I followed the instruction in the forum "PSPICE for TI install problem". FIPS is disabled, I restarted my computer and I still get the same error.
Hi Chelsea,
Would you please share this file?
"C:\Users\{YOUR_USER_NAME}\AppData\Roaming\Cadence\PSpiceTIInstall\cdsPspiceTIlog.txt"
JC
11:14:08 AM Wednesday, September 21, 2022 : parameter count = 1 11:14:08 AM Wednesday, September 21, 2022 : -wrapper 11:14:08 AM Wednesday, September 21, 2022 : Module Name: TIPSpice.exe 11:14:08 AM Wednesday, September 21, 2022 : Server OS = False 11:14:08 AM Wednesday, September 21, 2022 : Operating system version : 10.0.0.0 11:14:08 AM Wednesday, September 21, 2022 : Checking for proxy 11:14:09 AM Wednesday, September 21, 2022 : { "LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip", "LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt", "LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json", "LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json", "LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json", "LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip", "LibFirstInstall_LatestVersion": "17.40.006", "Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml", "Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer", "Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe", "Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1", "SoftwareUpdate_Expiry": { "Timestamp": "01:15:2099 15:07:19 GMT", "RegularMessage": { "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ", "HyperLink": "license agreement", "PostHyperLink": "." }, "ForceMessage": { "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the", "HyperLink": "license agreement", "PostHyperLink": ". Click Cancel to exit." } }, "UTM_Keyword": { "TIPSpice_Install": "HQS=pspiceforti", "Full_Install": "HQS=pspiceforti" }, "TI_URLs_Version": [ "17_4_2020_S006" ] } 11:14:09 AM Wednesday, September 21, 2022 : Checking if Licensing URL is accessible 11:14:09 AM Wednesday, September 21, 2022 : Initializing 11:14:09 AM Wednesday, September 21, 2022 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 11:14:09 AM Wednesday, September 21, 2022 : Response Content length = 1724 11:14:09 AM Wednesday, September 21, 2022 : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:14:09 AM Wednesday, September 21, 2022 : Reading Json URL File 11:14:09 AM Wednesday, September 21, 2022 : setting media download server URL from Json File 11:14:09 AM Wednesday, September 21, 2022 : Reading Json URL File 11:14:09 AM Wednesday, September 21, 2022 : setting Dll path from Json File 11:14:09 AM Wednesday, September 21, 2022 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:14:09 AM Wednesday, September 21, 2022 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:14:09 AM Wednesday, September 21, 2022 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 11:14:09 AM Wednesday, September 21, 2022 : LaunchTIPSpiceDlgs() 11:14:09 AM Wednesday, September 21, 2022 : Checking for compnts.dat 11:14:34 AM Wednesday, September 21, 2022 : error_code cdsVblRegisterInstallation: VblSuccess 11:14:34 AM Wednesday, September 21, 2022 : error_code cdsVblRequestLicense: VblSuccess 11:14:39 AM Wednesday, September 21, 2022 : Set Installation and Home Directory() 11:14:39 AM Wednesday, September 21, 2022 : Setting default Installation directory : C:\Cadence\PSpiceTI 11:14:39 AM Wednesday, September 21, 2022 : Reading CDS_HOME environment variable 11:14:39 AM Wednesday, September 21, 2022 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 11:14:39 AM Wednesday, September 21, 2022 : First time installation. CDS_HOME will be set to default HOME directory. 11:14:39 AM Wednesday, September 21, 2022 : Checking if CDS_HOME directory exists and whether user has permission to create it. 11:14:39 AM Wednesday, September 21, 2022 : Creating directory : C:\cds_spb_home 11:14:40 AM Wednesday, September 21, 2022 : Checking for memory space 11:14:40 AM Wednesday, September 21, 2022 : Memory space available 11:14:40 AM Wednesday, September 21, 2022 : Target Dir: C:\Cadence\PSpiceTI 11:14:40 AM Wednesday, September 21, 2022 : Working Dir: C:\cds_spb_home 11:14:40 AM Wednesday, September 21, 2022 : Silent ini file created 11:14:42 AM Wednesday, September 21, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK 11:14:42 AM Wednesday, September 21, 2022 : Starting download of data1.cab Attempt no 1 DataSize is 31794544 11:14:43 AM Wednesday, September 21, 2022 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK 11:14:43 AM Wednesday, September 21, 2022 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480 11:14:43 AM Wednesday, September 21, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini 11:14:43 AM Wednesday, September 21, 2022 : An exception occured which is causing the program to close. 11:14:43 AM Wednesday, September 21, 2022 : Details of exception are : Exception has been thrown by the target of an invocation. 11:14:43 AM Wednesday, September 21, 2022 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at TIPSpice.Utilities.GetFileChecksum(String filePath) at TIPSpice.FileDownloader.StartDownload() at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() 11:14:43 AM Wednesday, September 21, 2022 : Message: An error occurred and PSpice for TI needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall for error details. 