CCS: CCS5.5.0 Cannot create new build configuration
I want to press a button to add a new build configuration, but when I press it, nothing happens.
Previously, pressing a button displayed a popup for setting the build configuration.
"Delete" and "Rename" work normally.
It's the same if you try other projects.
How can I do "new create build configuration"?
Thank you in advance,
  • Your screenshot did not come through so I am unable to see the exact issue. However, please note that CCS 5.5 is very old and no longer supported. Is there a reason you need to use this older version? If not, we would highly recommend updating to a more recent version of CCS, which also very likely will not have this issue.
  • sorry. I re-pasted it.
    I am using this version to keep my team and development environment aligned, so the version cannot be changed...
    It didn't happen on another PC using the same version.
    At least I want to know the cause of the problem.
  • I couldn't find any known bug reports about this issue. Also since you mention the problem is not seen on another PC, I suspect it is something specific to the one PC. However there isn't a single cause that we can point to. I would try uninstalling and reinstalling CCS if you haven't already given that a try.
  • Thank you for suggesting.
    Uninstalling the app did not resolve the issue.
    But when I recreated the workspace, it worked as expected.
    I was not sure what the cause was, but this cleared the problem.
    Thank you for your cooperation.
