Hi all,
This problem started up again, now on a fresh install of CCS8.3 with exactly the same symptoms described below. I do have a lot of packages installed under c:\ti and I don't need them all. Should I try to remove some of those to see if TIREX comes back? If yes, what is the recommended way to remove these older packages? Can I just delete them from the file system or should I try to go through an uninstall process?
