PSPICE-FOR-TI: PSpice for TI installation stops on Configure Library
exactly same as here, but no way to complete the installation.I also tried to launch orLibraryDownload from the command line, just for test. Here is the result:
then, nothing happens.
Logs attached. Thanks!
The PSpice for TI installer accesses the internet to download and install various packages. Before starting the installer, ensure the following:
	1.	Internet connection is available
	2.	Security protocol TLS 1.2 is enabled
	3.	Following endpoints or resource locations are accessible from the system:
		a.	https://pcb.cadence.com/startPages
		b.	https://software-dl.ti.com/pspice
		c.	https://cdsplicwc.cadence.com/chws
If proxy credentials are required to access the Internet, provide the same when requested by the installer.
12:55:45 giovedì 15 giugno 2023 : *****CONNECTION STATUS CHECK*****
12:55:45 giovedì 15 giugno 2023 : Internet Connection : Available (Passed)
12:55:45 giovedì 15 giugno 2023 : Security Protocol TLS 1.2: Available. If PSpice for TI installation fails, unblock TLS 1.2
12:55:47 giovedì 15 giugno 2023 : Proxy Test : Proxy Credentials not needed
12:10:03 giovedì 15 giugno 2023 : parameter count = 1
12:10:03 giovedì 15 giugno 2023 : -wrapper
12:10:03 giovedì 15 giugno 2023 : Module Name: TIPSpice.exe
12:10:03 giovedì 15 giugno 2023 : Server OS = False
12:10:03 giovedì 15 giugno 2023 : Operating system version : 10.0.0.0
12:10:03 giovedì 15 giugno 2023 : Checking for proxy
12:10:04 giovedì 15 giugno 2023 : {
	"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
	"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
	"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
	"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
	"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
	"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
	"LibFirstInstall_LatestVersion": "17.40.009",
	"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
	"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
	"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
	"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
	"SoftwareUpdate_Expiry": {
		"Timestamp": "01:15:2099 15:07:19 GMT",
		"RegularMessage": {
			"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
			"HyperLink": "license agreement",
			"PostHyperLink": "."
		"ForceMessage": {
			"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
			"PostHyperLink": ".  Click Cancel to exit."
	"UTM_Keyword": {
		"TIPSpice_Install": "HQS=pspiceforti",
		"Full_Install": "HQS=pspiceforti"
	"TI_URLs_Version": [
		"17_4_2020_S006",
		"17_4_2020_S009"
12:10:04 giovedì 15 giugno 2023 : Checking if Licensing URL is accessible
12:10:05 giovedì 15 giugno 2023 : Initializing
12:10:05 giovedì 15 giugno 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:10:05 giovedì 15 giugno 2023 : Response Content length = 1745
12:10:05 giovedì 15 giugno 2023 : C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1745
12:10:05 giovedì 15 giugno 2023 : Reading Json URL File
12:10:05 giovedì 15 giugno 2023 : setting media download server URL from Json File
12:10:05 giovedì 15 giugno 2023 : setting Dll path from Json File
12:10:05 giovedì 15 giugno 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:10:05 giovedì 15 giugno 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:10:06 giovedì 15 giugno 2023 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system:
12:10:06 giovedì 15 giugno 2023 : LaunchTIPSpiceDlgs()
12:10:06 giovedì 15 giugno 2023 : Checking for compnts.dat
12:10:29 giovedì 15 giugno 2023 : error_code cdsVblRegisterInstallation: VblSuccess
12:10:30 giovedì 15 giugno 2023 : error_code cdsVblRequestLicense: VblSuccess
12:10:33 giovedì 15 giugno 2023 : Set Installation and Home Directory()
12:10:33 giovedì 15 giugno 2023 : Setting default Installation directory : C:\Cadence\PSpiceTI
12:10:33 giovedì 15 giugno 2023 : Reading CDS_HOME environment variable
12:10:33 giovedì 15 giugno 2023 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
12:10:33 giovedì 15 giugno 2023 : First time installation. CDS_HOME will be set to default HOME directory.
12:10:33 giovedì 15 giugno 2023 : Checking if CDS_HOME directory exists and whether user has permission to create it.
