There was progress!
I deleted the xml file and ran fsclean in a cmd window in the fsclean directory, as seen attached.
Now, I can start up CCS6, use the target configuration launch option, and I get a null exception error (see attached).
However, I am able to connect to target and load or run with symbols as I need.
I've noticed I also get this null exception error when I close CCS6.
So, this error is not preventing debug operation, but something is clearly not right.
I've spent a little time searching, but it is not obvious where this log file is.
Any advice?
Thank you for the help so far. Let me know if I should set your answer answer as the solution and open another question?
Neal
ngohara1991 said:So, this error is not preventing debug operation, but something is clearly not right.
Ah, the infamous "java.lang.NullPointerException". It could mean anything. To me, it is "I wish CCS had a more useful error message to spit out instead this generic default message".
The logs would be helpful. See:
http://processors.wiki.ti.com/index.php/Troubleshooting_CCSv6#CCS_Diagnostic_Logs
ngohara1991 said:Let me know if I should set your answer answer as the solution and open another question?
If you don't mind, that would be good to mark it as resolved. We still need to do some more investigations on real root cause but at least you can progress.
I will split off the new issue into a new thread.
ki
Here is the eclipse log file.
There are no files in the Debug Server Dump Files.
Here is the Install log
1145.ccs_setup_6.1.0.00104_install.log
Log started 11/05/2018 at 15:20:46 Preferred installation mode : unattended Trying to init installer in mode unattended Mode unattended successfully initialized Cannot delete file C:/Users/Neal_OHara/AppData/Local/Temp/bitrock_installer_11152.log Cannot delete file C:/Users/Neal_OHara/AppData/Local/Temp/bitrock_installer_12016.log [15:20:57] Product Name Code Composer Studio 6.1.0 [15:20:57] Product Version 6.1.0.00104 [15:20:57] Preparing to Install Preparing to Install Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin Unpacking files Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\dtplite.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\iconv.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\libexslt.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\libxml2.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\libxslt.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\page.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tcl84.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tcldocstrip.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tclpip84.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tclsh.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tclsh84.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tk84.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tkcon.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\wish.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\wish84.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\zlib.dll Directory already exists: C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\dict8.5.3 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itcl3.3 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\dde1.2 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\http2.5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\msgcat1.3 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\opt0.4 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\platform Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\reg1.1 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tbcload1.4 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\thread2.6.3 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tdom0.8.1 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs Unpacking files Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\libexslt.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\libxml2.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\libxslt.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl84.lib Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tclstub84.lib Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk84.lib Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tkstub84.lib Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\arrow.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\bitmap.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\button.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\buttonbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\calendar.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\ChangeLog Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\choosedir.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\choosefile.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\color.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\combobox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\configure.in Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\dialog.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\dragsite.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\drawerpanel.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\dropsite.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\dynhelp.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\entry.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\font.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\icons.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\init.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\label.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\labelentry.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\labelframe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\license.txt Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\listbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\mainframe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\Makefile.in Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\messagedlg.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\notebook.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\optiontree.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\pagesmgr.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\panedw.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\panelframe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\passwddlg.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\preferences.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\progressbar.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\progressdlg.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\properties.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\readme.txt Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\scrollframe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\scrollview.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\scrollw.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\separator.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\spinbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\splitlist.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\statusbar.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\stddialog.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\tablelist.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\text.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\titleframe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\todo.txt Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\tree.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\ttkbutton.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\utils.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\widget.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\wizard.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\xpm2image.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\bold.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\BWidget.gif.tkico Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\BWidget.png.tkico Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\copy.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\cut.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\downarrow.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\dragfile.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\dragicon.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\error.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\file.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\folder.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\hourglass.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\info.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\italic.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\minus.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\new.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\opcopy.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\open.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\openfold.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\oplink.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\opmove.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\overstrike.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\palette.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\passwd.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\paste.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\plus.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\print.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\question.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\redo.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\save.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\target.xbm Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\underline.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\undo.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\uparrow.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\images\warning.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\de.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\en.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\es.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\fr.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\hu.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\pl.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\BWidget\lang\pt_br.rc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\dict8.5.3\dict853.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\dict8.5.3\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itcl3.3\itcl.