbackSemaphore_s
    8027e1b4   _aAlgoDDE_CurrentMode_s32
    8017f7c0   _aAlgoDDE_F_Create_v
    00a83d78   _aAlgoDDE_v_PictData_as
    8027e1a0   _aAlgoEC_CurrentMode_s32
    80194d80   _aAlgoEC_F_Create_v
    80195c84   _aAlgoEC_F_TASK_v
    80195c38   _aAlgoEC_f_VFWLinkInit_s
    80195960   _aAlgoEC_f_setResultToZero
    009def40   _aAlgoEC_v_CamResultSet_as
    1080ca1c   _aAlgoEC_v_CaptureImgSemaphore_s
    8027e1a6   _aAlgoEC_v_CurrentResultIndex_u8
    009df0a0   _aAlgoEC_v_ImageBuffer
    1080c704   _aAlgoEC_v_ImgInUseSemaphore_s
    8027e1a7   _aAlgoEC_v_LastResultIndex_u8
    8027e1a5   _aAlgoEC_v_OutIndex_u8
    1080c6d8   _aAlgoEC_v_ProcessSemaphore_s
    009df078   _aAlgoEC_v_TargetDataData_s
    009df068   _aAlgoEC_v_TargetDataHeader_s
    009df07c   _aAlgoEC_v_TargetDataSetId_s
    009df054   _aAlgoEC_v_TargetDataSet_s
    009df000   _aAlgoEC_v_TargetData_s
    8027e1a4   _aAlgoEC_v_TrippleBufIdx_u8
    1080c6ac   _aAlgoEC_v_TskSemaphore_s
    1080c654   _aAlgoEC_v_WaitForProcessSemaphore_s
    1080c680   _aAlgoEC_v_WaitForVFWCallbackSemaphore_s
    00a5d9a0   _aAlgoEC_v_inputTargetPos_s
    8027e1f4   _aAlgoGT_CurrentMode_s32
    801a30a0   _aAlgoGT_F_Create_v
    00ac5d00   _aAlgoGT_V_SingleView_s
    8027df66   _aAlgoMAP_V_ExtLutSze_u16
    8027df64   _aAlgoMAP_V_StdLutSze_u16
    80197b20   _aAlgo_f_CalcDetMat3x3_f32
    80197c68   _aAlgo_f_CalcInvMat3x3_v
    80197ef4   _aAlgo_f_CalcMulMat3x3_3x3_v
    801a8d6c   _aAppAlgocontrol_F_CloseNormalOpAlgos_u1
    801a89c0   _aAppAlgocontrol_F_InitNormalOpAlgos_v
    801a8f58   _aAppAlgocontrol_F_NormalOpAlgosClosed_u1
    801a8fb0   _aAppAlgocontrol_F_RequestAlgoResult_v
    801a8b34   _aAppAlgocontrol_F_StartNormalOpAlgos_u1
    1080c628   _aAppAlgocontrol_v_CCFOpenCloseSemaphore_s
    1080c5a4   _aAppAlgocontrol_v_DDEOpenCloseSemaphore_s
    1080c5d0   _aAppAlgocontrol_v_ECOpenCloseSemaphore_s
    1080c5fc   _aAppAlgocontrol_v_GTOpenCloseSemaphore_s
    801ad8a8   _aAppEolcontrol_F_CloseEOL_v
    801ad8f8   _aAppEolcontrol_F_EOLClosed_u1
    801ada54   _aAppEolcontrol_F_EOLFinished_u1
    801ada28   _aAppEolcontrol_F_GetResult_u8
    801ad924   _aAppEolcontrol_F_Parameterize_v
    801ad9b4   _aAppEolcontrol_F_ProcessEol_v
    801ad738   _aAppEolcontrol_F_StartEOL_u1
    801b8de0   _aAppMessageSender_F_SendMessage_v
    801841f8   _aAppMessagehandler_f_ReceiveMCU_ALGO_LEARN_DATA_u1
    801834e8   _aAppMessagehandler_f_ReceiveMCU_BOOT_u1
    801841d4   _aAppMessagehandler_f_ReceiveMCU_CAM_INTRINSIC_DATA_u1
    80184ab8   _aAppMessagehandler_f_ReceiveMCU_DIAG_REQ_Abort_u1
    80184c40   _aAppMessagehandler_f_ReceiveMCU_DIAG_REQ_Data_u1
    80184b68   _aAppMessagehandler_f_ReceiveMCU_DIAG_REQ_Status_u1
    80184994   _aAppMessagehandler_f_ReceiveMCU_DIAG_REQ_u1
    8018418c   _aAppMessagehandler_f_ReceiveMCU_EOL_DATA_u1
    80184944   _aAppMessagehandler_f_ReceiveMCU_EOL_TARGETS_u1
    801841b0   _aAppMessagehandler_f_ReceiveMCU_OC_DATA_u1
    80183f04   _aAppMessagehandler_f_ReceiveMCU_REQ_DATA_u1
    80183fd0   _aAppMessagehandler_f_ReceiveMCU_REQ_STATE_u1
    80184220   _aAppMessagehandler_f_ReceiveMCU_VARIANT_CODING_u1
    801835f4   _aAppMessagehandler_f_ReceiveMCU_VEHICLE_STATE_u1
    80184070   _aAppMessagehandler_f_ReceiveMCU_VIEW_SELECT_u1
    80184d60   _aAppMessagehandler_f_ReceiveMCU_VIRTUAL_CAM_POSITIONS_u1
    80182b40   _aAppMessagehandler_f_SendDSP_BOOT_u1
    00aa8580   _aAppMessagehandler_v_EOLResultData_au8
    801aa1e0   _aAppMessagereceiver_F_InitRxBufQueue_v
    801aa3d8   _aAppMessagereceiver_F_ProcessMessages_v
    801aa220   _aAppMessagereceiver_F_ReceiveMessage_v
    80198140   _aAppStatehandler_F_RequestStateChange_u1
    80198800   _aAppStatehandler_F_RequestStateTransition_u1
    80198788   _aAppStatehandler_F_getApplicationState_e
    80198120   _aAppStatehandler_F_initApplicationState_v
    80199030   _aAppStatehandler_F_reportStateToMCU_v
    1080c578   _aAppStatehandler_v_ModeSemaphore_s
    801a82c0   _aApp_F_Drawlibcallback_v
    80182d00   _aApp_F_IPCRxErrorCallback_v
    801a8730   _aApp_F_Init_v
    801a8324   _aApp_F_MainTask_v
    00ac8748   _aApp_V_BootMessageData_au8
    00ac8714   _aApp_V_CCFAlgoInterface_s
    00ac8678   _aApp_V_DDEAlgoInterface_s
    00ac86ac   _aApp_V_ECAlgoInterface_s
    8027df40   _aApp_V_EOLCalibReceived_u1
    8027df41   _aApp_V_EOLCalibRequestCounter_u8
    8027df42   _aApp_V_EOLCalibRequestMAX_u8
    00ac86e0   _aApp_V_GTAlgoInterface_s
    8027df38   _aApp_V_InternalDisplayMode_e
    00aa8610   _aApp_V_RepAlgoData_au8
    00ac8758   _aApp_V_RepModeData_au8
    8027df3c   _aApp_V_RequestedDisplayMode_e
    8027e13c   _aApp_V_StopEOL_u1
    00ac7748   _aApp_V_VehicleStateCpy_s
    00ac784c   _aApp_V_VehicleState_Cpy_s
    00ac7838   _aApp_V_VehicleState_s
    00aa8650   _aApp_V_camStatus_s
    8027df5c   _aApp_V_ccfResultSize_s32
    8027df60   _aApp_V_ccfResult_ps
    8027df44   _aApp_V_ddeResultSize_s32
    8027df48   _aApp_V_ddeResult_ps
    8027df4c   _aApp_V_ecResultSize_s32
    8027df50   _aApp_V_ecResult_ps
    8027df54   _aApp_V_gtResultSize_s32
    8027df58   _aApp_V_gtResult_ps
    1080c80c   _aApp_v_SleepSemaphore_s
    80199f00   _aCornerDetect_F_mainDetector_s8
    801a0960   _aEoLC_F_MainCalc_s8
    801871c0   _aEuler_F_mainCalc_s8
    8018b6e0   _aExtrema_F_InitCandidates_s8
    80199104   _aGraph_F_BuildNeighborGraph_v
    80199300   _aGraph_F_CheckBiDirection_v
    801994a4   _aGraph_F_FilterCircles_v
    80199040   _aGraph_F_InitialNeighboGraph_pt
    801998ac   _aGraph_F_RemoveExceptionLink_v
    80199c08   _aGraph_F_getNeighborIndx
    80199b8c   _aGraph_F_isEmptyNeighbor_s8
    80192648   _aLComp_F_checkSingleCorner_s8
    80192360   _aLComp_F_countEachComponent_v
    80192778   _aLComp_F_regSubpixels_s8
    80192524   _aLComp_F_seeComplete_s8
    80190c20   _aSaddle_F_luccheseAll_v
    00ac7644   _aState_v_VehicleStateIf_s
    1080c54c   _aState_v_stateRWSemaphore_s
    00ac2ee0   _appDevParams
    801b25a0   _asin
    801b3d20   _asinf
    801b1680   _atan
    801b56e0   _atanf
    801b7880   _atexit
    801b6f20   _atoi
    00ac92d0   _aui8_sendbuf_uart0
    00ac92e0   _aui8_sendbuf_uart1
    008e2598   _av_CanPos_pt
    00015970   _buffer
    8027d560   _c_int00
    801882f0   _calcDetMat3x3_d32
    80188438   _calcInvMat3x3_v
    801886cc   _calcMultiplyMatrixes
    80188140   _calcTransVector_v
    801b6aa0   _call_dtors
    8026a278   _calloc
    8027e058   _ccErrorInt
    8027e054   _ccXferCompInt
    801963f8   _check_for_ack_or_nack
    801b7000   _close
    80184254   _copy_data_to_EC
    801ad2e0   _cos
    801b0e40   _cosf
    801b42e0   _crc16_ccitt
    8027e11c   _current_exposure
    8027e120   _current_gain
    00ac8da0   _d_ang
    00ac7008   _defInstInitConfig
    8027e0d8   _dspCtrlQ
    00ac8464   _dtors
    801a9de8   _eCAM_F_activateAecAgc_v
    801a9da8   _eCAM_F_deactivateAecAgc_v
    801a9ca0   _eCAM_F_disableTestImage_v
    801a9c60   _eCAM_F_enableTestImage_v
    801a9d74   _eCAM_F_getCOM8Status_u1
    801a9f48   _eCAM_F_getExposureTime_v
    801aa008   _eCAM_F_getGainValue_v
    801a9ce0   _eCAM_F_isTestImageEnabled_u1
    801aa08c   _eCAM_F_readRegister_u1
    801a9e54   _eCAM_F_setExposureTimeHi_v
    801a9e28   _eCAM_F_setExposureTimeLo_v
    801a9e84   _eCAM_F_setExposureTime_v
    801aa04c   _eCAM_F_setGain_v
    801a9d10   _eCAM_F_setVerticalFlip_v
    801a9d44   _eCAM_F_unsetVerticalFlip_v
    801aa0d0   _eCAM_F_writeRegister_u1
    8027e04b   _eCAM_v_ReadValue
    801aa12c   _eCam_F_CamReplyHandler_v
    801a3ac8   _eDIAG_F_DiagAbort_e
    801a4184   _eDIAG_F_GetDiagState
    801a41ac   _eDIAG_F_ResetActiveServices
    801a39c0   _eDIAG_F_SetDiagMode_v
    801a418c   _eDIAG_F_SetDiagState
    801a3d60   _eDiagnostic_F_Task_v
    8019ca64   _eFpgaCom_CmdLevel_F_CamReplyHandler_v
    8019cacc   _eFpgaCom_CmdLevel_F_FpgaReplyHandler_v
    8019c7ec   _eFpgaCom_CmdLevel_F_GetCacheValues_u8
    8019c660   _eFpgaCom_CmdLevel_F_Init_v
    8019ca84   _eFpgaCom_CmdLevel_F_McAspReplyHandler_v
    8019c8d0   _eFpgaCom_CmdLevel_F_ProcessCommand_u8
    8019c98c   _eFpgaCom_CmdLevel_F_SendCamMessage_u8
    8019c9e4   _eFpgaCom_CmdLevel_F_SetCacheValues_v
    8019c970   _eFpgaCom_CmdLevel_F_TickTimeoutTimer_v
