CCS/IWR6843: Error: Program "C:\ti\ccs920\ccs\utils\bin\gmake" is not found in PATH
Part Number: IWR6843
I'm trying to build level sensing lab from Industrial Tool Box 4.3.2 in Code Composer Studio. There are two projects in this lab, DSS and MSS. The DSS project is building successfully. While building MSS project, it is getting stuck in between, no progress. Then I stopped the build and got an Error,
I verified the "C:\ti\ccs920\ccs\utils\bin\" PATH and gmake application is there.
And I tried to build another project (vitals sign) from the same tool box and is building successfully.  I'm not sure how to fix the issue.
Anybody faced this issue before and have a fix?
  • Arun,
    Do you happen to have spaces in your workspace/project's directory path? If so, you may be hitting the issue described in this thread. Please check the workarounds noted there.
    Let us know if this does not address your issue.