12:10:33 giovedì 15 giugno 2023 : Creating directory : C:\cds_spb_home
12:10:37 giovedì 15 giugno 2023 : opening BrowseInstallationFolder
12:10:47 giovedì 15 giugno 2023 : Installation folder changed to C:\DevTools
12:11:04 giovedì 15 giugno 2023 : Checking for memory space
12:11:04 giovedì 15 giugno 2023 : Memory space available
12:11:04 giovedì 15 giugno 2023 : Target Dir: C:\DevTools\Cadence\PSpice for TI
12:11:04 giovedì 15 giugno 2023 : Working Dir: C:\cds_spb_home
12:11:04 giovedì 15 giugno 2023 : Silent ini file created
12:11:07 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
12:11:07 giovedì 15 giugno 2023 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
12:11:07 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
12:11:07 giovedì 15 giugno 2023 : Completing download of 0x0409.ini
12:11:07 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
12:11:07 giovedì 15 giugno 2023 : Starting download of data1.cab   Attempt no 1 DataSize is 31794546
12:11:11 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
12:11:11 giovedì 15 giugno 2023 : Starting download of data1.hdr   Attempt no 1 DataSize is 5038454
12:11:16 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
12:11:16 giovedì 15 giugno 2023 : Completing download of data1.hdr
12:11:19 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
12:11:19 giovedì 15 giugno 2023 : Starting download of data2.cab   Attempt no 1 DataSize is 170127360
12:11:21 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
12:11:21 giovedì 15 giugno 2023 : Completing download of data1.cab
12:11:22 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
12:11:22 giovedì 15 giugno 2023 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
12:14:22 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
12:14:22 giovedì 15 giugno 2023 : Completing download of data2.cab
12:14:27 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
12:14:27 giovedì 15 giugno 2023 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
12:15:16 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
12:15:16 giovedì 15 giugno 2023 : Completing download of data3.cab
12:15:19 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
12:15:19 giovedì 15 giugno 2023 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
12:18:55 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
12:18:56 giovedì 15 giugno 2023 : Completing download of data4.cab
12:18:59 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
12:18:59 giovedì 15 giugno 2023 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
12:19:45 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
12:19:45 giovedì 15 giugno 2023 : Completing download of data5.cab
12:19:47 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
12:19:47 giovedì 15 giugno 2023 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
12:23:32 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
12:23:33 giovedì 15 giugno 2023 : Completing download of data6.cab
12:23:36 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
12:23:36 giovedì 15 giugno 2023 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
12:24:45 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
12:24:46 giovedì 15 giugno 2023 : Completing download of data7.cab
12:24:49 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
12:24:49 giovedì 15 giugno 2023 : Starting download of data9.cab   Attempt no 1 DataSize is 83923568
12:26:19 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
12:26:19 giovedì 15 giugno 2023 : Completing download of data9.cab
12:26:21 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
12:26:21 giovedì 15 giugno 2023 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954488
12:26:23 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
12:26:23 giovedì 15 giugno 2023 : Completing download of installsetup.exe
12:26:25 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
12:26:25 giovedì 15 giugno 2023 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637496
12:26:27 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
12:26:27 giovedì 15 giugno 2023 : Completing download of ISSetup.dll
