How to install sys/bios bios_6_73_01_01.run in ubuntu, since it complains that the command is not found.
even after giving full permission.
bios_6_73_01_01.run: command not found
Hi Todd,
can you kindly let me know, if the command to run is just the one given below, or anything else?
before i attach the screenshot, probably that i'm using the wrong command.
sudo bios_6_73_01_01.run
Can you just try the bolded command? You should get prompted to select an install directory.
[sanc-build05:/db/vtree/toddm/bios_install]$ ./bios_6_73_01_01.run
Welcome to the bios 6_73_01_01 Setup Wizard.
Please specify the directory where bios 6_73_01_01 will be installed.
The following directories will be created in this directory:
bios_6_73_01_01
Installation Directory [/home/toddm/ti]:
Hi Todd,
I used this command, which for some reason didnt work before, worked now, to change the installation directory
sudo ./bios_6_73_01_01.run --prefix /opt/ti/