    8019cba4   _eFpgaCom_CmdLevel_F_TreatError_v
    801b1ac4   _eFpgaCom_F_ClearCamStatus_u8
    801b1ab4   _eFpgaCom_F_ClearGlobalStatus_u8
    801b19e0   _eFpgaCom_F_EnableTestImage_u8
    801b1a00   _eFpgaCom_F_EnableTransformationEngine_u8
    801b1a90   _eFpgaCom_F_GetCachedCamStatusBits_u8
    801b1aa4   _eFpgaCom_F_GetCachedCamStatus_u8
    801b1a6c   _eFpgaCom_F_GetCachedFpgaVersion_u8
    801b1a80   _eFpgaCom_F_GetCachedGlobalStatus_u8
    801b1980   _eFpgaCom_F_GetCamStatusBits_u8
    801b1990   _eFpgaCom_F_GetCamStatus_u8
    801b1958   _eFpgaCom_F_GetFpgaVersion_u8
    801b196c   _eFpgaCom_F_GetGlobalStatus_u8
    801b1920   _eFpgaCom_F_Init_v
    801b1a60   _eFpgaCom_F_LVDS_OUT_Off_u8
    801b19b4   _eFpgaCom_F_LatchRegisters_u8
    801b1b60   _eFpgaCom_F_ReadyToSend_v
    801b1b6c   _eFpgaCom_F_ReceivedDataByte_v
    801b1b8c   _eFpgaCom_F_RxTask_v
    801b1b38   _eFpgaCom_F_SendCamMessage_u8
    801b1af0   _eFpgaCom_F_SetBackgroundColor_u8
    801b1b04   _eFpgaCom_F_SetBrightnessCorrection_u8
    801b1b4c   _eFpgaCom_F_SetCacheValues_v
    801b19c4   _eFpgaCom_F_SetHighFrameRate_u8
    801b1b14   _eFpgaCom_F_SetHistogram_u8
    801b19d0   _eFpgaCom_F_SetLowFrameRate_u8
    801b1ad0   _eFpgaCom_F_SetSidebandChannelSelection_u8
    801b19a4   _eFpgaCom_F_StartRamTest_u8
    801b1a40   _eFpgaCom_F_SwitchOffCams_u8
    801b1a20   _eFpgaCom_F_SwitchOnCams_u8
    801b194c   _eFpgaCom_F_TickTimeoutTimer_v
    801b1ba0   _eFpgaCom_F_TxTask_v
    80194138   _eFpgaCom_HighLevel_F_BlankOffAllCams_u8
    80193f30   _eFpgaCom_HighLevel_F_BlankOffCams_u8
    801940cc   _eFpgaCom_HighLevel_F_BlankOnAllCams_u8
    80194000   _eFpgaCom_HighLevel_F_BlankOnCams_u8
    80194688   _eFpgaCom_HighLevel_F_ClearCamStatus_u8
    8019464c   _eFpgaCom_HighLevel_F_ClearGlobalStatus_u8
    80193d88   _eFpgaCom_HighLevel_F_EnableTestImage_u8
    80193df4   _eFpgaCom_HighLevel_F_EnableTransformationEngine_u8
    8019442c   _eFpgaCom_HighLevel_F_GetCachedCamStatusBits_u8
    80194490   _eFpgaCom_HighLevel_F_GetCachedCamStatus_u8
    801942ec   _eFpgaCom_HighLevel_F_GetCachedFpgaVersion_u8
    80194384   _eFpgaCom_HighLevel_F_GetCachedGlobalStatus_u8
    80193a8c   _eFpgaCom_HighLevel_F_GetCamStatusBits_u8
    801946c8   _eFpgaCom_HighLevel_F_GetCamStatusLive_u8
    80193aec   _eFpgaCom_HighLevel_F_GetCamStatus_u8
    80193964   _eFpgaCom_HighLevel_F_GetFpgaVersion_u8
    801939ec   _eFpgaCom_HighLevel_F_GetGlobalStatus_u8
    80193960   _eFpgaCom_HighLevel_F_Init_v
    80194284   _eFpgaCom_HighLevel_F_LVDS_OUT_Off_u8
    80193cd4   _eFpgaCom_HighLevel_F_LatchRegisters_u8
    80194af8   _eFpgaCom_HighLevel_F_SetBackgroundColor_u8
    80194b78   _eFpgaCom_HighLevel_F_SetBrightnessCorrection_u8
    80194214   _eFpgaCom_HighLevel_F_SetGrayFuncOff_u8
    801941a8   _eFpgaCom_HighLevel_F_SetGrayFuncOn_u8
    80193d10   _eFpgaCom_HighLevel_F_SetHighFrameRate_u8
    80194c14   _eFpgaCom_HighLevel_F_SetHistogram_u8
    80193d4c   _eFpgaCom_HighLevel_F_SetLowFrameRate_u8
    80194a88   _eFpgaCom_HighLevel_F_SetSidebandChannelSelection_u8
    80193cb0   _eFpgaCom_HighLevel_F_StartRamTest_u8
    80193ecc   _eFpgaCom_HighLevel_F_SwitchOffCams_u8
    80193e68   _eFpgaCom_HighLevel_F_SwitchOnCams_u8
    801ad038   _eFpgaCom_LowLevel_F_DiscardPendingRequests_v
    801ad024   _eFpgaCom_LowLevel_F_FlushRequests_v
    801acf00   _eFpgaCom_LowLevel_F_Init_v
    801acfd8   _eFpgaCom_LowLevel_F_ReadyToSend_v
    801ad098   _eFpgaCom_LowLevel_F_ReceivedDataByte_v
    801ad154   _eFpgaCom_LowLevel_F_RxTask_v
    801acff0   _eFpgaCom_LowLevel_F_SendRequest_v
    801ad060   _eFpgaCom_LowLevel_F_TxTask_v
    801a9784   _eFpgaCom_MsgLevel_F_EnableErrorMode_v
    801a96cc   _eFpgaCom_MsgLevel_F_FlushRequests_v
    801a9660   _eFpgaCom_MsgLevel_F_Init_v
    801a96d8   _eFpgaCom_MsgLevel_F_ReplyHandler_v
    801a96a8   _eFpgaCom_MsgLevel_F_SendCamRequest_v
    801a96b8   _eFpgaCom_MsgLevel_F_SendFpgaRequest_v
    801af1a0   _eFpgaCom_RingBuffer_F_GetFrontSlice_pau8
    801af040   _eFpgaCom_RingBuffer_F_Init_v
    801af1ec   _eFpgaCom_RingBuffer_F_IsBackSliceComplete_u1
    801af1d4   _eFpgaCom_RingBuffer_F_PopFrontSlice_v
    801af214   _eFpgaCom_RingBuffer_F_PopIncompleteBackSlice_v
    801af0c0   _eFpgaCom_RingBuffer_F_PushBackByte_u1
    801af114   _eFpgaCom_RingBuffer_F_PushBackSlice_u1
    801af0a8   _eFpgaCom_RingBuffer_F_UnusedBytes_u32
    801af304   _eFpgaCom_RingBuffer_f_MoveReadIndex_v
    801af298   _eFpgaCom_RingBuffer_f_MoveWriteIndex_v
    801af278   _eFpgaCom_RingBuffer_f_ReadPos_pau8
    801af258   _eFpgaCom_RingBuffer_f_WritePos_pau8
    801b7d68   _eFpgaCom_RxBuffer_F_GetFrontFrame_pau8
    801b7d00   _eFpgaCom_RxBuffer_F_Init_v
    801b7d94   _eFpgaCom_RxBuffer_F_IsBackFrameComplete_u1
    801b7d50   _eFpgaCom_RxBuffer_F_PopFrontFrame_v
    801b7d80   _eFpgaCom_RxBuffer_F_PopIncompleteBackFrame_v
    801b7d28   _eFpgaCom_RxBuffer_F_PushBackByte_u1
    801b5fc4   _eFpgaCom_TxBuffer_F_GetFrameCount_u32
    801b5fac   _eFpgaCom_TxBuffer_F_GetFrontFrame_pau8
    801b5ee0   _eFpgaCom_TxBuffer_F_Init_v
    801b5f84   _eFpgaCom_TxBuffer_F_PopFrontFrame_v
    801b5f34   _eFpgaCom_TxBuffer_F_PushBackFrame_v
    801b7e0c   _eIPC_F_GetNextTxFrame_v
    801b7dc0   _eIPC_F_Init_v
    801b7e44   _eIPC_F_ReceivedBreak_v
    801b7e24   _eIPC_F_ReceivedDataByte_v
    801b7e50   _eIPC_F_RxTask_v
    801b7de4   _eIPC_F_SendMessage_u8
    801b7e60   _eIPC_F_TxTask_v
    801a70cc   _eIPC_Protocol_F_BuildCancelFrame_v
    801a7090   _eIPC_Protocol_F_BuildMultiFrame_v
    801a7058   _eIPC_Protocol_F_BuildSingleFrame_v
    801a6d50   _eIPC_Protocol_F_DoesFrameNumberMatch_u1
    801a6c80   _eIPC_Protocol_F_GetFrameBody_pau8
    801a7008   _eIPC_Protocol_F_GetFrameCount_u32
    801a6d04   _eIPC_Protocol_F_GetFrameId_u8
    801a6c94   _eIPC_Protocol_F_GetMessageId_u16
    801a6d24   _eIPC_Protocol_F_GetTotalLength_u32
    801a6de8   _eIPC_Protocol_F_IsCancelFrame_u1
    801a6cc4   _eIPC_Protocol_F_IsChecksumCorrect_u1
    801a6dc0   _eIPC_Protocol_F_IsConsecutiveFrame_u1
    801a6d94   _eIPC_Protocol_F_IsFirstFrame_u1
    801a6fd4   _eIPC_Protocol_F_IsMultiFrameMessageId_u1
    801a6fa4   _eIPC_Protocol_F_IsSingleFrameMessageId_u1
    801a6e10   _eIPC_Protocol_F_IsValidRxMessageId_u1
    801a6ee8   _eIPC_Protocol_F_IsValidTxMessageId_u1
    801a5480   _eIPC_RxMultiFrame_F_Init_v
    801a54b4   _eIPC_RxMultiFrame_F_TreatFrame_v
    801ac940   _eIPC_RxMultiFrame_f_GetAttributes_p
    00ac8588   _eIPC_RxMultiFrame_v_GlobalAttributes_a
    801ac7c8   _eIPC_Rx_F_BuildMessage_v
    801ac840   _eIPC_Rx_F_DispatchLowLevelError_v
    801ac700   _eIPC_Rx_F_Init_v
    801ac7b8   _eIPC_Rx_F_ReceivedBreak_v
    801ac798   _eIPC_Rx_F_ReceivedDataByte_v
    801ac8c0   _eIPC_Rx_F_Task_v
    801ab6b4   _eIPC_Tx_F_GetNextTxFrame_v
    801ab5a0   _eIPC_Tx_F_Init_v
    801ab610   _eIPC_Tx_F_SendMessage_u8
    801ab714   _eIPC_Tx_F_Task_v
    80197054   _eMcASP_F_DiagEnterMode_b
    80197074   _eMcASP_F_DiagExitMode_b
    80197098   _eMcASP_F_DiagRetrieveResult_e
    80197148   _eMcASP_F_IsLUTSentToFPGA_b
    80196214   _eMcASP_F_Release_CCDC_VSYNC_v
    8019624c   _eMcASP_F_Task_v
    8019631c   _eMcASP_F_TxData_b
    801961a4   _eMcASP_F_UpdatePacketStatus_v
    00ac6d30   _edma3GblCfgParams
    801727e0   _edma3MemCpy
    801727b4   _edma3MemSet
    8027e134   _edma3NumPaRAMSets
    801b0158   _edma3OsProtectEntry
    801b00d4   _edma3OsProtectExit
    801b0078   _edma3OsSemCreate
    801b0040   _edma3OsSemDelete
    801b0004   _edma3OsSemGive
    801affc4   _edma3OsSemTake
    801aff80   _edma3OsWaitMsecs
    801b050c   _edma3deinit
    8019c238   _edma3fw_configure
    10800000   _edma3fw_dst_chunk_buffer
    8019c18c   _edma3fw_execute
    8019b980   _edma3fw_init
    1080e180   _edma3fw_startDstChunkTransfer
    801b03a0   _edma3init
    801a1a44   _edma3init_BurstReOrder
    801a1af8   _edma3init_with_encoder
    801ae978   _edma3memset
    801ae940   _edma3utils_init
    00ac7c8c   _errno
    8018be78   _f_BiVariantAppr_v
    801a1240   _f_Calibrate_v
    8018b800   _f_CleanCandidates_v
    8018ccd0   _f_CleanKeepSub_v
    8018d2b4   _f_ConvNorm_v
    80193218   _f_CountOneDir_u32
    8018c830   _f_ExtractbyCol_pf32
    8018c608   _f_ExtractbyRow_pf32
    8018c504   _f_FindInitialCandidates_u32