12:26:30 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
12:26:30 giovedì 15 giugno 2023 : Starting download of layout.bin   Attempt no 1 DataSize is 994
12:26:30 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
12:26:30 giovedì 15 giugno 2023 : Completing download of layout.bin
12:26:32 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
12:26:32 giovedì 15 giugno 2023 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
12:26:32 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
12:26:32 giovedì 15 giugno 2023 : Completing download of pspInstall.pdf
12:26:35 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
12:26:35 giovedì 15 giugno 2023 : Starting download of setup.bmp   Attempt no 1 DataSize is 414056
12:26:36 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
12:26:36 giovedì 15 giugno 2023 : Completing download of setup.bmp
12:26:39 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
12:26:39 giovedì 15 giugno 2023 : Starting download of setup.ini   Attempt no 1 DataSize is 2430
12:26:39 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
12:26:39 giovedì 15 giugno 2023 : Completing download of setup.ini
12:26:44 giovedì 15 giugno 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
12:26:44 giovedì 15 giugno 2023 : Starting download of setup.inx   Attempt no 1 DataSize is 575660
12:26:44 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
12:26:44 giovedì 15 giugno 2023 : Completing download of setup.inx
12:26:55 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
12:26:55 giovedì 15 giugno 2023 : Completing download of data8.cab
12:26:55 giovedì 15 giugno 2023 : 1116340 1116340
12:26:55 giovedì 15 giugno 2023 : Setup exe path: C:\DevTools\Cadence\PSpice for TI\PSpiceTI/software/\installsetup.exe
12:26:56 giovedì 15 giugno 2023 : Allegro Installation Start pid: 9396
12:27:08 giovedì 15 giugno 2023 : NumberOfComponentsToBeInstalled = 40106
12:27:08 giovedì 15 giugno 2023 : Updated NumberOfComponentsToBeInstalled = 40913,08
12:27:08 giovedì 15 giugno 2023 : Updated NumberOfComponentsInstalled = 402
12:30:48 giovedì 15 giugno 2023 : Feature transfer complete..disabling close button
12:30:48 giovedì 15 giugno 2023 : Installing: Runtime packages and redistributables
12:31:06 giovedì 15 giugno 2023 : Installing: Configuring documentation
12:31:07 giovedì 15 giugno 2023 : Installing: Configuring file associations
12:31:08 giovedì 15 giugno 2023 : Installing: Setting permissions for files and folders
12:31:13 giovedì 15 giugno 2023 : Installing: Creating Registries
12:31:13 giovedì 15 giugno 2023 : Installing: SQL Lite ODBC Driver
12:31:14 giovedì 15 giugno 2023 : Installing: Finishing Installation
12:31:31 giovedì 15 giugno 2023 : Running Library Configuration Executable
12:31:31 giovedì 15 giugno 2023 : Starting process: C:\DevTools\Cadence\PSpice for TI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
12:43:10 giovedì 15 giugno 2023 : orLibraryDownLoad.exe returned : 0
12:43:10 giovedì 15 giugno 2023 : Library Installation completed successfully.
12:43:10 giovedì 15 giugno 2023 : Downloading License file
12:43:11 giovedì 15 giugno 2023 : error_code cdsVblDownloadLicense: VblSuccess
12:43:11 giovedì 15 giugno 2023 : Downloading License file finish
12:43:11 giovedì 15 giugno 2023 : Removing generic credentials.
12:43:11 giovedì 15 giugno 2023 : PrepareUninstallation
12:43:11 giovedì 15 giugno 2023 : strLocalPath: C:\Users\Voulaz\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
12:43:11 giovedì 15 giugno 2023 : strLocalConfigPath: C:\Users\Voulaz\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
12:43:11 giovedì 15 giugno 2023 : strCachedLocForFV174Installer: "C:\Users\Voulaz\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
12:43:11 giovedì 15 giugno 2023 : ClearRunOnceIfNotNeeded()
12:43:11 giovedì 15 giugno 2023 : installSetupValue =
12:47:46 giovedì 15 giugno 2023 : parameter count = 1
12:47:46 giovedì 15 giugno 2023 : -wrapper
12:47:46 giovedì 15 giugno 2023 : Module Name: TIPSpice.exe
12:47:46 giovedì 15 giugno 2023 : Server OS = False
12:47:46 giovedì 15 giugno 2023 : Operating system version : 10.0.0.0