11:14:51 AM Wednesday, September 21, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab 11:14:51 AM Wednesday, September 21, 2022 : An exception occured which is causing the program to close. 11:14:51 AM Wednesday, September 21, 2022 : Details of exception are : Exception has been thrown by the target of an invocation. 11:14:51 AM Wednesday, September 21, 2022 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at TIPSpice.Utilities.GetFileChecksum(String filePath) at TIPSpice.FileDownloader.StartDownload() at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() 11:14:51 AM Wednesday, September 21, 2022 : Message: An error occurred and PSpice for TI needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall for error details. 11:15:33 AM Wednesday, September 21, 2022 : parameter count = 1 11:15:33 AM Wednesday, September 21, 2022 : -wrapper 11:15:33 AM Wednesday, September 21, 2022 : Module Name: TIPSpice.exe 11:15:33 AM Wednesday, September 21, 2022 : Server OS = False 11:15:33 AM Wednesday, September 21, 2022 : Operating system version : 10.0.0.0 11:15:33 AM Wednesday, September 21, 2022 : Checking for proxy 11:15:34 AM Wednesday, September 21, 2022 : { "LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip", "LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt", "LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json", "LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json", "LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json", "LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip", "LibFirstInstall_LatestVersion": "17.40.006", "Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml", "Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer", "Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe", "Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1", "SoftwareUpdate_Expiry": { "Timestamp": "01:15:2099 15:07:19 GMT", "RegularMessage": { "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ", "HyperLink": "license agreement", "PostHyperLink": "." }, "ForceMessage": { "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the", "HyperLink": "license agreement", "PostHyperLink": ". Click Cancel to exit." } }, "UTM_Keyword": { "TIPSpice_Install": "HQS=pspiceforti", "Full_Install": "HQS=pspiceforti" }, "TI_URLs_Version": [ "17_4_2020_S006" ] } 11:15:34 AM Wednesday, September 21, 2022 : Checking if Licensing URL is accessible 11:15:34 AM Wednesday, September 21, 2022 : Initializing 11:15:34 AM Wednesday, September 21, 2022 : Deleting file : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 11:15:34 AM Wednesday, September 21, 2022 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 11:15:34 AM Wednesday, September 21, 2022 : Response Content length = 1724 11:15:34 AM Wednesday, September 21, 2022 : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:15:34 AM Wednesday, September 21, 2022 : Reading Json URL File 11:15:34 AM Wednesday, September 21, 2022 : setting media download server URL from Json File 11:15:34 AM Wednesday, September 21, 2022 : Reading Json URL File 11:15:34 AM Wednesday, September 21, 2022 : setting Dll path from Json File 11:15:34 AM Wednesday, September 21, 2022 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:15:34 AM Wednesday, September 21, 2022 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:15:35 AM Wednesday, September 21, 2022 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 11:15:35 AM Wednesday, September 21, 2022 : LaunchTIPSpiceDlgs() 11:15:35 AM Wednesday, September 21, 2022 : Checking for compnts.dat 11:15:45 AM Wednesday, September 21, 2022 : error_code cdsVblRegisterInstallation: VblSuccess 11:15:45 AM Wednesday, September 21, 2022 : error_code cdsVblRequestLicense: VblSuccess 11:15:48 AM Wednesday, September 21, 2022 : Set Installation and Home Directory() 11:15:48 AM Wednesday, September 21, 2022 : Setting default Installation directory : C:\Cadence\PSpiceTI 11:15:48 AM Wednesday, September 21, 2022 : Reading CDS_HOME environment variable 11:15:48 AM Wednesday, September 21, 2022 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 11:15:48 AM Wednesday, September 21, 2022 : First time installation. CDS_HOME will be set to default HOME directory. 11:15:48 AM Wednesday, September 21, 2022 : Checking if CDS_HOME directory exists and whether user has permission to create it. 11:15:48 AM Wednesday, September 21, 2022 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 11:15:56 AM Wednesday, September 21, 2022 : Checking for memory space 11:15:56 AM Wednesday, September 21, 2022 : Memory space available 11:15:56 AM Wednesday, September 21, 2022 : Target Dir: C:\Cadence\PSpiceTI 11:15:56 AM Wednesday, September 21, 2022 : Working Dir: C:\cds_spb_home 11:15:56 AM Wednesday, September 21, 2022 : Silent ini file created 11:15:56 AM Wednesday, September 21, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:15:56 AM Wednesday, September 21, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:15:56 AM Wednesday, September 21, 2022 : Exception has been thrown by the target of an invocation. 