    80193314   _f_FindMaxComponent_v
    8018cf68   _f_FitParabolas2D_t
    8019372c   _f_GridRowCol2_s8
    801937c8   _f_GridRowCol_s8
    801932c0   _f_LocateMaxPoints_v
    8018c414   _f_MathRound_u16
    8018c314   _f_MatrixDeterminant_f32
    801970e4   _f_McASP_SetIdleState
    80197114   _f_McASP_SetStartState
    8018b924   _f_NeighborExtrema_v
    8018bf38   _f_QuadraticRegression_v
    8018ca54   _f_RegisterSubpixel_v
    80193860   _f_Round_u16
    80192268   _f_aRound_u16
    8019154c   _f_backsubs1_v
    8019a114   _f_buildNeighborList_v
    80188990   _f_calcGroundTruthGrid_u16
    80192e84   _f_calcPointsbyRim_v
    80188b84   _f_calculateGroundTruth_u16
    80193508   _f_checkPartialDir_v
    801913c8   _f_copy6x6_v
    8019a32c   _f_corrLensMap_v
    80192a28   _f_countOneCorner_s8
    80187744   _f_createProjectionMatrix_v
    80187364   _f_createRotationMatrix_v
    801914ac   _f_fill6x1_v
    8019a218   _f_findLargestComponent_s8
    80199e18   _f_getAllDirection_v
    80190ccc   _f_getBlockMatrix_v
    80190df8   _f_getCoefficients_v
    8019ab68   _f_getCornerRes_v
    80199ca4   _f_getDirection_v
    801930e0   _f_getDirections_v
    8018d1e8   _f_getDistance_f32
    80199c54   _f_getNeighborLen_f32
    80191100   _f_getOffset2_v
    8019a890   _f_getPolyVal_f32
    80193664   _f_getSeedNr_s8
    801a0ef8   _f_getTargetPos_v
    8018be34   _f_inRange_u8
    80191308   _f_inv6x6_v
    8018ba14   _f_isCandidate_s8
    80191e98   _f_luComp1_su16
    80191294   _f_lucchese1Pix_v
    80192c10   _f_markOneCandidate_s8
    80187074   _f_max_d32
    80187130   _f_min_u8
    80191d58   _f_mult6x11x1_v
    80191bf4   _f_mult6x11x6_v
    80191944   _f_mult6x6x11_v
    80191aac   _f_mult6x6x1_v
    801a11a4   _f_padImage_v
    80189320   _f_pruneCorners_u8
    80199dd0   _f_removeNeighborInfo_v
    80193384   _f_removePartialDir_v
    80188f78   _f_setDefaultPara
    801870c8   _f_sign_d32
    8019a988   _f_sortCorners_v
    80187174   _f_square_d32
    80191880   _f_transpose11x6_t
    80192920   _f_validateCorners_s8
    801b6140   _fclose
    801b9100   _floor
    801b5c60   _fputc
    801afc80   _fputs
    8026a040   _free
    801b4ee0   _frexp
    801b5840   _frexpf
    801b7940   _fseek
    8027e184   _g_newthread_s
    8027e180   _g_oldthread_s
    8027e1d4   _hEdma
    80280f04   _hRxAppBuf
    80280f2c   _hRxAppBufMulFrame
    801eefd0   _hRxBufQueue
    8027e10c   _hVFW_for_PRD_tFWD
    8027e05c   _hwInt
    00ab2d48   _i_ExtLut_pau64
    00ab0be8   _i_StdLut_pau32
    801aaf54   _initQueues
    801b4680   _ldexp
    801b5560   _ldexpf
    801727a4   _lisrEdma3CCErrHandler0
    801722d0   _lisrEdma3ComplHandler0
    801720a0   _lisrEdma3TC0ErrHandler0
    8017208c   _lisrEdma3TC1ErrHandler0
    80172078   _lisrEdma3TC2ErrHandler0
    80172068   _lisrEdma3TC3ErrHandler0
    80172054   _lisrEdma3TC4ErrHandler0
    80172044   _lisrEdma3TC5ErrHandler0
    80172030   _lisrEdma3TC6ErrHandler0
    80172020   _lisrEdma3TC7ErrHandler0
    8019e4e0   _loop_for_n_times
    801b7a00   _lseek
    801b7ac0   _ltoa
    00abfd38   _m_twist
    801b3324   _main
    8026a068   _malloc
    00ac2eb8   _mcaspXmtSetup
    8026a198   _memalign
    801b9160   _memccpy
    801b84c0   _memcpy
    801b70e0   _memset
    801b7b80   _modf
    801b91c0   _modff
    801b32f8   _myExit
    8027e04c   _numEdma3EvtQue
    8027e050   _numEdma3Tc
    801b53c0   _pPrj_Buf_F_Alloc_p
    801b54f8   _pPrj_Buf_F_CheckPoolSettings_u1
    801b53f8   _pPrj_Buf_F_Free_v
    801b54b0   _pPrj_Buf_F_GetBufferSize_u32
    801b5468   _pPrj_Buf_F_GetFreeBufferCount_u32
    801b5420   _pPrj_Buf_F_GetPoolCapacity_u32
    801a1dc0   _pow
    801b8c60   _printf
    8019e90c   _psc_change_state
    00ac9340   _ptrEdma3TcIsrHandler
    801b5c60   _putc
    80186910   _pythag
    801b8ce0   _readmsg
    8026a0cc   _realloc
    801b9780   _remove
    00abdc98   _resMgrInstance
    00abd9b8   _resMgrObj
    8027e0e4   _rtdxNullChanCnt
    8027e0e8   _rtdxNullFuncCnt
    8027e0f0   _rtdxRecNotDoneCnt
    8027e0f8   _rtdxXmtErrorCnt
    8027e0ec   _rtdxXmtNotDoneCnt
    8027e0f4   _rtdxXmtRestartCnt
    1080d494   _rtdx_buffer_state
    1080d450   _rtdx_mon_state
    801a7ba0   _sDrawHandler_F_Handler_v
    801a7b80   _sDrawHandler_F_Init_v
    801a7cc4   _sDrawHandler_F_SetRenderList_v
    00ac9104   _sDrawHandler_v_Semaphore_s
    8017b494   _sDraw_F_BezierPath_v
    8017abe8   _sDraw_F_Line_v
    80179640   _sDraw_F_Pictogram_v
    801795c0   _sDraw_F_Pixel_v
    801791c4   _sDraw_F_RotatedPictogram_v
    801791b8   _sDraw_F_SelectImageBuf_v
    80179144   _sDraw_F_SetAlpha_v
    80179130   _sDraw_F_SetBufResolution_v
    801790c8   _sDraw_F_SetColor_v
    80179060   _sDraw_F_SetRGBA_v
    80177c80   _sDraw_F_SubPixelLine_v
    80178ce4   _sDraw_F_Trajectory_v
    801b4840   _sOvl_F_ApplyOverlay_v
    8027e1e4   _sOvl_V_NextProcTimeBufferId_u32
    00ac9128   _sOvl_V_ProcessTimeBufferInUs_au32
    8027e1e8   _sOvl_V_SkipOverlayProcessingForModuleTest_u32
    00ac72c8   _sampleEdma3GblCfgParams
    00ac759c   _sampleInstInitConfig
    8019e798   _setup_ddr2
    8019e2b8   _setup_pll_1
    8019e518   _setup_pll_2
    801b5080   _setvbuf
    801aece0   _sin
    801b1120   _sinf
    801b2800   _sqrt
    801b4100   _sqrtf
    00ac7ac0   _staticPoolObj
    00ac7a78   _staticPoolParams
    00ac92f0   _strECMAttrs
    80184e80   _svdcmp
    80186a28   _svdreorder
    00ac8d40   _t
    801acb20   _tan
    00ac72a8   _tcErrorInt
    1080e800   _tccCallbackWithSema
    1080c9f0   _test_sem
    1080e0e0   _trace
    8027def4   _ui32_FramingErrorCounter
    8027df28   _ui32_IntPendCount
    8027df2c   _ui32_IntPendMax
    8027df04   _ui32_IrqFramingErrorCounter
    8027df14   _ui32_IrqIoDevError
    8027df10   _ui32_IrqNotPendingError
    8027df18   _ui32_IrqOverrunErrorCounter
    8027df08   _ui32_IrqParityErrorCounter
    8027df00   _ui32_IrqRxBreakCounter
    8027df24   _ui32_IrqRxLineStatusDr
    8027df20   _ui32_IrqRxTimeout
    8027df0c   _ui32_IrqUnknownIntId
    8027df1c   _ui32_IrqUnknownLineStatusError
    8027defc   _ui32_OverrunErrorCounter
    8027def8   _ui32_ParityErrorCounter
    8027def0   _ui32_RxBreakCounter
    8027df30   _ui32_TaskUart0Timeout1
    8027df34   _ui32_TaskUart0Timeout2
    801b8d60   _unlink
    8018354c   _unpack_data
    00abd478   _userInstInitConfig
    00000000   _v_CanPosSub_pt
    00ac2f00   _v_FlashHandler_buff
    000157c0   _v_Grid_pt
    008e4508   _v_ImgData_pu8
    00005dc0   _v_NeighborList_s
    007e7918   _v_NormImg_pf32
    00ac3300   _v_ParamTable
    007e8598   _v_cCandidates_su8
    008e44d8   _v_pLens_pf32
    80197160   _vgg_H_from_x_lin
    801b3700   _vgg_condition_2d
    801ae1e0   _vgg_conditioner_from_pts
    801b7c40   _write
    801b9220   _writemsg
    00ab82c8   _zlib_inflate_state
    00aba7f8   _zlib_window
    1080c7e0   aAlgoCCF_v_ImgInUseSemaphore_s
    1080c7b4   aAlgoCCF_v_ProcessSemaphore_s
    1080c788   aAlgoCCF_v_TskSemaphore_s
    1080c730   aAlgoCCF_v_WaitForProcessSemaphore_s
    1080c75c   aAlgoCCF_v_WaitForVFWCallbackSemaphore_s
    1080ca1c   aAlgoEC_v_CaptureImgSemaphore_s
    1080c704   aAlgoEC_v_ImgInUseSemaphore_s
    1080c6d8   aAlgoEC_v_ProcessSemaphore_s
    1080c6ac   aAlgoEC_v_TskSemaphore_s
    1080c654   aAlgoEC_v_WaitForProcessSemaphore_s
    1080c680   aAlgoEC_v_WaitForVFWCallbackSemaphore_s
    1080c628   aAppAlgocontrol_v_CCFOpenCloseSemaphore_s
    1080c5a4   aAppAlgocontrol_v_DDEOpenCloseSemaphore_s
    1080c5d0   aAppAlgocontrol_v_ECOpenCloseSemaphore_s
    1080c5fc   aAppAlgocontrol_v_GTOpenCloseSemaphore_s
    1080c578   aAppStatehandler_v_ModeSemaphore_s
    1080c80c   aApp_v_SleepSemaphore_s
    1080c54c   aState_v_stateRWSemaphore_s
    ffffffff   binit
    801b97e0   cinit
    80004000   edata
    8027e238   end
    801b97e0   etext
    80280f04   hRxAppBuf
    80280678   hRxAppBuf$databeg
    80280f2c   hRxAppBufMulFrame
    8027ec38   hRxAppBufMulFrame$databeg
    801eefd0   hRxBufQueue
    1080d800   hwi0
    1080d820   hwi1
    1080d940   hwi10
    1080d960   hwi11
    1080d980   hwi12
    1080d9a0   hwi13
    1080d9c0   hwi14
    1080d9e0   hwi15
    1080d840   hwi2
    1080d860   hwi3
    1080d880   hwi4
    1080d8a0   hwi5