12:47:46 giovedì 15 giugno 2023 : Checking for proxy
12:47:46 giovedì 15 giugno 2023 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006",
		"17_4_2020_S009"
12:47:46 giovedì 15 giugno 2023 : Checking if Licensing URL is accessible
12:47:47 giovedì 15 giugno 2023 : Initializing
12:47:47 giovedì 15 giugno 2023 : Deleting file : C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:47:48 giovedì 15 giugno 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:47:48 giovedì 15 giugno 2023 : Response Content length = 1745
12:47:48 giovedì 15 giugno 2023 : C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1745
12:47:48 giovedì 15 giugno 2023 : Reading Json URL File
12:47:48 giovedì 15 giugno 2023 : setting media download server URL from Json File
12:47:48 giovedì 15 giugno 2023 : setting Dll path from Json File
12:47:48 giovedì 15 giugno 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:47:48 giovedì 15 giugno 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:47:48 giovedì 15 giugno 2023 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system: 17.40.009
12:47:48 giovedì 15 giugno 2023 : Repair mode
12:47:48 giovedì 15 giugno 2023 : Check if CDS_HOME is set
12:47:48 giovedì 15 giugno 2023 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
12:47:48 giovedì 15 giugno 2023 : LaunchTIPSpiceDlgs()
12:47:48 giovedì 15 giugno 2023 : Checking for compnts.dat
12:48:03 giovedì 15 giugno 2023 : error_code cdsVblRegisterInstallation: VblSuccess
12:48:04 giovedì 15 giugno 2023 : error_code cdsVblRequestLicense: VblSuccess
12:48:07 giovedì 15 giugno 2023 : Set Installation and Home Directory()
12:48:11 giovedì 15 giugno 2023 : Checking for memory space
12:48:11 giovedì 15 giugno 2023 : Memory space available
12:48:11 giovedì 15 giugno 2023 : Target Dir: C:\DevTools\Cadence\PSpice for TI
12:48:11 giovedì 15 giugno 2023 : Working Dir: C:\cds_spb_home
12:48:11 giovedì 15 giugno 2023 : Silent ini file created
12:48:11 giovedì 15 giugno 2023 : Skipping download of 0x0409.ini DataSize is 22480
12:48:11 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
12:48:11 giovedì 15 giugno 2023 : Skipping download of data1.hdr DataSize is 5038454
12:48:11 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
12:48:11 giovedì 15 giugno 2023 : Skipping download of data1.cab DataSize is 31794546
12:48:11 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
12:48:11 giovedì 15 giugno 2023 : Skipping download of data2.cab DataSize is 170127360
12:48:11 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
12:48:12 giovedì 15 giugno 2023 : Skipping download of data3.cab DataSize is 209715200
12:48:12 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
12:48:12 giovedì 15 giugno 2023 : Skipping download of data4.cab DataSize is 209715200
12:48:12 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
12:48:12 giovedì 15 giugno 2023 : Skipping download of data5.cab DataSize is 209715200
12:48:12 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
12:48:13 giovedì 15 giugno 2023 : Skipping download of data6.cab DataSize is 209715200
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
12:48:13 giovedì 15 giugno 2023 : Skipping download of data7.cab DataSize is 209715200
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
12:48:13 giovedì 15 giugno 2023 : Skipping download of data9.cab DataSize is 83923568
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
12:48:13 giovedì 15 giugno 2023 : Skipping download of installsetup.exe DataSize is 954488
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
12:48:13 giovedì 15 giugno 2023 : Skipping download of ISSetup.dll DataSize is 1637496
12:48:13 giovedì 15 giugno 2023 : Skipping download of pspInstall.pdf DataSize is 85357
12:48:13 giovedì 15 giugno 2023 : Skipping download of layout.bin DataSize is 994
12:48:13 giovedì 15 giugno 2023 : Skipping download of setup.ini DataSize is 2430
12:48:13 giovedì 15 giugno 2023 : Skipping download of setup.inx DataSize is 575660
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
12:48:13 giovedì 15 giugno 2023 : Skipping download of setup.bmp DataSize is 414056