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itcl3.3\itcl.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itcl3.3\itcl33.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itcl3.3\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\Archetype.itk Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\itk.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\itk.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\itk33.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\tclIndex Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\Toplevel.itk Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\itk3.3\Widget.itk Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\auto.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\history.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\init.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\ldAout.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\package.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\parray.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\safe.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tclConfig-shared.sh Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tclConfig.sh Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tclIndex Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\word.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\dde1.2\dde.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\dde1.2\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\dde1.2\tcldde12.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\ascii.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\big5.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1250.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1251.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1252.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1253.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1254.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1255.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1256.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1257.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp1258.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp437.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp737.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp775.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp850.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp852.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp855.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp857.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp860.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp861.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp862.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp863.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp864.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp865.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp866.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp869.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp874.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp932.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp936.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp949.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\cp950.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\dingbats.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\ebcdic.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\euc-cn.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\euc-jp.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\euc-kr.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\gb12345.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\gb1988.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\gb2312-raw.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\gb2312.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso2022-jp.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso2022-kr.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso2022.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-1.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-10.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-13.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-14.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-15.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-16.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-2.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-3.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-4.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-5.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-6.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-7.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-8.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\iso8859-9.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\jis0201.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\jis0208.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\jis0212.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\koi8-r.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\koi8-u.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\ksc5601.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\shiftjis.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\symbol.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\encoding\tis-620.enc Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\http2.5\http.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\http2.5\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\msgcat1.3\msgcat.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\msgcat1.3\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\opt0.4\optparse.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\opt0.4\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\platform\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\platform\platform.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\platform\shell.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\reg1.1\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\reg1.1\registry.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\reg1.1\tclreg11.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tbcload1.4\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tbcload1.4\tbcload.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\tbcload1.4\tbcload14.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\thread2.6.3\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\thread2.6.3\thread263.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tcl8.4\thread2.6.3\ttrace.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tdom0.8.1\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tdom0.8.1\tdom.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tdom0.8.1\tdom0.8.1.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tdom0.8.1\tdom081.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\altTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\aquaTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\button.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\clamTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\classicTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\combobox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\cursors.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\defaults.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\dialog.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\entry.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\fonts.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\icons.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\keynav.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\menubutton.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\notebook.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\paned.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\progress.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\scale.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\scrollbar.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\stepTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\tile.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\tile0.7.5.tap Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\tile075.dll Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\treeview.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\utils.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\winTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tile0.7.5\xpTheme.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\bgerror.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\button.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\choosedir.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\clrpick.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\comdlg.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\console.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\dialog.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\entry.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\focus.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\listbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\menu.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\mkpsenc.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\obsolete.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\optMenu.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\palette.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\panedwindow.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\pkgIndex.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\prolog.ps Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\safetk.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\scale.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\scrlbar.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\spinbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tclIndex Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tearoff.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\text.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tk.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tkAppInit.c Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tkConfig-shared.sh Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tkConfig.sh Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\tkfbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\unsupported.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\xmfbox.