    1080d8c0   hwi6
    1080d8e0   hwi7
    1080d900   hwi8
    1080d920   hwi9
    8026edf0   pinit
    1080c9f0   test_sem
    1080e0e0   trace
    80278000   trace$buf
    00000001   trace$datatype
    00000000   trace$log
    00000800   trace$size
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    address    name
    00000000   CLK_PRDHIGH
    00000000   CLK_TDDR
    00000000   CLK_TDDRHIGH
    00000000   CLK_TIMERNUM
    00000000   DEV$
    00000000   DGN$
    00000000   DHL$
    00000000   DHL_gChannelsAvailable
    00000000   DIO_NUMSWIBASE
    00000000   DIO_NUMTSKBASE
    00000000   DIO_STATIC
    00000000   DPI$
    00000000   DVTEvent_Log$log
    00000000   GBL_BCACHEREADADDR0
    00000000   GBL_BCACHEREADADDR1
    00000000   GBL_BCACHEREADADDR2
    00000000   GBL_BIGENDIAN
    00000000   GBL_CACHE
    00000000   GBL_CALLCSLCFGINIT
    00000000   GBL_ENABLE_SK
    00000000   GBL_GEMTRUECOMPEN
    00000000   GBL_L2MAR0_31
    00000000   GBL_L2MAR160_191
    00000000   GBL_L2MAR192_223
    00000000   GBL_L2MAR224_255
    00000000   GBL_L2MAR32_63
    00000000   GBL_L2MAR64_95
    00000000   GBL_L2MAR96_127
    00000000   GBL_NULL
    00000000   GBL_PROCID
    00000000   GBL_ROM
    00000000   GBL_SUPPORTCSL
    00000000   HOOK$
    00000000   HOOK_KNLID
    00000000   HST_DSM
    00000000   HST_NONE
    00000000   HWI_GENERATE_RESET_VEC
    00000000   HWI_INT10$hwi
    00000000   HWI_INT11$hwi
    00000000   HWI_INT12$hwi
    00000000   HWI_INT13$hwi
    00000000   HWI_INT14$hwi
    00000000   HWI_INT15$hwi
    00000000   HWI_INT4$hwi
    00000000   HWI_INT5$hwi
    00000000   HWI_INT6$hwi
    00000000   HWI_INT7$hwi
    00000000   HWI_INT8$hwi
    00000000   HWI_INT9$hwi
    00000000   HWI_NMI$hwi
    00000000   HWI_POLARITYMASK
    00000000   HWI_RESERVED0$hwi
    00000000   HWI_RESERVED1$hwi
    00000000   HWI_RESET
    00000000   HWI_RESET$hwi
    00000000   HWI_ZEROTAB
    00000000   IDL_busyObj$iB
    00000000   IDL_busyObj$operation
    00000000   KNL_swi$ord
    00000000   KNL_swi$pri
    00000000   KNL_swi$sts$unittype
    00000000   KNL_swi$swi
    00000000   LOG_CamCtrl$log
    00000000   LOG_MIC$log
    00000000   LOG_UART$log
    00000000   LOG_system$datatype
    00000000   LOG_system$log
    00000000   MBX$
    00000000   MEM_NULL
    00000000   MEM_USEMPC
    00000000   MSGQ$
    00000000   MSGQ_USEMSGQ
    00000000   OBJ$
    00000000   PIP$
    00000000   PIP_gNextId
    00000000   PRD_TriggerFrameWatchdog$prd
    00000000   PRD_TriggerFrameWatchdog$sts$filter
    00000000   PRD_swi$ord
    00000000   PRD_swi$sts$unittype
    00000000   PRD_swi$swi
    00000000   RTA_fromHost$hst
    00000000   RTA_fromHost$mode
    00000000   RTA_toHost$hst
    00000000   RTA_toHost$id
    00000000   RTDX_MODE
    00000000   RTDX_USERTEXECUTION
    00000000   SIO$
    00000000   _CLK_TDDR
    00000000   _GBL_CACHE
    00000000   _HWI_RESET
    00000000   trace$log
    00000001   BUF$
    00000001   BUF_ENABLED
    00000001   CLK$
    00000001   CLK_CALDIV
    00000001   CLK_CALMULT
    00000001   CLK_ENABLEHTIME
    00000001   CLK_HTIMEDIV
    00000001   CLK_HTIMEMULT
    00000001   CLK_LTIMEDIV
    00000001   CLK_RESETTIMER
    00000001   CLK_USETIMER
    00000001   DIO$
    00000001   DVTEvent_Log$datatype
    00000001   ECM$
    00000001   ECM_ENABLE
    00000001   GBL$
    00000001   GBL_ENABLEINST
    00000001   GBL_L2CONFIGURE
    00000001   GBL_USERINIT
    00000001   GBL_boot
    00000001   GIO$
    00000001   HST$
    00000001   HST_RTDX
    00000001   HWI$
    00000001   HWI_ENABLE_EXC
    00000001   HWI_NMI
    00000001   IDL$
    00000001   IDL_USECLKIDLTIME
    00000001   IDL_busyObj$filter
    00000001   IDL_busyObj$iA
    00000001   IDL_busyObj$iC
    00000001   ISRC$
    00000001   KNL_swi$dorta
    00000001   KNL_swi$sts$filtmaxmult
    00000001   KNL_swi$sts$filtsummult
    00000001   LCK$
    00000001   LOG$
    00000001   LOG_CamCtrl$datatype
    00000001   LOG_ENABLED
    00000001   LOG_MIC$datatype
    00000001   LOG_UART$datatype
    00000001   MEM$
    00000001   MEM_gNumHeap
    00000001   POOL$
    00000001   POOL_USEPOOL
    00000001   PRD$
    00000001   PRD_A_TABLEN
    00000001   PRD_SCALAR
    00000001   PRD_TriggerFrameWatchdog$mode
    00000001   PRD_TriggerFrameWatchdog$ord
    00000001   PRD_swi$dorta
    00000001   PRD_swi$pri
    00000001   PRD_swi$sts$filtmaxmult
    00000001   PRD_swi$sts$filtsummult
    00000001   QUE$
    00000001   RTA_fromHost$id
    00000001   RTA_toHost$mode
    00000001   RTDX$
    00000001   RTDX_NORMALIZED_HDR
    00000001   RTDX_USERTDX
    00000001   SEM$
    00000001   STS$
    00000001   SWI$
    00000001   SYS$
    00000001   TSK$
    00000001   TSK_App$sts$filtmaxmult
    00000001   TSK_App$sts$filtsummult
    00000001   UDEV$
    00000001   _HWI_NMI
    00000002   GBL_L2MODE
    00000002   HWI_RESERVED0
    00000002   IDL_busyObj$unittype
    00000002   KNL_swi$sts$filter
    00000002   PIP_A_TABLEN
    00000002   PIP_gNumEmbed
    00000002   PRD_TriggerFrameWatchdog$sts$unittype
    00000002   PRD_swi$sts$filter
    00000002   SWI_A_TABLEN
    00000002   TSK_App$sts$filter
    00000002   TSK_DRAWLIB$sts$filter
    00000003   HWI_RESERVED1
    00000004   EVENT4
    00000004   HWI_INT4
    00000004   RTA_fromHost$framesize
    00000004   _EVENT4
    00000004   _HWI_INT4
    00000005   CLK_COUNTSPMSHIGH
    00000005   CLK_TIMMODE
    00000005   EVENT5
    00000005   HWI_INT5
    00000005   _EVENT5
    00000005   _HWI_INT5
    00000006   EVENT6
    00000006   HWI_INT6
    00000006   IDL_CALIBRERROR
    00000006   LOG_A_TABLEN
    00000006   TSK_DRAWLIB$pri
    00000006   _EVENT6
    00000006   _HWI_INT6
    00000007   EVENT7
    00000007   GBL_L1DMODE
    00000007   GBL_L1PMODE
    00000007   HWI_INT7
    00000007   TSK_App$pri
    00000007   _EVENT7
    00000007   _HWI_INT7
    00000008   EVENT8
    00000008   HWI_INT8
    00000008   _EVENT8
    00000008   _HWI_INT8
    00000009   EVENT9
    00000009   HWI_INT9
    00000009   _EVENT9
    00000009   _HWI_INT9
    0000000a   EVENT10
    0000000a   HWI_INT10
    0000000a   _EVENT10
    0000000a   _HWI_INT10
    0000000b   EVENT11
    0000000b   HWI_INT11
    0000000b   _EVENT11
    0000000b   _HWI_INT11
    0000000c   EVENT12
    0000000c   HWI_INT12
    0000000c   TSK_DRAWLIB$ord
    0000000c   _EVENT12
    0000000c   _HWI_INT12
    0000000d   EVENT13
    0000000d   HWI_INT13
    0000000d   TSK_App$ord
    0000000d   _EVENT13
    0000000d   _HWI_INT13
    0000000e   EVENT14
    0000000e   HWI_INT14
    0000000e   TSK_FpgaCom_RX$pri
    0000000e   TSK_FpgaCom_Tx$pri
    0000000e   _EVENT14
    0000000e   _HWI_INT14
    0000000f   EVENT15
    0000000f   HWI_INT15
    0000000f   _EVENT15
    0000000f   _HWI_INT15
    00000010   EVENT16
    00000010   _EVENT16
    00000011   EVENT17
    00000011   TSK_FpgaCom_RX$ord
    00000011   _EVENT17
    00000012   EVENT18
    00000012   TSK_FpgaCom_Tx$ord
    00000012   _EVENT18
    00000013   EVENT19
    00000013   _EVENT19
    00000014   EVENT20
    00000014   TSK_Diagnostic$ord
    00000014   _EVENT20
    00000015   EVENT21
    00000015   _EVENT21
    00000016   EVENT22
    00000016   _EVENT22
    00000017   EVENT23
    00000017   _EVENT23
    00000018   EVENT24
    00000018   _EVENT24
    00000019   EVENT25
    00000019   _EVENT25
    0000001a   EVENT26
    0000001a   _EVENT26
    0000001b   EVENT27
    0000001b   _EVENT27
    0000001c   EVENT28
    0000001c   _EVENT28
    0000001d   EVENT29
    0000001d   _EVENT29
    0000001e   EVENT30
    0000001e   _EVENT30
    0000001f   EVENT31
    0000001f   _EVENT31
    00000020   CLK_TCR
    00000020   EVENT32
    00000020   _EVENT32
    00000021   EVENT33
    00000021   _EVENT33
    00000022   EVENT34
    00000022   _EVENT34
    00000023   EVENT35
    00000023   _EVENT35
    00000024   EVENT36
    00000024   _EVENT36
    00000025   EVENT37
    00000025   _EVENT37
    00000026   EVENT38
    00000026   _EVENT38
    00000027   EVENT39
    00000027   _EVENT39
    00000028   EVENT40
    00000028   PRD_TriggerFrameWatchdog$period
    00000028   _EVENT40
    00000029   EVENT41
    00000029   _EVENT41
    0000002a   EVENT42
    0000002a   _EVENT42
    0000002b   EVENT43
    0000002b   _EVENT43