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
12:48:13 giovedì 15 giugno 2023 : 460472 460472
12:48:13 giovedì 15 giugno 2023 : Setup exe path: C:\DevTools\Cadence\PSpice for TI\PSpiceTI/software/\installsetup.exe
12:48:13 giovedì 15 giugno 2023 : Skipping download of data8.cab DataSize is 209715200
12:48:13 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
12:48:13 giovedì 15 giugno 2023 : Allegro Installation Start pid: 21408
12:48:26 giovedì 15 giugno 2023 : NumberOfComponentsToBeInstalled = 40106
12:48:26 giovedì 15 giugno 2023 : Updated NumberOfComponentsToBeInstalled = 40913,08
12:48:26 giovedì 15 giugno 2023 : Updated NumberOfComponentsInstalled = 402
12:51:31 giovedì 15 giugno 2023 : Feature transfer complete..disabling close button
12:51:31 giovedì 15 giugno 2023 : Installing: Runtime packages and redistributables
12:51:48 giovedì 15 giugno 2023 : Installing: Configuring documentation
12:51:49 giovedì 15 giugno 2023 : Installing: Configuring file associations
12:51:49 giovedì 15 giugno 2023 : Installing: Setting permissions for files and folders
12:51:54 giovedì 15 giugno 2023 : Installing: Creating Registries
12:51:54 giovedì 15 giugno 2023 : Installing: SQL Lite ODBC Driver
12:51:55 giovedì 15 giugno 2023 : Installing: Finishing Installation
12:52:13 giovedì 15 giugno 2023 : Running Library Configuration Executable
12:52:13 giovedì 15 giugno 2023 : Starting process: C:\DevTools\Cadence\PSpice for TI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
12:54:44 giovedì 15 giugno 2023 : Exiting Installation Installing Dialog
12:54:44 giovedì 15 giugno 2023 : An exception occured which is causing the program to close.
12:54:44 giovedì 15 giugno 2023 : Details of exception are : Not enough quota is available to process this command
12:54:44 giovedì 15 giugno 2023 : Stack Trace for the exception is    at MS.Win32.ManagedWndProcTracker.HookUpDefWindowProc(IntPtr hwnd)
   at MS.Win32.ManagedWndProcTracker.OnAppDomainProcessExit()
   at MS.Internal.ShutDownListener.HandleShutDown(Object sender, EventArgs e)
12:54:44 giovedì 15 giugno 2023 : Message: An error occurred and PSpice for TI needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall for error details.
12:55:45 giovedì 15 giugno 2023 : parameter count = 1
12:55:45 giovedì 15 giugno 2023 : -wrapper
12:55:45 giovedì 15 giugno 2023 : Module Name: TIPSpice.exe
12:55:45 giovedì 15 giugno 2023 : Server OS = False
12:55:45 giovedì 15 giugno 2023 : Operating system version : 10.0.0.0
12:55:45 giovedì 15 giugno 2023 : Checking for proxy
12:55:47 giovedì 15 giugno 2023 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006",
		"17_4_2020_S009"
12:55:47 giovedì 15 giugno 2023 : Checking if Licensing URL is accessible
12:55:49 giovedì 15 giugno 2023 : Initializing
12:55:49 giovedì 15 giugno 2023 : Deleting file : C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:55:49 giovedì 15 giugno 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:55:49 giovedì 15 giugno 2023 : Response Content length = 1745
12:55:49 giovedì 15 giugno 2023 : C:\Users\Voulaz\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1745
12:55:49 giovedì 15 giugno 2023 : Reading Json URL File
12:55:49 giovedì 15 giugno 2023 : setting media download server URL from Json File
12:55:49 giovedì 15 giugno 2023 : setting Dll path from Json File
12:55:49 giovedì 15 giugno 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:55:49 giovedì 15 giugno 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:55:51 giovedì 15 giugno 2023 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system: 17.40.009
12:55:51 giovedì 15 giugno 2023 : Repair mode
12:55:51 giovedì 15 giugno 2023 : Check if CDS_HOME is set
12:55:51 giovedì 15 giugno 2023 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
12:55:51 giovedì 15 giugno 2023 : LaunchTIPSpiceDlgs()
12:55:51 giovedì 15 giugno 2023 : Checking for compnts.dat
12:55:57 giovedì 15 giugno 2023 : error_code cdsVblRegisterInstallation: VblSuccess
12:55:58 giovedì 15 giugno 2023 : error_code cdsVblRequestLicense: VblSuccess
12:56:01 giovedì 15 giugno 2023 : Set Installation and Home Directory()