11:15:56 AM Wednesday, September 21, 2022 : Exception has been thrown by the target of an invocation. 11:15:56 AM Wednesday, September 21, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:15:56 AM Wednesday, September 21, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:30:11 AM Wednesday, September 21, 2022 : parameter count = 1 11:30:11 AM Wednesday, September 21, 2022 : -wrapper 11:30:12 AM Wednesday, September 21, 2022 : Module Name: TIPSpice.exe 11:30:12 AM Wednesday, September 21, 2022 : Server OS = False 11:30:12 AM Wednesday, September 21, 2022 : Operating system version : 10.0.0.0 11:30:12 AM Wednesday, September 21, 2022 : Checking for proxy 11:30:12 AM Wednesday, September 21, 2022 : { "LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip", "LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt", "LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json", "LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json", "LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json", "LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip", "LibFirstInstall_LatestVersion": "17.40.006", "Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml", "Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer", "Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe", "Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1", "SoftwareUpdate_Expiry": { "Timestamp": "01:15:2099 15:07:19 GMT", "RegularMessage": { "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ", "HyperLink": "license agreement", "PostHyperLink": "." }, "ForceMessage": { "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the", "HyperLink": "license agreement", "PostHyperLink": ". Click Cancel to exit." } }, "UTM_Keyword": { "TIPSpice_Install": "HQS=pspiceforti", "Full_Install": "HQS=pspiceforti" }, "TI_URLs_Version": [ "17_4_2020_S006" ] } 11:30:12 AM Wednesday, September 21, 2022 : Checking if Licensing URL is accessible 11:30:12 AM Wednesday, September 21, 2022 : Initializing 11:30:12 AM Wednesday, September 21, 2022 : Deleting file : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 11:30:12 AM Wednesday, September 21, 2022 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 11:30:12 AM Wednesday, September 21, 2022 : Response Content length = 1724 11:30:12 AM Wednesday, September 21, 2022 : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:30:12 AM Wednesday, September 21, 2022 : Reading Json URL File 11:30:12 AM Wednesday, September 21, 2022 : setting media download server URL from Json File 11:30:12 AM Wednesday, September 21, 2022 : Reading Json URL File 11:30:12 AM Wednesday, September 21, 2022 : setting Dll path from Json File 11:30:12 AM Wednesday, September 21, 2022 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:30:12 AM Wednesday, September 21, 2022 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:30:12 AM Wednesday, September 21, 2022 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 11:30:12 AM Wednesday, September 21, 2022 : LaunchTIPSpiceDlgs() 11:30:12 AM Wednesday, September 21, 2022 : Checking for compnts.dat 11:30:53 AM Wednesday, September 21, 2022 : error_code cdsVblRegisterInstallation: VblSuccess 11:30:53 AM Wednesday, September 21, 2022 : error_code cdsVblRequestLicense: VblSuccess 11:30:57 AM Wednesday, September 21, 2022 : Set Installation and Home Directory() 11:30:57 AM Wednesday, September 21, 2022 : Setting default Installation directory : C:\Cadence\PSpiceTI 11:30:57 AM Wednesday, September 21, 2022 : Reading CDS_HOME environment variable 11:30:57 AM Wednesday, September 21, 2022 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 11:30:57 AM Wednesday, September 21, 2022 : First time installation. CDS_HOME will be set to default HOME directory. 11:30:57 AM Wednesday, September 21, 2022 : Checking if CDS_HOME directory exists and whether user has permission to create it. 11:30:57 AM Wednesday, September 21, 2022 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 11:30:59 AM Wednesday, September 21, 2022 : Checking for memory space 11:30:59 AM Wednesday, September 21, 2022 : Memory space available 11:30:59 AM Wednesday, September 21, 2022 : Target Dir: C:\Cadence\PSpiceTI 11:30:59 AM Wednesday, September 21, 2022 : Working Dir: C:\cds_spb_home 11:30:59 AM Wednesday, September 21, 2022 : Silent ini file created 11:30:59 AM Wednesday, September 21, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:30:59 AM Wednesday, September 21, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:30:59 AM Wednesday, September 21, 2022 : Exception has been thrown by the target of an invocation. 11:30:59 AM Wednesday, September 21, 2022 : Exception has been thrown by the target of an invocation. 