    0000002c   EVENT44
    0000002c   _EVENT44
    0000002d   EVENT45
    0000002d   _EVENT45
    0000002e   EVENT46
    0000002e   _EVENT46
    0000002f   EVENT47
    0000002f   _EVENT47
    00000030   EVENT48
    00000030   _EVENT48
    00000031   EVENT49
    00000031   _EVENT49
    00000032   EVENT50
    00000032   _EVENT50
    00000033   EVENT51
    00000033   _EVENT51
    00000034   EVENT52
    00000034   _EVENT52
    00000035   EVENT53
    00000035   _EVENT53
    00000036   EVENT54
    00000036   _EVENT54
    00000037   EVENT55
    00000037   _EVENT55
    00000038   EVENT56
    00000038   _EVENT56
    00000039   EVENT57
    00000039   _EVENT57
    0000003a   EVENT58
    0000003a   _EVENT58
    0000003b   EVENT59
    0000003b   _EVENT59
    0000003c   EVENT60
    0000003c   _EVENT60
    0000003d   EVENT61
    0000003d   _EVENT61
    0000003e   EVENT62
    0000003e   GBL_DSPTYPE
    0000003e   _EVENT62
    0000003f   EVENT63
    0000003f   _EVENT63
    00000040   EVENT64
    00000040   HST_MAXFRAMESET
    00000040   LOG_MIC$size
    00000040   LOG_UART$size
    00000040   RTA_toHost$framesize
    00000040   _EVENT64
    00000041   EVENT65
    00000041   _EVENT65
    00000042   EVENT66
    00000042   GBL_FOOTPRINT
    00000042   _EVENT66
    00000043   EVENT67
    00000043   _EVENT67
    00000044   EVENT68
    00000044   _EVENT68
    00000045   EVENT69
    00000045   _EVENT69
    00000046   EVENT70
    00000046   _EVENT70
    00000047   EVENT71
    00000047   _EVENT71
    00000048   EVENT72
    00000048   _EVENT72
    00000049   EVENT73
    00000049   _EVENT73
    0000004a   EVENT74
    0000004a   _EVENT74
    0000004b   EVENT75
    0000004b   _EVENT75
    0000004c   EVENT76
    0000004c   _EVENT76
    0000004d   EVENT77
    0000004d   _EVENT77
    0000004e   EVENT78
    0000004e   _EVENT78
    0000004f   EVENT79
    0000004f   _EVENT79
    00000050   EVENT80
    00000050   _EVENT80
    00000051   EVENT81
    00000051   _EVENT81
    00000052   EVENT82
    00000052   _EVENT82
    00000053   EVENT83
    00000053   _EVENT83
    00000054   EVENT84
    00000054   _EVENT84
    00000055   EVENT85
    00000055   _EVENT85
    00000056   EVENT86
    00000056   _EVENT86
    00000057   EVENT87
    00000057   _EVENT87
    00000058   EVENT88
    00000058   _EVENT88
    00000059   EVENT89
    00000059   _EVENT89
    0000005a   EVENT90
    0000005a   _EVENT90
    0000005b   EVENT91
    0000005b   _EVENT91
    0000005c   EVENT92
    0000005c   _EVENT92
    0000005d   EVENT93
    0000005d   _EVENT93
    0000005e   EVENT94
    0000005e   _EVENT94
    0000005f   EVENT95
    0000005f   _EVENT95
    00000060   EVENT96
    00000060   _EVENT96
    00000061   EVENT97
    00000061   _EVENT97
    00000062   EVENT98
    00000062   _EVENT98
    00000063   EVENT99
    00000063   _EVENT99
    00000064   EVENT100
    00000064   PIP_OBJSIZE
    00000064   _EVENT100
    00000065   EVENT101
    00000065   _EVENT101
    00000066   EVENT102
    00000066   _EVENT102
    00000067   EVENT103
    00000067   _EVENT103
    00000068   EVENT104
    00000068   _EVENT104
    00000069   EVENT105
    00000069   _EVENT105
    0000006a   EVENT106
    0000006a   _EVENT106
    0000006b   EVENT107
    0000006b   _EVENT107
    0000006c   EVENT108
    0000006c   _EVENT108
    0000006d   EVENT109
    0000006d   _EVENT109
    0000006e   EVENT110
    0000006e   _EVENT110
    0000006f   EVENT111
    0000006f   _EVENT111
    00000070   EVENT112
    00000070   _EVENT112
    00000071   EVENT113
    00000071   _EVENT113
    00000072   EVENT114
    00000072   _EVENT114
    00000073   EVENT115
    00000073   _EVENT115
    00000074   EVENT116
    00000074   _EVENT116
    00000075   EVENT117
    00000075   _EVENT117
    00000076   EVENT118
    00000076   _EVENT118
    00000077   EVENT119
    00000077   _EVENT119
    00000078   EVENT120
    00000078   _EVENT120
    00000079   EVENT121
    00000079   _EVENT121
    0000007a   EVENT122
    0000007a   _EVENT122
    0000007b   EVENT123
    0000007b   _EVENT123
    0000007c   EVENT124
    0000007c   _EVENT124
    0000007d   EVENT125
    0000007d   _EVENT125
    0000007e   EVENT126
    0000007e   _EVENT126
    0000007f   EVENT127
    0000007f   _EVENT127
    00000080   LOG_CamCtrl$size
    000000ff   HST_MAXFRAMEALLOWED
    000003e8   CLK_MICROSECS
    00000400   HST_DSMMEMSIZE
    00000400   LOG_system$size
    00000408   RTDX_BUFMEMSIZE
    00000800   trace$size
    00001000   TSK_STACKSIZE
    00001918   GBL_CLKTYPE
    00001963   GBL_DSPSUBTYPE
    00002000   DVTEvent_Log$size
    00004000   CLK_INTBIT
    00005204   GBL_A_VERSION
    00006978   CLK_INPUTCLK
    00006978   CLK_PRD
    00006978   GBL_CLKIN
    00006978   _CLK_PRD
    000078f8   HWI_CFGDISPATCHED
    0000dbef   GBL_TRCMASKVALUE
    000157c0   _v_Grid_pt
    00015970   _buffer
    0005c490   CLK_COUNTSPMS
    0005c490   CLK_HTIMEPERLTIME
    0005c490   CLK_LTIMEMULT
    0005c490   GBL_FREQ
    00100000   DDR2$L
    00a5d9f4   _BUF_ATTRS
    00a84280   _FULL_FRO
    00a873e0   _FULL_REA
    00a8a540   _TOP_FRO
    00a8d6a0   _TOP_REA
    00a90800   _TOP_TRA
    00a9fee0   _EOL_FRONT
    00aa2040   _EOL_RIGHT
    00aa41a0   _EOL_REAR
    00aa6300   _EOL_LEFT
    00aa8460   _V_Luts_s
    00ab3d94   _MEM_ATTRS
    00abd9b8   _resMgrObj
    00abfd38   _m_twist
    00ac1404   _QUE_ATTRS
    00ac7c8c   _errno
    00ac7e90   __ftable
    00ac7f80   __tmpnams
    00ac8020   __ft_end
    00ac8464   _dtors
    00ac89d0   _KNL_dummy
    00ac8d40   _t
    00ac8d58   _K
    00ac8da0   _d_ang
    00ac8fa0   _TSK_ATTRS
    00ac9000   _OBJ_table
    00ac93dc   _SIO_ATTRS
    00ac9410   _SWI_ATTRS
    00ac9498   _HWI_ATTRS
    00ac94d4   _ECM_ATTRS
    00ac94dc   _GIO_ATTRS
    00ac94e4   _SEM_ATTRS
    00ac94ec   __lock
    00ac94f0   __unlock
    01c21400   CLK_REGS
    01c21400   _CLK_REGS
    03020100   HWI_INTRMUX1
    06042f0c   HWI_INTRMUX3
    0b0a0908   HWI_INTRMUX2
    1080c28c   SEM_videoConfigReady
    1080c2b8   SEM_ctrl
    1080c2b8   _SEM_ctrl
    1080c2e4   SEM_data
    1080c2e4   _SEM_data
    1080c310   SEM_uart0_sendbuf_empty
    1080c33c   SEM_uart1_sendbuf_empty
    1080c368   SEM_uart0_send_fifo_empty
    1080c394   SEM_uart1_send_fifo_empty
    1080c3c0   SEM_uart0_send_tel_rdy
    1080c3ec   SEM_uart1_send_tel_rdy
    1080c418   SEM_APPInit
    1080c470   SEM_uart0
    1080c470   _SEM_uart0
    1080c49c   SEM_uart1
    1080c49c   _SEM_uart1
    1080c4c8   SEM_RxFramesInFifo
    1080c4f4   SEM_TxMessagesInQueue
    1080c520   SEM_TxFramesFree
    1080c838   SEM_uart0_tx_data_pending
    1080c864   SEM_uart1_tx_data_pending
    1080c890   SEM_Cam_Write_Register
    1080c8bc   SEM_Cam_Read_Register
    1080c8e8   SEM_McASP_CCDC_VSYNC
    1080c914   SEM_McASP_PACKET_STATUS
    1080c940   SEM_McASP_QDataReady
    1080c96c   SEM_McASP_SIOInit
    1080c998   SEM_McASP_DIAG_LUTS_STATUS_RDY
    1080c9c4   SEM_DiagnosticReq
    1080c9f0   _test_sem
    1080c9f0   test_sem
    1080cf8c   PRD_A_TABBEG
    1080cf8c   PRD_TriggerFrameWatchdog
    1080cfa8   PRD_TriggerFrameWatchdog$aaa
    1080cfac   IDL_A_TABBEG
    1080cfac   IDL_cpuLoad
    1080cfac   PRD_A_TABEND
    1080cfb0   LNK_dataPump
    1080cfb4   RTA_dispatcher
    1080cfb8   CpuLoadCheck
    1080cfbc   IDL_END
    1080d4b4   HST_A_TABBEG
    1080d4b8   RTA_fromHost
    1080d4c0   RTA_fromHost$rtdx
    1080d4d4   RTA_toHost
    1080d4dc   RTA_toHost$rtdx
    1080d4f0   HST_A_TABEND
    1080d4f0   RTA_fromHost$buf
    1080d500   LOG_MIC$buf
    1080d600   LOG_CamCtrl$buf
    1080d800   HWI_A_VECS
    1080d800   hwi0
    1080d820   hwi1
    1080d840   hwi2
    1080d860   hwi3
    1080d880   hwi4
    1080d8a0   hwi5
    1080d8c0   hwi6
    1080d8e0   hwi7
    1080d900   hwi8
    1080d920   hwi9
    1080d940   hwi10
    1080d960   hwi11
    1080d980   hwi12
    1080d9a0   hwi13
    1080d9c0   hwi14
    1080d9e0   hwi15
    1080dc00   PRD_TriggerFrameWatchdog$sts$stsobj
    1080dc00   STS_A_TABBEG
    1080dc04   PRD_TriggerFrameWatchdog$sts
    1080dc10   KNL_swi$sts$stsobj
    1080dc14   KNL_swi$sts
    1080dc20   PRD_swi$sts$stsobj
    1080dc24   PRD_swi$sts
    1080dc30   TSK_idle$sts$stsobj
    1080dc34   TSK_idle$sts
    1080dc40   TSK_VideoAlgo$sts$stsobj
    1080dc44   TSK_VideoAlgo$sts