12:56:02 giovedì 15 giugno 2023 : Checking for memory space
12:56:02 giovedì 15 giugno 2023 : Memory space available
12:56:02 giovedì 15 giugno 2023 : Target Dir: C:\DevTools\Cadence\PSpice for TI
12:56:02 giovedì 15 giugno 2023 : Working Dir: C:\cds_spb_home
12:56:02 giovedì 15 giugno 2023 : Silent ini file created
12:56:02 giovedì 15 giugno 2023 : Skipping download of 0x0409.ini DataSize is 22480
12:56:02 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
12:56:02 giovedì 15 giugno 2023 : Skipping download of data1.hdr DataSize is 5038454
12:56:02 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
12:56:03 giovedì 15 giugno 2023 : Skipping download of data1.cab DataSize is 31794546
12:56:03 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
12:56:03 giovedì 15 giugno 2023 : Skipping download of data2.cab DataSize is 170127360
12:56:03 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
12:56:03 giovedì 15 giugno 2023 : Skipping download of data3.cab DataSize is 209715200
12:56:03 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
12:56:04 giovedì 15 giugno 2023 : Skipping download of data4.cab DataSize is 209715200
12:56:04 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
12:56:04 giovedì 15 giugno 2023 : Skipping download of data5.cab DataSize is 209715200
12:56:04 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
12:56:04 giovedì 15 giugno 2023 : Skipping download of data6.cab DataSize is 209715200
12:56:04 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
12:56:05 giovedì 15 giugno 2023 : Skipping download of data7.cab DataSize is 209715200
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
12:56:05 giovedì 15 giugno 2023 : Skipping download of data9.cab DataSize is 83923568
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
12:56:05 giovedì 15 giugno 2023 : Skipping download of installsetup.exe DataSize is 954488
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
12:56:05 giovedì 15 giugno 2023 : Skipping download of ISSetup.dll DataSize is 1637496
12:56:05 giovedì 15 giugno 2023 : Skipping download of pspInstall.pdf DataSize is 85357
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
12:56:05 giovedì 15 giugno 2023 : Skipping download of setup.ini DataSize is 2430
12:56:05 giovedì 15 giugno 2023 : Skipping download of setup.inx DataSize is 575660
12:56:05 giovedì 15 giugno 2023 : Skipping download of layout.bin DataSize is 994
12:56:05 giovedì 15 giugno 2023 : Skipping download of setup.bmp DataSize is 414056
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
12:56:05 giovedì 15 giugno 2023 : 787872 787872
12:56:05 giovedì 15 giugno 2023 : Setup exe path: C:\DevTools\Cadence\PSpice for TI\PSpiceTI/software/\installsetup.exe
12:56:05 giovedì 15 giugno 2023 : Skipping download of data8.cab DataSize is 209715200
12:56:05 giovedì 15 giugno 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
12:56:05 giovedì 15 giugno 2023 : Allegro Installation Start pid: 23136
12:56:18 giovedì 15 giugno 2023 : NumberOfComponentsToBeInstalled = 40106
12:56:18 giovedì 15 giugno 2023 : Updated NumberOfComponentsToBeInstalled = 40913,08
12:56:18 giovedì 15 giugno 2023 : Updated NumberOfComponentsInstalled = 402
12:57:48 giovedì 15 giugno 2023 : Feature transfer complete..disabling close button
12:57:48 giovedì 15 giugno 2023 : Installing: Runtime packages and redistributables
12:58:05 giovedì 15 giugno 2023 : Installing: Configuring documentation
12:58:06 giovedì 15 giugno 2023 : Installing: Configuring file associations
12:58:06 giovedì 15 giugno 2023 : Installing: Setting permissions for files and folders
12:58:11 giovedì 15 giugno 2023 : Installing: Creating Registries
12:58:11 giovedì 15 giugno 2023 : Installing: SQL Lite ODBC Driver
12:58:12 giovedì 15 giugno 2023 : Installing: Finishing Installation
12:58:30 giovedì 15 giugno 2023 : Running Library Configuration Executable
12:58:30 giovedì 15 giugno 2023 : Starting process: C:\DevTools\Cadence\PSpice for TI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
13:01:55 giovedì 15 giugno 2023 : Exiting Installation Installing Dialog