11:30:59 AM Wednesday, September 21, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 11:30:59 AM Wednesday, September 21, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 1:37:48 PM Thursday, September 22, 2022 : parameter count = 1 1:37:48 PM Thursday, September 22, 2022 : -wrapper 1:37:49 PM Thursday, September 22, 2022 : Module Name: TIPSpice.exe 1:37:49 PM Thursday, September 22, 2022 : Server OS = False 1:37:49 PM Thursday, September 22, 2022 : Operating system version : 10.0.0.0 1:37:49 PM Thursday, September 22, 2022 : Checking for proxy 1:37:49 PM Thursday, September 22, 2022 : { "LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip", "LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt", "LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json", "LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json", "LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json", "LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip", "LibFirstInstall_LatestVersion": "17.40.006", "Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml", "Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer", "Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe", "Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1", "SoftwareUpdate_Expiry": { "Timestamp": "01:15:2099 15:07:19 GMT", "RegularMessage": { "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ", "HyperLink": "license agreement", "PostHyperLink": "." }, "ForceMessage": { "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the", "HyperLink": "license agreement", "PostHyperLink": ". Click Cancel to exit." } }, "UTM_Keyword": { "TIPSpice_Install": "HQS=pspiceforti", "Full_Install": "HQS=pspiceforti" }, "TI_URLs_Version": [ "17_4_2020_S006" ] } 1:37:49 PM Thursday, September 22, 2022 : Checking if Licensing URL is accessible 1:37:49 PM Thursday, September 22, 2022 : Initializing 1:37:49 PM Thursday, September 22, 2022 : Deleting file : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 1:37:49 PM Thursday, September 22, 2022 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 1:37:49 PM Thursday, September 22, 2022 : Response Content length = 1724 1:37:49 PM Thursday, September 22, 2022 : C:\Users\Chelsea\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 1:37:49 PM Thursday, September 22, 2022 : Reading Json URL File 1:37:49 PM Thursday, September 22, 2022 : setting media download server URL from Json File 1:37:49 PM Thursday, September 22, 2022 : Reading Json URL File 1:37:49 PM Thursday, September 22, 2022 : setting Dll path from Json File 1:37:49 PM Thursday, September 22, 2022 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 1:37:49 PM Thursday, September 22, 2022 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 1:37:49 PM Thursday, September 22, 2022 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 1:37:49 PM Thursday, September 22, 2022 : LaunchTIPSpiceDlgs() 1:37:49 PM Thursday, September 22, 2022 : Checking for compnts.dat 1:38:06 PM Thursday, September 22, 2022 : error_code cdsVblRegisterInstallation: VblSuccess 1:38:07 PM Thursday, September 22, 2022 : error_code cdsVblRequestLicense: VblSuccess 1:38:10 PM Thursday, September 22, 2022 : Set Installation and Home Directory() 1:38:10 PM Thursday, September 22, 2022 : Setting default Installation directory : C:\Cadence\PSpiceTI 1:38:10 PM Thursday, September 22, 2022 : Reading CDS_HOME environment variable 1:38:10 PM Thursday, September 22, 2022 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 1:38:10 PM Thursday, September 22, 2022 : First time installation. CDS_HOME will be set to default HOME directory. 1:38:10 PM Thursday, September 22, 2022 : Checking if CDS_HOME directory exists and whether user has permission to create it. 1:38:10 PM Thursday, September 22, 2022 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 1:38:12 PM Thursday, September 22, 2022 : Checking for memory space 1:38:12 PM Thursday, September 22, 2022 : Memory space available 1:38:12 PM Thursday, September 22, 2022 : Target Dir: C:\Cadence\PSpiceTI 1:38:12 PM Thursday, September 22, 2022 : Working Dir: C:\cds_spb_home 1:38:12 PM Thursday, September 22, 2022 : Silent ini file created 1:38:12 PM Thursday, September 22, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 1:38:12 PM Thursday, September 22, 2022 : Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 1:38:12 PM Thursday, September 22, 2022 : Exception has been thrown by the target of an invocation. 1:38:12 PM Thursday, September 22, 2022 : Exception has been thrown by the target of an invocation. 1:38:12 PM Thursday, September 22, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation. 1:38:12 PM Thursday, September 22, 2022 : Message: Installation cannot proceed because the system does not allow non FIPS-compliant encryption. Disable the option to use FIPS compliant algorithms for encryption in the Local Security Policy window, restart the computer, and start installation.
Thanks Chelsea. This confirms the error you got although it is weird if the machine has been rebooted. We'll let you know if additional test is needed.
JC
Hi Chelsea,
Once rebooted, the setting should be present in the Windows registry. Would you please double-check the value of "Enabled" DWORD value in the following registry after restarting the machine:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\FipsAlgorithmPolicy?
Example from my system:
thanks,
JC
Hi Chelsea,
Please try this:
Please let us know what happens.
JC