    1080dc50   TSK_VideoAlgoLow$sts$stsobj
    1080dc54   TSK_VideoAlgoLow$sts
    1080dc60   TSK_VideoAlgoMed$sts$stsobj
    1080dc64   TSK_VideoAlgoMed$sts
    1080dc70   TSK_VfwCapture$sts$stsobj
    1080dc74   TSK_VfwCapture$sts
    1080dc80   TSK_VfwControl$sts$stsobj
    1080dc84   TSK_VfwControl$sts
    1080dc90   TSK_VfwInit$sts$stsobj
    1080dc94   TSK_VfwInit$sts
    1080dca0   TSK_VfwDistri$sts$stsobj
    1080dca4   TSK_VfwDistri$sts
    1080dcb0   TSK_VfwConverterBE$sts$stsobj
    1080dcb4   TSK_VfwConverterBE$sts
    1080dcc0   TSK_VfwDisplay$sts$stsobj
    1080dcc4   TSK_VfwDisplay$sts
    1080dcd0   TSK_UART0_TX$sts$stsobj
    1080dcd4   TSK_UART0_TX$sts
    1080dce0   TSK_DRAWLIB$sts$stsobj
    1080dce4   TSK_DRAWLIB$sts
    1080dcf0   TSK_App$sts$stsobj
    1080dcf4   TSK_App$sts
    1080dd00   TSK_mcuIPC_rx$sts$stsobj
    1080dd04   TSK_mcuIPC_rx$sts
    1080dd10   TSK_aAlgoCCF$sts$stsobj
    1080dd14   TSK_aAlgoCCF$sts
    1080dd20   TSK_mcuIPC_tx$sts$stsobj
    1080dd24   TSK_mcuIPC_tx$sts
    1080dd30   TSK_aAlgoEC$sts$stsobj
    1080dd34   TSK_aAlgoEC$sts
    1080dd40   TSK_FpgaCom_RX$sts$stsobj
    1080dd44   TSK_FpgaCom_RX$sts
    1080dd50   TSK_FpgaCom_Tx$sts$stsobj
    1080dd54   TSK_FpgaCom_Tx$sts
    1080dd60   TSK_McASP$sts$stsobj
    1080dd64   TSK_McASP$sts
    1080dd70   TSK_Diagnostic$sts$stsobj
    1080dd74   TSK_Diagnostic$sts
    1080dd80   IDL_busyObj$stsobj
    1080dd84   IDL_busyObj
    1080dd90   KNL_swi
    1080dd90   STS_A_TABEND
    1080dd90   SWI_A_TABBEG
    1080dd90   _KNL_swi
    1080ddbc   PRD_SWIHANDLE
    1080ddbc   PRD_swi
    1080ddbc   _PRD_swi
    1080dde8   IDL_A_CALBEG
    1080dde8   IDL_cpuLoad$
    1080dde8   SWI_A_TABEND
    1080ddec   LNK_dataPump$
    1080ddf0   RTA_dispatcher$
    1080ddf4   CpuLoadCheck$
    1080ddf8   IDL_END$
    1080de00   LOG_UART$buf
    1080df00   RTA_toHost$buf
    1080e000   PIP_A_TABBEG
    1080e000   RTA_fromHost$pipe
    1080e004   RTA_fromHost$pipe$rd
    1080e030   RTA_fromHost$pipe$aaa
    1080e034   RTA_fromHost$pipe$wr
    1080e060   RTA_fromHost$pipe$bbb
    1080e064   RTA_toHost$pipe
    1080e068   RTA_toHost$pipe$rd
    1080e094   RTA_toHost$pipe$aaa
    1080e098   RTA_toHost$pipe$wr
    1080e0c4   RTA_toHost$pipe$bbb
    1080e0c8   LOG_A_TABBEG
    1080e0c8   LOG_system
    1080e0c8   PIP_A_TABEND
    1080e0e0   _trace
    1080e0e0   trace
    1080e0f8   DVTEvent_Log
    1080e110   LOG_UART
    1080e110   _LOG_UART
    1080e128   LOG_MIC
    1080e128   _LOG_MIC
    1080e140   LOG_CamCtrl
    1080e158   CLK_A_TABBEG
    1080e158   LOG_A_TABEND
    1080e158   PRD_clock
    1080e158   _PRD_clock
    1080e15c   CLK_null
    80004000   .data
    80004000   DDR2$B
    80004000   _DDR2_base
    80004000   ___data__
    80004000   ___edata__
    80004000   edata
    801686b0   __ctypes_
    80169b59   PRD_TriggerFrameWatchdog$sts$maxfmt
    80169b60   .text
    80169b60   ___text__
    80169b62   PRD_TriggerFrameWatchdog$sts$sumfmt
    80169b6b   PRD_TriggerFrameWatchdog$sts$avgfmt
    80169b76   KNL_swi$sts$maxfmt
    80169b7e   KNL_swi$sts$sumfmt
    80169b86   KNL_swi$sts$avgfmt
    80169b90   PRD_swi$sts$maxfmt
    80169b98   PRD_swi$sts$sumfmt
    80169ba0   PRD_swi$sts$avgfmt
    80169baa   TSK_idle$sts$maxfmt
    80169bb2   TSK_idle$sts$sumfmt
    80169bba   TSK_idle$sts$avgfmt
    80169bc4   TSK_VideoAlgo$sts$maxfmt
    80169bcc   TSK_VideoAlgo$sts$sumfmt
    80169bd4   TSK_VideoAlgo$sts$avgfmt
    80169bde   TSK_VideoAlgoLow$sts$maxfmt
    80169be6   TSK_VideoAlgoLow$sts$sumfmt
    80169bee   TSK_VideoAlgoLow$sts$avgfmt
    80169bf8   TSK_VideoAlgoMed$sts$maxfmt
    80169c00   TSK_VideoAlgoMed$sts$sumfmt
    80169c08   TSK_VideoAlgoMed$sts$avgfmt
    80169c12   TSK_VfwCapture$sts$maxfmt
    80169c1a   TSK_VfwCapture$sts$sumfmt
    80169c22   TSK_VfwCapture$sts$avgfmt
    80169c2c   TSK_VfwControl$sts$maxfmt
    80169c34   TSK_VfwControl$sts$sumfmt
    80169c3c   TSK_VfwControl$sts$avgfmt
    80169c46   TSK_VfwInit$sts$maxfmt
    80169c4e   TSK_VfwInit$sts$sumfmt
    80169c56   TSK_VfwInit$sts$avgfmt
    80169c60   TSK_VfwDistri$sts$maxfmt
    80169c68   TSK_VfwDistri$sts$sumfmt
    80169c70   TSK_VfwDistri$sts$avgfmt
    80169c7a   TSK_VfwConverterBE$sts$maxfmt
    80169c82   TSK_VfwConverterBE$sts$sumfmt
    80169c8a   TSK_VfwConverterBE$sts$avgfmt
    80169c94   TSK_VfwDisplay$sts$maxfmt
    80169c9c   TSK_VfwDisplay$sts$sumfmt
    80169ca4   TSK_VfwDisplay$sts$avgfmt
    80169cae   TSK_UART0_TX$sts$maxfmt
    80169cb6   TSK_UART0_TX$sts$sumfmt
    80169cbe   TSK_UART0_TX$sts$avgfmt
    80169cc8   TSK_DRAWLIB$sts$maxfmt
    80169cd0   TSK_DRAWLIB$sts$sumfmt
    80169cd8   TSK_DRAWLIB$sts$avgfmt
    80169ce2   TSK_App$sts$maxfmt
    80169cea   TSK_App$sts$sumfmt
    80169cf2   TSK_App$sts$avgfmt
    80169cfc   TSK_mcuIPC_rx$sts$maxfmt
    80169d04   TSK_mcuIPC_rx$sts$sumfmt
    80169d0c   TSK_mcuIPC_rx$sts$avgfmt
    80169d16   TSK_aAlgoCCF$sts$maxfmt
    80169d1e   TSK_aAlgoCCF$sts$sumfmt
    80169d26   TSK_aAlgoCCF$sts$avgfmt
    80169d30   TSK_mcuIPC_tx$sts$maxfmt
    80169d38   TSK_mcuIPC_tx$sts$sumfmt
    80169d40   TSK_mcuIPC_tx$sts$avgfmt
    80169d4a   TSK_aAlgoEC$sts$maxfmt
    80169d52   TSK_aAlgoEC$sts$sumfmt
    80169d5a   TSK_aAlgoEC$sts$avgfmt
    80169d64   TSK_FpgaCom_RX$sts$maxfmt
    80169d6c   TSK_FpgaCom_RX$sts$sumfmt
    80169d74   TSK_FpgaCom_RX$sts$avgfmt
    80169d7e   TSK_FpgaCom_Tx$sts$maxfmt
    80169d86   TSK_FpgaCom_Tx$sts$sumfmt
    80169d8e   TSK_FpgaCom_Tx$sts$avgfmt
    80169d98   TSK_McASP$sts$maxfmt
    80169da0   TSK_McASP$sts$sumfmt
    80169da8   TSK_McASP$sts$avgfmt
    80169db2   TSK_Diagnostic$sts$maxfmt
    80169dba   TSK_Diagnostic$sts$sumfmt
    80169dc2   TSK_Diagnostic$sts$avgfmt
    80169dcc   IDL_busyObj$maxfmt
    80169dcf   IDL_busyObj$sumfmt
    80169dd2   IDL_busyObj$avgfmt
    8017bfa8   _EDMA3_DRV_setPaRAMField
    8017c200   _EDMA3_DRV_setPaRAMEntry
    8017c2c0   _EDMA3_DRV_setPaRAM
    8017c3c8   _EDMA3_DRV_setOptField
    8017c62c   _EDMA3_DRV_setEvtQPriority
    8017c7e4   _EDMA3_DRV_setDestParams
    8017c9c8   _EDMA3_DRV_setDestIndex
    8017cacc   _EDMA3_DRV_setCCRegister
    8017cbc8   _EDMA3_DRV_disableTransfer
    8017d080   _EDMA3_DRV_freeChannel
    8017d3a8   _EDMA3_DRV_requestChannel
    8017dfac   _EDMA3_DRV_open
    8017e234   _EDMA3_DRV_mapChToEvtQ
    8017e40c   _EDMA3_DRV_linkChannel
    8017e540   _EDMA3_DRV_getPaRAMPhyAddr
    8017e5e8   _EDMA3_DRV_getPaRAMField
    8017e800   _EDMA3_DRV_getPaRAMEntry
    8017e8c0   _EDMA3_DRV_getPaRAM
    8017e9e0   _EDMA3_DRV_getOptField
    8017eb60   _EDMA3_DRV_getMapChToEvtQ
    8017ec44   _EDMA3_DRV_getCCRegister
    8017ecc0   _EDMA3_DRV_enableTransfer
    8017ef00   _EDMA3_DRV_delete
    8017efe0   _EDMA3_DRV_create
    8017f260   _EDMA3_DRV_close
    8017f370   _EDMA3_DRV_clearErrorBits
    8017f480   _EDMA3_DRV_checkAndClearTcc
    8017f568   _EDMA3_DRV_chainChannel
    8017f700   _EDMA3_DRV_Ioctl
    80184e80   _svdcmp
    80186910   _pythag
    80187074   _f_max_d32
    80187130   _f_min_u8
    8018d6a0   _CCDC_IsrVD0
    8018d814   _CCDC_IsrVD1
    8018db34   _CCDC_init
    8018db38   _CCDC_myInit
    8018db58   _CCDC_mdBindDev
    8018dbb8   _CCDC_mdCreateChan
    8018e42c   _CCDC_mdDeleteChan
    8018e4f8   _CCDC_readChan
    8018e9f8   _CCDC_writeChan
    8018eb64   _CCDC_mdSubmitChan
    8018f050   _CCDC_mdControlChan
    8019d2e0   _VPBE_Isr
    8019d4c4   _VPBE_init
    8019dee0   _DM643x_init
    8019df28   _DM643x_SwitchPowerModule
    8019e1c4   _Disable_VPSS
    8019e1f4   _Disable_EDMA
    801a1dc0   _pow
    801a5d00   __divd
    801aa700   __divf
    801acb20   _tan
    801ad2e0   _cos
    801ade20   _QUE_drop
    801ae5a0   __printfi
    801aece0   _sin
    801af380   __addf
    801afc80   _fputs
    801b03a0   _edma3init
    801b0e40   _cosf
    801b1120   _sinf
    801b1680   _atan
    801b1e60   _DIO_tskReclaim
    801b1e88   _DIO_tskReady
    801b1ea4   _DIO_tskIssue
    801b1f48   _DIO_tskIdle
    801b2044   _DIO_tskCallback
    801b20e0   __divull
    801b2340   __mpyd
    801b25a0   _asin
    801b2800   _sqrt
    801b2a40   __addd
    801b32d8   GBL_USERINITFXN
    801b32f8   SYS_ABORTFXN
    801b32f8   SYS_EXITFXN
    801b32f8   _myExit
    801b3324   _main
    801b3920   __frcaddd