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\logo.eps Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\logo100.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\logo64.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\logoLarge.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\logoMed.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo.eps Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo100.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo150.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo175.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo200.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\pwrdLogo75.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\README Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\images\tai-ku.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\cs.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\de.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\el.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\en.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\en_gb.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\eo.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\es.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\es_ES.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\fr.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\it.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\nl.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\pl.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\pt.msg Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\lib\tk8.4\msgs\ru.msg Directory already exists: C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util Unpacking files Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\CCSCubeSmall.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\ccs_installini_windows.xml Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\ccs_manifest_windows.xml Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\ofview-x64.zip Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\ofview.zip Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\proxyfinder.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\unzip.exe Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\zip.exe Extracting compressed file C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\OpenedFilesView.chm Extracting compressed file C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\OpenedFilesView.exe Extracting compressed file C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\util\readme.txt Directory already exists: C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates Unpacking files Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ewa1.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ewa2.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ewa3.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ewa4.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\install-certs.bat Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\sd1.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ti1.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ti2.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ti3.p7b Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\certificates\ti4.p7b Directory already exists: C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5 Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\error_report Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\install Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\launch Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\resources Creating directory C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\update_frontend Unpacking files Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Externs.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Images.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\InstallDir.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\json-1.2.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Logger.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\ProgramArgs.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\PropertiesFile.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\PropertiesFileWriter.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Util.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Validation.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\Validation.itcl.contrib Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\BasePane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\FinishPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\ProgressPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\ProgressUpdate.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\SilentProgressPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\panes\ThreadedProgressUpdate.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\AppsJson.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\AppsProduct.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\Component.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\ComponentDetail.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\ConfigFileFeature.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\ConfigFileReader.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\ConfigFileWriter.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\Edition.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\editManifest.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\InstallComponent.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\InstallIni.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\JsonReader.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\Manifest.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\PaneTreeItem.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\ProductFamily.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\UpdateManifest.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\common\xml\XmlReader.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\error_report\error_report.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\error_report\main.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\install\.buildpath Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\install\.project Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\install\InstallComponents.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\launch\main.launch Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\launch\udpate.launch Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\main.tcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\ResponseFile.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\AppsPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\BaseTextPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\BaseTreePane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\ComponentsPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\EmulatorsPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\InstallDirPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\ISAPane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\panes\LicensePane.itcl Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\resources\appIcon.xcf Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\resources\appsIcon.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\resources\CCScube.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\main_frontend\resources\CCSCubeSmall.gif Unpacking C:\Users\Neal_OHara\AppData\Local\Temp\ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\installer_tcl\update_frontend\main.tcl [15:21:00] admin = 1 [15:21:00] installertype = setup [15:21:01] [15:21:01] running C:\Users\Neal_OHara\AppData\Local\Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tclsh "C:/Users/Neal_OHara/AppData/Local/Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5/installer_tcl/main_frontend/main.tcl" --installersrc "//lord/prod/Software/Code_Composer/6.1/English" --installertmp "C:/Users/Neal_OHara/AppData/Local/Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5" --buildid 6.1.0.00104 --installer "//lord/prod/Software/Code_Composer/6.1/English/ccs_setup_6.1.0.00104.exe" --bitness 64-bit Executing C:\Users\Neal_OHara\AppData\Local\Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5\tcl\bin\tclsh "C:/Users/Neal_OHara/AppData/Local/Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5/installer_tcl/main_frontend/main.tcl" --installersrc "//lord/prod/Software/Code_Composer/6.1/English" --installertmp "C:/Users/Neal_OHara/AppData/Local/Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5" --buildid 6.1.0.00104 --installer "//lord/prod/Software/Code_Composer/6.1/English/ccs_setup_6.1.0.00104.exe" --bitness 64-bit Script exit code: 0 Script output: Script stderr: [15:22:56] [15:22:56] [15:22:56] ccsdir = c:/ti/ccsv6 [15:22:56] Found C:\Users\Neal_OHara\AppData\Local\Temp/ccs_fe0bc6b7-bf98-4c7c-446d-b0b3ecae2eb5/finish.txt [15:22:56] deleting Code Composer Studio 0.. 0 [15:22:56] deleting temp directory [15:22:57] Launching ccs 1 Executing C:\ti\ccsv6\eclipse\\ccstudio.exe & Script exit code: 0 Script output: Script stderr: Creating Uninstaller Creating uninstaller 25% Creating uninstaller 50% Creating uninstaller 75% Creating uninstaller 100% Installation completed [15:23:00] ccsdir = c:/ti/ccsv6
Here is the Debug Server Log, with a capture of the exception error:
It shows something about a TargetType exception, near the end?
Let me know if there's anything else I should send.
Neal
This might be the same problem as CCS 6.1.1 Memory Browser can open without all toolbar options, for which SDSCM00052465 was raised.ngohara1991 said:I've been playing around with it, and I think I only get the error if the Memory Browser is open, on the first launch after starting CC6.
SDSCM00052465 was reported as fixed in CCS 6.1.2.
Interesting, it does feel like the same problem.
Although, I am using CCS 6.1.0.00104, which he claims does not repeat the problem.
Anyhow, I will just work around the problem for now. We are trying to use a static version of CCS/TI compilers for archival reasons, so I will stick with this until the project lead approves an update.
Thanks for the explanation of the problem,
Neal
ngohara1991 said:Although, I am using CCS 6.1.0.00104, which he claims does not repeat the problem.
According to your installation logs you posted in the other thread, you have CCSv6.1.1.00022
https://e2e.ti.com/support/tools/ccs/f/81/p/743832/2746582#2746582
Perhaps you updated to that version when you applied the various CCS updates.
ki
