Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
CCS/DSPBIOS: DSP Bios Not running on Windows 10
Part Number: DSPBIOS
Hi
Just received a new laptop. It's running windows 10 64bit. Code Composer Studio is working fine. But I can not open DSP Bios configuration tool.
I am getting the following popup messages:
Popup 1. "Failed to update the system registry. Please try using REGEDIT.
press Ok button to close.
Popup 2. "CoCreateInstance failed: hiervw.dll"
Popup 3. "Unable to Create BIOS Config Server"
Code Composer Studio version is 5.2
DSP version TMS320C6424
DSP/Bios version 5.41.13.42
I can not find a fix for this in the forum.
    as I remember CCS5.2 is not supported on Win10.
    Unfortunately I can't reproduce this error.
    However, I can't help but wonder that the installation has somehow became corrupt. Unfortunately I could find only one instance where this error was found, thus you can follow the procedure mentioned there.
    https://e2e.ti.com/support/tools/ccs/f/81/t/750904
    Hope this helps,
    Rafael
  • Hi
    I reinstalled Code Composer Studio and it solved the problem.
    Thanks for the support