    801b3b20   __mpyf
    801b3d20   _asinf
    801b4100   _sqrtf
    801b4680   _ldexp
    801b4ba0   __divul
    801b4ee0   _frexp
    801b5080   _setvbuf
    801b5560   _ldexpf
    801b56e0   _atanf
    801b5840   _frexpf
    801b5c60   _fputc
    801b5c60   _putc
    801b6140   _fclose
    801b6340   _LOAD_init
    801b64a0   _DM643x_PowerON
    801b65a0   _HOSTlseek
    801b66a0   __frcmpyd
    801b68a0   __nround
    801b69a0   __wrt_ok
    801b6ba0   _HOSTopen
    801b6c80   __cmpd
    801b6d60   __divi
    801b6e40   __roundf
    801b6f20   _atoi
    801b7000   _close
    801b70e0   _memset
    801b71c0   _HOSTread
    801b7340   _HOSTwrite
    801b74c0   __cleanup
    801b7640   __divu
    801b7700   __doflush
    801b77c0   __remi
    801b7880   _atexit
    801b7940   _fseek
    801b7a00   _lseek
    801b7ac0   _ltoa
    801b7b80   _modf
    801b7c40   _write
    801b7e80   _HOSTclose
    801b7f20   __cvtdf
    801b7fc0   __divli
    801b81a0   __fixdli
    801b8380   __remu
    801b84c0   _memcpy
    801b86a0   _QUE_newq
    801b86c0   _QUE_headq
    801b870c   _QUE_nextq
    801b8860   __cmpf
    801b88e0   __fixdi
    801b8960   __fixdu
    801b89e0   __fixfi
    801b8a60   __fixfu
    801b8ae0   __fltlid
    801b8b60   __llshl
    801b8be0   __renormd
    801b8c60   _printf
    801b8ce0   _readmsg
    801b8d60   _unlink
    801b8e60   _DM643x_PinMux
    801b8ec0   __cvtfd
    801b8f20   __fltid
    801b8f80   __fltif
    801b8fe0   __frcmpyf
    801b9040   __llshru
    801b90a0   __subcull
    801b9100   _floor
    801b9160   _memccpy
    801b91c0   _modff
    801b9220   _writemsg
    801b9278   C$$IO$$
    801b92c0   ___isinf
    801b93c0   __fltud
    801b9400   __fltuf
    801b9440   __negd
    801b9480   __negf
    801b94c0   __remli
    801b9540   __subd
    801b9580   __subf
    801b95c0   _DIO_ctrl
    801b9640   __negll
    801b9660   __nop
    801b96c0   __pop_rts
    801b96e0   __push_rts
    801b9740   __trunc
    801b9760   __truncf
    801b9780   _remove
    801b97e0   ___cinit__
    801b97e0   ___etext__
    801b97e0   cinit
    801b97e0   etext
    801eabd0   TSK_FpgaCom_RX$stack
    801ecb68   TSK_FpgaCom_RX$stkptr
    801ecbd0   TSK_FpgaCom_Tx$stack
    801eeb68   TSK_FpgaCom_Tx$stkptr
    801eebd0   TSK_DRAWLIB$stack
    801eef68   TSK_DRAWLIB$stkptr
    801eefd8   QUE_TxMessages_s
    801eefe0   QUE_TxFrames_s
    801eefe8   QUE_McASPTxFrame
    801eeff0   GIO$config
    801ef000   LOG_system$buf
    801f0000   DVTEvent_Log$buf
    801f8000   TSK_App$stack
    801fff98   TSK_App$stkptr
    80200000   TSK_VfwCapture$stack
    80207f98   TSK_VfwCapture$stkptr
    80208000   TSK_VfwConverterBE$stack
    8020ff98   TSK_VfwConverterBE$stkptr
    80210000   TSK_VfwDisplay$stack
    80217f98   TSK_VfwDisplay$stkptr
    80218000   TSK_VfwDistri$stack
    8021ff98   TSK_VfwDistri$stkptr
    80220000   TSK_VideoAlgo$stack
    80227f98   TSK_VideoAlgo$stkptr
    80228000   TSK_VideoAlgoLow$stack
    8022ff98   TSK_VideoAlgoLow$stkptr
    80230000   TSK_VideoAlgoMed$stack
    80237f98   TSK_VideoAlgoMed$stkptr
    80238000   TSK_aAlgoCCF$stack
    8023ff98   TSK_aAlgoCCF$stkptr
    80240000   TSK_aAlgoEC$stack
    80247f98   TSK_aAlgoEC$stkptr
    80248000   TSK_idle$stack
    8024ff98   TSK_idle$stkptr
    80250000   TSK_mcuIPC_rx$stack
    80257f98   TSK_mcuIPC_rx$stkptr
    80258000   TSK_mcuIPC_tx$stack
    8025ff98   TSK_mcuIPC_tx$stkptr
    80260000   TSK_VfwControl$stack
    80267c98   TSK_VfwControl$stkptr
    802682c0   LNK_F_checkBufferCall
    802682e0   LNK_F_getChanPtr
    80268338   LNK_F_init
    80268340   LNK_F_dataPump
    80268350   LNK_rcloop
    80268414   LNK_rdrtry
    80268424   LNK_rrloop
    802684e4   LNK_wrrtry
    802684f0   LNK_wrloop
    802685c0   LNK_newin
    802686f4   LNK_newout
    80268848   LNK_F_readCallBack
    80268880   _EXC_nmi
    802688b4   _EXC_internal
    80268b60   _EXC_init
    80268ba0   _EXC_getLastStatus
    80268bc0   _EXC_external
    80268bf4   _EXC_exceptionHandler
    80268d70   _EXC_clearLastStatus
    80268da0   CLK_HOOKFXN
    80268da0   HWI_F_dispatch
    80268da0   _HWI_F_dispatch
    80269280   SWI_F_enable
    802692f0   SWI_F_post
    802692f0   _SWI_post
    80269464   SWI_EXECFXN
    80269464   SWI_F_exec
    8026948c   SWI_F_iexec
    8026950c   SWI_F_run
    8026950c   SWI_RUNFXN
    80269740   PRD_F_swi
    802699c0   PRD_F_tick
    80269da0   _GIO_create
    8026a040   _free
    8026a068   _malloc
    8026a0cc   _realloc
    8026a198   _memalign
    8026a278   _calloc
    8026a2e0   RTA_F_getlog
    8026a318   RTA_F_getsts
    8026a358   RTA_F_readblk
    8026a374   RTA_F_writeword
    8026a380   RTA_F_resetmem
    8026a3c0   RTA_F_dispatch
    8026a40c   RTA_execute
    8026a560   _KNL_run
    8026ae00   _MEM_alloc
    8026afe0   _C62_plug
    8026afe0   _C64_plug
    8026afe8   _C62_dispatchPlug
    8026afe8   _C64_dispatchPlug
    8026b1c0   _EXC_dispatch
    8026b384   _EXC_setReturnPtr
    8026b56c   PRD_THOOKFXN
    8026b56c   _KNL_tick
    8026b580   PIP_F_take
    8026b5f8   PIP_F_give
    8026b5f8   PIP_F_probe
    8026b6c8   PIP_F_start
    8026b940   _MEM_free
    8026bb00   _GIO_submit
    8026bff0   _BCACHE_wbInv
    8026c004   _BCACHE_wb
    8026c014   _BCACHE_inv
    8026c040   _TSK_setup
    8026c1e0   CLK_F_getltime
    8026c1f0   CLK_F_isr
    8026c330   CLK_F_itime
    8026c330   _CLK_F_itime
    8026c330   _CLK_itime
    8026c380   _BUF_create
    8026c500   _KNL_saveIsrFrame
    8026c5ac   _KNL_switch
    8026c658   KNL_glue
    8026c920   _TSK_exit
    8026ca60   _BCACHE_setSize
    8026caa4   _BCACHE_setMar
    8026caf4   _BCACHE_bootInit
    8026caf4   _BCACHE_setCacheToSram
    8026cb24   _BCACHE_getSize
    8026cb74   _BCACHE_getMar
    8026cc04   _GBL_cacheInit64P
    8026ccc0   _KNL_check
    8026cd88   _KNL_idle
    8026cdb0   _KNL_max
    8026d020   _ECM_dispatch
    8026d120   _GIO_delete
    8026d320   GIO_POSTFXN
    8026d320   _SEM_post
    8026d4e0   _DEV_match
    8026d5a0   _KNL_exit
    8026d5e0   _KNL_enter
    8026d8a0   _DEV_mkframe
    8026da80   _SYS_exit
    8026dbc0   _SIO_issue
    8026dc60   _ATM_andi
    8026dc60   _ATM_andu
    8026dc70   _ATM_cleari
    8026dc70   _ATM_clearu
    8026dc80   _ATM_deci
    8026dc80   _ATM_decu
    8026dc90   _ATM_inci
    8026dc90   _ATM_incu
    8026dca4   _ATM_ori
    8026dca4   _ATM_oru
    8026dcb4   _ATM_seti
    8026dcb4   _ATM_setu
    8026dd60   _HWI_dispatchPlug
    8026dde0   _HWI_eventMap
    8026de60   _KNL_ipost
    8026dee0   _KNL_post
    8026df60   _LCK_post
    8026df80   _LCK_pend
    8026dfe0   LOG_F_event
    8026dfe0   _LOG_event
    8026e0e0   GIO_CREATEFXN
    8026e260   _BCACHE_wait
    8026e2e0   IDL_F_calibrate
    8026e440   _SYS_error
    8026e4a0   _BUF_free
    8026e500   _DEV_rmframe
    8026e560   _ECM_dispatchPlug
    8026e5c0   FXN_F_nop
    8026e5c4   FXN_F_run
    8026e5c4   _FXN_F_run
    8026e600   FXN_F_zero
    8026e600   _FXN_F_zero
    8026e620   _HWI_disable
    8026e638   _HWI_enable
    8026e64c   _HWI_restore
    8026e680   IDL_F_busy
    8026e7a0   GIO_PENDFXN
    8026e7a0   _SEM_pend
    8026e800   STS_F_delta
    8026e800   _STS_delta
    8026e82c   STS_F_add
    8026e82c   _STS_add
    8026e848   STS_F_reset
    8026e848   _STS_reset
    8026e860   _SYS_abort
    8026e8c0   SYS_PUTCFXN
    8026e920   _CLK_measure
    8026e980   _BUF_alloc
    8026e9c0   _BUF_stat
    8026ea00   _C62_disableIER
    8026ea00   _C64_disableIER
    8026ea18   _C62_enableIER
    8026ea18   _C64_enableIER
    8026ea2c   _C62_clearIFR
    8026ea2c   _C64_clearIFR
    8026ea40   _ECM_disableEvent
    8026ea80   _ECM_enableEvent
    8026eac0   IDL_CALIBRFXN
    8026eac0   IDL_F_stub
    8026eb40   _QUE_get
    8026eb68   _QUE_put
    8026eb80   RTA_F_andn
    8026eb98   RTA_F_or
    8026ec00   _CLK_countspms
    8026ec20   _CLK_getltime
    8026ec40   _CLK_getprd
    8026ec60   TSK_VCREATEFXN
    8026ec60   TSK_VDELETEFXN
    8026ec60   TSK_VEXITFXN
    8026ec60   _FXN_F_nop
    8026ec80   _GBL_getVersion
    8026eca0   IDL_F_loop
    8026eca0   _IDL_loop
    8026ecc0   _IOM_mdNotImpl
    8026ece0   _LOG_printf
    8026ed00   GIO_DELETEFXN
    8026ed20   _STS_set
    8026ed40   _SYS_zero
