CCS/AWR1843BOOST: AWR1843BOOST
Part Number: AWR1843BOOST
Other Parts Discussed in Thread: MATHLIB
Hello!
I am encountering this error when I try to run the demo code for AWR1843BOOST on CCS v9_2. Please help me fix it. Thanks!\
mmw/profiles/subdir_rules.mk:26: recipe for target 'build-1178731025-inproc' failed
js: "./config.bld", line 10: Error: Can't find the target named 'ti.targets.arm.elf.R4F_big_endian' along the path 'C:/ti/dsplib_c64Px_3_4_0_0/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/bios_6_73_01_01/packages;C:/ti/ccs920/xdctools_3_60_01_27_core/packages;..;': please check the spelling of the target's name and that it exists along this path.
xdctools_3_60_01_27_core\gmake.exe: *** No rule to make target '.configuro'. Stop.
js: "C:/ti/ccs920/xdctools_3_60_01_27_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: *** [build-1178731025-inproc] Error 1
gmake: *** [build-1178731025] Error 2
mmw/profiles/subdir_rules.mk:23: recipe for target 'build-1178731025' failed
mmw/profiles/subdir_rules.mk:12: recipe for target 'build-720664609-inproc' failed
gmake[1]: *** [build-720664609-inproc] Error 1
mmw/profiles/subdir_rules.mk:9: recipe for target 'build-720664609' failed
gmake: *** [build-720664609] Error 2
mmw/dss/subdir_rules.mk:19: recipe for target 'build-850254209-inproc' failed
gmake[1]: *** [build-850254209-inproc] Error 1
mmw/dss/subdir_rules.mk:16: recipe for target 'build-850254209' failed
gmake: *** [build-850254209] Error 2
mmw/profiles/subdir_rules.mk:54: recipe for target 'build-1029542113-inproc' failed
gmake[1]: *** [build-1029542113-inproc] Error 1
gmake: *** [build-1029542113] Error 2
mmw/profiles/subdir_rules.mk:51: recipe for target 'build-1029542113' failed
making package.mak (because of package.bld) ...
mmw/mss/subdir_rules.mk:19: recipe for target 'build-193114399-inproc' failed
gmake[1]: *** [build-193114399-inproc] Error 1
gmake: *** [build-193114399] Error 2
mmw/mss/subdir_rules.mk:16: recipe for target 'build-193114399' failed
mmw/profiles/subdir_rules.mk:40: recipe for target 'build-138107679-inproc' failed
gmake[1]: *** [build-138107679-inproc] Error 1
gmake: *** [build-138107679] Error 2
mmw/profiles/subdir_rules.mk:37: recipe for target 'build-138107679' failed
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
Likhitha
  • Hi Likhitha,
    I don't get which application you are trying to build here with CCS.
    But as per last error lines, you need to check Platform and target settings in the CCS project properties
    Target- ti.targets.elf.C674 (DSS), ti.targets.arm.elf.R4Ft (MSS)
    Platform- ti.platforms.cortexR:AWR18XX:false:200
    Jitendra