    8026ed48   _SYS_one
    8026ed60   SYS_ERRORFXN
    8026ed80   _UTL_halt
    8026eda0   CLK_F_gethtime
    8026eda0   CLK_TIMEFXN
    8026eda0   _CLK_gethtime
    8026edc0   _MSGQ32_setErrorHandler
    8026ede0   SYS$config
    8026edf0   ___pinit__
    8026edf0   pinit
    80274700   TSK_VfwInit$stack
    80276698   TSK_VfwInit$stkptr
    80276700   TSK_Diagnostic$stack
    80277698   TSK_Diagnostic$stkptr
    80277700   GBL_stackbeg
    80277700   _HWI_STKTOP
    80277700   __stack
    80277ef8   _HWI_STKBOTTOM
    80277eff   GBL_stackend
    80277f00   BUF_PoolTxSingleFrameData_s$databeg
    80277ff0   TRC_cinit
    80277ff4   TRC_R_mask
    80277ff8   GBL_initdone
    80278000   trace$buf
    8027a000   TSK_McASP$stack
    8027af98   TSK_McASP$stkptr
    8027b000   _HSRTDX_rec
    8027b760   _HSRTDX_xmt
    8027bcc0   _RTDX_Poll
    8027cd20   BIOS_init
    8027cd20   _BIOS_init
    8027cee8   BIOS$$CLKON
    8027cf28   BIOS$$CLKOFF
    8027cfe8   BIOS_start
    8027cfe8   _BIOS_start
    8027d120   _DEV_init
    8027d240   _POOL_init
    8027d360   _MSGQ32_init
    8027d480   _CLK_enableTimer
    8027d560   _c_int00
    8027d620   _MEM_init
    8027d6c0   _BUF_init
    8027d740   _TSK_init
    8027d7a0   _GIO_init
    8027d7c0   _OBJ_init
    8027d7e0   _DIO_init
    8027d800   $bss
    8027d800   .bss
    8027d800   _MEM_memtab
    8027d800   ___bss__
    8027d80c   _ECM_dispatchTab
    8027dc0c   _GIO
    8027dc10   DDR2
    8027dc10   MEM_MALLOCSEG
    8027dc10   MEM_SEGZERO
    8027dc10   TSK_STACKSEG
    8027dc10   _DDR2
    8027dc14   RTA_fromHost$pipe$dtab
    8027dc20   RTA_toHost$pipe$dtab
    8027dc2c   _DEV_devinit
    8027dc40   _HWI_dispatchTab
    8027dd40   IDL_D_tabbeg
    8027dd44   IDL_D_calibrate
    8027dd48   IDL_D_calbeg
    8027dd4c   LOG_D_system
    8027dd4c   _LOG_D_system
    8027dd50   PIP_D_tabbeg
    8027dd54   PIP_D_tablen
    8027dd58   CLK_R_time
    8027dd5c   CLK_D_timefxn
    8027dd60   CLK_D_tabbeg
    8027dd64   CLK_D_isrhook
    8027dd68   CLK_D_idletime
    8027dd6c   _CLK_htimeDiv
    8027dd70   _CLK_htimeMult
    8027dd74   _CLK_ltimeDiv
    8027dd78   _CLK_ltimeMult
    8027dd7c   _CLK_D_dirty
    8027dd80   _CLK_D_prd
    8027dd84   _CLK_D_tddr
    8027dd88   _CLK_D_countspms
    8027dd8c   PRD_D_tick
    8027dd8c   _PRD_D_tick
    8027dd90   PRD_D_cur
    8027dd94   PRD_D_elapsed
    8027dd98   PRD_D_prevtim
    8027dd9c   PRD_D_scalar
    8027dda0   PRD_D_swihandle
    8027dda4   PRD_D_tabbeg
    8027dda8   PRD_D_tablen
    8027ddac   PRD_D_thook
    8027ddb0   RTA_D_fromHost
    8027ddb4   RTA_D_toHost
    8027ddb8   RTA_D_logval
    8027ddc8   RTA_D_stsval
    8027ddd4   HST_D_chanmask
    8027ddd8   HST_D_tabbeg
    8027dddc   HST_D_tabend
    8027dde0   _GBL_procId
    8027dde4   _GBL_clkIn
    8027dde8   _GBL_freq
    8027ddec   _MEM_D_NUMSEGMENTS
    8027ddf0   _MEM_D_memtab
    8027ddf4   _MEM_D_freelist
    8027ddf8   _MEM_D_lockaddr
    8027ddfc   _MEM_D_unlockaddr
    8027de00   _SYS
    8027de0c   SWI_D_runaddr
    8027de0c   _SWI_data
    8027de10   SWI_D_execaddr
    8027de14   SWI_D_curmask
    8027de18   SWI_D_curset
    8027de1c   SWI_D_lock
    8027de20   SWI_D_curmbox
    8027de24   SWI_D_curfxn
    8027de28   SWI_D_rdybeg
    8027de2c   SWI_D_inswi
    8027de30   SWI_D_rdytab
    8027dea8   _KNL_wFlag
    8027deac   _KNL_wList
    8027deb0   _KNL_alarm
    8027deb4   _KNL_setpri
    8027deb8   _KNL_inactive
    8027debc   _KNL_priority
    8027dec0   _KNL_set
    8027dec4   _KNL_curtask
    8027dec8   _KNL_prevtask
    8027decc   _KNL_curtime
    8027ded0   _KNL_swiptr
    8027ded4   _KNL_curqueue
    8027ded8   _KNL_maxqueue
    8027dedc   _KNL_tswitchfxn
    8027dee0   _KNL_tcreatefxn
    8027dee4   _KNL_tdeletefxn
    8027dee8   _KNL_treadyfxn
    8027deec   _KNL_idlefxn
    8027df68   _EXC_sysTrapTable
    8027df70   _EXC_returnPtr
    8027df8c   _DSP_QU_ACK_REQ_DATA_ID
    8027df94   _DSP_EOL_Status
    8027df98   _DOOR_STATUS
    8027df9c   _MIRROR_STATUS
    8027dfa4   HWI_D_spsave
    8027dfa4   _HWI_D_spsave
    8027dfa4   _HWI_data
    8027dfb0   _HWI_D_inhwi
    8027dfb4   HWI_D_bss
    8027dfb8   HWI_D_ccmask
    8027dfec   LNK_dspFrameRequestMask
    8027dfec   _LNK_dspFrameRequestMask
    8027dff0   LNK_dspFrameReadyMask
    8027dff0   _LNK_dspFrameReadyMask
    8027dff4   LNK_readPend
    8027dff4   _LNK_readPend
    8027dff8   LNK_readDone
    8027dff8   _LNK_readDone
    8027dffc   LNK_readFail
    8027dffc   _LNK_readFail
    8027e000   LNK_writeFail
    8027e000   _LNK_writeFail
    8027e05c   _hwInt
    8027e0ac   _EXC_exceptionHook
    8027e0b0   _EXC_internalHook
    8027e0b4   _EXC_externalHook
    8027e0b8   _EXC_nmiHook
    8027e0d8   _dspCtrlQ
    8027e15c   _TSK_pid
    8027e160   _TSK
    8027e17c   _MajorVersion
    8027e17d   _MinorVersion
    8027e1b0   _DSP_Diagnostic_Status
    8027e1bc   _CLK_DFLTMICROSECS
    8027e1c0   _CLK_D_microseconds
    8027e1d4   _hEdma
    8027e204   _CLK_htimePerLtime
    8027e20c   IDL_D_busyObj
    8027e210   _MEM
    8027e214   _MEM_staticMemtab
    8027e218   _POOL
    8027e234   _MSGQ32
    8027e238   BUF_PoolTxMultiFrameData_s$databeg
    8027e238   ___end__
    8027e238   end
    8027f644   TSK_idle
    8027f644   _TSK_idle
    8027f6a4   TSK_VideoAlgo
    8027f704   TSK_VideoAlgoLow
    8027f764   TSK_VideoAlgoMed
    8027f7c4   TSK_VfwCapture
    8027f824   TSK_VfwControl
    8027f884   TSK_VfwInit
    8027f8e4   TSK_VfwDistri
    8027f944   TSK_VfwConverterBE
    8027f9a4   TSK_VfwDisplay
    8027fa04   TSK_UART0_TX
    8027fa64   TSK_DRAWLIB
    8027fac4   TSK_App
    8027fac4   _TSK_App
    8027fb24   TSK_mcuIPC_rx
    8027fb84   TSK_aAlgoCCF
    8027fbe4   TSK_mcuIPC_tx
    8027fc44   TSK_aAlgoEC
    8027fca4   TSK_FpgaCom_RX
    8027fd04   TSK_FpgaCom_Tx
    8027fd64   TSK_McASP
    8027fd64   _TSK_McASP
    8027fdc4   TSK_Diagnostic
    8027fe18   BUF_McASPQueueMemPool$databeg
    80280278   TSK_UART0_TX$stack
    80280610   TSK_UART0_TX$stkptr
    802808f8   BUF_PoolTxFrames_s$databeg
    80280ad8   BUF_PoolTxMessages_s$databeg
    80280dd8   __CIOBUF_
    80280f04   _hRxAppBuf
    80280f04   hRxAppBuf
    80280f54   BUF_PoolTxFrames_s
    80280f54   _BUF_PoolTxFrames_s
    80280f7c   BUF_PoolTxMessages_s
    80280f7c   _BUF_PoolTxMessages_s
    80280fa4   BUF_PoolTxMultiFrameData_s
    80280fa4   _BUF_PoolTxMultiFrameData_s
    80280fcc   BUF_PoolTxSingleFrameData_s
    80280fcc   _BUF_PoolTxSingleFrameData_s
    80280ff4   BUF_McASPQueueMemPool
    80280ff4   _BUF_McASPQueueMemPool
    80281010   UDEV_McASPDevice$obj
    8028101c   UDEV_McASPDevice$device
    80281034   DIO_DIO_McASP$obj
    80281040   DIO_DIO_McASP$device
    80281058   UDEV_CCDC$obj
    80281064   UDEV_CCDC$device
    8028107c   UDEV_VPBE$obj
    80281088   UDEV_VPBE$device
    ffdfffff   ECM_EVTMASK2
    ffffffff   DDR2_MSGQ32
    ffffffff   DDR2_VIDEO
    ffffffff   ECM_EVTMASK0
    ffffffff   ECM_EVTMASK1
    ffffffff   ECM_EVTMASK3
    ffffffff   GBL_L2MAR128_159
    ffffffff   HST_DSMBUFSEG
    ffffffff   L1D_CACHE
    ffffffff   L1D_RAM
    ffffffff   L1P_CACHE
    ffffffff   L2_CACHE
    ffffffff   L2_RAM
    ffffffff   RTDX_DATAMEMSEG
    ffffffff   _DDR2_MSGQ32
    ffffffff   _DDR2_VIDEO
    ffffffff   _L1D_CACHE
    ffffffff   _L1D_RAM
    ffffffff   _L1P_CACHE
    ffffffff   _L2_CACHE
    ffffffff   _L2_RAM
    ffffffff   ___binit__
    ffffffff   binit
    [2603 symbols]
  • Looks like you have some other objects allocated to ddr2_video section.  Are these part of your far section or have you explicitly placed them in the ddr2_video section in the source code?  If you add up the size of these objects and subtract that from the available space, you end up with the "big hole" George was talking about.  Looks like you just don't have enough memory to fit all of the desired objects in this section.
    ddr2_video
    *          0    80300000    0129ec00     UNINITIALIZED
                      80300000    00b0e800     vfw_frontend.obj (.ddr2_video)
                      80e0e800    0040b000     vfw_ovly_pool.obj (.ddr2_video)
                      81219800    00308400     vfw_backend.obj (.ddr2_video)
                      81521c00    0007d000     vfw_algo_pool.obj (.ddr2_video)
